DEV-11113
DEV-11113
    SPARKFUNELECTRONICS
    ATMEGA328 ARDUINO PRO MINI 5V
DEV-11113 数据手册
Arduino Pro Mini (DEV-11113) Name ADC Power PWM GND Serial Control Ext Interrupt Arduino PC Interrupt Port Misc Programmed as Arduino Pro Mini w/ ATMega328 16MHz/ 5V VCC TXO To FTDI breakout FTDI Header To target board GND GND VCC RXI PCINT17 PCINT16 TXD RXD PCINT14 PCINT18 OC2B PCINT19 T1 AIN0 XCK OC0B OC0A CLKO OC1A INT1 T0 PCINT21 PCINT22 INT0 8-bit PCINT20 8-bit 8-bit IN1 ICP1 PCINT23 PCINT1 8-bit PCINT0 PD1 PD0 PC6 PD2 PD3 PD4 PD5 PD6 PD7 PB0 PB1 Power Raw:5V-16V (6V-12V recommended) VCC:5V Maximum current: 150mA @5V D1 D0 Reset GND D2 D3 D4 D5 D6 D7 D8 D9 TX0 RXI RST GND 2 3 4 5 6 7 8 9 RXI TXO DTR Reset Button ATMega328P Absolute maxiumum VCC: 6V Maximum current for chip: 200mA Maximum current per pin: 40mA Recommended current per pin:20mA 8-bit Atmel AVR Flash Program Memory: 32kB EEPROM: 1kB Internal SRAM 2kB ADC:10-bit PWM:8bit DTR GRN BLK GND CTS RAW GND RST VCC A3 A2 A1 A0 13 12 11 10 RAW GND Reset VCC A3/D17 A2/D16 A1/D15 A0/D14 D13 D12 D11 D10 A5 A4 A5/D19 PC5 A4/D18 PC4 A7 A6 A7 A6 ADC7 ADC6 LEDs Power: Red User (D13): Green PC6 PCINT14 PC3 PC2 PC1 PC0 PB5 PB4 PB3 PCB2 ADC3 ADC2 ADC1 ADC0 SCK MISO 8-bit 8-bit ADC5 ADC4 SCL SDA PCINT11 PCINT10 PCINT9 PCINT8 PCINT5 LED PCINT4 MOSI SS PCINT13 PCINT12 PCINT3 PCINT2 OC2A OC1B
DEV-11113 价格&库存
很抱歉,暂时无法提供与“DEV-11113”相匹配的价格&库存,您可以联系我们找货
