ISD-COB19xx
User’s Manual
Publication Release Date: June 12, 2008
Revision 1.0
J19 FMC1
2
J13 FMC3
J15 R/P
J14 FMC2
1
3
4
5
Hardware Configuration
1. Frequency selection: J16, J17 and J18. Use jumper to select desired
sampling frequency.
Sampling Frequency
Rosc
J16
12 kHz
53.3 KΩ
J17
8 kHz
80 KΩ
J18
6.4 kHz
100 KΩ
2. Mode setting: use J12 to select /Mode or Norm mode operation. Example
below illustrated Norm mode setting that the two left pins are shorted. After a
new condition is selected on NORM / MODE , the power must be cycled to enable
new setting. User can perform the following to recycle the power: remove power
from the board -> short J12 momentary -> re-apply the power.
Norm
Mode
Revision 1.0
(a) Mode: direct trigger mode
a. SW4 ~ SW7, SW9~SW12 to play/record message.
b. J15: set SW4~SW7, SW9~SW12 to perform play or record.
c. J19 (FMC1), J14 (FMC2), J13 (FMC3): setup various fixedmessage configurations.
d. J4, J5, J6, J7, J8, J9, J10, J11 should be in open (no jumper)
positions.
(b) Norm: address trigger mode
a. J4 (S0), J5 (S1), J6 (S2), J7 (S3): start address
b. J8 (M0), J9 (M1), J10 (M2), J11 (M3): end address
c. SW1 (Record): level-hold (after 1 sec holding) or edge-trigger
(toggle on-off), low active, recording from start to end addresses.
d. SW2 (PlayE): low active input, edge-trigger playback from start
to end addresses & toggle on-off.
e. SW3 (PlayL): low active input, Level-hold playback start to end
addresses. Holding PlayL constantly Low will perform looping
playback function from start to end addresses.
f. J13, J14, J15, J19 should be in open (no jumper) positions.
3. J1: Power connector
4. J2: Speaker connector
5. J3 Feed-Through: Low active input, Level-hold. When Feed-Through is
selected (J3 shorted), the MIC+ input is configured to a single-ended input with
1Vp-p maximum input amplitude and feed-through to the speaker outputs.
Revision 1.0
SCHEMATIC:
SW7
1
U1
3
S2
4
S3
PL
VCCD
1
J11 E3
1
2
3
J10 E2
1
2
3
1
2
3
1
2
3
6
E0
7
VSSA
8
E1
9
E2
10
E3
11
VSSP2
SW8
1
M6
2
SW9
1
M7
2
SW10
1
M8
2
SW11
1
SP-
J19 +
1
2
3
FMC1
12
13
14
NORM/Mode
S1/M2
FT
S2/M3
XCLK/FMC3
S3/M4
REC / R/P
Play L/FMC1 Play E/FMC2
E0/M5
LED
VSSA
VCCA
E1/M6
ROSC
E2/M7
MIC-
E3/M8
MIC+
VSSP2
AGC
SP-
VSSP1
VCCP
VCCP
SP+
27
J3
26
FT
25
XCLK
24
REC
23
PE
22
LED
21
VCCA
ROSC
19
MIC- C9
18
MIC+ C10
FMC2
PE
FT
2
1
0.1uF
VSSP1
10uF
C4
2
17
1
VCCD or J1-1
VCCA
R2
0.1uF
53K 1
R6
80K
R7
100K
VSSP1
15
SP+
J16
12KHz
2
J17
8KHz
2
J18
6.4KHz
2
0.1uF
C12
16
0.1uF
VSSP2
10uF
C6
4.7uF
J2
1
2
0.1uF
VSSD
VCCA
C7
10uF
C8
2
LED
1
VCCD
C5
SW2
1
D1
R1 1k
ISD1900
I14B00X Die
300 mil 28L SOIC
VCCP
C3
1
C2
2
2
10uF
1
VCCP
2
PE
1
Sp+
R4
X1
4.7K
MIC
1
2
2 pinstrip
C1
SW1
Rec
1
SPEAKER
M5
2
S0/M1
VCCD
28
1
E1
PL
E0
J9
5
VCCD
2
J8
2
S1
VCCD
VSSD
1
2
S0
1
2
SW3
VSSD
FMC3
J12 +
J13 +
J14 +
J15 +
1
1
1
1
2
2
2
2
3
3
3
3
Mode
Rec
VCCP
SW6
1
M4
2
GND
Norm
VCCA
M3
2
- S0
1
2
3
R3
Knowels
(423-1023-ND)
2
SW5
1
J4
C11
4.7uF
1
M2
2
- S1
1
2
3
VCCD
SW4
1
J5
M1
2
- S3
- S2
J7
1 J6
1
2
2
3
3
2 pinstrip
POWER
1
2
J1
4.7K
0.1uF
VSSA
For any technical details of the ISD1900 series, please refer to the datasheet.
Revision 1.0
R5
VCCA or J1-1
4.7K
很抱歉,暂时无法提供与“ISD-COB1916”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+117.274321+15.17257
