410-217
410-217
    DIGILENT(迪芝伦)
    BOARD PMODAD2 FOR AD7991
410-217 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com PmodAD2™ Reference Manual Revised May 24, 2016 This manual applies to the PmodAD2 rev. A Overview The PmodAD2 is an analog-to-digital converter powered by the Analog Devices AD7991. Users may communicate with the board through I2C to configure up to 4 conversion channels at 12 bits of resolution. Features include:       Up to four 12-bit analog to digital converter channels On-board 2.048 V voltage reference Jumper selectable reference input Small PCB size for flexible designs (1.0 in × 0.8 in)(2.5 cm × 2.0 cm) Follows Digilent Interface Specification Library and example code available in resource center The PmodAD2. 1 Functional Description The PmodAD2 utilizes Analog Devices® AD7991 to provide up to four channels of 12-bit analog-to-digital conversion. 2 Interfacing with the Pmod The PmodAD2 communicates with the host board via the I²C protocol. System boards are able to call the Pmod by sending out the device address of 0b0101000 followed by the appropriate read or write bit. If a write bit is chosen, users may then configure the on-board chip to only use certain channels or may immediately start reading the 12 bits of data from the 16-bit data register if the read bit is sent. Unlike other devices that use I²C, no addresses are associated with these two registers; only the read/write bit at the end of the slave address distinguishes between the two registers. By default, all four channels have analog-toDOC#: 502-217 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 2 PmodAD2™ Reference Manual digital conversions performed on them sequentially with the supply voltage VCC acting as the voltage reference for the ADC. After each conversion is performed, the device places itself into power-down mode. Upon a read command, the device will wake itself up and prepare for a conversion, which takes approximately 0.6 μs. The actual conversion process takes approximately 1.0 μs. Pin 1&5 2&6 3&7 4&8 Signal SCL SDA GND VCC Description Serial Clock Serial Data Power Supply Ground Power Supply (3.3V/5V) Table 1. Pinout description table. Any external power applied to the PmodAD2 must be within 2.7V and 5.5V; however, it is recommended that the Pmod is operated at 3.3V. 3 Physical Dimensions The pins on the pin header are spaced 100 mil apart. The PCB is 1 inch long on the sides parallel to the pins on the pin header and 0.8 inches long on the sides perpendicular to the pin header. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 2
410-217 价格&库存
很抱歉,暂时无法提供与“410-217”相匹配的价格&库存,您可以联系我们找货
  • 1+167.404571+21.54249
