DFR0316
DFR0316
    DFROBOT
    MCP342418-BITADC-4CHANNELWIT
DFR0316 数据手册
    MCP3424 18‐Bit ADC‐4 Channel with Programmable Gain  Amplifier (SKU:DFR0316)  Contents      1 Introduction 2 Applications 3 Specifications 4 Interface 5 Tutorial 5.1 Measure Voltage by Arduino 5.2 Measure Voltage by RPi Introduction The module integrates MCP3432 A/D converter chip. The module can provide analog input function for Raspberry Pi and provide high accuracy analog input for Arduino. MCP3424 is one of the low noise and high accuracy 18-Bit delta-sigma analog-to-digital (∆Σ A/D) converter family members of the MCP342X series. Its characteristic is:    Self calibration of internal offset and gain per each conversion. The user can select the PGA gain before the analog-to-digital conversion takes place. This allows the device to convert a very weak input signal with high resolution. The device have two conversion modes: (a)One-Shot mode: the device performs a single conversion and enters a low current standby mode automatically until it receives another conversion command. (b)Continuous mode: the conversion takes place continuously at the set conversion speed. Applications     Temperature Sensing with RTD, Thermistor, and Thermocouple Bridge Sensing for Pressure, Strain, and Force Weigh Scales Battery Fuel Gauges Specifications              Operating Voltage: 2.7 - 5.5V Standy Current: 300nA (5V) Operating Temperature: -40°C ~ +125°C On-Board Voltage Reference: 2.048V ± 0.05%, Drift 15 PPM /°C On-Board Programmable Gain Amplifier (PGA): x1,x2,x4,x8 Differential Input Full Scale Range: -2.048V / PGA ~ 2.048V / PGA (e.g., PGA=4, Range is -0.512 ~ 0.512V) Programmable Resolution: 12, 14, 16, 18bits Programmable Data Rate: 240, 60, 15, 3.75 SPS Gain Error: 0.05% (PGA = 1, 18bits) Offset Error: 15uV (PGA = 1, 18bits) Input Interface: 4 differential channels, PIN header of 2.54mm spacing Output Interface: I2C, PIN header of 2.54mm spacing Size: 27x16mm Interface  Input and output pins showed in the diagram.  Switch: set I2C address. Tutorial Measure Voltage by Arduino a) Target: Measure voltage by Arduino b) Hardware List     DF_UNO 1 MCP3432 module 1 Regulated power or AA battery 1 Dupont wires c) Software List   Arduino IDE Arduino MCP3424 library d) Connected diagram e) Step by step 1. 2. 3. 4. Adjust voltage of Regulated Power to 0-2.085V, and then power on. Install Arduino MCP3424 library, see Install Arduino MCP3424 library Open Arduino IDE Upload code to UNO /* MCP 3424 version 1.2 example sketch OneShotConversion Written by B@tto Contact : batto@hotmail.fr In this example, one conversion per second is performed on channel 1 and 16 bits resolution. A new conversion has to be initiated by the user */ #include #include MCP3424 MCP(0x68); // Decaration of MCP3424 with Address of I2C long Voltage; void setup(){ Serial.begin(9600); MCP.Configuration(1,16,0,1); // Channel 1, 16 bits resolution, one-shot mo de, amplifier gain = 1 } void loop(){ MCP.NewConversion(); // New conversion is initiated Voltage=MCP.Measure(); lete conversion // Measure, note that the library waits for a comp Serial.print("Voltage = "); Serial.print(Voltage); Serial.println("uV"); // unit: microVolt delay (1000); } f) Result  Open Ardino serial monitor, the voltage will be displayed. Measure Voltage by RPi a) Target: Measure voltage by RPi b) Hardware List  Raspberry Pi B+ 1   Regulated power or AA battery 1 Dupont wires c) Software List  MCP3424 I2C Linux driver d) Connected Diagram: refer to the previous tutorial, connect I2C and power in the GPIO of RPi to the MCP3424 module. e) Step by step: refer to the "Readme" of the Driver. Powered By DFRobot © 2008-2017
DFR0316 价格&库存
很抱歉,暂时无法提供与“DFR0316”相匹配的价格&库存,您可以联系我们找货
DFR0316
  • 1+105.802781+13.71588
库存:47
