ARDUINO NANO
Code: A000005
The Arduino Nano is a compact board similar to the UNO.
The Arduino Nano is a small, complete, and breadboard‐friendly board based on
the ATmega328 (Arduino Nano 3.x). It has more or less the same functionality of
the Arduino Duemilanove, but in a different package. It lacks only a DC power jack,
and works with a Mini‐B USB cable instead of a standard one.
Getting Started
You can find in the Getting Started section all the information you need to
configure your board, use the Arduino Software (IDE), and start tinker with coding
and electronics.
https://www.arduino.cc/en/Guide/HomePage
https://www.arduino.cc/en/Main/Software
TECH SPECS
Microcontroller
Architecture
Operating Voltage
Flash Memory
SRAM
Clock Speed
Analog I/O Pins
EEPROM
DC Current per I/O Pins
Input Voltage
Digital I/O Pins
PWM Output
Power Consumption
PCB Size
Weight
Product Code
ATmega328
AVR
5 V
32 KB of which 2 KB used by bootloader
2 KB
16 MHz
8
1 KB
40 mA (I/O Pins)
7‐12 V
22
6
19 mA
18 x 45 mm
7 g
A000005
OSH: Schematics
The Arduino Nano is open‐source hardware! You can build your own board using
the following files:
EAGLE FILES IN .ZIP
https://content.arduino.cc/assets/arduino‐nano‐reference.zip
SCHEMATICS IN .PDF
https://www.arduino.cc/en/uploads/Main/Arduino_Nano‐Rev3.2‐SCH.pdf
Power
The Arduino Nano can be powered via the Mini‐B USB connection, 6‐20V
unregulated external power supply (pin 30), or 5V regulated external power supply
(pin 27). The power source is automatically selected to the highest voltage source.
Memory
The ATmega328 has 32 KB, (also with 2 KB used for the bootloader. The
ATmega328 has 2 KB of SRAM and 1 KB of EEPROM.
Input and Output
Each of the 14 digital pins on the Nano can be used as an input or output, using
pinMode(), digitalWrite(), and digitalRead() functions. They operate at 5 volts.
Each pin can provide or receive a maximum of 40 mA and has an internal pull‐up
resistor (disconnected by default) of 20‐50 kOhms. In addition, some pins have
specialized functions:
Serial: 0 (RX) and 1 (TX). Used to receive (RX) and transmit (TX) TTL serial data. These
pins are connected to the corresponding pins of the FTDI USB‐to‐TTL Serial chip.
External Interrupts: 2 and 3. These pins can be configured to trigger an interrupt on a low
value, a rising or falling edge, or a change in value. See the attachInterrupt() function for
details.
PWM: 3, 5, 6, 9, 10, and 11. Provide 8‐bit PWM output with the analogWrite() function.
SPI: 10 (SS), 11 (MOSI), 12 (MISO), 13 (SCK). These pins support SPI communication,
which, although provided by the underlying hardware, is not currently included in the
Arduino language.
LED: 13. There is a built‐in LED connected to digital pin 13. When the pin is HIGH value,
the LED is on, when the pin is LOW, it's off.
The Nano has 8 analog inputs, each of which provide 10 bits of resolution (i.e.
1024 different values). By default they measure from ground to 5 volts, though is it
possible to change the upper end of their range using the analogReference()
function. Analog pins 6 and 7 cannot be used as digital pins. Additionally, some
pins have specialized functionality:
I2C: 4 (SDA) and 5 (SCL). Support I2C (TWI) communication using the Wire library
(documentation on the Wiring website).
There are a couple of other pins on the board:
AREF. Reference voltage for the analog inputs. Used with analogReference().
Reset. Bring this line LOW to reset the microcontroller. Typically used to add a reset
button to shields which block the one on the board.
Communication
The Arduino Nano has a number of facilities for communicating with a computer,
another Arduino, or other microcontrollers. The ATmega328 provide UART TTL (5V)
serial communication, which is available on digital pins 0 (RX) and 1 (TX). An FTDI
FT232RL on the board channels this serial communication over USB and the FTDI
drivers (included with the Arduino software) provide a virtual com port to software
on the computer. The Arduino software includes a serial monitor which allows
simple textual data to be sent to and from the Arduino board. The RX and TX LEDs
on the board will flash when data is being transmitted via the FTDI chip and USB
connection to the computer (but not for serial communication on pins 0 and 1). A
SoftwareSerial library allows for serial communication on any of the Nano's digital
pins. The ATmega328 also support I2C (TWI) and SPI communication. The Arduino
software includes a Wire library to simplify use of the I2C bus. To use the SPI
communication, please see ATmega328 datasheet.
Programming
The Arduino Nano can be programmed with the Arduino software (download).
Select "Arduino Duemilanove or Nano w/ ATmega328" from the Tools > Board
menu (according to the microcontroller on your board). The ATmega328 on the
Arduino Nano comes preburned with a bootloader that allows you to upload new
code to it without the use of an external hardware programmer. It communicates
using the original STK500 protocol. You can also bypass the bootloader and
program the microcontroller through the ICSP (In‐Circuit Serial Programming)
header using Arduino ISP or similar.
Automatic (Software) Reset
Rather then requiring a physical press of the reset button before an upload, the
Arduino Nano is designed in a way that allows it to be reset by software running on
a connected computer. One of the hardware flow control lines (DTR) of the
FT232RL is connected to the reset line of the ATmega328 via a 100 nanofarad
capacitor. When this line is asserted (taken low), the reset line drops long enough
to reset the chip. The Arduino software uses this capability to allow you to upload
code by simply pressing the upload button in the Arduino environment. This means
that the bootloader can have a shorter timeout, as the lowering of DTR can be
well‐coordinated with the start of the upload. This setup has other implications.
When the Nano is connected to either a computer running Mac OS X or Linux, it
resets each time a connection is made to it from software (via USB). For the
following half‐second or so, the bootloader is running on the Nano. While it is
programmed to ignore malformed data (i.e. anything besides an upload of new
code), it will intercept the first few bytes of data sent to the board after a
connection is opened. If a sketch running on the board receives one‐time
configuration or other data when it first starts, make sure that the software with
which it communicates waits a second after opening the connection and before
sending this data.
https://store.arduino.cc/usa/arduino‐usb‐2‐serial‐micro 12‐7‐17
很抱歉,暂时无法提供与“A000005”相匹配的价格&库存,您可以联系我们找货
