410-236
410-236
    DIGILENT(迪芝伦)
    FMC-HMI HUMAN-MACHINE INTERFACE
410-236 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com FMC-HDMI™ Reference Manual Revised September 3, 2014 This manual applies to the FMC-HDMI rev. D Overview The FPGA Mezzanine Card High-Definition Multimedia Interface (FMC-HDMI) peripheral board enables developers to add HDMI input ports to field-programmable gate array (FPGA) based systems. The FMC-HDMI provides a development platform for customers to utilize high-definition image capturing for use with image processing applications. Features include: • • • • • • (2x) HDMI Type A Receptacles HDMI Receiver (ADV7611) HDMI Buffer (AD8195) On-board EDID EEPROM Male FMC LPC connector for digital signals Compatible with a wide range of VADJ voltages (1.8V – 3.3V) The FMC-HDMI. 1 Functional Description The FMC-HDMI card contains two HDMI input ports. The first port, HDMI1, contains an ADI ADV7611 Receiver and outputs a decoded, level translated digital video signal to the FMC connector. The second port, HDMI2, contains an ADI AD8195 Buffer and outputs an HDMI-encoded signal to the FMC connector, leaving the system board to decode the signal (either in the FPGA or an external receiver). The appropriateness of the HDMI port depends entirely on the application. For instance, although HDMI2 does not decode the signal, it outputs to a smaller number of pins (14 instead of 36), which is useful in designs with limited input availability. Since the decoding must be done on the connected system board, the circuitry must support HDMI-type signaling that is TMDS. For example, Xilinx® FPGA families support the TMDS_33 input standard in 3.3Vpowered I/O banks. DOC#: 502-264 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 4 FMC-HDMI™ Reference Manual 1.1 HDMI1: Analog Devices ADV7611 Receiver An Analog Devices ADV7611 Receiver decodes the signal on HDMI1. This low power, 165 MHz receiver supports formats up to UXGA 60Hz at 8 bit at 161 MHz. It has been tested at WUXGA (1080p) 60Hz at 148.5 MHz. The 2 receiver provides an audio output port for audio extracted from the HDMI signal in the following formats: I S, S/PDIF, and Direct Stream Transfer (DST). It also features an advanced mute controller. The ADV7611 Receiver contains several other features, such as a CEC 1.4-compatible controller for consumer device remote control and discovery and EDID (Extended Display Identification Data) RAM. Note: For more information on the ADV7611, see ADI datasheets and User Guide available online at: http://www.analog.com/ADV7611 Below are the pin-outs from the ADV7611 Receiver and other HDMI1 port signals to the FMC connector: FMC Pin HDMI1 Function FMC Pin HDMI1 Function LA19_P HDMI1_P0 LA04_P HDMI1_P18 LA20_N HDMI1_P1 LA03_N HDMI1_P19 LA20_P HDMI1_P2 LA03_P HDMI1_P20 LA15_N HDMI1_P3 LA02_N HDMI1_P21 LA14_N HDMI1_P4 LA02_P HDMI1_P22 LA15_P HDMI1_P5 LA00_N_CC HDMI1_P23 LA16_N HDMI1_P6 LA18_P_CC HDMI1_SCLK LA16_P HDMI1_P7 LA21_P HDMI1_LRCLK LA11_N HDMI1_P8 LA17_P_CC HDMI1_MCLK LA14_P HDMI1_P9 LA23_N HDMI1_AP LA11_P HDMI1_P10 LA22_P HDMI1_VS LA12_N HDMI1_P11 LA19_N HDMI1_HS LA12_P HDMI1_P12 LA22_N HDMI1_DE LA07_N HDMI1_P13 LA00_P_CC HDMI1_LLC LA08_N HDMI1_P14 LA25_P HDMI1_SDA LA07_P HDMI1_P15 LA21_N HDMI1_SCL LA08_P HDMI1_P16 LA23_P HDMI1_RESETN LA04_N HDMI1_P17 LA25_N HDMI1_INT1 Table 1. HDMI1-FMC pin mapping. 2 The ADV7611 is configured and controlled via an I C interface, which is accessible through the HDMI1SDA and HDMI1SCL pins on the FMC connector. The ADV7611 User Guide specifically describes the different registers and commands necessary to control the Receiver. There are level translators present on all audio and video signals, which can level shift to 1.8V, 2.5V, and 3.3V. The desired level is set by the VADJ voltage level. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 4 FMC-HDMI™ Reference Manual 1.2 HDMI2: Analog Devices AD8195 Buffer The AD8195 is an HDMI buffer with equalized TMDS inputs and optionally pre-emphasized TMDS outputs. The AD8195 includes bidirectional buffering for the DDC bus and bidirectional buffering with integrated pull-up resistors for the CEC bus. The DDC and CEC buffers are powered independently of the TMDS buffers so that DDC/CEC functionality can be maintained when the system is powered off. An on-board pre-programmed EEPROM is connected to the DDC (Display Data Channel) bus of the HDMI2 port. The following EDID (Extended Display Identification Data) is programmed in the factory: 00 0 0 1 0 2 0 3 0 4 0 5 0 6 0 7 0 0x0 0 0xFF 0x0 A 0x0 1 0x5 5 0x6 9 0x0 0 0x0 0 01 02 0xFF 0xFF 0x1 6 0x5 0 0x0 1 0x0 0 0x6 C 0x0 0 0x0 0 0x0 1 0x5 4 0x0 1 0x0 0 0x6 5 0x0 0 0x0 0 03 0xFF 0x03 0xBF 0x01 0xD 0 0x6E 0x00 0x00 04 05 0xF F 0x8 1 0xE F 0x0 1 0x5 2 0x7 4 0x0 0 0x0 0 0xF F 0x3 3 0x8 0 0x0 1 0x0 0 0x2 0 0x0 0 0x0 0 06 07 08 0xFF 0x00 0x10 0x1 D 0x78 0x02 0x01 0x01 0x01 0x01 0x1 D 0x00 0x00 0x1E 0x00 0x48 0x44 0x4 D 0x00 0x00 0x00 0x00 0x00 0x00 09 0A 0xE C 0x0 1 0x0 1 0x7 2 0x0 0 0x4 9 0x0 0 0x0 0 0x0 0 0xF 1 0x0 1 0x5 1 0x0 0 0x0 0 0x0 0 0x0 0 0B 0x01 0xA 2 0x01 0xD 0 0xFC 0x00 0x00 0x00 0C 0D 0E 0F 0x0 0 0x5 7 0x0 1 0x1 E 0x0 0 0x0 0 0x0 0 0x0 0 0x0 0 0x5 2 0x0 1 0x2 0 0x4 4 0x1 0 0x0 0 0x0 0 0x0 0 0x9 F 0x0 1 0x6 E 0x6 9 0x0 0 0x0 0 0x0 0 0x0 0 0x2 7 0x0 1 0x2 8 0x6 7 0x0 0 0x1 0 0x0 E Table 2. EEPROM pre-programmed content. The EEPROM can be freely re-written through the J4 header holes and 6-pin Pmod cable. During EEPROM programming, power to the EEPROM is provided by pin 6 of J4, so make sure there is no HDMI cable plugged in at the same time. Below are the pin-outs from the AD8195 Buffer and other HDMI2 port signals to the FMC connector: FMC Pin HDMI2 Function FMC Pin HDMI2 Function LA06_P HDMI2_D0_P LA01_N_CC HDMI2_CLK_N LA06_N HDMI2_D0_N LA13_P HDMI2_SCL LA05_P HDMI2_D1_P LA13_N HDMI2_SDA LA05_N HDMI2_D1_N LA09_P HDMI2_PE_EN LA10_P HDMI2_D2_P LA09_N HDMI2_TX_EN LA10_N HDMI2_D2_N LA17_N_CC HDMI2_HPA LA01_P_CC HDMI2_CLK_P LA18_N_CC HDMI2_CEC_OUT Table 3. HDMI2-FMC pin mapping. WARNING: VADJ must be 3.3V to properly use the buffer on HDMI2. The TX_EN pin is held low by default, so the buffer is disabled on power-up. With the buffer disabled, VADJ can be in the range of (1.8V-3.3V). Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 3 of 4 FMC-HDMI™ Reference Manual Note: For more information on the AD8195, see ADI datasheets available online at http://www.analog.com/AD8195 1.3 FMC Support The FMC-HDMI uses a Samtec ASP-134604-01 low pin-count male connector as the main connector for digital signals. The board fully conforms to the VITA 57.1 specs. The connector supports the full range of 1.8V-3.3V bank supply voltages (VADJ). The EEPROM with designator IC2 (see board schematic) serves as the IPMI EEPROM, providing hardware definition information. For more information, consult the VITA 57.1 specs. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 4 of 4
410-236
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离型双向可控硅,具有光隔离功能,用于交流负载的控制。
3. 引脚分配:共有6个引脚,分别为门极G、阴极K1、阳极A1、阴极K2、阳极A2、发射极E。
4. 参数特性:包括触发电流、关断电压、隔离电压等参数。
5. 功能详解:EL817通过光信号控制交流负载的通断,适用于家电控制、工业控制等领域。
6. 应用信息:广泛应用于家用电器、工业设备等需要光隔离控制的场合。
7. 封装信息:采用DIP6封装。
410-236 价格&库存
很抱歉,暂时无法提供与“410-236”相匹配的价格&库存,您可以联系我们找货
