DEV-13736
DEV-13736
    SPARKFUNELECTRONICS
    K20 Teensy 3.2 Kinetis MCU 32-Bit ARM® Cortex®-M4 Embedded Evaluation Board
DEV-13736 数据手册
Page 1 of 2 Export Restrictions This product has some level of export control/restriction, so may be delayed by 2-3 business days when shipping outside the United States. Contact us with questions, or we will contact you after you place your order. Teensy 3.2 DE V-13 736 RO HS       2  images are CC BY-NC-SA 3.0 Description: The Teensy is a breadboard-friendly development board with loads of features in a, well, teensy package. Each Teensy 3.2 comes pre-flashed with a bootloader so you can program it using the on-board USB connection: No external programmer needed! You can program for the Teensy in your favorite program editor using C or you can install the Teensyduino add-on for the Arduino IDE and write Arduino sketches for Teensy! The processor on the Teensy also has access to the USB and can emulate any kind of USB device you need it to be, making it great for USB-MIDI and other HID projects. The 32 bit processor brings a few other features to the table as well, such as multiple channels of Direct Memory Access, several high-resolution ADCs and even an I2S digital audio interface! There are also 4 separate interval timers plus a delay timer! Oh yeah, and all pins have interrupt capability. Also, it can provide system voltage of 3.3V to other devices at up to 100mA. All of this functionality is jammed into a 1.4 x 0.7 inch board with all headers on a 0.1" grid so you can slap in on a breadboard and get to work! The Teensy 3.2 adds a more powerful 3.3 volt regulator, with the ability to directly power an ESP8266 Wifi, WIZ820io Ethernet, and other 3.3V add-on boards that require a little more power. Additionally, if it is used within the Teensy 3.1 limits of operation, the Teensy 3.2 and 3.1 are interchangeable! Note: This does not come with a USB cable, please check below for an appropriate one. Dimensions: 1.4 x 0.7" (~35 x 18 mm) Features: • 32 bit ARM Cortex-M4 72 MHz CPU (M4 = DSP extensions) Page 2 of 2 • • • • • • • • • • • • 256K Flash Memory, 64K RAM, 2K EEPROM 21 High Resolution Analog Inputs (13 bits usable, 16 bit hardware) 34 Digital I/O Pins (5V tolerance on Digital Inputs) 12 PWM outputs 7 Timers for intervals/delays, separate from PWM USB with dedicated DMA memory transfers 3 UARTs (serial ports) SPI, I2C, I2S,CAN Bus, IR modulator I2S (for high quality audio interface) Real Time Clock (with user-added 32.768 crystal and battery) 16 DMA channels (separate from USB) Touch Sensor Inputs https://www.sparkfun.com/products/13736 10/22/2015
DEV-13736 价格&库存
很抱歉,暂时无法提供与“DEV-13736”相匹配的价格&库存,您可以联系我们找货
