EHE004
EHE004
    MIDE(米德)
    LTC3588 Volture™ Series Power Management, Energy Harvesting Evaluation Board
EHE004 数据手册
EHE004 ENERGY HARVESTING ELECTRONICS FEATURES DESCRIPTION  Simple and Easy Charge Management for Vibration Energy Harvesting  Integrates directly with all Volture™ Energy Harvesters The EHE004 is an energy harvesting power conditioning circuit, which converts the AC output from a piezoelectric energy harvester to a regulated DC output.  Parallel or Series Piezoelectric Connection – Improved Efficiency  User Selectable DC Output – (1.8V, 2.5V, 3.3V, 3.6V) APPLICATIONS  Industrial Health Monitoring Network Sensors  Condition Based Maintenance Sensors  Wireless HVAC Sensors  Mobile Asset Tracking  Tire Pressure Sensors  Oil and Gas Sensors  All Air, Land, and Sea Vehicle Sensors  Battery and Hard Wired Power Replacement TYPICAL APPLICATION Figure 1: Representative energy harvesting system using a Volture™ piezoelectric energy harvester and the EHE004 charge management electronics. The EHE004 consists of a full-wave rectifier with integrated charge management and DC-DC conversion, and connects directly to any Volture™ piezoelectric energy harvesting product. The DC output can be configured to the following voltage settings: 1.8V, 2.5V, 3.3V, and 3.6V. The board includes 200 μF of storage capacitance onboard - more capacitance can be added if required. The EHE004 utilizes the Linear Technology LTC3588-1 piezoelectric charge management IC - designed to maximize total piezoelectric energy harvester output and mechanical-to-electrical conversion efficiency with medium to heavy loads. Each Volture™ energy harvesting product has two piezoelectric wafers. The EHE004 provides the user with ability to connect these wafers either in series or parallel. The series setting provides power output at lower g levels for small vibration amplitude applications. The parallel setting provides higher average power output levels at higher vibration amplitude levels. For more information please contact Mide Tech. Corp by emailing: volture@mide.com CHARGE MANAGEMENT VIN GND VCC OUT VSTORE MICRO CONTROLLER TX/RX EHE004 CHARGE MANAGEMENT SYSTEM SENSOR REVISION N0. 002 REVISION DATE: 01-23-2013 SENSOR SENSOR 1 EHE004 ELECTRICAL CHARACTERISTICS PRINCIPLE OF OPERATION The LTC3588-1 Piezoelectric Energy Harvesting Power Supply from Linear Technology is the primary component on the EHE004. From Linear Technology’s datasheet: Referring to Figure 2b, The LTC3588-1 power supply IC integrates an extremely low quiescent current voltage comparator with a highly efficient buck regulator. The buck regulator is activated when the rectified input voltage, VCAP, rises above the pre-set undervoltage lockout (UVLO) rising voltage threshold for the chosen output voltage setting (Page 5 table ‘Specification’). The regulator remains active until the input voltage has been depleted to the UVLO falling threshold, at which point the buck operation is disabled. Thus, for as long as the load demand exceeds the input power (as in typical sensor or battery charger applications), the input voltage will hover between the UVLO rising and falling thresholds. In cases where the input power exceeds the load demand, the VCAP voltage will rise beyond the UVLO rising threshold, storing the excess power on the input capacitor. If the voltage at VCAP exceeds approximately 20VDC, an internal voltage clamp (5mA continuous rating) prevents damage to the device. “The LTC3588-1 integrates a low-loss full-wave bridge rectifier with a high efficiency buck converter to form a complete energy harvesting solution optimized for high output impedance energy sources such as piezoelectric transducers. An ultralow quiescent current undervoltage lockout (UVLO) mode with a wide hysteresis window allows charge to accumulate on an input capacitor until the buck converter can efficiently transfer a portion of the stored charge to the output. In regulation, the LTC3588-1 enters a sleep state in which both input and output quiescent currents are minimal. The buck converter turns on and off as needed to maintain regulation. Four output voltages, 1.8V, 2.5V, 3.3V and 3.6V, are pin selectable with up to 100mA of continuous output current; however, the output capacitor may be sized to service a higher output current burst. An input protective shunt set at 20V enables greater energy storage for a given amount of input capacitance.” For more information on the LTC3588-1 please visit: http://cds.linear.com/docs/Datasheet/35881fa.pdf REVISION N0. 002 REVISION DATE: 01-23-2013 2 EHE004 CONFIGURATION The EHE004 has two means of signal rectification (Normal and Superseries) and two ways to connect the two piezoelectric wafers in a Volture™ product (Series and Parallel). There are also four options for the regulated DC output (1.8V, 2.5V, 3.3V, and 3.6V). In total there are sixteen possible configuration settings. The vibration environment and voltage requirements dictated by the application will determine the best configuration settings for the EHE004. Maximum Power Point: The efficiency of power transfer from the piezo to the load, and thus normalized power (mW/G), will be at maximum when the loaded piezo voltage (for moderate to heavy loads, equal to the average UVLO voltage) is approximately ½ its open-circuit voltage. However, the ouput will continue to increase with increasing vibration amplitude. For light loads where VCAP is not depleted to the UVLO voltage during buck operation, transfer efficiency is inconsequential as more power is available than the load can use. Normal vs. “Superseries”: The difference between ‘Normal’ and ‘Superseries’, is the bridge rectifier connection. In the normal mode of operation, the bridge rectifier is operated in fullbridge mode and its output voltage is half the peak-to-peak input voltage minus two diode drops. In the “superseries” configuration, the rectifier operates in a half-bridge mode with only one diode drop. The normal mode is recommended for maximum power output at moderate input voltages, however the halfbridge mode will allow operation from slightly lower minimum input voltages. REVISION N0. 002 Parallel vs. Series operation: All of MIDE’s Volture products contain two piezo elements stacked in a bimorph configuration and pinned out independently, allowing the user to choose between parallel and series connection. On the EHE004 board, switch SW1 selects between parallel (doubled current, lower input voltage) and series (doubled input voltage, lower current) connection. Generally low level vibrations are best suited to the series configuration and high level vibrations are best suited to the parallel configuration. However, the optimal setting will depend on a number of factors including which Volture product is being used and the parameters of the vibration environment. The table below shows the general configuration settings for different application types. However, each application is unique and the optimal settings will depend on both the application and Volture™ or other piezoelectric element used for the energy conversion. Application (Vibration Level) Very Low Amplitude General EHE004 Configuration Settings SW1 SW3 Series Superseries Low to Moderate Amplitude Series or Superseries Moderate Amplitude Parallel Normal High Amplitude Parallel Normal Table 1: General configuration guide listing for various applications. Every application is unique and may not fit these general settings. REVISION DATE: 01-23-2013 3 EHE004 CONFIGURATION How do I configure the EHE004? Configuring the EHE004 is done by using the combination of switches which appear on the top side of the board. The switch at the top right, designated SW3, controls the bridge rectifier connection. Place in the “NORM” position (downward) for normal operation, and the “SS” position for half-wave (“superseries”) operation. The switch in the lower right hand side, SW1, switches between parallel (downward, “Par.” position) and series (upward, “Ser.” position) piezo connection. The switch located in the top left hand corner of the board, designated SW2, sets the output voltage as marked below. In the legend below, the left and right digit refer to the left and right toggle switch, respectively, and the “1” or ON position is toward the dot marked on the switch. Switch #2 (SW2) Switch #3 (SW3) – DC Output Setting – Rectification Method SWITCH UP FIRST DECIMAL BECOMES = 00 SWITCH DOWN FIRST DECIMAL BECOMES = 10 SWITCH UP SECOND DECIMAL BECOMES = 00 SWITCH DOWN SECOND DECIMAL BECOMES = 01 SUPERSERIES – SWITCH UP NORMAL – SWITCH DOWN OUTPUT VOLTAGE Switch #1 (SW1) SWITCH #2 LEFT & RIGHT 00 = 1.8V = UP UP 10 = 3.3V = DOWN UP 01 = 2.5V = UP DOWN 11 = 3.6V = DOWN DOWN – Piezo Connection SERIES – SWITCH UP PARALLEL – SWITCH DOWN CONNECTION INFORMATION The terminal block at the bottom-left of the board (solder or screw terminals) provides the regulated output and other signals from the EHE004. The connections from left to right are: GND – Electrical ground VOUT – Regulated output voltage VCAP – Test point for measuring the voltage across the input capacitor(s). Additional capacitance can be added between this terminal & GND as needed. PGOOD – Active-high Power Good signal. This signal will be high (true) when the output is in regulation and will go low (false) when the output voltage drops below 92% of its regulated value. This will typically occur once the input voltage falls below the UVLO threshold or if the maximum output current is exceeded. REVISION N0. 002 In addition, a low-voltage auxiliary power source, such as a solar cell, can be added by soldering to the AUX+ and AUX- pads at the bottom-left corner of the board, provided the source complies with the absolute maximum ratings set forth above (VAC≤18V, RSOURCE>400OHMS, SW3=SUPERSERIES). A blocking diode (400mV typical voltage drop) in series with the AUX input prevents reverse leakage across the device. REVISION DATE: 01-23-2013 4 EHE004 SPECIFICATIONS The following provides a brief summary of the most important specifications of the EHE004. For complete specifications and performance plots for the LTC3588-1 charge management IC, please refer to the LTC3588-1 data sheet. For Volture™ specifications, such as typical relationships between frequency, tip mass and output voltage for each product, please refer to the Volture™ data sheet. Specification Value (typical @ 25°C) Input capacitance 200uF (stock product – custom values available upon request) Output capacitance 10uF Maximum Input Voltage 18V (low impedance sources) 1 Maximum Peak Protective Shunt Current 25mA (1ms duration) Maximum Continuous Protective Shunt Current 5mA Quiescent Current UVLO 450nA Buck Enabled, Sleeping (Vin = 4.5V) 950nA Buck Enabled, Sleeping (Vin = 18V) 1.7uA Buck Enabled, Active 2 150uA Maximum Output Current 100mA NOTE 1: An internal clamp circuit limits the input voltage to 20V; the maximum input voltage stated may be safely exceeded provided the maximum input current condition is satisfied. REVISION N0. 002 NOTE 2: Does not include active switching or inductor currents (Isw=0). Dynamic supply current is higher due to gate charge being delivered at the switching frequency. REVISION DATE: 01-23-2013 5 EHE004 OPERATION Vout setting (V) UVLO rising (V) UVLO falling (V) Vmpp (V) 1.8 4.04 2.87 7.4 3.1 Vripple @ Vin=UVLO (mV) 3 120 2.5 4.04 2.87 7.5 3.1 120 160 3.3 5.05 3.67 9.3 3.6 140 280 3.6 5.05 4.02 9.6 3.6 160 300 NOTE 1: Approximate maximum power point (opencircuit piezo voltage) at which power transfer to the load is maximized. 1 Vmin (V) 2 Vripple @ Vin=20 (mV)3 160 NOTE 3: Ripple values measured at no load and the 10uF onboard output capacitance. NOTE 2: Minimum start-up voltage in halfbridge (“superseries”) configuration. PERFORMANCE PLOTS Volture™ energy harvesting products can be found on the Volture™ datasheet. V25W, 1.8V, 75 Hz, 2.4 gram Tip Mass, Reg Cap 2 Normal, Series Normal, Parallel Superseries, Series Superseries, Parallel 1.8 1.6 Average Power (mW) The EHE004 performance was measured while connected to a Volture™ V25W piezoelectric energy harvester. The system was properly clamped and tuned using the procedures detailed in the Volture™ datasheet. The assembly was attached to a shake table to generate vibrations to test the system. The shake table was driven by a function generator and the amplitude was measured with an accelerometer. To determine average power, the output duty cycle at the known output voltage over a fixed 1.00K-ohm load was measured. 1.4 1.2 1 0.8 0.6 0.4 Performance measurements were taken at 0.25g, 0.50g, 0.75g, and 1g amplitudes. The lowest amplitude at which the EHE004 input exceeded the UVLO threshold, producing a usable output, was also recorded. The figure below shows the results for these tests. For the same amplitude conditions, other Volture™ products would exhibit similar performance characteristics though with different power output levels. Typical average power output levels for REVISION N0. 002 0.2 0 0 0.2 0.4 0.6 0.8 1 Amplitude (g) This representative figure shows how the different settings on the EHE004 can be used most efficiently given the vibration profile that this specific energy harvester with this tip mass was subjected to. For lowest amplitude vibrations (in this instance below 0.175 gee) REVISION DATE: 01-23-2013 6 EHE004 PERFORMANCE PLOTS the only setting that was able to provide any output was the Superseries, Parallel setting. From approximately 0.175 gee to 0.25 gee the Normal, Series setting was best. For all amplitudes above 0.25 gee the Normal, Parallel was the most efficient. It should be noted that these curves will vary substantially depending on the product that is used as well as the tip mass that is used to tune the product. In conclusion what this representative curve shows is that the piezo’s output energy and voltage for certain settings will allow the system to operate closer to the half open circuit voltage causing more efficient operation. For low level vibration the series setting is needed to get the piezo voltage output to reach the minimum voltage to operate the EHE004. BOARD SCHEMATIC AND DIMENSIONS Volture™ Product 0.100 0.700 EHE004 A 2 X 0.089 2-56 THRU 1.031 V22B / V22BL N/A N/A N/A V20W / V25W 1.250 0.588 0.986 V21B / V21BL 0.600 0.633 1.031 V22B / V22BL N/A N/A N/A VOS1 VOS0 3588-1 0 0 1 1 0 1 0 1 1.8V 2.5V 3.3V 3.6V U1 SW1 P$6 2 C2 + C100 C101 100nF AUX - VCAP J4 100uF 3 C1 1uF 1 100uF 2 3 P$1 SW3 1 P$4 P$3 1 2 3 4 5 GND PZ1 PGOOD PZ2 D0 CAP D1 VIN VIN2 SW VOUT 3.45V 4.1V 4.5V 5.0V GND PAD 9 VOS0 8 VOS1 7 6 VIN2 LTC3588MSE L1 10uH 3588-2 PGOOD VCAP P$3 GND SW1: Piezo Conection Down: Wafers in parallel Up: Wafers in series 47uF C4 DNP GND REVISION N0. 002 V+ P$2 P$1 C3 GND SW3/J4 “Superseries” select 1-2: Normal bridges operation 2-3: Halfbridge operation PGOOD P$4 4.7uF V+ AUX + D9 QPXX_RA 0.633 SW2: Output Voltage Select 1 BAT43W P$2 V21B / V21BL 0.600 Figure 2: EHE004 Board dimensions when used with one of Mide’s Volture energy harvesters. Maximum component height on the board is 0.10”. All dimensions are in inches. VIN2 VNS0 2 3 SW2 CAS-D20 4 VNS1 5 6 GND P$5 0.986 SW2 Volture V2xx pin 1-4 is as follows: Piezo wafers on pin 1&2, 3&4 J3 0.588 +VOUT B V20W / V25W 1.250 GND J1 GND VOLTURE 1.600 B with J3 Connector V+ PRODUCT 1.450 B without J3 Connector C5 VOLTURE PRODUCT A Figure 2b: EHE004 Schematic REVISION DATE: 01-23-2013 7 EHE004 BOARD SCHEMATIC AND DIMENSIONS Table 1: EHE004 Bill of Materials Qty Parts (Ref Des.) Package Value Manufacturer Part Number 1 C1 0603 1uF Yageo, CC0603ZRY5V7BB105 1 C5 0603 4.7uF Murata, GRM188R60J475ME19D 1 L1 1210 10uH Taiyo Yuden, CBC3225T100MR 1 C3 1206 47uF Kemet, C1206C476M9PACTU 1 C2 0603 100nF TDK, C1608Y5V1E104Z 2 C100, C101 Case D (7343 Metric) 100uF Kemet, T491X107K025ZT 1 J1 0.100" Screw Terminals 1 D9 SOD80C 1 SW3 CAS-120 Copal Electronics, CAS-120TA 1 SW2 CAS-D20 Copal Electronics, CAS-D20TB 1 U1 10-MSOP Linear Technology, LTC3588EMSE-1#PBF 1 J3 0.100" x 4 Sullins, PPTC041LGBN-R 1 SW1 EG1390 E-Switch, EG1390A Phoenix Contact, 1725672 BAT43W Figure 3: PCB top side Micro Commercial Co., BAT43W-TP Figure 4: PCB bottom side REVISION N0. 002 REVISION DATE: 01-23-2013 8
EHE004 价格&库存
很抱歉,暂时无法提供与“EHE004”相匹配的价格&库存,您可以联系我们找货
