XA-AUDIO-8CH
XA-AUDIO-8CH
    XMOS
    CS42448 - Interface, Digital Audio Evaluation Board
XA-AUDIO-8CH 数据手册
XMOS Audio Interface - Quick Start Guide Version 1v0 Publication Date: 2009/12/17 Copyright © 2009 XMOS Ltd. All Rights Reserved. XMOS Audio Interface - Quick Start Guide (1v0) 1 2/8 XMOS Audio Interface The XMOS Audio Interface provides a complete multi-channel digital audio interface for XMOS Development Kits including the XS1-G Development Kit (XDK). The board provides six analog channels in and eight analog channels out with additional stereo S/PDIF, MIDI, instrument, microphone and headphone sockets. The analog channels are provided by an I2S CODEC. MIDI and S/PDIF are controlled directly from an attached XMOS device. The XAI Kit includes: XAI Audio Interface Board 64-way IDC Connector MIDI Expansion Cable Requirements: You require an XMOS development kit to use the XAI. Example software is available from XMOS providing a full reference design for your audio solutions. www.xmos.com XMOS Audio Interface - Quick Start Guide (1v0) 2 3/8 Getting Started Download and install the demonstration software from the XMOS website, according to your license agreement. To use a USB or AVB input, remove the back of the XDK and set DIP switches as required—see Figure 3. Replace the back cover. Connect your USB or AVB input device to the XDK. If you are using a USB device connect it to the USB port on the right-hand side of the XDK. If you are using an AVB device connect it to the Ethernet RJ45 socket to the right—see Figure 2 Connect the XAI to the XDK using the 64-way IDC cable supplied. Connect additional audio input and output devices to the XAI—see Figure 1 for details of input and output connectors. Plug-in the XDK using the 12V power supplies provided with the Kit. Switch on the XDK and wait for the LEDs to flash to indicate that the devices is initialised. The kit is now ready for use. www.xmos.com XMOS Audio Interface - Quick Start Guide (1v0) 3 4/8 XAI Connectors MIDI IN/OUT INSTRUMENT IN MIC IN AUDIO IN XDK 64-way IDC XAI AUDIO OUT HEADPHONE Select Input Switch COAX IN LINE OUT S/PDIF IN COAX OUT S/PDIF OUT Figure 1: XAI Connectors ~ If you are using the Coax or S/PDIF input connector, you must use the Select Input Switch to select the input device—left for Coax and right for S/PDIF. The Coax and S/PDIF output connectors are permanently enabled. www.xmos.com XMOS Audio Interface - Quick Start Guide (1v0) 4 5/8 XDK Connectors XAI 64-way IDC RJ45 ETHERNET USB (Host/Debug) 12V PSU ON/OFF SWITCH USB (User) RJ45 XSYS CONNECTORS (RESERVED) Figure 2: XDK Connectors www.xmos.com XMOS Audio Interface - Quick Start Guide (1v0) 5 6/8 XDK DIP Switches To use an USB or AVB input to the XDK, the DIP switches on the back of the XDK motherboard must be set as follows: USB Off On Bank 0 ✓ ✓ ✓ ✓ Bank 1 ✓ ✓ ✓ ✓ Bank 2 ✓ ✓ ✓ ✓ Bank 3 ✓ ✓ ✓ ✓ Bank 4 ✓ ✓ ✓ ✓ Bank 5 ✓ ✓ ✓ ✓ AVB Off On Bank 0 ✓ ✓ ✓ ✓ Bank 1 ✓ ✓ ✓ ✓ Bank 2 ✓ ✓ ✓ ✓ Bank 3 ✓ ✓ ✓ ✓ Bank 4 ✓ ✓ ✓ ✓ Bank 5 ✓ ✓ ✓ ✓ Figure 3: XDK DIP Switches www.xmos.com XMOS Audio Interface - Quick Start Guide (1v0) 6 7/8 Port map The table below provides a full description of the port-to-pin mappings used on the XAI board: Pin 1b XnD0 XnD1 XnD2 XnD3 XnD4 XnD5 XnD6 XnD7 XnD8 XnD9 XnD10 XnD11 XnD12 XnD13 XnD14 XnD15 XnD16 XnD17 XnD18 XnD19 XnD20 XnD21 XnD22 XnD23 XnD24 XnD25 XnD26 XnD27 XnD28 XnD29 XnD30 XnD31 XnD32 XnD33 XnD34 XnD35 XnD36 XnD37 XnD38 XnD39 XnD40 XnD41 XnD42 XnD43 4b Port 8b 16b P1A0 P1B0 P4A0 P4A1 P4B0 P4B1 P4B2 P4B3 P4A2 P4A3 P8A0 P8A1 P8A2 P8A3 P8A4 P8A5 P8A6 P8A7 P16A0 P16A1 P16A2 P16A3 P16A4 P16A5 P16A6 P16A7 P1C0 P1D0 P1E0 P1F0 P4C0 P4C1 P4D0 P4D1 P4D2 P4D3 P4C2 P4C3 P8B0 P8B1 P8B2 P8B3 P8B4 P8B5 P8B6 P8B7 P16A8 P16A9 P16A10 P16A11 P16A12 P16A13 P16A14 P16A15 P1G0 P1H0 P1I0 P1J0 SCLK (Serial Clock or Bit Clock) LRCK (Left/Right Clock or Word Clock) SDA (I2C) SCL (I2C) DAC_SD1 DAC_SD2 DAC_SD3 DAC_SD4 RST_N (Reset to CODEC) Low Cost DAC Frequency Select INT (Interrupt from CODEC) ADC_SD1 ADC_SD2 ADC_SD3 Low Cost DAC LRCK P4E0 P4E1 P4F0 P4F1 P4F2 P4F3 P4E2 P4E3 P1K0 P1L0 P1M0 P1N0 P1O0 P1P0 Processor 2 P8C0 P8C1 P8C2 P8C3 P8C4 P8C5 P8C6 P8C7 P8D0 P8D1 P8D2 P8D3 P8D4 P8D5 P8D6 P8D7 P16B0 P16B1 P16B2 P16B3 P16B4 P16B5 P16B6 P16B7 P16B8 P16B9 P16B10 P16B11 P16B12 P16B13 P16B14 P16B15 MIDI OUT MIDI IN SPDIF_TX SPDIF_RX CLK_OUT (From Clock Synchronisation Chip) CLK_IN (To Clock Synchronisation Chip) Low Cost DAC DATA Low Cost DAC SCLK www.xmos.com XMOS Audio Interface - Quick Start Guide (1v0) 7 8/8 Further Information Further information on the XAI (including the hardware manual, schematics and board design files) is available at: www.xmos.com/xai. 8 Document History Date Release Comment 2009-12-17 1v0 First release Disclaimer XMOS Ltd. is the owner or licensee of this design, code, or Information (collectively, the “Information”) and is providing it to you “AS IS” with no warranty of any kind, express or implied and shall have no liability in relation to its use. XMOS Ltd. makes no representation that the Information, or any particular implementation thereof, is or will be free from any claims of infringement and again, shall have no liability in relation to any such claims. Copyright ©2009 XMOS Ltd. All Rights Reserved. XMOS and the XMOS logo are registered trademarks of XMOS Ltd in the United Kingdom and other countries, and may not be used without written permission. Company and product names mentioned in this document are the trademarks or registered trademarks of their respective owners. Where those designations appear in this document, and XMOS was aware of a trademark claim, the designations have been printed with initial capital letters or in all capitals. www.xmos.com
XA-AUDIO-8CH 价格&库存
很抱歉,暂时无法提供与“XA-AUDIO-8CH”相匹配的价格&库存,您可以联系我们找货
