TSA7887DB
TSA7887DB
    TOUCHSTONESEMICONDUCTOR
    BOARD EVAL TSA7887
TSA7887DB 数据手册
TSA7887 A Micropower, 2-channel, 125-ksps, Serial-Output 12-bit SAR ADC FEATURES DESCRIPTION            Alternate Source for AD7887 Single-supply Operation: +2.7V to +5.25V INL: ±1LSB - TSA7887B ±2LSBs - TSA7887A One or Two Single-ended Analog Inputs Internal Wide-bandwidth Track-and-Hold Internal +2.5-V Reference Flexible Power/Throughput-Rate Management 0.85mA at 125ksps (Internal VREF ON) 0.7mA at 125ksps (Internal VREF OFF) Shutdown-mode Supply Current: 1μA (max) SPI®/QSPI™/MICROWIRE™/DSP-Compatible Serial Interfaces1 Operating Temperature Range: -40ºC to +125ºC 8-pin SOIC and MSOP Packaging APPLICATIONS Instrumentation and Control Systems High-Speed Modems Battery-powered systems: Personal Digital Assistants, Medical Instruments, Mobile Communications The TSA7887 – an alternate source for the AD7887 is a self-contained, 2-channel, high-speed, micropower, 12-bit analog-to-digital converter (ADC) that operates from a single +2.7V to +5.25V power supply. The TSA7887 is capable of a 125-ksps throughput rate with an external 2MHz serial clock and draws 0.85mA supply current. The wideband input track-and-hold acquires signals in 500ns and features a single-ended sampling topology. Output data coding is straight binary and the ADC is capable of converting full power signals up to 2.5 MHz. The ADC also contains an integrated 2.5V reference or the VREF pin can be overdriven by an external reference. The TSA7887’s provides one or two analog inputs each with an analog input range from 0 to VREF. In two-channel operation, the analog input range is 0V to VDD. Efficient circuit design ensures low power consumption of 2mW (typical) for normal operation and 3μW in power-down operation. The TSA7887 is fully specified from -40ºC to +125ºC and is available in 8-pin SOIC and MSOP packages. FUNCTIONAL BLOCK DIAGRAM 1 SPI and QSPI are trademarks of Motorola, Inc. MICROWIRE is a trademark of National Semiconductor Corporation Page 1 © 2014 Silicon Laboratories, Inc. All rights reserved. TSA7887 ABSOLUTE MAXIMUM RATINGS VDD to AGND ................................................................ −0.3V to +7V Analog Input Voltage (AIN0, AIN1) to AGND .... −0.3V to VDD + 0.3V Digital Input Voltage to AGND........................... −0.3V to VDD + 0.3V Digital Output Voltage to AGND ........................ −0.3V to VDD + 0.3V REFIN/REFOUT to AGND ................................ −0.3V to VDD + 0.3V Input Current to Any Pin Except Supplies1 ............................. ±10mA Operating Temperature Range A, B Versions ..................................................... −40°C to +125°C Storage Temperature Range ................................. −65°C to +150°C Junction Temperature ........................................................... +150°C SOIC/MSOP Package Power Dissipation ............................. 450mW θJA Thermal Impedance .....................................157°C/W (SOIC) 205.9°C/W (MSOP) θJC Thermal Impedance .......................................56°C/W (SOIC) 43.74°C/W (MSOP) Lead Temperature, Soldering Vapor Phase (60 sec) ........................................................ 215°C Infrared (15 sec) ................................................................ 220°C Pb-Free Temperature, Soldering Reflow ............................. 260(0)°C ESD ............................................................................................. 4kV Electrical and thermal stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to any absolute maximum rating conditions for extended periods may affect device reliability and lifetime. PACKAGE/ORDERING INFORMATION ORDER NUMBER PART MARKING CARRIER QUANTITY TUBE 97 Tape & Reel 2500 TUBE 97 Tape & Reel 2500 CARRIER QUANTITY TUBE 50 Tape & Reel 2500 TSA7887ARZ TS7887A TSA7887ARZ-REEL TSA7887BRZ TS7887B TSA7887BRZ-REEL ORDER NUMBER PART MARKING TSA7887ARMZ TAAV TSA7887ARMZ-REEL Lead-free Program: Silicon Labs supplies only lead-free packaging. Consult Silicon Labs for products specified with wider operating temperature ranges. Page 2 TSA7887 Rev. 1.0 TSA7887 ELECTRICAL CHARACTERISTICS VDD = +2.7V to +5.25V; VREF = 2.5V External/Internal Reference unless otherwise noted; fSCLK = 2 MHz; TA = TMIN to TMAX, unless otherwise noted. Parameter DYNAMIC PERFORMANCE Signal to Noise + Distortion Ratio (SNR)2 Total Harmonic Distortion (THD) Peak Harmonic or Spurious Noise Intermodulation Distortion (IMD) Second-Order Terms Third-Order Terms Channel-to-Channel Isolation Full-Power Bandwidth DC ACCURACY(Any channel) Resolution Integral Nonlinearity Differential Nonlinearity Offset Error Offset Error Match Gain Error Gain Error Match ANALOG INPUT Input Voltage Ranges Leakage Current Input Capacitance REFERENCE INPUT/OUTPUT REFIN Input Voltage Range Input Impedance REFOUT Output Voltage REFOUT Temperature Coefficient LOGIC INPUTS Input High Voltage, VINH Input Low Voltage, VINL Input Current, IIN Input Capacitance, CIN3 LOGIC OUTPUTS Output High Voltage, VOH Output Low Voltage, VOL Floating-State Leakage Current Floating-State Output Capacitance4 A Version1 B Version1 Unit 71 −80 –80 71 −80 −80 dB (typ) dB (typ) db (typ) fIN = 10 kHz sine wave, fSAMPLE = 125 ksps fIN = 10 kHz sine wave, fSAMPLE = 125 ksps fIN = 10 kHz sine wave, fSAMPLE = 125 ksps −80 −80 −80 −80 −80 −80 dB (typ) dB (typ) dB (typ) f1 = 9.983 kHz, f2 = 10.05 kHz, fSAMPLE = 125 ksps f1 = 9.983 kHz, f2 = 10.05 kHz, fSAMPLE = 125 ksps fIN = 25 kHz 2.5 2.5 MHz (typ) Measured at 3 dB down 12 ±2 ±2 ±3 12 ±1 ±1 ±3 Bits LSB (max) LSB (max) LSB (max) Guaranteed no missing codes to 11 bits (A Grade) VDD = 5V, dual-channel mode ±4 ±6 0.5 ±2 ±1 ±6 2 ±4 ±6 0.5 ±2 ±1 ±6 2 LSB (max) LSB (typ) LSB (max) LSB (typ) LSB (max) LSB (typ) LSB (max) 0 to VREF 0 to VREF V ±5 10 ±5 10 μA (max) pF (typ) 2.5/VDD 10 2.45/2.55 ±50 2.5/VDD 10 2.45/2.55 ±50 V (min/max) kΩ (typ) V (min/max) ppm/°C (typ) 2.4 2.1 0.8 2.4 2.1 0.8 V (min) V (min) V (max) VDD = 4.75V to 5.25V VDD = 2.7V to 3.6V VDD = 2.7 V to 5.25 V ±1 10 ±1 10 μA (max) pF (max) Typically 10 nA, VIN = 0 V or VDD VDD − 0.5 0.4 ±1 10 VDD − 0.5 0.4 ±1 10 V (min) V (max) μA (max) pF (max) Output Coding CONVERSION RATE Throughput Time Track-and-Hold Acquisition Time Conversion Time TSA7887 Rev. 1.0 Test Conditions/Comments VDD = 3V, dual-channel mode Single-channel mode Dual-channel mode Single-channel mode, external reference Single-channel mode, internal reference Functional from 1.2V Very high impedance if internal reference disabled ISOURCE = 200 μA VDD = 2.7V to 5.25V ISINK = 200 μA Straight (Natural) Binary 16 16 SCLK cycles 1.5 14.5 1.5 14.5 SCLK cycles SCLK cycles Conversion time plus acquisition time is 125 ksps, with 2 MHz Clock 7.25 μs (2 MHz Clock) Page 3 TSA7887 ELECTRICAL SPECIFICATIONS (continued) VDD = +2.7V to +5.25V; VREF = 2.5V External/internal reference unless otherwise noted; fSCLK = 2 MHz; TA = TMIN to TMAX, unless otherwise noted. Parameter POWER REQUIREMENTS VDD IDD Normal Mode4 (PM Mode 2) Static Operational (fSAMPLE = 125 kSPS) Using Standby Mode (PM Mode 4) Using Shutdown Mode (PM Modes 1 and 3) Standby Mode5 Shutdown Mode5 Normal Mode Power Dissipation Shutdown Power Dissipation Standby Power Dissipation A Version1 B Version1 Unit +2.7/+5.25 +2.7/+5.25 V (min/max) 700 850 700 450 120 12 700 850 700 450 120 12 μA (max) μA (typ) μA (typ) μA (typ) μA (typ) μA (typ) Internal reference enabled Internal reference disabled fSAMPLE = 50 ksps fSAMPLE = 10 ksps fSAMPLE = 1 ksps 210 1 2 3.5 2.1 5 210 1 2 3.5 2.1 5 μA (max) μA (max) μA (max) mW (max) mW (max) μW (max) VDD = 2.7V to 5.25V VDD = 2.7V to 3.6V VDD = 4.75V to 5.25V VDD = 5 V VDD = 3 V VDD = 5 V 3 1.05 630 3 1.05 630 μW (max) mW (max) μW (max) VDD = 3 V VDD = 5 V VDD = 3 V Test Conditions/Comments Note 1: The TSA7887’s temperature range is –40°C to +125°C for both A and B versions. Note 2: SNR calculation includes distortion and noise components. Note 3: Sample tested at TA = 25°C to ensure compliance. Note 4: All digital inputs at GND except for CS at VDD. All digital outputs are unloaded. Analog inputs are connected to GND. Note 5: SCLK is at GND when SCLK is off. All digital inputs are at GND except for CS at VDD. All digital outputs are unloaded. Analog inputs are connected to GND. Page 4 TSA7887 Rev. 1.0 RTFDS TSA7887 TIMING SPECIFICATIONS1 Parameter fSCLK2 tCONVERT Limit at TMIN, TMAX (A, B Versions) 4.75V to 5.25V 2.7V to 3.6V 2 14.5 × tSCLK 2 14.5 × tSCLK Unit Description MHz (max) tACQ t1 t23 t33 t4 t5 t6 1.5 × tSCLK 10 30 1.5 × tSCLK 10 60 ns (min) ns (max) Throughput time = tCONVERT + tACQ = 16 tSCLK 75 20 20 0.4 × tSCLK 100 20 20 0.4 × tSCLK ns (max) ns (min) ns (min) ns (min) Data setup time prior to SCLK rising edge Data valid to SCLK hold time SCLK high pulse width t7 t84 t9 0.4 × tSCLK 80 5 0.4 × tSCLK 80 5 ns (min) ns (max) μs (typ) CS rising edge to DOUT high-Z Power-up time from shutdown CS to SCLK setup time Delay from CS until DOUT three-state disabled Data access time after SCLK falling edge SCLK low pulse width Note 1: Timing specifications are sample tested at 25°C to ensure compliance. All input signals are specified with tr = tf = 5 ns (10% to 90% of VDD) and timed relative to a voltage level of 1.6V. Note 2: The mark/space ratio for the SCLK input is 40/60 to 60/40. See Serial Interface section for additional details. Note 3: Measured with the load circuit as shown below and defined as the time required for the output to cross 0.8V or 2.0V. Note 4: Timing specification t8 is derived from the measured time taken by the data outputs to change 0.5V when loaded with the circuit shown below. The measured result is then extrapolated back to remove the effects of charging or discharging the 50pF capacitor. This means that the time, t8, quoted in the timing characteristics is the true bus relinquish time of the TSA7887 and is independent of bus loading. Load Circuit Used for TSA7887’s Digital Output Timing Specifications. TSA7887 Rev. 1.0 Page 5 TSA7887 TYPICAL PERFORMANCE CHARACTERISTICS Dynamic Performance vs Frequency Power Supply Rejection vs Frequency 0 -20 FFT RESULTS - dB POWER SUPPLY REJECTION - dB -77 4096-point FFT 125kHz Sampling Rate 10kHz Fundamental -40 -60 -80 -100 -120 -140 10 0 20 30 40 50 60 FREQUENCY - kHz -81 VDD = 2.7V/5.5V REFIN (External) = 2.488V 100mVPP Sine Wave on VDD -85 -89 -93 -97 2.65 12.9 23.2 33.7 43.9 54.4 64.2 FREQUENCY - kHz Signal-to-Noise Ratio vs Frequency SIGNAL-TO-NOISE RATIO - dB 72 VDD = 5V REFIN (External) = 5V 71.5 71 70.5 70 0.7 11 21.4 31.8 42.1 FREQUENCY - kHz Page 6 TSA7887 Rev. 1.0 TSA7887 PIN FUNCTIONS PIN LABEL 1 CS 2 VDD 3 GND 4 AIN1/VREF 5 AIN0 6 DIN 7 DOUT 8 SCLK TSA7887 Rev. 1.0 DESCRIPTION Chip Select: As an active low logic input signal, the CS input provides the dual function of initiating TSA7887 conversions as well as framing the serial data transfer. When the TSA7887 is operated in Mode 1(its default power management mode), the CS pin also acts as the shutdown pin in that the TSA7887 is powered-down when the CS pin is logic high. Power Supply Voltage: The TSA7887’s VDD range +2.7V to +5.25V. In two-channel operation, the VDD pin also serves as the TSA7887’s voltage reference source during conversions. For optimal performance, the VDD pin should be bypassed to GND with a 10-µF tantalum capacitor in parallel with a 0.1µF ceramic capacitor. Analog Ground Pin: The GND pin is the ground reference point for all TSA7887 internal circuitry. In systems with separate AGND and DGND planes, the TSA7887’s GND pin should be connected to the AGND plane. Analog Input Channel 1/External VREF Input: In single-channel mode, the AIN1/VREF pin is configured as VREFIN/OUT. In this mode, the TSA7887’s internal 2.5V reference can be accessed or an external reference can be applied to this pin thereby overriding the internal reference. The reference voltage range for an externally-applied reference is 1.2V to VDD. In two-channel mode, the AIN1/VREF pin operates as a second analog input channel, AIN1. The input voltage range on AIN1 is 0 to VDD. Analog Input Channel 0: In single-channel operation, AIN0 is the TSA7887’s analog input with an input voltage range of 0V to VREF. In two-channel operation, the AIN0 pin exhibits an analog input range of 0V to VDD. Serial Data Input: Serial data to be loaded into the TSA7887’s control register is applied at the DIN pin. Serial data is loaded into the ADC from the host processor on low-to-high SCLK transitions (see the Control Register section for additional information). Configuring the TSA7887 as a single-channel, read-only ADC can be achieved by hard-wiring the DIN pin to GND or by applying a logic LOW at all times at the DIN pin. Serial Data Output: The TSA7887’s conversion result is available on this pin. Serial data is transferred out of the TS7887 on high-to low transitions of SCLK. The 12-bit conversion result is comprised of four leading zeros followed by the 12 bits of conversion data formatted MSB first. Thus, a total of 16 SCLK high-to-low transitions transfers the conversion result to the host processor as shown in the corresponding timing diagram of Figure 14. Serial-Clock Input: SCLK is used for (3) purposes: a) to load serial data from the host processor into the TSA7887’s control register on low-to-high SCLK transitions; b) to transfer the 12-bit conversion result to the host processor on high-to-low SCLK transitions; and c) to control the TSA7887’s conversion process. Page 7 TSA7887 TSA7887 CONTROL REGISTER DESCRIPTION The TSA7887’s write-only control register is 8-bits wide. Serial ADC configuration data is uploaded from the host processor at the TSA7887’s DIN pin on low-to-high SCLK transitions. Serial input data is uploaded to the TSA7887 simultaneously as the conversion result is transferred out of the TSA7887. All serial data transfers require 16 serial clocks transitions. After a high-to-low CS transition signal, serial data available on the first eight low-to-high SCLK transitions is transferred into the control register. The first bit in the serial data stream is always interpreted as the MSB. Upon initial powerup, the TSA7887’s default control register bit is cleared to all zeros (all “0”s). Table 1 lists the functions of the Control Register’s 8 bits. Table 1. TSA7887’s 8-Bit Control Register Content Description DB7 (MSB) DONTC DB6 ZERO DBx 7 Label DONTC 6 ZERO 5 REF 4 SIN/DUAL 3 CH 2 ZERO 1 0 PM1 PM0 DB5 REF DB4 SIN/DUAL DB3 CH DB2 ZERO DB1 PM1 DB0 (LSB) PM0 Comment Control Register DB7: Bit status of DB7 is “Don’t Care.” In other words, the DB7 bit can be a “0” or a “1”. Control Register DB6: To ensure correct TS7887 operation, Control Register DB6 status must always be a “zero” (“0”). Control Register DB5 – Internal Voltage Reference Configuration: The status of DB5 determines whether the TSA7887’s internal voltage reference is enabled or disabled. A “0” in the DB5 location will enable the TSA7887’s internal voltage reference (default condition). To disable the TSA7887’s internal voltage reference, a “1” must be written into DB5’s register location. Control Register DB4 - Single-Channel/Dual-Channel Configuration. Control Register DB4 configures the TSA7887 as a single-channel or two-channel ADC. Loading a “zero” (“0”) into this register location configures the TSA7887 for single-channel operation with the AIN1/VREF pin configured to for internal VREF operation (default configuration). In this case, the analog input signal range is 0V to VREF. Loading a “one” (“1”) into this register location configures the TSA7887 for two-channel operation with the AIN1/VREF pin configured to its AIN1 function as the second analog input. In addition, the conversion process’s reference voltage is internally connected to VDD. In this case, the analog input signal range is 0V to VDD. To obtain best performance from the TSA7887 in two-channel operation, the ADC’s internal reference should be disabled; that is, a “1” should be loaded into DB5’s register location. Control Register DB3 - Channel Select Bit: The bit status of DB3 determines on which channel the TSA7887 is converting. When the ADC is configured for dual-channel operation, DB3 determines which channel is converted on the next conversion cycle. When DB3 is a “zero” (a “0”), the AIN0 input is selected and, when DB3 is a “one” (a “1”), the AIN1 input is selected. DB3 should be a “zero” (“0”) when the TSA7887 is configured for single-channel operation. Control Register DB2: To ensure correct TS7887 operation, Control Register DB2 status must always be a “zero” (“0”). Control Register DB1 and DB0 - Power Management Operating Modes: DB1 and DB0 are decoded to configure the TSA7887 into one of four operating modes as shown in Table 2. Table 2. TSA7887’s Power Management Operating Modes PM1 PM0 0 0 0 1 1 0 1 1 Page 8 Mode PM Mode 1: In this operating mode, the TSA7887’s power-down mode is enabled if its CS input is a “one” ( a “1”) and is operating in full-power mode when its CS input is a “zero” (a “0”). Thus, the TSA7887 is powered down on a low-to-high CS transition and is powered up on a high-to-low CS transition. PM Mode 2: In this operating mode and regardless of the status of any of the logic inputs, the TSA7887 is always fully powered up. PM Mode 3: In this operating mode, the TSA7887 is automatically powered down at the end of each conversion regardless of the state of the CS input. ADC wake-up time from full shutdown is 5μs and system design should ensure that at least 5μs have elapsed before attempting to perform a conversion in this mode; otherwise, an invalid conversion result may occur. PM Mode 4: In this operating mode, the TSA7887 is configured for standby operation after conversion. Sections of the TSA7887 are powered down; however, the internal 2.5-V reference voltage remains powered up. While PM Mode 4 is similar to PM Mode 3, PM Mode 4 operation allows the TSA7887 to power up much faster. For optimal performance, the Control Register’s REF bit (DB5) should be a “zero” (“0”) to ensure the internal reference is enabled/remains enabled. TSA7887 Rev. 1.0 TSA7887 DESCRIPTION OF OPERATION The TSA7887 is a single-supply, low-power, single/dual-channel, 12-bit successiveapproximation ADC with an easy-to-use serial interface. The ADC can be operated from a 3V supply (2.7V to 3.6V) or from a 5V supply (4.75V to 5.25V). When operated from either a 3V or 5V supply, the TSA7887 can operate at throughput rates up to 125ksps when an external 2 MHz clock is applied. In 8-pin SOIC and MSOP packages, the TSA7887 integrates a 2.5-V reference, a high-speed track/hold, a successive-approximation ADC, and a serial digital interface. An external serial clock is used to transfer data to/from the ADC and controls the TSA7887’s conversion process. The TSA7887 can be configured for single- or two-channel operation. When configured as a single-channel ADC, the analog input range is 0 to VREF (where an externally applied VREF, if used, can range between 1.2 V and VDD). When the TSA7887 is configured for two-channel applications, the analog input range on each channel is set internally from 0V to VDD. If the TSA7887 is configured for single-channel operation, the TSA7887 can be operated in a readonly mode by applying a logic LOW at all times to the DIN pin (Pin 6) or by hard-wiring the DIN pin permanently to GND. For maximum flexibility to address multiple configurations based on the application, the DIN input can be used to load ADC configuration data from a host processor into the TSA7887’s 8-bit Control Register. TSA7887 Operation and Transfer Function analog input on one side and REF on the other, the analog signal is acquired. During the acquisition phase, the inputs to the comparator are balanced since both inputs are connected to REF. During the conversion phase as shown in the equivalent circuit in Figure 2, Switch SW1 is moved from Position A to GND at Position B and Switch SW2 is opened. At this point in time, the inputs to Figure 2: TSA7887’s Conversion Phase Equivalent Circuit the comparator become unbalanced. The TSA7887’s control logic and the chargeredistribution DAC work together to add or subtract fixed packets of charge from the sampling capacitor to balance once again the comparator input terminals. At the time when the comparator is rebalanced, the conversion process is complete and the ADC’s control logic generates the ADC serial output conversion data. Figure 3 illustrates the ideal transfer function for the TSA7887 where the output data is coded straight binary. Thus, the designed code transitions occur at successive integer LSB values (that is, at 1 LSB, at 2 LSBs, etc) where the LSB size is VREF/4096. The TSA7887 is a successive-approximation ADC, the core of which is a charge-redistribution DAC. Figure 1 illustrates an equivalent circuit for the TSA7887 in signal acquisition phase. Here, Switch SW1 is in Position A and Switch SW2 is closed. With the sampling capacitor’s terminals connected to the Figure 1:TSA7887’s Acquisition Phase Equivalent Circuit TSA7887 Rev. 1.0 Figure 3: TSA7887’s Unipolar Transfer Function for Straight Binary Digital Data. Page 9 TSA7887 Typical Application Circuit Figure 4 shows a typical application circuit for the TSA7887 where the ADC’s GND pin is connected to the analog ground plane of the system. In this application circuit, the TSA7887 has been configured for two-channel operation so the ADC’s VREF is internally connected to VDD; as a result, avoided. Thus, the analog input signal should never exceed the either VDD or GND by more than 200mV. Even though the maximum current these diodes can conduct without causing irreversible damage to the ADC is 20mA, any small amount of forward diode current into the substrate because of an overvoltage condition on an unselected channel can cause inaccurate conversion results on the selected channel. Attributed to parasitic package pin capacitance, capacitor C1 in Figure 5 is typically about 1 pF. Resistor R1 is the equivalent series resistance of the TSA7887’s input multiplexer and input sampling switch and is approximately 100Ω. Capacitor C2 is the ADC sampling capacitor and has a typical capacitance of 10 pF. Figure 4: TSA7887's Typical Application Circuit. the analog input range on either analog input is 0V to VDD. It is always considered good engineering practice to bypass the ADC’s VDD with good quality capacitors with short leads (surface-mount components are preferred) and located a very short distance from the ADC. The conversion result at the DOUT pin is a 16-bit word with four leading zeros followed by the MSB of the 12-bit conversion result. In low-power applications, automatic-power-down-atthe-end-of-conversion modes (PM Modes 3 or 4) should be used to improve the ADC’s power consumption-versus-throughput rate performance. For additional information on the TSA7887’s four power management operating modes, please consult the Operating Modes section of the datasheet. Analog Input Details In signal-acquisition (or ac) applications, the use of an external R-C low-pass filter on either or both analog inputs can be useful in removing out-of-band high-frequency components from the analog input signal. In applications where harmonic distortion and signal-to-noise ratio performance are important, the analog input(s) should be driven from a lowimpedance source. Large source impedances will affect significantly the TSA7887’s ac performance. To lower the driving-point impedance level may impose the use of an input buffer amplifier. The optimal choice for the external drive op amp will be determined by application requirements as well as the TSA7887’s dynamic performance. When the analog input is not driven by an external amplifier, the driving-point source impedance should be low. The maximum source impedance will depend upon the amount of total harmonic distortion (THD) that can be tolerated in the application. THD will increase as the source impedance increases Figure 5: TSA7887’s Analog Input Equivalent Circuit. Page 10 TOTAL HARMONIC DISTORTION - dBc Figure 6: TSA7887 THD vs Analog Input Frequency An equivalent circuit of the analog input structure of the TSA7887 is illustrated in Figure 5 where diodes D1 and D2 serve as ESD-clamp protection for the analog inputs. Since there are diodes from the analog input to both VDD and GND, it is important any forward conduction of current in D1 or D2 is -60 -65 VDD = 5V 5V External Reference -70 -75 -80 RIN = 10Ω, CIN = 10nF -85 RIN = 50Ω, CIN = 2.2nF -90 0.2 40 20 30 10 INPUT FREQUENCY - kHz 50 TSA7887 Rev. 1.0 TSA7887 and performance will degrade. Figure 6 illustrates how the TSA7887’s harmonic performance as a function of frequency is affected by different source impedances. The TSA7887’s Internal 2.5-V Reference Using the REF bit (the DB5 bit) in the TSA7887’s Control Register, the TSA7887’s internal 2.5-V reference can be enabled (DB5 cleared to “0”) or disabled (DB5 set to “1”). If enabled (the default condition), the internal voltage reference can be used in applications for other purposes and, if this is desired, the reference should be buffered by an external, precision op amp. If an external, precision voltage reference is to be used instead of the TSA7887’s internal reference, the internal reference is automatically overdriven. In this case, the TSA7887’s internal reference should be disabled by setting the REF bit in the control register. When the internal reference is disabled, switch SW1 as shown in Figure 7 opens and the input impedance seen at the AIN1/VREF pin is the reference buffer’s input up the TSA7887 again. When the TSA7887 is programmed in PM Mode 1 (i.e., [PM1,PM0] = [0,0], the default condition), the TSA7887 is powered down on a low-to-high CS transition and powers up from shutdown on a high-to-low CS transition. If the CS pin is toggled low-to-high during the conversion in this operating mode, the ADC is immediately powered down. Cold-Start and Standby Power-Up Delay Times When VDD is first applied to the TSA7887 (in other words, from cold start-up), the ADC powers up in PM Mode 1 ([PM1,PM0] = [0,0]). Upon a subsequent high-to-low CS transition, the TSA7887’s power-up delay time is approximately 5μs When using an external voltage reference in single-channel operation or when the TSA7887 is powered up from standby mode (PM Mode 4), its power-up delay time is approximately 1μs because the internal reference has been either disabled (refer to Control Register DB5) or the internal reference has remained powered up (via PM Mode 4). Since the TSA7887’s power-up delay time PM Mode 4 is very short, powering up the ADC and executing a conversion with valid results in the same read/write operation is feasible. TSA7887 Power Consumption vs. Throughput Rate Considerations Figure 7: TSA7887’s Integrated 2.5-V VREF Circuitry. impedance, approximately in the gigaohm range (GΩ). When the internal reference is enabled, the input impedance at the AIN1/VREF pin is typically 10kΩ. When the TSA7887 is configured for twochannel operation, the TSA7887’s reference is set internally to VDD. In operating the TSA7887 in auto-shutdown mode (PM Mode 3), in auto-standby mode (PM Mode 4), or in PM Mode 1, the average power drawn by the TSA7887 decreases at lower throughput rates. As shown in Figure 8, the average power drawn from Figure 8: TSA7887 Power Consumption vs Throughput Rate The TSA7887 provides flexible power management to allow the user to achieve the best power performance for a given throughput rate. The four power management options are selected by programming the TSA7887’s power management bits (“PM” Bits PM1 and PM0) in the control register as summarized in Table 6. When the PM bits are programmed for either of the auto power-down modes (PM Mode 3 or 4), the TSA7887 is powereddown on the 16th low-to-high SCLK transition after a high-to-low CS transition. The first high-to-low SCLK transition after a high-to-low CS transition powers- POWER CONSUMPTION - mW 10 TSA7887’s Power-Down Operating Modes VDD = 5V SCLK = 2MHz 1 VDD = 3V SCLK = 2MHz 0.1 0.01 0 10 20 30 40 50 THROUGHPUT RATE - ksps TSA7887 Rev. 1.0 Page 11 TSA7887 the supplies by the ADC is commensurately reduced the longer the TSA7887 remains in a powered-down state. For example, consider the following TSA7887 application configuration: (a) the ADC is powered from VDD = 5V and is configured for PM Mode 3 (that is, [PM1, PM0] = [1,0], where the ADC’s internal reference is enabled and the ADC automatically powers down after the conversion is completed); and (b) the ADC operates at a throughput rate of 10 ksps with a 2-MHz SCLK. Given the above configuration, the TSA7887’s power consumption during normal operation is 3.5mW at VDD = 5 V (0.7mA x 5V). Since its powerup delay time is 5μs and its conversion-plusacquisition time is ~7.75μs (tCONVERT + tACQ = 14.5 x tSCLK + 1.5 x tSCLK = 15.5 x tSCLK), the TSA7887 consumes 3.5mW for 12.75μs during each conversion cycle. Since the conversion cycle time (100μs) is the reciprocal of the ADC’s throughput rate (10ksps), the average power consumed by the TSA7887 during each conversion cycle is (12.75/100) × (3.5mW), or 446.25μW. If the ADC’s configuration were unchanged and, if the supply voltage were then reduced to 3V, the power consumed by the ADC would then be 2.1mW (0.7mA x 3V). Since the total time required for power-up, acquisition, and conversion remains at 12.75μs, the average power consumed during each cycle at a 10-ksps throughput rate is (12.75/100) × (2.1mW), or 267.75μW. The TSA7887’s power consumption vs. throughput rate when configured for automatic shutdown post conversion and operating on both 5V and 3V supplies is illustrated in Figure 8. Power Management Operating Modes Designed to provide flexible power consumption profiles, the TSA7887 incorporates four different operating modes to optimize the ADC’s power consumption/throughput-rate ratio. As previously described in Table 6, the four different modes of operation in the TSA7887 are controlled by the PM1 and PM0 bits of the Control Register. Also mentioned previously, the TSA7887 can be configured as a read-only ADC by forcing an all zeros (“0”s) condition in the control register. This can be easily done by applying a logic LOW at all times to the DIN pin or hard-wiring the DIN pin directly to GND. Power Management Mode 1 Operation: [PM1,PM0] = [0,0] Power Management Operating Mode 1 is used to control the TSA7887’s power-down using the CS pin. Whenever the CS pin is low, the TSA7887 is fully powered up; whenever the CS pin is high, the TSA7887 is completely powered down. When the CS pin is toggled high-to-low, all internal circuitry starts to power up where it can take as long as 5μs for the TSA7887’s internal circuitry to power up completely. As a result, any conversion start sequence should not be initiated during this initial 5μs power-up delay. Figure 9 shows a general operating diagram of the TSA7887 in PM Mode 1. The analog input signal is sampled on the second low-to-high SCLK transition following the initial high-to-low CS transition. System timing design should incorporate a 5-μs delay between the high-to-low CS transition and the second low-to-high SCLK transition. In microcontroller applications, this is achieved by Figure 9: TSA7887’s Power Management Mode 1 Operation Diagram. Page 12 TSA7887 Rev. 1.0 TSA7887 driving the CS pin from one of the host processor’s port lines and ensuring that the serial data read (from the microcontroller’s serial port) is not initiated for at least 5μs. In DSP applications, where the CS signal is derived typically from the DSP’s serial frame synchronization port, it is usually not possible to separate a high-tolow CS transition and a second low-to-high SCLK transition by up to 5μs without affecting the DSP system serial clock speed. Therefore, system timing design should incorporate a WRITE to the TSA7887’s control register to terminate PM Mode 1 operation and program the ADC into PM Mode 2; that is, by writing [PM1,PM0] = [0,1] into the TSA7887’s control register. To get a valid conversion result, a second conversion must be initiated when the ADC is powered up. A WRITE operation that takes place with this second conversion can program the ADC back into PM Mode 1 where the power-down operation is enabled when the CS pin is toggled high Power Management Mode 2 Operation: [PM1,PM0] = [0,1] Regardless of the status of the CS signal, the TSA7887 remains fully powered up in this mode of operation. PM Mode 2 should be used for fastest throughput rate performance because the system timing design does not need to incorporate the TSA7887’s 5-μs power-up delay time. Figure 10 shows the general operating diagram for the TSA7887 in PM Mode 2. Serial data programmed into the TSA7887 at the DIN input during the first eight clock cycles of data transfer are loaded to the control register. For the TSA7887 to remain in PM Mode 2, system timing design must always write [PM1, PM0] = [0,1] into the control register on every serial input data transfer. A high-to-low CS transition initiates the conversion sequence and the analog input signal is sampled on the second low-to-high SCLK transition. Sixteen serial clock cycles are required to complete the conversion and to transfer the conversion result to the host processor. Another conversion can be initiated immediately by toggling the CS pin low again once data transfer is complete (that is, once the CS signal is toggled high). Power Management Mode 3 Operation: [PM1, PM0] = [1,0] In this mode, the TSA7887 is automatically powered down at the end of every conversion. It is similar to PM Mode 1 except that the status of the CS signal in PM Mode 3 does not have any effect on the powerdown status of the TSA7887. Figure 11 shows the general operating diagram of the TSA7887 in PM Mode 3. On the first high-to-low SCLK transition after CS is toggled low, all TSA7887’s internal circuitry starts to power up. Similarly to PM Mode 1, it can take as long as 5μs for the TSA7887’s internal circuitry to power up completely. As a result, any conversion start sequence should not be initiated during this initial 5-μs power-up delay. The analog input signal is sampled on the second low-to-high SCLK transition following the high-to-low CS transition. As shown in Figure 18, system timing design should incorporate a 5-μs delay between the first high-to-low SCLK transition and the second low-to-high SCLK transition after the high-to-low CS transition. Figure 10: TSA7887’s Power Management Mode 2 Operation Diagram. TSA7887 Rev. 1.0 Page 13 TSA7887 Figure 11: TSA7887’s Power Management Mode 3 Operation Diagram for Slow-SCLK Microcontrollers. Figure 12: TSA7887’s Power Management Mode 3 Operation Diagram for Fast-SCLK Microcontrollers and DSPs. In microcontroller applications (or in systems with a slow serial clock), the system timing design can be devised to accommodate this timing alignment by assigning the CS signal to one of the port lines and then adjusting the timing such that the serial data read (from the microcontroller’s serial port) is not initiated for at least 5μs. However, in systems with higher speed serial clocks (not unlike high-speed serial-clock DSP applications), it may not be possible to insert a 5μs delay between ADC power up and the first low-tohigh SCLK transition. Therefore, system timing design should incorporate a WRITE to the TSA7887’s control register to terminate the ADC’s PM Mode 3 operation and program the TSA7887 into PM Mode 2; that is, by writing [PM1,PM0] = [0,1] into the TSA7887’s control register. To get a valid conversion result, a second conversion must be initiated when the ADC is powered up – see Figure 19. A WRITE operation that takes place with this second conversion can program the ADC back Page 14 into PM Mode 3 where the power-down operation is enabled when the conversion sequence terminates. Power Management Mode 4 Operation: [PM1,PM0] = [1,1] In PM Mode 4, the TSA7887 is automatically placed in standby (or sleep) mode at the end of every conversion. In this mode, all internal circuitry is powered down except for the internal 2.5-V reference. PM Mode 4 is similar to PM Mode 3; in this case, the power-up delay time is much shorter (1μs vs 5μs) because the internal reference remains powered up at all times. Figure 13 shows the general operating diagram of the TSA7887 in PM Mode 4. On the first high-to-low SCLK transition after the CS pin is toggled low, the TSA7887 is powered up out of its standby mode. Since the TSA7887’s power-up delay time PM Mode 4 is very short, powering up the ADC and executing a conversion with valid results in the same read/write operation is feasible. The analog input signal is sampled on the second low-to-high SCLK transition TSA7887 Rev. 1.0 TSA7887 Figure 13: TSA7887’s Power Management Mode 4 Operation Diagram. following the high-to-low CS transition. At the end of conversion (after the last low-to-high SCLK transition), the ADC is powered down automatically back into its standby mode. The TSA7887’s Serial Interface Description Figure 14 shows the detailed timing diagram for TSA7887’s serial interface. The serial clock provides the conversion clock and also controls the transfer of data to/from the TSA7887 during conversion. The CS signal initiates the serial data transfer and controls the TSA7887’s conversion process. In PM Modes 1, 3, and 4, a high-to-low CS transition powers up the ADC. In all cases, the CS signal gates SCLK to the TSA7887 and sets the ADC’s internal track-and-hold into track mode. The analog input signal is then sampled on the second low-tohigh SCLK transition following the high-to-low CS transition. Thus, the analog input signal is acquired during the first 1.5 SCLK clock cycles (tACQ) after the high-to-low CS transition. In modes where the high- to-low CS transition powers up the ADC, the acquisition time must include a 5-μs power-up delay. The ADC’s internal track-and-hold moves from track mode to hold mode on the second low-to-high SCLK transition and a conversion is also initiated on this transition. The conversion process takes an additional 14.5 SCLK cycles to complete. After the conversion is completed, a subsequent low-to-high CS transition sets the serial data bus back into a high-Z (or three-state) condition. A new conversion can be initiated if the CS signal is left low. In dual-channel operation, the current conversion result is associated to the selected analog channel programmed during the previous write cycle to the control register. Therefore, in dual-channel operation, the system code design must perform a channel address write for the next conversion while the current conversion is in progress. Writing serial data to the Control Register always takes place and occurs on the first eight low-to-high SCLK transitions. However, the TSA7887 can be configured as a read-only device by physically Figure 14: TSA7887’s Detailed Serial Interface Timing Diagram. TSA7887 Rev. 1.0 Page 15 TSA7887 loading all “zeros” (“0”s) into the Control Register every time, by applying a logic LOW to the DIN pin at all times, or by hard-wiring the DIN pin to GND. When the TSA7887 is configured in WRITE/READ modes, system code design must be designed always to load the correct data onto the DIN line when reading data from the TSA7887. Sixteen serial clock cycles are required to perform the conversion process and to transfer data to/access data from the TSA7887. In applications where the first serial clock transition following a highto-low CS transition is a high-to-low SCLK transition, DOUT transitions from a high-Z state to a first leading zero; thus, the first low-to-high SCLK transition generates the first leading zero on DOUT. In applications where the first serial clock transition following a high-to-low CS transition is a low-to-high SCLK transition, the first leading zero may not be set up in time for the host processor to read it correctly. However, subsequent DOUT bits are transferred out on high-to-low SCLK transitions so that they are ready for the host processor on the following low-tohigh SCLK transition. Thus, the second leading zero is transferred out on the high-to-low SCLK transition subsequent to the first low-to-high SCLK transition. Therefore, DOUT’s final bit in the data transfer is valid on the 16th low-to-high SCLK transition, having been transferred out of the ADC on the previous high-to-low SCLK transition. Figure 15: Interfacing the TSA7887 to TSM320C5x-type DSPs. TSA7887’s CS input. The TMS320C5x’s serial port control register (SPC) must be configured in the following manner: Table 3: TMS320C5x Serial Port Control Register Setup FO 0 FSM 1 MCM 1 TXM 1 A TSA7887 to ADSP-21xx DSP Interface The TSA7887 is easily interfaced to the ADSP-21xx (or equivalent) family of DSPs using an inverter between the ADSP-21xx’s serial clock and the TSA7887 as shown in Figure 16. The ADSP-21xx’s SPORT control register should be configured in Alternate Framing mode as shown in Table 4 and the ADSP-21xx’s serial clock frequency is set in its SCLKDIV register. Interfacing the TSA7887 to IndustryStandard Microprocessors and DSPs The serial interface on the TSA7887 allows the ADC to be directly connected to a number of many microprocessors and DSPs. How to interface the TSA7887 with some of the more common microcontroller and DSP serial interface protocols is covered in this section. Figure 16: Interfacing the TSA7887 to ADSP-21xx-type DSPs. A TSA7887 to TMS320C5x DSP Interface Table 4: SPORT0 Control Register Setup With peripheral serial devices like the TSA7887, the TMS320C5x’s serial interface has a continuous serial clock and frame synchronization signals to time the data transfer operations. A single logic inverter is the only glue logic required between the TMS320C5x’s CLKX output and the TSA7887 SCLK input and is illustrated in the connection diagram of Figure 15. The TMS320C5x’s serial port is configured to operate in burst mode using the TMS320C5x’s internal CLKX (serial clock transmit) and FSX (frame sync transmit) programmed as the Page 16 Bit(s) TFSW, RFSW INVRFS, INVTFS DTYPE SLEN ISCLK TFSR, RFSR IRFS ITFS Setting 1 1 00 1111 1111 1 0 1 Description Alternative framing Active-low frame signal Right justified data 16-bit data word Internal serial clock Frame every word TSA7887 Rev. 1.0 TSA7887 With the ADSP-21xx’s TFS and RFS pins of its SPORT connected together, the TFS is configured as an output and RFS configured as an input. The frame synchronization signal generated on the TFS output serves as the TSA7887’s CS input. In this example, however, since a timer interrupt is used to control the sampling rate of the ADC, it may not be possible to perform equidistant sampling (a required criterion in all signal processing applications) under certain application conditions. The ADSP-21xx’s timer registers are configured in such a manner that an interrupt is generated internally at the required sample interval. When the timer interrupt is received, an ADC control word is transmitted at the DT output with TFS. The TFS signal is then used to control the RFS and hence the data read from the TSA7887. When the instruction to transmit with TFS is executed (that is, AX0 = TX0), the state of the SCLK is checked. The DSP waits until the SCLK has toggled high-to-low-to-high before a transmission will commence. If the timer and SCLK values are set such that the instruction to transmit occurs on or near the low-to-high SCLK transition, data may be transmitted or the DSP may wait to transmit data until the next clock edge. For example, consider an ADSP-2111 that has been chosen as the host processor. Since it has a 16-MHz master clock frequency, a SCLKDIV value of 3 is necessary to program its SPORT serial clock output to operate at 2MHz for the TSA7887 (16MHz ÷ 23 = 2MHz); thus, eight master clock periods will elapse for every one TSA7887 SCLK period. If the ADSP-2111’s timer registers are loaded with a value of 803, 100.5 SCLKs will occur between interrupts and subsequently between transmit instructions. Because the transmit instruction occurs on an SCLK edge, non-equidistant sampling is the result. The DSP will implement equidistant sampling only if the number of SCLKs between interrupts is a whole integer number. A TSA7887 to DSP56xxx DSP Interface Connecting the TSA7887 for use with Freescale’s (nee Motorola’s) DSP56xxx family of DSPs is shown in Figure 17 where an inverter is used between the DSP56xxx’s SCK output and the TSA7887’s SCLK input. The DSP56xxx’s SSI (synchronous serial interface) is configured in synchronous mode (SYN bit = 1 in CRB) with an internally generated 1-bit clock period frame sync for both Tx and Rx (Bits FSL1 = 1 and FSL0 = 0 in CRB). Word length is set to 16 by setting bits WL1 = 1 and WL0 = 0 in CRA. TSA7887 Rev. 1.0 Figure 17: Interfacing the TSA7887 to DSP56xxx-type DSPs. A TSA7887 to 68HC11 Microcontroller Interface Connecting the TSA7887 to Freescale’s 68HC11 (nee Motorola’s MC68HC11) is shown in Figure 18. The microcontroller’s serial peripheral interface (SPI) is configured for Master Mode (MSTR = 1) with its Clock Polarity Bit (CPOL) set to 1 and Clock Phase Bit (CPHA) set to 1. Serial data transfer from the TSA7887 to the 68HC11 requires two 8-bit transfers and the 68HC11’s SPI is configured by writing to the SPI Control Register (SPCR) — consult the 68HC11 User Manual for more information. Figure 18: Interfacing the TSA7887 to 68HC11-type Microcontrollers. A TSA7887 to 8051 Microcontroller Interface Using the parallel port of legacy 8051-type (or equivalent) microcontrollers, a serial interface to the TSA7887 can be designed as shown in Figure 19. As a result, full duplex serial transfer to be implemented. The technique involves “bit-banging” one of the the microcontroller’s I/O ports (for example, P1.0) to generate a serial clock and using Figure 19: Interfacing the TSA7887 to Legacy 8051-type Microcontrollers. Page 17 TSA7887 two other I/O ports (for example, P1.1 for DOUT and P1.2 for DIN) to transfer data from/to the TSA7887. operation, two consecutive read/write operations are required. For additional information, please consult the PIC16/PIC17 Microcontroller User Manual. A TSA7887 to PIC16C6x/PIC16C7x Microcontroller Interface As shown in Figure 20, the connection between the TSA7887 and the PIC16C6x/PIC16C7x is simple and does not require any glue logic circuits. The PIC16C6x synchronous serial port (SSP) is configured as an SPI master with its clock polarity bit set to 1 by writing to the synchronous serial port control register (SSPCON). In this example, I/O port RA1 is being used to generate the TSA7887’s CS signal. Since this microcontroller family only transfers eight bits of data during each serial transfer Figure 20: Interfacing the TSA7887 to PIC16C6x/PIC16C7x-type Microcontrollers. APPLICATIONS INFORMATION Ground Plane Management and Layout For best performance, printed circuit boards should always be used and wire-wrap boards are not recommended. Good PC board layout techniques ensure that digital and analog signal lines are kept separate from each other, analog and digital (especially clock) lines are not routed parallel to one another, and high-speed digital lines are not routed underneath the ADC package. A contiguous analog ground plane should be routed under the TSA7887 to avoid digital noise coupling. A single-point analog ground (star ground point) should be created at the ADC’s GND and separate from any digital logic ground. All analog grounds as well as the ADC’s GND pin should be connected to the star ground. No other digital system ground should be made to this ground connection. For lowest-noise operation, the ground return to the star ground’s power supply should be low impedance and as short as possible. Page 18 Even though the TSA7887’s exhibits excellent supply rejection as shown in th Typical Operating Characteristics, it is always considered good engineering practice to prevent high-frequency noise on the TSA7887’s VDD power supply from affecting the ADC’s high-speed comparator. Therefore, the VDD supply pin should be bypassed to the star ground with 0.1μF and 10μF capacitors in parallel and placed close to the ADC’s Pin 2 as was shown in Figure 4. Component lead lengths should be very short for optimal supply-noise rejection. If the power supply is very noisy, an optional 10-Ω resistor inserted in series with the TSA7887’s VDD pin can be used in conjunction with the bypass capacitors to form a low-pass filter. Evaluating the TSA7887’s Dynamic Performance The recommended layout for the TSA7887 is outlined in the demo board manual for the TSA7887. The demo board kit includes a fully assembled/tested demo board and documentation describing how to evaluate the TSA7887’s dynamic performance using Silicon Labs’ proprietary TSDAVB data acquisition/capture kit. TSA7887 Rev. 1.0 TSA7887 PACKAGE OUTLINE DRAWING 8-Pin MSOP Package Outline Drawing (N.B., Drawings are not to scale) TSA7887 Rev. 1.0 Page 19 TSA7887 PACKAGE OUTLINE DRAWING 8-Pin SOIC Package Outline Drawing (N.B., Drawings are not to scale) Patent Notice Silicon Labs invests in research and development to help our customers differentiate in the market with innovative low-power, small size, analog-intensive mixed-signal solutions. Silicon Labs' extensive patent portfolio is a testament to our unique approach and world-class engineering team. The information in this document is believed to be accurate in all respects at the time of publication but is subject to change without notice. Silicon Laboratories assumes no responsibility for errors and omissions, and disclaims responsibility for any consequences resulting from the use of information included herein. Additionally, Silicon Laboratories assumes no responsibility for the functioning of undescribed features or parameters. Silicon Laboratories reserves the right to make changes without further notice. Silicon Laboratories makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Silicon Laboratories assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation consequential or incidental damages. Silicon Laboratories products are not designed, intended, or authorized for use in applications intended to support or sustain life, or for any other application in which the failure of the Silicon Laboratories product could create a situation where personal injury or death may occur. Should Buyer purchase or use Silicon Laboratories products for any such unintended or unauthorized application, Buyer shall indemnify and hold Silicon Laboratories harmless against all claims and damages. Silicon Laboratories and Silicon Labs are trademarks of Silicon Laboratories Inc. Other products or brandnames mentioned herein are trademarks or registered trademarks of their respective holders. Page 20 Silicon Laboratories, Inc. 400 West Cesar Chavez, Austin, TX 78701 +1 (512) 416-8500 ▪ www.silabs.com TSA7887 Rev. 1.0 Smart. Connected. Energy-Friendly Products Quality Support and Community www.silabs.com/products www.silabs.com/quality community.silabs.com Disclaimer Silicon Laboratories intends to provide customers with the latest, accurate, and in-depth documentation of all peripherals and modules available for system and software implementers using or intending to use the Silicon Laboratories products. Characterization data, available modules and peripherals, memory sizes and memory addresses refer to each specific device, and "Typical" parameters provided can and do vary in different applications. Application examples described herein are for illustrative purposes only. Silicon Laboratories reserves the right to make changes without further notice and limitation to product information, specifications, and descriptions herein, and does not give warranties as to the accuracy or completeness of the included information. Silicon Laboratories shall have no liability for the consequences of use of the information supplied herein. This document does not imply or express copyright licenses granted hereunder to design or fabricate any integrated circuits. The products must not be used within any Life Support System without the specific written consent of Silicon Laboratories. A "Life Support System" is any product or system intended to support or sustain life and/or health, which, if it fails, can be reasonably expected to result in significant personal injury or death. Silicon Laboratories products are generally not intended for military applications. Silicon Laboratories products shall under no circumstances be used in weapons of mass destruction including (but not limited to) nuclear, biological or chemical weapons, or missiles capable of delivering such weapons. Trademark Information Silicon Laboratories Inc., Silicon Laboratories, Silicon Labs, SiLabs and the Silicon Labs logo, CMEMS®, EFM, EFM32, EFR, Energy Micro, Energy Micro logo and combinations thereof, "the world’s most energy friendly microcontrollers", Ember®, EZLink®, EZMac®, EZRadio®, EZRadioPRO®, DSPLL®, ISOmodem ®, Precision32®, ProSLIC®, SiPHY®, USBXpress® and others are trademarks or registered trademarks of Silicon Laboratories Inc. ARM, CORTEX, Cortex-M3 and THUMB are trademarks or registered trademarks of ARM Holdings. Keil is a registered trademark of ARM Limited. All other products or brand names mentioned herein are trademarks of their respective holders. Silicon Laboratories Inc. 400 West Cesar Chavez Austin, TX 78701 USA http://www.silabs.com
TSA7887DB 价格&库存
很抱歉,暂时无法提供与“TSA7887DB”相匹配的价格&库存,您可以联系我们找货
