BOB-10653
BOB-10653
    SPARKFUNELECTRONICS
    ISD1932 - Audio, Voice Record/Playback Evaluation Board
BOB-10653 数据手册
Page 1 of 2   SparkFun Voice Recorder Breakout - ISD1932 B OB-10 653 ROH S       1  images are CC BY-NC-SA 3.0 3D Download: Sketchup, STL, Blender Description: This is a breakout board for the ISD1932, a multiple-message record/playback device. This single chip can record up to 64 seconds worth of voice messages. Microphone inputs and speaker outputs are all handled by the ISD1932. A switch is connected to allow selection of the ISD1932’s operating mode - address trigger or direct trigger. You must cycle the power after switching the mode. An LED is also populated on the board and will illuminate when the device is recording. An external resistor is necessary to select the record duration and sampling frequency, which can range from 21.2 - 64 seconds (4-12kHz sampling frequency). The board breaks out all pins of the ISD1932 to 0.1" spaced headers. This product comes as shown in the pictures with filtering capacitors, an LED, mode selecting switch and the ISD1932 IC. The new version of this board also includes a microphone and a 3.5mm audio jack. Features: • Operating mode selector switch Page 2 of 2 • • • • • 2.4V to 5VDC supply voltage LED indicates if the board is recording Record up to 64 seconds of audio All pins of the ISD1932 broken out to 0.1" headers Breadboard friendly https://www.sparkfun.com/products/10653 11/16/2015
BOB-10653 价格&库存
很抱歉,暂时无法提供与“BOB-10653”相匹配的价格&库存,您可以联系我们找货
