DEV-13305
DEV-13305
    SPARKFUNELECTRONICS
    KL2x Teensy-LC Kinetis MCU 32-Bit ARM® Cortex®-M0+ Embedded Evaluation Board
DEV-13305 数据手册
Page 1 of 2 Export Restrictions This product has some level of export control/restriction, so may be delayed by 2-3 business days when shipping outside the United States. Contact us with questions, or we will contact you after you place your order. Teensy LC DE V-13 305 RO HS       6  images are CC BY-NC-SA 3.0 Description: The Teensy is a breadboard-friendly development board with loads of features in a, well, teensy package. The Teensy LC (Low Cost) is a 32 bit microcontroller board that provides you with an uncomplicated option for getting started with the Teensy line of products without breaking the bank! The Teensy LC comes pre-flashed with a bootloader so you can program it using the on-board USB connection: No external programmer needed! You can program for the Teensy in your favorite program editor using C or you can install the Teensyduino add-on for the Arduino IDE and write Arduino sketches for Teensy! The processor on the Teensy also has access to the USB and can emulate any kind of USB device you need it to be, making it great for USB-MIDI and other HID projects. The 32 bit processor brings a few other features to the table as well, such as multiple channels of Direct Memory Access and an I2S digital audio interface! There are also 2 separate interval timers! Also, the Teensy LC can provide system voltage of 3.3V or 5V to other devices at up to 5-20mA. All of this functionality is jammed into a 1.4 x 0.7 inch board with all headers on a 0.1" grid so you can slap it on a breadboard and get to work! So, what sets the Teensy LC apart from the Teensy 3.1? First off, this version has been streamlined to be as cost effective as possible. Obviously, the LC doesn’t share a lot of power that the 3.1 possesses but by no means does it make the LC a ‘weak’ board! The Teensy LC is equipped with 8kB RAM, 62kB of flash memory, and 27 Digital I/O pins with 13 high res Analog inputs. Note: The Teensy LC does not come with a micro-B USB cable, please check the Recommended Products section below for an appropriate one. Dimensions: 1.4 x 0.7" (~35 x 18 mm) Page 2 of 2 Features: • • • • • • • • • • • 32 bit ARM Cortex-M0+ 48 MHz CPU 62kB Flash Memory, 8kB RAM, 1/8(emu)kB EEPROM 13 High Resolution Analog Inputs 27 Digital I/O Pins (NOT 5V Tolerant) 10 PWM outputs 7 Timers for intervals/delays, separate from PWM 3 UARTs (serial ports) SPI, I2C, & I2S I2S (for high quality audio interface) 4 Lightweight DMA channels Touch Sensor Inputs https://www.sparkfun.com/products/13305 10/22/2015
DEV-13305 价格&库存
很抱歉,暂时无法提供与“DEV-13305”相匹配的价格&库存,您可以联系我们找货
