410-296
410-296
    DIGILENT(迪芝伦)
    BOARD CEREBOT MX7CK FOR PIC32
410-296 数据手册
Cerebot MX7cK™ Board Reference Manual Revision: June 24, 2013 Note: This document applies to REV B and C of the board. 1300 Henley Court | Pullman, WA 99163 (509) 334 6306 Voice and Fax Overview The Cerebot MX7cK is a microcontroller development board based on the Microchip PIC32MX795F512L, a member of the 32-bit PIC32 microcontroller family. It is compatible with Digilent’s line of Pmod™ peripheral modules, and is suitable for use with the Microchip MPLAB® IDE tools. The Cerebot MX7cK is also compatible for use with the chipKIT™ MPIDE development environment. ChipKIT and MPIDE is a PIC32 based system compatible with many existing Arduino™ code examples, reference materials and other resources. The Cerebot MX7cK is designed to be easy to use and suitable for use by anyone from beginners to advanced users for experimenting with embedded control and network communications application. A built in programming/debugging circuit compatible with the Microchip MPLAB® IDE is provided, so no additional hardware is required for use with MPLAB. The kit contains everything needed to start developing embedded applications using either the MPLAB® IDE or the MPIDE. The Cerebot MX7cK provides 52 I/O pins that support a number of peripheral functions, such as UART, SPI and I2C™ ports as well as five pulse width modulated outputs and five external interrupt inputs. Its network and communications features also include a 10/100 Ethernet interface, Full Speed USB 2.0 OTG interface, and dual CAN network interfaces. Ten of the I/O pins can be used as analog inputs in addition to their use as digital inputs and outputs. Cerebot MX7cK Circuit Diagram The Cerebot MX7cK can be powered in various ways via USB, or using an external AC-DC power adapter. Doc: 502-223 page 1 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual Functional Description The Cerebot MX7cK is designed for embedded control and network communications applications as well as for general microprocessor experimentation. Firmware suitable for many applications can be downloaded to the Cerebot MX7cK’s programmable PIC32 microcontroller. Features of the Cerebot MX7cK include:            a PIC32MX795F512L microcontroller support for programming and debugging within the Microchip MPLAB development environment support for programming within the chipKIT MPIDE development environment six Pmod connectors for Digilent peripheral module boards 10/100 Ethernet USB 2.0 compatible Device, Host, and OTG support two CAN network interfaces three push buttons four LEDs multiple power supply options, including USB powered ESD protection and short circuit protection for all I/O pins. Features of the PIC32MX795F512L include:             512KB internal program flash memory 128KB internal SRAM memory USB 2.0 compliant full-speed On-TheGo (OTG) controller with dedicated DMA channel 10/100 Ethernet controller two CAN network controllers up to four serial peripheral interfaces (SPI) up to six UART serial interfaces up to four I2C serial interfaces five 16-bit timer/counters five timer capture inputs five compare/PWM outputs sixteen 10-bit analog inputs www.digilentinc.com  two analog comparators The Cerebot MX7cK has a number of input/output connection options, and is designed to work with the Digilent line of Pmod peripheral modules that provide various input and output functions. For more information, see www.digilentinc.com. In addition to the Pmod connectors, the board provides three push buttons and four LEDs for user I/O, as well as providing connections for two I2C busses. A serial EEPROM is provided on one of the I2C busses. The Cerebot MX7cK features a flexible power supply system with a number of options for powering the board as well as powering peripheral devices connected to the board. It can be USB powered via the debug USB port, the USB UART serial port, or the USB device port. It can also be powered from an external 5V power supply. Programming Tools The Cerebot MX7cK can be used with either the Microchip MPLAB® development environment or the chipKIT MPIDE development environment. When used with the MPLAB® IDE, in-system-programming and debugging of firmware running on the PIC32MX795 microcontroller is supported using an on-board programming/debugging circuit licensed from Microchip. The Cerebot MX7cK is immediately useable with either the MPLAB IDE or the chipKIT MPIDE. No additional hardware is required to use the board with the Microchip MPLAB tools. Using the Cerebot MX7cK with Microchip Development Tools The Microchip MPLAB® IDE or the MPLAB® X IDE can be used to program and debug code running on the Cerebot MX7cK board using the built-in programming/debugging circuit. The MPLAB development environment can be downloaded from the Microchip web site. This software suite includes a free evaluation copy page 2 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual of the Microchip C32 compiler for use with the PIC32 microcontroller family. The licensed debugger is compatible with the MPLAB IDE version 8.63 or later or all versions of MPLAB X. When creating a new project, use the “Configure.Select Device…” menu to specify the PIC32 device being used. Ensure that the device is set to PIC32MX795F512L. In order to use the on-board programming/debugging circuit it must be selected as the debugger or programmer within the MPLAB IDE. Use the “Debugger.Select Tool” menu, or the “Programmer.Select Tool” menu, and select “Licensed Debugger” as the programmer or debugger. The licensed debugger interface uses USB connector J15, labeled DEBUG. Connector J15 is a USB micro-B connector located on the left side of the board below the Ethernet RJ45 connector. Use a USB-A to micro-B cable (provided with the board) to connect to an available USB port on the PC. When the licensed debugger is selected as the programming or debugging device, the MPLAB IDE will check the version number of the firmware running on the debugger and offer to update if it is out of date with the version of MPLAB being used. The PIC32 in-system programming/debugging interface uses two pins on the microcontroller. These devices support two alternate pin pairs for this interface: PGC1/PGD1 or PGC2/PGD2. The PGC2/PGD2 pair is used by default. Due to conflicting uses of the microcontroller pins, the Cerebot MX7cK is designed to use the PGC1/PGD1 pair of pins. Because of this, it is necessary to select the use of PGC1/PGD1 for the debugging interface. This is done using configuration variables set using the #pragma config statement. The following statement must be used to configure the microcontroller for use with the on-board licensed debugger circuit: www.digilentinc.com #pragma config ICESEL = ICS_PGx1 The MPLAB IDE may report an error indicating that the device is not configured for debugging until a program containing this statement has been programmed into the board. The MCLR pin on the PIC32 microcontroller is used by the hardware programming/debugging interface to reset the processor. This same pin is used by the USB serial converter to reset the processor when using the MPIDE. It is possible that the reset function from the USB serial interface can interfere with correct operation of the Microchip programming and debugging tools. If this happens, jumper JP11 can be used to disconnect the USB serial converter reset circuit. Remove the shorting block from JP11 to disable the reset circuit. If the shorting block has been removed, it is necessary to reinstall it on JP11 in order to use the Cerebot MX7cK board with the MPIDE again. Using the Microchip development tools to program the Cerebot MX7cK will erase the chipKIT boot loader. To use the board with the chipKIT MPIDE again, it is necessary to program the boot loader back onto the board. The programming file for the boot loader programmed into the board by Digilent at the factory is available for download from the product page for the Cerebot MX7cK on the Digilent web site. Additionally, the boot loader source code is available in the chipKIT project repository at www.github.com/chipKIT32/pic32Arduino-Bootloader. To reprogram the boot loader using MPLAB, perform the following steps:  Use the “Configure.Select Device …” menu to select the PIC32MX795F512L  Use the “Programmer.Select Programmer” menu to select the “Licensed Debugger”.  Use the “File Import…” dialog box to navigate to and select the boot loader programming downloaded from the Digilent web site. The file name will be something like: chipKIT_Bootloader_MX7cK.hex  Use the “Programmer.Program” command to program all memories on the device. page 3 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual Using the Cerebot MX7cK with the chipKIT MPIDE ChipKIT and the MPIDE is a PIC32 based hardware and software system compatible with many existing Arduino™ code examples, reference materials and other resources. The MPIDE development platform was produced by modifying the Arduino™ IDE and is fully backward compatible with the Arduino IDE. The Cerebot MX7cK board is designed to be fully compatible with the chipKIT MPIDE system, version 20111221 or later. The MPIDE uses a serial communications port to communicate with a boot loader running in the target board. The serial port on the MX7cK board is implemented using an FTDI FT232R USB serial converter. Before attempting to use the MPIDE with the MX7cK, the appropriate USB device driver must be installed. Driving the MCLR line low resets the microcontroller, restarting execution with the boot loader. The automatic reset action when the serial communications connection is opened can be disabled. To disable this operation, remove the shorting block from jumper JP11. The shorting block is reinstalled on JP11 to restore operation with the MPIDE. Two red LEDs (LD9 and LD10) will blink when data is being sent or received between the Cerebot MX7cK and the PC over the serial connection. The header connector J1 provides access to the other serial handshaking signals provided by the FT232R. Connector J1 is not loaded at the factory but can be installed by the user to access these signals. Additional Reference Documentation The USB serial converter on the Cerebot MX7cK uses USB connector J2, labeled UART on the board. This connector is a USB microAB, and is located on the lower left side of the board adjacent to the power switch. Use a standard USB-A to micro-B cable (provided with the board) to connect the board to an available USB port on the PC. In the MPIDE, use the “Tools.Board” command to select the Cerebot MX7cK from the list of available boards. Use the “Tools.Serial Port” command to choose the appropriate serial port from the list of available serial ports on the PC. When the MPIDE needs to communicate with the MX7cK board, the PIC32 microcontroller is reset and starts running the boot loader. The MPIDE then establishes communications with the boot loader and downloads the user’s program, programming it into the flash memory in the microcontroller When the MPIDE opens the serial communications connection on the PC, the DTR pin on the FT232R chip is driven low. This pin is coupled through a capacitor to the MCLR pin on the PIC32 microcontroller. www.digilentinc.com Additional information about the Cerebot MX7cK board and the use and operation of the PIC32MX795F512L microcontroller can be obtained from the following sources. The Cerebot MX7cK Schematic, as well as various support libraries, and example reference designs are available on the board product page on the Digilent web site: www.digilentinc.com The PIC32MX5XX/6XX/7XX Family Data Sheet and the PIC32MX Family Reference Manual available from the Microchip web site: www.microchip.com Reference material for the chipKIT MPIDE system is included in the MPIDE software download, and on-line in the chipKIT wiki. Help with questions and problems using the board with the chipKIT MPIDE software can also be obtained in the chipKIT forums: www.github.com/chipKIT32 (software download) www.chipKIT.org/wiki www.chipKIT.org/forum page 4 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual Board Hardware Description The following describes the various hardware features of the Cerebot MX7cK board and the PIC32XM795F512L microcontroller. Board Power Supply Switch SW1, in the lower left corner of the board is the power switch. Place this switch in the ON position to turn on board power and in the OFF position to turn off board power. The Cerebot MX7cK may be USB powered via either the USB debug port, the USB UART port, or the USB device port. Alternatively, the board may be powered via dedicated, “external”, power supply connectors. Jumper block J3 selects the power source used to provide power to the board. This jumper block provides the following four positions:  USB – power is supplied by USB device connector J19. This is used when the Cerebot MX7cK is being used to implement a USB bus powered device.  EXT – Power is supplied by one of the external power connectors.  DBG – Power is supplied by DEBUG USB connector J15.  UART – Power is supplied by UART USB connector J2. Place the shorting block in the appropriate position on J3 for the desired power source for the board. The Cerebot MX7cK is rated for external power from 3.6 to 5.5 volts DC. Using a voltage outside this range will damage the board and connected devices. For most purposes, when using external power, a regulated 5V supply should be used. If the board is operated from an external supply with a voltage less than 5V, some features won’t work correctly. The USB specification requires that USB devices not draw more than 100mA of current www.digilentinc.com until they have enumerated on the USB bus and informed the host that they want to consume more current. To meet this specification, the debugger circuit turns on main board power by driving the PWR_ON signal high after successfully enumerating on the USB bus. The bus labeled on the schematic as VCC5V0 is powered when this occurs. The VCC5V0 bus powers the input to the main board voltage regulator, the input voltage to the USB bus voltage load switch used when using the board as a USB host, the power supply voltage for the CAN transceivers, and the 5V0 side of the power select jumpers for the Pmod connectors. The voltage on the VCC5V0 bus will be 5V when the board is being operated from USB power or an external regulated 5V supply. If a different external supply voltage is used, that voltage will appear on the VCC5V0 bus. The power supply selected by the shorting block on J3 will appear on the input power supply bus, labeled VIN in the schematic. This voltage is regulated to 3.3V to power the licensed debugger circuit by IC11, a Microchip MCP1801 Low Dropout voltage regulator. This regulator is turned on and the debugger circuit is powered whenever the power switch is in the on position. The VIN power bus also supplies power to IC9, a PFET load switch used to turn main board power on or off. When the power switch is turned on, transistor Q7A attempts to drive the ON/OFF pin of IC9 high to enable the main power supply. If the licensed debugger is connected to an active USB port, it initially disables the main power supply by holding the PWR_ON signal low. This causes Q8B to hold the ON/OFF pin of IC9 low, forcing the main supply off. The licensed debugger will enumerate with the host computer and once it has successfully enumerated, will turn on the main board power supply by driving the PWR_ON signal high. If the licensed debugger is not connected to an active USB port, the signal labeled DBG5V0 will not be powered. Transistor Q8B will be unable to hold the ON/OFF pin low and the page 5 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual main power supply will be turned on immediately when the power switch is turned on. When load switch IC9 is turned on, it powers the board unregulated power bus VCC5V0, which provides the input power to the main regulator. The main board power supply is a switch mode voltage regulator implemented using a Microchip MCP16301 switch mode step-down regulator, IC10. This regulator provides 3.3V at up to 600 mA with approximately 96% efficiency. When the main power supply is enabled, it powers the regulated power bus VCC3V3 When powering the board from an external power supply, there are two connectors that can be used: J17 and J18. The barrel connector, J17, is used to power the board from a “wall wart” style power supply. This type of power supply is available from many sources. Digilent has a power supply available, the 5V Switching Power Supply, that can be used with connector J17. Connector J17 is a 2.5mm x 5.5mm coaxial connector wired with the center terminal as the positive voltage. Connector J18 is a screw terminal connector for an alternative power supply connection for use with battery packs, bench supplies or other power sources where use of a hard wired power supply is desirable. Connectors J17 and J18 are wired in parallel and connect to the EXT position on the Power Select jumper block J3. A shorting block should be placed on the “EXT” position of J3 when using this option for board power. Only one of the external power connectors should be used at a time. If multiple power supplies are connected simultaneously, damage to the board or the power supplies may occur. When the Cerebot MX7cK is operating as a USB host, an external power supply connected to either J17 or J18 must be used to power the board. In addition to powering the logic on the Cerebot MX7cK board, this supply provides the www.digilentinc.com USB bus voltage supplied to any connected USB device and must be a regulated 5V with at least 500mA current capability to meet the USB specifications. The CAN bus operates at 5V, and therefore the transceivers for the two CAN interfaces require 5V to operate correctly and within the CAN specification. When using the CAN network interfaces, the board should be operated from a 5V supply if using an external power supply. The PIC32 microcontroller and on-board I/O devices operate at a supply voltage of 3.3V provided by the VCC3V3 bus. The main voltage regulator is capable of providing a maximum of 600mA of current. The PIC32 microcontroller will use approximately 85mA when running at 80MHz. The SMSC LAN8720 Ethernet PHY consumes approximately 45mA when operating at 100Mbps. The Microchip MCP2551 CAN transceivers can draw up to 75mA each when operating the CAN busses. The other circuitry on the board will draw 10-20 mA. The remaining current is available to provide power to attached Pmods and I2C devices. The Cerebot MX7cK can provide power to any peripheral modules attached to the Pmod connectors, JA-JF, and to I2C devices powered from the I2C daisy chain connectors, J7 and J8. Each Pmod connector provides power pins that can be powered from either the switched main power bus, VCC5V0, or regulated voltage, VCC3V3, by setting the voltage jumper block to the desired position. The I2C connectors only provide the regulated voltage, VCC3V3. Pmod™ Connectors The Cerebot MX7cK has six connectors for connecting Digilent Pmod peripheral modules. The Pmod connectors, labeled JA–JF, are 2x6 pin, right-angle, female pin header connectors. Each connector has an associated power select jumper block labeled JPA–JPF. page 6 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual Digilent Pmods are a line of small peripheral modules that provide various kinds of I/O interfaces. The Pmod product line includes such things as button, switch and LED modules, connector modules, LCD displays, high current output drivers, various kinds of RF interfaces, and many others. There are two styles of Pmod connector: sixpin and twelve-pin. Both connectors use standard pin headers with 100mil spaced pins. The six-pin connectors have the pins in a 1x6 configuration, while the twelve-pin connectors use a 2x6 configuration. All of the Pmod connectors on the Cerebot MX7cK are twelve pin connectors. Six-pin Pmod connectors provide four I/O signals, ground and a switchable power connection. The twelve-pin connectors provide eight I/O signals, two power and two ground pins. The twelve-pin connectors have the signals arranged so that one twelve-pin connector is equivalent to two of the six-pin connectors. Pins 1–4 and 7–10 are the signal pins, pins 5 and 11 are the ground pins and pins 6 & 12 are the power supply pins. The pin numbering that Digilent uses on the twelve-pin Pmod connectors is non-standard. The upper row of pins are numbered 1–6, left to right (when viewed from the top of the board), and the lower row of pins are numbered 7–12, left to right. This is in keeping with the convention that the upper and lower rows of pins can be considered to be two sixpin connectors stacked. When viewed from the end of the connector, pin 1 is the upper right pin and pin 7 is immediately below it (closer to the PCB). Each Pmod connector has an associated power select jumper. These are used to select the power supply voltage supplied to the power supply pins on the Pmod connector. They are switchable between either the unregulated power supply, VCC5V0 or the 3.3V main board supply, VCC3V3. Place the shorting block in the 3V3 position for regulated 3.3V and in the 5V0 position to use the unregulated supply. www.digilentinc.com Each signal pin on the Pmod connectors is connected to an input/output pin on the PIC32 microcontroller. Each pin has a 200 ohm series resistor and an ESD protection diode. The series resistor provides short circuit protection to prevent damaging the I/O block in the microcontroller if the pin is inadvertently shorted to VDD or GND, or two outputs are shorted together. The ESD protection diode protects the I/O block from damage due to electro-static discharge. The 200 ohm resistor in series with each I/O pin limits the amount of current that can be sourced from the microcontroller pins. There will be a 200mV voltage drop per mA of current sourced by the pin. This will not be a problem when driving typical, high impedance, logic inputs, but can be problematic when trying to drive low impedance inputs. If some cases, it may be necessary to use external buffers when trying to drive low impedance inputs. Although ESD protection is provided between the connector pins and the microcontroller pins, ESD safe handling procedures should be followed when handling the circuit board. The pins on the microcontroller and other circuits on the board are exposed and can be damaged through ESD when handling the board. Digilent Pmod peripheral modules can either be plugged directly into the connectors on the Cerebot MX7cK or attached via cables. Digilent has a variety of Pmod interconnect cables available. See the Pinout Tables in Appendix C, below, for more information about connecting peripheral modules and other devices to the Cerebot MX7cK. These tables describe the mapping between pins on the PIC32MX795 microcontroller and the pins on the various connectors. The PIC32 microcontroller can source or sink a maximum of 18mA on all digital I/O pins. However, to keep the output voltage within the specified input/output voltage range (V OL 0.4V, VOH 2.4V) the pin current must be restricted to page 7 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual +7/-12mA. The maximum current that can be sourced or sunk across all I/O pins simultaneously is +/-200mA. The maximum voltage that can be applied to any digital I/O pin is 5.5V. The maximum voltage that can be applied to any analog input capable pin is 3.6V. For more detailed specifications, refer to the PIC32MX5XX/6XX/7XX Family Data Sheet. Digital Inputs and Outputs The Cerebot MX7cK board provides access to 48 of the I/O pins from the PIC32MX795 microcontroller via the Pmod connectors. Four additional I/O pins can be accessed via the I2C connectors, J7 and J8. Any of the pins on the Pmod or I2C connectors can be individually accessed for digital input or output. Note that when the I2C signals on J7 or J8 are being used for I2C communications, they are not available for general purpose I/O. On PIC32 microcontrollers, the input/output pins are grouped into I/O Ports and are accessed via peripheral registers in the microcontroller. There are seven I/O Ports numbered A–G and each is 16 bits wide. Depending on the particular PIC32 microcontroller, some of the I/O Ports are not present, and not all 16 bits are present in all I/O Ports. Each I/O Port has four associated registers: TRIS, LAT, PORT, and ODC. The registers for I/O Port A are named TRISA, LATA, PORTA and ODCA. The registers for the other I/O Ports are named similarly. The TRIS register is used to set the pin direction. Setting a TRIS bit to 0 makes the pin an output. Setting the TRIS bit to 1 makes the pin an input. The LAT register is used to write to the I/O Port. Writing to the LAT register sets any pins configured as outputs. Reading from the LAT register returns the last value written. the current state of all of the pins in the I/O Port. Writing to the PORT register is equivalent to writing to the LAT register. PIC32 microcontrollers allow any pin set as an output to be configured as either a normal totem-pole output or as an open-drain output. The ODC register is used to control the output type. Setting an ODC bit to 0 makes the pin a normal output and setting it to 1 makes the pin an open drain output. Refer to the PIC32MX5XX/6XX/7XX Family Data Sheet, and the PIC32 Family Reference Manual, Section 12, IO Ports, for more detailed information about the operation of the I/O Ports in the microcontroller. Pmod connector JF, pins 8, 9, and 10 are connected to the signals TCK/RA1, TDI/RA4, and TDO/RA5 respectively. These microcontroller pins are shared between general purpose I/O functions and use by the JTAG controller. The JTAG controller is enabled on reset, so these pins are not available for general purpose I/O until the JTAG controller is disabled. The following statement can be used to disable the JTAG controller: DDPCONbits.JTAGEN = 0; The JTAG controller is disabled by the startup initialization code in the MPIDE runtime. It is not necessary to disable the JTAG controller when using the board with MPIDE. The chipKIT MPIDE system uses logical pin numbers to identify digital I/O pins on the connectors. These pin numbers start with pin 0 and are numbered up consecutively. On the Cerebot MX7cK, pin numbers 0-47 are used to access the pins on the Pmod connectors and pin numbers 55-58 are used for the signal pins on the I2C connectors, J7 and J8. The pin numbers are assigned so that connector JA pin 1 (JA-01) is digital pin 0, JA pin 2 (JA-02) is digital pin 1, and so on. The PORT register is used to read from the I/O Port. Reading from the PORT register returns www.digilentinc.com page 8 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual Pins 0-7 are on connector JA, pins 8-15 on JB, pins 16-23 on JC, pins 24-31 and so on. Refer to the tables in Appendix B for detailed information about the pin mapping between Pmod connector, logical pin number, and PIC32 microcontroller pin number and pin function. When using the Cerebot MX7cK with the chipKIT MPIDE the functions pinMode(), digitalRead(), and digitalWrite() are used for digital pin I/O. The pinMode() function is used to set the pin direction. Pin direction can be set to: INPUT, OUTPUT, or OPEN. OPEN is used for opendrain and implies output. The digitalRead() and digitalWrite() functions are used to read or write the pins. DigitalRead() returns the current state of the specified pin, and digitalWrite is used to set the state of an output pin. The pin state can be either HIGH or LOW. Push Buttons and LEDs The Cerebot MX7cK board provides three push button switches for user input and four LEDs for output. The buttons, BTN1 and BTN2 are connected to I/O Port G, bits 6 and 7 respectively. BTN3 is connected to I/O Port A, bit 0. To read the buttons, pins 6 and 7 of I/O Port G and pin 0 of I/O Port A must be configured as inputs by setting the corresponding bits in the TRISG and TRISA registers. The button state is then obtained by reading the PORTG or PORTA registers. When a button is pressed, the corresponding bit will be high (‘1’). The pins used by the buttons are dedicated to this use and do not appear on any connector. Button BTN3 is connected to the signal TMS/RA0 on the PIC32 microcontroller. This microcontroller pin is shared between general purpose I/O functions and use by the JTAG controller. The JTAG controller is enabled on reset, and so BTN3 is not useable as a button input until the JTAG controller is disabled. The www.digilentinc.com following statement can be used to disable the JTAG controller: DDPCONbits.JTAGEN = 0; The JTAG controller is disabled by the startup initialization code in the MPIDE runtime. It is not necessary to disable the JTAG controller when using the board with MPIDE. The four LEDs are connected to bits 12-15 of I/O Port G. LED 1 is connected to bit 12, LED 2 is connected to bit 13, and so on. These four pins are dedicated to use with the LEDs and do not appear on any connector pin. To use the LEDs, configure the desired bits as outputs by clearing the corresponding bits in the TRISG register. The state of an LED is set by writing values to the LATG register. Setting a bit to 1 will illuminate the LED and setting the bit to 0 will turn it off. When using the MPIDE and the chipKIT system, the buttons are accessed using digitalRead() and the LEDs using digitalWrite(). Use the following pins to access them:        BTN1 – PIN_BTN1, pin 48, RG6 BTN2 – PIN_BTN2, pin 49, RG7 BTN3 – PIN_BTN3, pin 50, RA0 LD1 – PIN_LED1, pin 51, RG12 LD2 – PIN_LED2, pin 52, RG13 LD3 – PIN_LED3, pin 53, RG14 LD4 – PIN_LED4, pin 54, RG15 5V Signal Compatibility The PIC32 microcontroller operates at 3.3V. And the I/O pins provide 3.3V logic levels. It is possible, in some circumstances, to use the Cerebot MX7cK to operate with 5V logic devices however. There are two issues to consider when dealing with 5V compatibility for 3.3V logic. The first is protection of 3.3V inputs from damage caused by 5V signals. The second is whether the 3.3V output is high enough to be recognized as a logic high value by a 5V input. page 9 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual The digital only I/O pins on the PIC32 microcontroller are 5V tolerant. It is safe to apply 5V logic signals directly to these pins without risk of damage to the microcontroller. with pins that are not 5V tolerant on the PIC32 microcontroller. The analog capable I/O pins on the PIC32 are not 5V tolerant. The absolute maximum voltage rating for the analog pins is 3.6V. Generally, the analog pins are the pins on I/O port B, however, there are other non-5V tolerant pins on the device. A reset button is at the upper right corner of the board. Pressing this button will reset the PIC32 microcontroller. RESET Refer to the PIC32MX5XX/6XX/7XX Family Data Sheet for more information about which pins on the device are 5V tolerant before applying input signals higher than 3.3V to any pin on the Cerebot MX7cK board. If a 5V signal is applied to a non-5V tolerant pin, some external means must be used to limit the applied voltage to 3.6V or less. The Cerebot MX7cK board provides 200 ohm series resistors between the microcontroller pins and the Pmod connector pins. These resistors are primarily intended to provide short circuit protection on the outputs, but will also provide limited protection if a 5V signal is inadvertently applied to a non-5V tolerant pin. One technique that can be used to limit an input voltage to a safe level is to use a 200 ohm series resistor and Shottky diode connected to the 3.3V supply to clamp the voltage. The minimum output high voltage of the PIC32 microcontroller is rated at 2.4V when sourcing 12mA of current. When driving a high impedance input (typical of CMOS logic) the output high voltage will be close to 3.3V. Some 5V devices will recognize this voltage as a logic high input, and some won’t. Many 5V logic inputs will work reliably with 3.3V inputs. If the 3.3V logic output is not sufficient for 5V logic input to be reliably seen as a logic high input signal, some external means must be used to raise the output level. In some cases, a pull-up resistor to 5V is sufficient. A pull-up resistor in the range of 2Kohm–10kOhm can be used. This technique should not be used www.digilentinc.com page 10 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual PIC32 Peripheral Devices The following describes the peripheral devices available in the PIC32MX795F512L microcontroller and how they are accessed on the Cerebot MX7cK board. CPU Clock Source The PIC32 microcontroller supports numerous clock source options for the main processor operating clock. The Cerebot MX7cK board is designed to operate with either a silicon resonator from Discera, IC2, for use with the EC oscillator option, or an external crystal, X1, for use with the XT oscillator option. Standard production boards will have an 8Mhz Discera silicon resonator loaded and the EC oscillator option should be used. If IC2 is not loaded, an 8Mhz crystal will be loaded for X1 (on the bottom of the board) and the XT oscillator option should be used. Oscillator options are selected via the configuration settings specified using the #pragma config statement. Use #pragma config POSCMOD=EC to select the EC option and #pragma config POSCMOD=XT to select the XT option. Using the internal system clock phase-locked loop (PLL), it is possible to select numerous multiples or divisions of the 8Mhz oscillator to produce CPU operating frequencies up to 80Mhz. The clock circuit PLL provides an input divider, multiplier, and output divider. The external clock frequency (8Mhz) is first divided by the input divider value selected. This is multiplied by the selected multiplier value and then finally divided by the selected output divider. The result is the system clock, SYSCLK, frequency. The SYSCLK frequency is used by the CPU, DMA controller, interrupt controller and pre-fetch cache. The operating frequency is selected using the PIC32MX795 configuration variables. These are set using the #pragma config statement. Use #pragma config FPLLIDIV to set the input divider, #pragma config FPLLMUL to set the multiplication factor and #pragma config FPLLODIV to set the www.digilentinc.com output divider. Refer to the PIC32MX5XX/6XX/7XX Family Data Sheet and the PIC32MX Family Reference Manual, Section 6. Oscillators for information on how to choose the correct values, as not all combinations of multiplication and division factors will work. In addition to configuring the SYSCLK frequency, the peripheral bus clock, PBCLK, frequency is also configurable. The peripheral bus clock is used for most peripheral devices, and in particular is the clock used by the timers, and serial controllers (UART, SPI, I2C). The PBLCK frequency is a division of the SYSCLK frequency selected using #pragma config FPBDIV. The PBCLK divider can be set to divide by 1, 2, 4, or 8. The following example will set up the Cerebot MX7cK for operation with a SYSCLK frequency of 80Mhz and a PBCLK frequency of 10Mhz: #pragma #pragma #pragma #pragma #pragma #pragma config config config config config config FNOSC = PRIPLL POSCMOD = EC FPLLIDIV = DIV_2 FPLLMUL = MUL_20 FPLLODIV = DIV_1 FPBDIV = DIV_8 Documentation for the PIC32 configuration variables can be found in the PIC32MX Configuration Settings guide. This is found using the “Help.Topics…” command in the MPLAB IDE. Also, refer to Appendix C for an example of setting the configuration variables. When using the Cerebot MX7cK with the chipKIT MPIDE software, the clock source is set by the boot loader and no action is required. Ethernet Interface The Cerebot MX7cK provides the ability to interface with 10Mbps or 100Mbps Ethernet networks. The PIC32MX795 microcontroller contains a 10/100 Ethernet Medium Access Controller (MAC). External to the PIC32 microcontroller, the Cerebot MX7cK board provides an SMSC LAN8720 Ethernet Physical page 11 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual Layer Transceiver (PHY). Together, the MAC and PHY in combination with an appropriate coupling transformer and RJ45 jack provide a standard 10/100 Ethernet interface. The RJ45 connector J11, provides the physical connection to an Ethernet network using a standard Ethernet cable. All devices on an Ethernet network must have a unique address. This address is used to direct packets on the network to a specific device and to identify the device that originated a packet. An Ethernet MAC uses a 48-bit address value, commonly called the “MAC Address”. These address values are globally unique to ensure that no two devices on a network can have conflicting addresses. MAC addresses are assigned by the IEEE. Each PIC32MX795 device is programmed at the factory to have a unique MAC address that will be loaded by default when the device is reset. Digilent provides another unique MAC address that can be used as well. This address is printed on a sticker attached to the bottom of the board. The Digilent provided MAC address is a twelve digit hexadecimal number of the form: 00183Exxxxxx, where xxxxxx represents six hexadecimal digits. This value is used to initialize the Ethernet Controller MAC Station Address registers in the Ethernet controller of the PIC32MX795 microcontroller. In order to connect to and operate with an Ethernet network, the PIC32 microcontroller must be running network protocol stack firmware. Normally, the TCP/IP (Transmission Control Protocol/Internet Protocol) network protocol is used and “TCP/IP Stack” software must be used. The Microchip Applications Library, available for download from the Microchip web site provides full protocol stack support compatible with the PIC32MX795 MAC and the LAN8720 PHY. Microchip also provides numerous example programs illustrating the use of their network protocol stack for various applications. When not using the Microchip network protocol stack, refer to the manufacturer documentation www.digilentinc.com for the PIC32MX795 and LAN8720, plus network protocol documentation, for operation of the Ethernet interface. Digilent has Network libraries available that can be used to develop both client and server applications when using the board with the chipKIT MPIDE development environment. These libraries are built on a custom version of the Microchip Applications Library network stack and support various network protocols such as TCP, UDP, DHCP and others to provide complete Ethernet network support. These libraries can be downloaded from the Cerebot MX7cK product page on the Digilent web site. The Digilent chipKIT libraries contain examples illustrating various network applications. The PIC32MX795 microcontroller provides two alternate sets of pins that can be used to connect the MAC to the external PHY. It also provides two alternate standard MAC/PHY interface signaling conventions. The Cerebot MX7cK is designed to use the standard (not the alternate) pins, and to use the RMII (not the MII) interface signaling convention. These options are selected using the configuration variables in the PIC32 microcontroller and are specified using the #pragma config statement. To enable the Ethernet controller in the correct configuration, the following statements must appear in the main program module: #pragma config FETHIO=ON #pragma config FMIIEN=OFF The chipKIT MPIDE boot loader sets these configuration variables, and so no action is necessary when using the MPIDE software system. The LAN8720 PHY has a reset signal, labeled NRST in the schematic, used to reset the PHY. This signal is connected to the TRCLK/RA6 pin on the PIC32 microcontroller. The NRST signal is active low. Configure the microcontroller pin as an output and drive it low to reset the PHY, or drive it high to allow the PHY to come out of page 12 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual reset and begin operation. The NRST signal is pulled low on the board, so that the PHY is held in reset by default. To allow the PHY to operate, this pin must be driven high. This reset operation is not part of the Microchip network protocol stack, and so driving NRST high must be done before initializing the Microchip network stack. The Digilent chipKIT network libraries perform this automatically, and so no action is necessary when using the board with the MPIDE software system and the Digilent libraries. USB Interface The PIC32MX795 microcontroller contains a USB 2.0 Compliant, Full Speed Device and On-The-Go (OTG) controller. This controller provides the following features:      USB full speed host and device support Low speed host support USB OTG support Endpoint buffering anywhere in system RAM Integrated DMA to access system RAM and Flash memory. The USB controller uses a phased lock loop, PLL, to generate the necessary USB clock frequency from the external primary oscillator input frequency. By default, this PLL is disabled. In order to use the USB controller, it is necessary to enable the USB PLL, and set the input divider to the correct value to generate a valid USB clock. The input to the USB PLL must be 4Mhz. The Cerebot MX7cK provides an 8Mhz clock to the PIC32 microcontroller, so a USB PLL input divider value of 2 must be used. These parameters are set in the PIC32 microcontroller configuration registers using the #pragma config statement. The following statements must be used to configure the PIC32 microcontroller for use of the USB controller: #pragma config UPLLEN = ON #pragma config UPLLIDIV = DIV_2 www.digilentinc.com When using the chipKIT MPIDE development environment, these will have been set by the boot loader, so no action is needed. When operating as a USB device, the Cerebot MX7cK can be used as a self powered device or as a bus powered device. To operate as a self powered device, an external power supply should be connected to one of the external power connectors (J17 or J18) and a shorting block placed on the “EXT” position of J3. To operate as a bus powered device, the shorting block should be placed in the USB Device position, “USB”, on J3. Note that when operating as a bus powered device, the Cerebot MX7cK and all devices connected to it are limited to using no more than 500mA of current to remain in compliance with the USB specification. Connector J19, on the bottom of the board in the lower right corner is the Device/OTG connector. This is a standard USB micro-AB connector. Connect a cable with a micro-A plug (optionally available from Digilent) from this connector to an available USB port on a PC or USB hub for device operation. When operating as a USB host, the Cerebot MX7cK must be externally powered. Connect a regulated 5V power supply to one of the external power connectors (J17, or J18) and ensure that the shorting block is in the, “EXT” position of J3. The power supply used must be a regulated 5V supply. The Cerebot MX7cK board provides power to the attached USB device when operating as a host and the USB specification requires the use of a 5V power supply. NOTE: Providing a voltage greater than 5V can damage the Cerebot MX7cK board and/or the USB device being used. Connector J20, on the top of the board in the lower right corner is the USB host connector. This is a standard USB type A receptacle. USB devices may be connected either directly or through a standard USB cable. Jumper JP10 is used to route power to the host connector being used. Place the shorting page 13 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual block in the “A” position when using the standard USB type A (host) Connector, J20. Place the shorting block in the “MICRO” position for use with the USB micro-AB (OTG) connector, J19. the chipKIT MPIDE development environment. These libraries are built on a custom version of the Microchip Applications Library and can be downloaded from the Cerebot MX7cK product page on the Digilent web site. When operating as a USB host, the PIC32MX795 microcontroller controls application of power to the connected device via the VBUSON control pin. The VBUSON signal is connected to the circuit net labeled P32_VBUSON in the schematic. Bus power is applied to the attached USB device by driving the VBUSON pin high. Power is removed from the device by driving the VBUSON pin low. The VBUSON pin is accessed via bit 3 of the U1OTGCON register. The Digilent chipKIT libraries contain examples illustrating various USB host and device applications. CAN Interface The Controller Area Network (CAN) is a control networking standard originally developed for use in automobile systems, but has since become a standard used in various industrial control and building automation networking applications as well. The VBUSON pin drives the enable input of a Texas Instruments TPS2051B Current-Limited Power Distribution Switch to control the application of USB power to the host connector. This switch has over-current detection capability and provides an overcurrent fault indication by pulling the signal P32_USBOC low. The over-current output indication can be monitored via I/O Port D pin 13 (RD13) on the PIC32MX795 microcontroller. This pin can function as change notification pin 19 (CN19), so that a change notification interrupt can be used to detect the overcurrent condition. The PIC32MX795 microcontroller contains two independent CAN network controllers. These CAN controllers in combination with two Microchip MCP2551 CAN transceivers allow the Cerebot MX7cK board to operate on up to two independent CAN networks. Refer to the PIC32MX5XX/6XX/7XX Family Data Sheet and the PIC32 Family Reference Manual, Section 34, Controller Area Network (CAN), plus CAN network documentation for information on operation of the CAN controllers and CAN networking in general. Details about the operation of the TPS2051B can be obtained from the data sheet available at the Texas Instruments web site. The Microchip C32 peripheral library, plib, provides basic support for all CAN operations using the CAN controllers in the PIC32MX795 microcontroller. The Microchip Applications Library, MAL, available on the Microchip web site contains USB driver code for implementing either USB host devices or USB function devices. This library contains numerous examples demonstrating both device and host operation of PIC32 microcontrollers. With minor modification or configuration, these reference designs are suitable to use for developing USB firmware for the Cerebot MX7cK board. Digilent has USB libraries available that can be used to develop both USB device and USB host applications when using the board with www.digilentinc.com Digilent has a basic CAN library available for use with the chipKIT MPIDE software environment. This library can be downloaded from the Cerebot MX7cK product page on the Digilent web site. The PIC32MX795 microcontroller provides two sets of pins that can be used to connect the CAN controllers to the external transceivers. The Cerebot MX7cK is designed to use the alternate (not the standard) pins. This selection is made using the configuration variables in the microcontroller, set using a #pragma config statement. To select the use of the alternate page 14 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual interface pins, the following statement must appear in the main program module: #pragma config FCANIO=OFF The chipKIT MPIDE boot loader sets the configuration variables, and so no action is necessary when using the MPIDE software system. The pins on the PIC32MX795 microcontroller used by signals for the CAN1 controller to connect to its transceiver are shared with two of the signals for the UART2 and SPI4 ports. Jumpers JP1 and JP2 are used to select the use of these two signals. Place JP1 and JP2 in the CAN position for use of the CAN1 network interface. Place JP1 and JP2 in the PMOD position for use of these signals for UART or SPI operation. These signals connect to pins 1 & 4 of Pmod connector JF. When JP1 and JP2 are in the CAN position, Pins 1 & 4 of Pmod connector JF are not useable. In some cases it may be possible to use UART2 at the same time as CAN1 as the RX and TX pins are not used by the CAN interface (only RTS and CTS are used). When JP1 and JP2 are in the CAN position Pmod pins JF-01 and JF-04 are not connected to the PIC32 microcontroller. There is no standard connector for use with CAN networks. The Cerebot MX7cK board provides two 2x6 pin header connectors for access to the CAN signals. Connector J9 provides access to the signals for the CAN1 network controller, and connector J10 provides access to the signals for CAN2. Refer to the Cerebot MX7cK schematic, Sheet 6, for information on the connectors and signal assignments. Digilent 6-pin or 2x6 to dual 6-pin cables can be used to daisy chain Digilent boards together in a CAN network. A Digilent 6-Pin cable in combination with a Digilent PmodCON1 Screw Terminal Connector module can be used to connect the Cerebot MX7cK board to other network wiring configurations. The CAN network standard requires that the network nodes at each end of a network provide 120 ohm termination. The Cerebot www.digilentinc.com MX7cK provides termination resistors and jumpers to enable/disable them depending on the location of the board in the network. Jumper JP5 is used to enable/disable the termination resistor for the CAN1 network connector, and JP7 is used to enable/disable the termination resistor for CAN2. Install a shorting block on the jumper pins to enable the termination resistor, or remove the shorting block to disable it. UART Interface The PIC32MX795 microcontroller can provide up to six UARTs. Due to conflicting uses of many of the pins used by the UARTs, the Cerebot MX7cK is designed to allow use of two of them: UART1 and UART2. The UARTs can provide either a 2-wire or a 4-wire asynchronous serial interface. The 2-wire interface provides receive (RX) and transmit (TX) pins. The 4-wire interface includes request-to-send (RTS) and clear-to-send (CTS) in addition to receive and transmit. UART1 can be accessed from Pmod connector JE and UART2 can be accessed from Pmod connector JF using the following pins:     U1CTS U1TX U1RX U1RTS JE-01 JE-02 JE-03 JE-04     U2CTS U2TX U2RX U2RTS JF-01 JF-02 JF-03 JF-04 Note that early versions of the Microchip PIC32MX5XX/6XX/7XX Family Data Sheet refer to UART1 as UART1A and UART2 as UART3A. Detailed information about the operation of the UART peripherals can be found in the PIC32 Family Reference Manual, Section 21, UART. The USB Serial converter is connected to UART1. The MPIDE uses this to communicate page 15 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual with the boot loader. This can also be used for a serial communications interface between the Cerebot MX7cK board and other software running on a PC. Resistors are used to decouple the USB serial interface and so UART1 can also be used via Pmod connector JE when not using it to communicate with the USB serial converter. the slave, it simultaneously receives a byte from the slave. Note that when using the MPIDE software, devices connected to JE can interfere with the operation of the serial interface and prevent the MPIDE from successfully downloading sketches to the board. If this happens, disconnect the external device from JE until the sketch has been downloaded and then reconnect it. The following gives the mapping between SPI signals and connector pins: When using the Cerebot MX7cK with the MPIDE and the chipKIT system, the UARTs are accessed using the HardwareSerial facility built into the system. UART1, Pmod connector JE, is accessed using the Serial object and UART2, Pmod connector JF, is accessed using Serial1. Serial Peripheral Interface (SPI) SPI is a four wire synchronous serial interface and SPI devices can operate as either master devices or as slave device. The PIC32 microcontroller labels the four SPI signals as Slave Select (SS), Serial Data Out (SDO), Serial Data In (SDI), and Serial Clock (SCK). A master device transmits SS, SDO and SCK, and receives SDI. A slave device receives SS, SDI, and SCK and transmits SDO. The SS signal is used to enable the slave device, and this signal is only significant for slave devices. A master device can use any general purpose I/O pin to generate SS to enable the slave. An SPI transaction begins with the master device bringing SS low. When the slave sees SS go low it becomes enabled and waits for the master to send data. The master shifts data out on SDO and simultaneously shifts data in on SDI. The slave device receives data from the master on its SDI pin and simultaneously sends data to the master on its SDO pin. Each time the master sends a byte to www.digilentinc.com The PIC32MX795 microcontroller provides four Serial Peripheral Interfaces. The Cerebot MX7cK supports use of three ports: SPI1, SPI3 and SPI4. These are accessed using Pmod connectors JD, JE, and JF.     SS1 SDO1 SDI1 SCK1 JD-01 JD-02 JD-03 JD-04     SS3 SDO3 SDI3 SCK3 JE-01 JE-02 JE-03 JE-04     SS4 SDO4 SDI4 SCK4 JF-01 JF-02 JF-03 JF-04 Note that early versions of the Microchip PIC32MX5Xx/6XX/7XX Family Data Sheet refer to SPI3 as SPI1A and SPI4 as SPI3A. Detailed information about the operation of the SPI peripherals can be found in the PIC32 Family Reference Manual, Section 23, Serial Peripheral Interface. When using the Cerebot MX7cK with the MPIDE and the chipKIT system, the SPI ports are accessed using either the standard chipKIT SPI library or using the Digilent DSPI library. The standard SPI library supports access to a single SPI port, SPI4, Pmod connector JF. This is accessed using the SPI object. The DSPI library supports access to all three SPI ports. The DSPI0 object class is used to create an object used to access SPI1, Pmod connector JD. The DSPI1 object class is used to access SPI3, Pmod connector JE, and the page 16 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual DSPI2 object class is used to access SPI4, Pmod connector JF. lines low. One device on the I2C bus must provide the pull-up resistors. I2C™ Interface On the Cerebot MX7cK, I2C2, connector J8, has permanently connected, 2.2K ohm, pull-up resistors. I2C1, connector J7, provides selectable pull-ups that can be enabled or disabled via jumper blocks JP3 and JP4. The pull-ups are enabled by installing shorting blocks on JP3 and JP4. They are disabled by removing the shorting blocks. Only one device on the bus should have the pull-ups enabled. The I2C daisy chain connectors, J7 and J8, each provide two positions for connecting to the I2C signals, power and ground. By using two-wire or four-wire MTE cables (available separately from Digilent) a daisy chain of multiple Cerebot MX7cK boards or other I2Ccapable boards can be created. The I2C bus is an open-collector bus. Devices on the bus actively drive the signals low. The high state on the I2C signals is achieved by pull-up resistors when no device is driving the www.digilentinc.com Pull-ups Enabled 3V3 GND SDA SCL 3V3 In addition to I2C1 and I2C2, two other I2C interfaces, I2C3 and I2C5 can be accessed via pins on Pmod connectors. I2C3 can be accessed via Pmod connector JE, pins JE-02 (SCL3) and JE-03 (SDA3). I2C5 can be accessed via Pmod connector JF, pins JF-02 (SCL5) and JF-03 (SDA5) GND The pull-ups on I2C1 on the Cerebot MX7cK board are actually implemented using current mirrors rather than simple resistors. These current mirrors source approximately 1.7mA. The use of current mirrors provides faster rise times on the I2C signals and provides the ability to drive longer cable runs reliably than would be the case with simple pull-up resistors. SCL The PIC32MX795 microcontroller provides for up to five independent I2C interfaces. The Cerebot MX7cK is designed to provide dedicated access to two of these interfaces I2C1 and I2C2 via I2C daisy chain connectors J7 and J8. Connector J7 provides access to I2C1 while connector J8 provides access to I2C2. If the I2C interfaces on Pmod connectors JE or JF are being used, external pull-up resistors must be provided. These resistors can be in the range 1K ohm to 10K ohm, and should be connected to pull the pins to 3.3V. SDA The Inter-Integrated Circuit (I2CTM) Interface provides a medium speed (100K or 400K bps) synchronous serial communications bus. The I2C interface provides master and slave operation using either 7 bit or 10 bit device addressing. Each device is given a unique address, and the protocol provides the ability to address packets to a specific device or to broadcast packets to all devices on the bus. Refer to the Microchip PIC32MX5XX/6XX/7XX Family Data Sheet and the PIC32 Family Reference Manual, Section 24, Inter-Integrated Circuit, for detailed information on configuring and using the I2C interface. Pull-ups Disabled Jumper Settings for I2C Pull-Up Resistors When using the Cerebot MX7cK with the MPIDE and the chipKIT system, the I2C interfaces are accessed using the standard chipKIT Wire library, or the Digilent DTWI library. page 17 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual The Wire library supports a single I2C interface, I2C2 on J8. This is accessed using the Wire object. The DTWI library supports four I2C interfaces. The DTWI0 object class is used to create an object for access to I2C1, connector J7, and the DTWI1 object class is used to access I2C2, connector J8. The DTWI2 object class is used to access I2C3, Pmod connector JE, and the DTWI3 object class is used to access I2C5, Pmod connector JF. The pinouts of the I2C connectors are as follows: Connector J7 – I2C1  J7-1, J7-2 – SCL1  J7-3, J7-4 – SDA1  J7-5, J7-6 – GND  J7-7, J7-8 – VCC3V3 Connector J8 – I2C2  J8-1, J8-2 – SCL2  J8-3, J8-4 – SDA2  J8-5, J8-6 – GND  J8-7, J8-8 – VCC3V3 Pmod connector JE – I2C3  JE-02 – SCL3  JE-03 – SDA3 Pmod connector JF – I2C5  JF-02 – SCL5  JF-03 – SDA5 On-Board I2C Peripheral Device The Cerebot MX7cK provides one on-board I2C peripheral device, a Microchip 24LC256 serial EEPROM. This device is connected to I2C2. The 24LC256 is a 256Kbit (32Kbyte) serial EEPROM device to provide non-volatile memory storage. The device address for the 24LC256 is 1010000 (0x50). When using the chipKIT MPIDE software, this device can be accessed using the Wire library Wire object, or using the DTWI library via the DTWI1 object class. www.digilentinc.com Refer to the Microchip data sheet for detailed information on the operation of this device. Analog Inputs The PIC32MX795 microcontroller provides a 10-bit analog to digital (A/D) converter that provides up to sixteen analog inputs. The Cerebot MX7cK board provides access to 10 of these inputs via the Pmod connectors. The converted values produced by the A/D converter will be in the range 0–1023. For detailed information on the operation and use of the A/D converter, refer to the PIC32 Family Reference Manual, Section 17, 10-bit AD Converter. The analog inputs are accessed using the analogRead() function in the chipKIT MPIDE software. The analog input pin number is specified using the symbols A0–A9. The digital pin numbers for the pins or the numbers 0–9 can also be used, but using the symbols A0– A9 is recommended. The following gives the Pmod connector position, digital pin number, and microcontroller I/O port and bit number for the analog inputs:           A0 – JA-01, digital pin 0, RB02 A1 – JA-02, digital pin 1, RB03 A2 – JA-03, digital pin 2, RB04 A3 – JA-04, digital pin 3, RB06 A4 – JA-07, digital pin 4, RB07 A5 – JA-08, digital pin 5, RB08 A6 – JA-09, digital pin 6, RB09 A7 – JA-10, digital pin 7, RB10 A8 – JC-07, digital pin 20, RB15 A9 – JC-10, digital pin 23, RB14 A/D Converter Voltage Reference The PIC32 microcontroller provides two voltage reference inputs to the analog to digital converter. Vref- is used set the lower reference level and Vref+ is used to set the upper reference level. These references can be page 18 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual connected to internal references or to external references using two of the analog input pins. When the internal references are being used, Vref- is connected to VSS and Vref+ is connected to VDD. This means that the voltage input range at the analog input pins is 0V–3.3V. In this case, an input voltage of 0V will convert to ~0, an input voltage of 1.65V will convert to ~511, and an input voltage of 3.3V will convert to ~1023. Either one, or both, of the references can be connected to external reference pins. When this is done, the references can be set to voltages other than 0V and 3.3V. If, for example, both references were selected to use external references, with 1V applied to Vref- and 2V applied to Vref+, the input voltage range at the analog input pins would be from 1V to 2V. An applied voltage of 1V would have a converted value of ~0, 1.5V would have a converted value of ~511, and 2V would have a converted value of ~1023. When both external references are being used, Vref+ must have a higher voltage applied to in than Vref-. The analog reference input pins appear on Pmod connector JE, pins 9 & 10. Vref- is on pin JE-09, and Vref+ is on pin JE-10. These pins are not available to be used for digital I/O when being used as an external reference. When using the chipKIT MPIDE software, the use of external analog references is selected using the analogReference() function. The following values can be used with analogReference():  DEFAULT – Vref- = 0V, Vref+ = 3.3V  INTERNAL – same as default  EXTERNAL – Vref- = 0V, Vref+ = voltage at A2  EXTMINUS – Vref- = voltage at A3, Vref+ = 3.3V  EXTPLUSMINUS – Vref- = voltage at A3, Vref+ = voltage at A2 www.digilentinc.com Timers The PIC32MX795 microcontroller provides five timers that can be used for various timing functions. These timers are each 16 bits wide, although two pairs, TIMER2/TIMER3 and TIMER4/TIMER5 can be combined to produce 32 bit wide timers. A timer consists of a control register, a counter register, and a period register. The control register is used to configure the timer for various modes of operation. The count register counts cycles of the clock source selected via the control register. This clock source can be the peripheral bus clock or a division of the peripheral bus clock via a pre-scaler divider. The period register can be used to generate an interrupt and/or reset the count register when a pre-determined value is reached. Each timer has an associated input pin. In some operating modes, this pin can be used as an external clock input to the timer, or as a gate input to turn on/off incrementing of the counter register under control of an external signal. The following gives the Pmod connector position, chipKIT pin number, and microcontroller I/O port and bit number for the timer input pins.      T1CK – not available T2CK – JC-01, digital pin 16, RC01 T3CK – not available T4CK – not available T5CK – JD-03, digital pin 26, RC04 For detailed information on the operation of the PIC32 timers, refer to the PIC32 Family Reference Manual, Section 14, Timers. When using the chipKIT MPIDE software, the symbols PIN_TCK2 and PIN_TCK5 can be used to access the timer input pins. Control and operation of the timers is not explicitly provided in the current version of the chipKIT MPIDE software. This capability will be added in a future version of the software. page 19 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual Timers are used implicitly by various core functions and libraries, however.  OC4 – JD-09, digital pin 30, RD03  OC5 – JC-09, digital pin 22, RD04 Output Compare Input Capture The PIC32MX795 microcontroller provides five output compare units that can be used to control the timing of state changes on certain output pins or to generate pulse width modulated (PWM) outputs. The PIC32MX795 microcontroller provides five input capture units. The design of the Cerebot MX7cK board allows the use of three of them. Each output compare unit works with a particular output pin (OC1-OC5). It can be programmed to control the pin in any of the following ways:       PWM output Generate continuous pulses Generate a single pulse Toggle the output pin Generate falling edge Generate rising edge The output compare units work in conjunction with a timer. Either Timer2 or Timer3 can be used with any of the five output compare units. Refer to the PIC32 Family Reference Manual, Section 16, Output Compare for detailed information on the use of the output compares units. When using the chipKIT MPIDE software, these are accessed using the analogWrite() function. The digital pin number, or preferably, the symbols PIN_OC1 through PIN_OC5 are used to specify the pin. The chipKIT MPIDE software currently only supports using the output compare units to generate PWM outputs. It uses Timer2 to control the output compares. The following gives Pmod connector position, chipKIT pin number, and microcontroller I/O port and bit number for the output compare unit’s output pins:  OC1 – JD-02, digital pin 25, RD00  OC2 – JD-07, digital pin 28, RD01  OC3 – JD-08, digital pin 29, RD02 www.digilentinc.com An input capture unit works in conjunction with a timer and monitors the state of an associated pin. When the pin changes state, the current value of the timer is captured. The input capture units can be used with either Timer2 or Timer3. The input capture unit can be programmed to be sensitive to either a rising edge, a falling edge, or both edges on the input pin. An interrupt can also be signaled when an input capture is triggered. Each input capture has a four level deep FIFO that can buffer up to four capture events. For detailed information on the operation and use of the input capture units, refer to the PIC32 Family Reference Manual, Section 15, Input Capture. The following gives the Pmod connector position, chipKIT pin number, and microcontroller port and bit number for the input capture units input pins:      IC1 – not available IC2 – JD-01, digital pin 24, RD09 IC3 – JD-04, digital pin 27, RD10 IC4 – not available IC5 – JD-10, digital pin 31, RD12 When using the chipKIT MPIDE software, the symbols PIN_IC2, PIN_IC3, and PIN_IC5 can be used to access the capture input pins. Use of the input capture units is not currently supported in the chipKIT MPIDE software. This will be added in a future version. page 20 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual External Interrupts Citizen CFS206-32.768KDZF-UB is a crystal part that can be used in this location. The PIC32 microcontroller provides five external interrupt inputs. An external interrupt input can be used to generate an interrupt to the microprocessor CPU when the pin changes state. They can be programmed to interrupt on a rising edge or a falling edge on the pin. Refer to the PIC32 Family Reference Manual, Section 8, Interrupts for more information on the operation of the external interrupts. These are accessed using the attachInterrupt() and detachInterrupt() functions when using the chipKIT MPIDE software. The interrupt number is specified using the numbers 0-4, or preferably, the symbols EXT_INT0 through EXT_INT4. The symbols PIN_INT0 through PIN_INT4 are also defined to refer to the digital pin numbers used for the external interrupt inputs. The following gives connector position, chipKIT pin number, and microcontroller I/O port and bit number. Note that INT0-INT1 are on Pmod connectors. INT3 and INT4 are on I2C1 daisy chain connector J7. When using these pins as external interrupt inputs, they are not available to use for I2C. It may also be necessary to disable the pull-ups by pulling the shorting blocks from JP3 or JP4.      INT0 – JD-02, digital pin 25, RD00 INT1 – JE-07, digital pin 36, RE08 INT2 – JF-07, digital pin 44, RE09 INT3 – J7-1 & J7-2, digital pin 57, RA14 INT4 – J7-3 & J7-4, digital pin 58, RA15 RTCC The PIC32 microcontroller contains a low frequency oscillator and Real Time Clock/Calendar circuit, RTCC, that can be used to maintain time and date information. The operation of the RTCC requires a 32.768Khz frequency source. The crystal X2 position, just above and on the right of the PIC32 microcontroller, IC1, is provided for the user to solder in a 32Khz watch crystal. The www.digilentinc.com page 21 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual Appendix A: Connector Descriptions and Jumper Settings Label JA-JF Function Pmod Connectors These connectors provide access to the I/O pins on the PIC32MX795 microcontroller. Digilent Pmod peripheral modules can be attached to these connectors. These connectors can be used for general access to I/O pins on the PIC32MX795 microcontroller. JPA – JPF Pmod header power select Any of the Pmod connectors can provide either regulated or unregulated power. To use regulated power, place the jumper block over the center pin and the pin marked 3V3. To use unregulated power, place the jumper block over the center pin and the pin marked 5V0. J1 USB Serial converter auxiliary signals This connector can be used to access the auxiliary RS232 handshaking signals not used on the Cerebot MX4cK board. J2 USB Serial converter (UART) connector This USB micro-AB connector is used to connect the FT232R serial converter to a USB port on the user PC. J3 Power supply source select This jumper is used to select the source of main board power. Place the shorting block in the, “USB” position to have the board powered from the USB device connector, J19. Place the shorting block in the, “EXT” position to have the board powered from one of the external power connectors, J17 or J18. Place the shorting block in the, “DBG” position to have the board powered from the debug USB connector, J15. Place the shorting block in the “UART” position to have the board powered from the USB serial converter connector, J2 J7 I2C1 daisy chain connector This connector provides access to the I2C signals, power and ground for I2C1. J8 I2C2 daisy chain connector This connector provides access to the I2C signals, power and ground for I2C2. J9 CAN #1 Connector This connector is used to access the signals for CAN #1. J10 CAN #2 Connector This connector is used to access the signals for CAN #2. J11 Ethernet Connector www.digilentinc.com page 22 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual This connector provides access to the 10/100 Ethernet port. J12J14 J15 Do Not Use. J17 External Power Connector This is a 2.5mm x 5.5mm, center positive, coax power connector used to provide external power to the board. The optional Digilent 5V Switching Power Supply is connected here. J18 External Power Connector This is a screw terminal connector used to provide external power to the board. Be sure to observe proper polarity (marked near the connector) when providing power via this connector, or damage to the board and/or connected devices may result. J19 USB Device / OTG Connector This is a USB micro-AB connector. It is used when using the PIC32MX795 microcontroller to implement a USB device or OTG Host/Device. J20 USB Host Connector This is a standard sized USB type A connector. This connector is used to connect USB devices to the board when using the PIC32MX795 microcontroller to implement an embedded USB host. JP1 & JP2 CAN or Pmod Select These jumpers select microcontroller signals RF12 and RF13 for use with CAN #1 or Pmod connector JF. Place these jumpers in the CAN position to use CAN #1. Place the jumpers in the PMOD position to use then with Pmod connector JF. JP3 & JP4 Pull-up enable for I2C1 These two jumpers are used to enable/disable the pull-up resistors on I2C1. Insert shorting blocks on these two jumpers to enable the pull-up resistors. Remove the shorting blocks to disable the pull-up resistors. Only a single device on the I2C bus should have the pull-up resistors enabled. JP5 CAN #1 Termination This jumper is used to enable/disable the 120 ohm termination resistor for CAN #1. Insert the shorting block to enable the termination resistor, remove it to disable the termination resistor. JP6 CAN #1 5V0 Enable This jumper is used to enable/disable providing 5V to the CAN #1 connector. Insert the shorting block to connect the board 5V0 supply to pins 9 & 10 of CAN #1 connector. Remove the shorting block to disconnect the 5V0 supply. JP7 CAN #2 Termination This jumper is used to enable/disable the 120 ohm termination resistor for CAN #2. Insert the shorting block to enable the termination resistor, remove it to disable the termination resistor. Debug USB Connector This connector is used to connect the on-board programming and debug circuit to the PC for use with the MPLAB IDE. www.digilentinc.com page 23 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual JP8 CAN #1 5V0 Enable This jumper is used to enable/disable providing 5V to the CAN #1 connector. Insert the shorting block to connect the board 5V0 supply to pins 9 & 10 of CAN #1 connector. Remove the shorting block to disconnect the 5V0 supply. JP9 Do Not Use JP10 USB host power select This jumper is used to select which host connector is powered when host power is enabled. Place the shorting block in the “MICRO” position to supply power to the USB micro-AB OTG Connector, J19. Place the shorting block in the “A” position to supply power to the USB type A Host Connector, J20. JP11 USB Serial converter reset disconnect This is used to connect/disconnect the USB serial converter reset circuit from the PIC32 MCLR pin. The shorting block must be in place on this jumper when using the chipKIT MPIDE development tools. Remove the shorting block if the USB serial converter is interfering with proper operation of the licensed debugger circuit. JP17 Do Not Use www.digilentinc.com page 24 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual Appendix B: Example of Configuration Values The following example illustrates setting the configuration values in the PIC32 microcontroller on the Cerebot MX7cK. The microcontroller configuration should be done in a single source file in the project, and is typically done in the ‘main’ project source file. This example sets all configuration values to valid values for the Cerebot MX7cK board. It sets the system clock for processor operation at 80Mhz, and the peripheral bus at 10Mhz. /* ------------------------------------------------------------ */ /* PIC32 Configuration Settings */ /* ------------------------------------------------------------ */ /* Oscillator Settings */ #pragma config FNOSC #pragma config POSCMOD #pragma config FPLLIDIV #pragma config FPLLMUL #pragma config FPLLODIV #pragma config FPBDIV #pragma config FSOSCEN = = = = = = = PRIPLL EC DIV_2 MUL_20 DIV_1 DIV_8 OFF // // // // // // // Oscillator selection Primary oscillator mode PLL input divider PLL multiplier PLL output divider Peripheral bus clock divider Secondary oscillator enable /* Clock control settings */ #pragma config IESO = OFF #pragma config FCKSM = CSDCMD #pragma config OSCIOFNC = OFF // Internal/external clock switchover // Clock switching (CSx)/Clock monitor (CMx) // Clock output on OSCO pin enable /* USB Settings */ #pragma config UPLLEN = ON #pragma config UPLLIDIV = DIV_2 #pragma config FVBUSONIO = OFF #pragma config FUSBIDIO = OFF // // // // USB PLL enable USB PLL input divider VBUS pin control USBID pin control /* Other Peripheral Device settings */ #pragma config FWDTEN = OFF // Watchdog timer enable #pragma config WDTPS = PS1024 // Watchdog timer post-scaler #pragma config FSRSSEL = PRIORITY_7 // SRS interrupt priority #pragma config FCANIO = OFF // Standard/alternate CAN pin select #pragma config FETHIO = ON // Standard/alternate ETH pin select #pragma config FMIIEN = OFF // MII/RMII select (OFF=RMII) /* Code */ #pragma #pragma #pragma Protection settings config CP config BWP config PWP /* Debug settings */ #pragma config ICESEL www.digilentinc.com = OFF = OFF = OFF // Code protection // Boot flash write protect // Program flash write protect = ICS_PGx1 // ICE pin selection page 25 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual Appendix C: Connector and Jumper Block Pinout Tables Arranged by Microcontroller Pin Number PIC32 Pin # Connector Pin chipKIT Pin # MCU Port Bit PIC32 Signal Name Notes 1 3 4 5 6 7 8 9 LD4 JB-08 JB-09 JB-10 JC-01 N/A N/A JD-03 54 13 14 15 16 N/A N/A 26 RG15 RE05 RE06 RE07 RC01 RC02 RC03 RC04 AERXERR/RG15 PMD5/RE5 PMD6/RE6 PMD7/RE7 T2CK/RC1 T3CK/AC2TX/RC2 T4CK/AC2RX/RC3 T5CK/SDI1/RC4 LED4 10 11 12 14 17 18 19 20 21 22 BTN1 BTN2 N/A N/A BTN3 JE-07 JF-07 N/A JA-03 JA-02 48 49 N/A N/A 50 36 44 59 2 1 RG06 RG07 RG08 RG09 RA00 RE08 RE09 RB05 RB04 RB03 .../SCK2A/U2BTX/U2ARTS/PMA5/CN8/RG6 .../SDA2A/SDI2A/U2ARX/PMA4/CN9/RG7 .../SCL2A/SDO2A/U2ATX/PMA3/CN10/RG8 .../SS2A/U2BRX/U2ACTS/PMA2/CN11/RG9 TMS/RA0 AERXD0/INT1/RE8 AERXD1/INT2/RE9 AN5/C1IN+/VBUSON/CN7/RB5 AN4/C1IN-/CN6/RB4 AN3/C2IN+/CN5/RB3 BTN1 BTN2 Ethernet PHY Ethernet PHY BTN3 23 24 25 26 27 28 29 32 33 34 JA-01 N/A N/A JA-04 JA-07 JE-09 JE-10 JA-08 JA-09 JA-10 0 N/A N/A 3 4 38 39 5 6 7 RB02 RB01 RB00 RB06 RB07 RA09 RA10 RB08 RB09 RB10 AN2/C2IN-/CN4/RB2 PGEC1/AN1/CN3/RB1 PGED1/AN0/CN2/RB0 PGEC2/AN6/OCFA/RB6 PGED2/AN7/RB7 Vref-/CVref-/AERXD2/PMA7/RA9 Vref+/CVref+/AERXD3/PMA6/RA10 AN8/C1OUT/RB8 AN9/C2OUT/RB9 CVrefout/PMA13/AN10/RB10 35 38 39 40 41 42 43 44 47 48 N/A JF-08 JF-04 JF-01 N/A N/A JC-10 JC-07 JE-01 JE-04 N/A 45 43 40 N/A N/A 23 20 32 35 RB11 RA01 RF13 RF12 RB12 RB13 RB14 RB15 RD14 RD15 AN11/ERXERR/AETXERR/PMA12/RB11 TCK/RA1 AC1TX/SCK3A/U3BTX/U3ARTS/RF13 AC1RX/SS3A/U3BRX/U3ACTS/RF12 AN12/ERXD0/AECRS/PMA11/RB12 AN13/ERXD1/AECOL/PMA10/RB13 AN14/ERXD2/AETXD3/PMALH/PMA1/RB14 AN15/.../OCFB/PMALL/PMA0/CN12/RB15 AETXD0/SS1A/U1BRX/U1ACTS/CN20/RD14 AETXD1/SCK1A/U1BTX/U1ARTS/CN21/RD15 www.digilentinc.com CAN2 CAN2 USB VBUSON debug PGD debug PGC Ethernet PHY also CAN1 (JP-2) also CAN1 (JP-1) Ethernet PHY Ethernet PHY page 26 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual 49 50 51 JF-03 JF-02 N/A 42 41 N/A RF04 RF05 RF03 SDA3A/SDI3A/U3ARX/PMA9/CN17/RF4 SCL3A/SDO3A/U3ATX/PMA8/CN18/RF5 USBID/RF3 52 53 56 57 58 59 60 61 63 64 JE-03 JE-02 N/A N/A J7-1,J7-2 J7-3,J7-4 JF-09 JF-10 N/A N/A 34 33 N/A N/A 55 56 46 47 N/A N/A RF02 RF08 RG03 RG02 RA02 RA03 RA04 RA05 RC12 RC15 SDA1A/SDI1A/U1ARX/RF2 SCL1A/SDO1A/U1ATX/RF8 D-/RG3 D+/RG2 SCL2/RA2 SDA2/RA3 TDI/RA4 TDO/RA5 OSC1/CLKI/RC12 OSC2/CLKO/RC15 66 67 68 69 70 71 72 73 74 76 J8-1,J8-2 J8-3.J8-4 N/A JD-01 JD-04 N/A JD-02 N/A N/A JD-07 57 58 N/A 24 27 N/A 25 N/A N/A 28 RA14 RA15 RD08 RD09 RD10 RD11 RD00 RC13 RC14 RD01 AETXCLK/SCL1/INT3/RA14 AETXEN/SDA1/INT4/RA15 RTCC/EMDIO/AEMDIO/IC1/RD8 SS1/IC2/RD9 SCK1/IC3/PMCS2/PMA15/RD10 EMDC/AEMDC/IC4/PMCS1/PMA14/RD11 SDO1/OC1/INT0/RD0 SOSCI/CN1/RC13 SOSCO/T1CK/CN0/RC14 OC2/RD1 77 78 79 JD-08 JD-09 JD-10 29 30 31 RD02 RD03 RD12 OC3/RD2 OC4/RD3 ETXD2/IC5/PMD12/RD12 80 81 N/A JC-09 60 22 RD13 RD04 ETXD3/PMD13/CN19/RD13 OC5/PMWR/CN13/RD4 82 83 84 87 88 89 90 91 92 93 JC-08 N/A JC-04 N/A N/A JC-03 JC-02 N/A JE-08 JB-01 21 N/A 19 N/A N/A 18 17 N/A 37 8 RD05 RD06 RD07 RF00 RF01 RG01 RG00 RA06 RA07 RE00 PMRD/CN14/RD5 ETXEN/PMD14/CN15/RD6 ETXCLK/PMD15/CN16/RD7 C1RX/ETXD1/PMD11/RF0 C1TX/ETXD0/PMD10/RF1 C2TX/ETXERR/PMD9/RG1 C2RX/PMD8/RG0 TRCLK/RA6 TRD3/RA7 PMD0/RE0 94 95 96 97 JB-02 LD3 LD1 LD2 9 53 51 52 RE01 RG14 RG12 RG13 PMD1/RE1 TRD2/RG14 TRD1/RG12 TRD0/RG13 www.digilentinc.com USBID (USB-4) D- (USB-2) D+ (USB-3) I2C2 I2C2 Primary Oscillator Primary Oscillator I2C1 I2C1 Ethernet PHY Ethernet PHY Secondary Oscillator Secondary Oscillator USB Overcurrent detect Ethernet PHY Ethernet PHY Ethernet PHY Ethernet PHY Reset LED3 LED1 LED2 page 27 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual 98 99 100 JB-03 JB-04 JB-07 www.digilentinc.com 10 11 12 RE02 RE03 RE04 PMD2/RE2 PMD3/RE3 PMD4/RE4 page 28 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual Arranged by Connector Pin Number and Digital Pin Number PIC32 Pin # Connector Pin chipKIT Pin # MCU Port Bit Signal 23 22 21 26 JA-01 JA-02 JA-03 JA-04 0 1 2 3 RB02 RB03 RB04 RB06 AN2/C2IN-/CN4/RB2 AN3/C2IN+/CN5/RB3 AN4/C1IN-/CN6/RB4 PGEC2/AN6/OCFA/RB6 27 32 JA-07 JA-08 4 5 RB07 RB08 PGED2/AN7/RB7 AN8/C1OUT/RB8 33 34 JA-09 JA-10 6 7 RB09 RB10 AN9/C2OUT/RB9 CVrefout/PMA13/AN10/RB10 93 94 98 99 JB-01 JB-02 JB-03 JB-04 8 9 10 11 RE00 RE01 RE02 RE03 PMD0/RE0 PMD1/RE1 PMD2/RE2 PMD3/RE3 100 3 JB-07 JB-08 12 13 RE04 RE05 PMD4/RE4 PMD5/RE5 4 5 6 90 89 84 JB-09 JB-10 JC-01 JC-02 JC-03 JC-04 14 15 16 17 18 19 RE06 RE07 RC01 RG00 RG01 RD07 PMD6/RE6 PMD7/RE7 T2CK/RC1 C2RX/PMD8/RG0 C2TX/ETXERR/PMD9/RG1 ETXCLK/PMD15/CN16/RD7 44 82 JC-07 JC-08 20 21 RB15 RD05 AN15/.../OCFB/PMALL/PMA0/CN12/RB15 PMRD/CN14/RD5 81 43 JC-09 JC-10 22 23 RD04 RB14 OC5/PMWR/CN13/RD4 AN14/ERXD2/AETXD3/PMALH/PMA1/RB14 69 72 9 70 76 77 JD-01 JD-02 JD-03 JD-04 JD-07 JD-08 24 25 26 27 28 29 RD09 RD00 RC04 RD10 RD01 RD02 SS1/IC2/RD9 SDO1/OC1/INT0/RD0 T5CK/SDI1/RC4 SCK1/IC3/PMCS2/PMA15/RD10 OC2/RD1 OC3/RD2 78 79 47 53 52 48 18 92 28 JD-09 JD-10 JE-01 JE-02 JE-03 JE-04 JE-07 JE-08 JE-09 30 31 32 33 34 35 36 37 38 RD03 RD12 RD14 RF08 RF02 RD15 RE08 RA07 RA09 OC4/RD3 ETXD2/IC5/PMD12/RD12 AETXD0/SS1A/U1BRX/U1ACTS/CN20/RD14 SCL1A/SDO1A/U1ATX/RF8 SDA1A/SDI1A/U1ARX/RF2 AETXD1/SCK1A/U1BTX/U1ARTS/CN21/RD15 AERXD0/INT1/RE8 TRD3/RA7 Vref-/CVref-/AERXD2/PMA7/RA9 www.digilentinc.com Notes page 29 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual 29 40 50 JE-10 JF-01 JF-02 39 40 41 RA10 RF12 RF05 Vref+/CVref+/AERXD3/PMA6/RA10 AC1RX/SS3A/U3BRX/U3ACTS/RF12 SCL3A/SDO3A/U3ATX/PMA8/CN18/RF5 49 39 19 38 60 61 10 11 17 96 JF-03 JF-04 JF-07 JF-08 JF-09 JF-10 BTN1 BTN2 BTN3 LD1 42 43 44 45 46 47 48 49 50 51 RF04 RF13 RE09 RA01 RA04 RA05 RG06 RG07 RA00 RG12 SDA3A/SDI3A/U3ARX/PMA9/CN17/RF4 AC1TX/SCK3A/U3BTX/U3ARTS/RF13 AERXD1/INT2/RE9 TCK/RA1 TDI/RA4 TDO/RA5 .../SCK2A/U2BTX/U2ARTS/PMA5/CN8/RG6 .../SDA2A/SDI2A/U2ARX/PMA4/CN9/RG7 TMS/RA0 TRD1/RG12 97 95 1 58 59 66 67 20 LD2 LD3 LD4 J7-1,J7-2 J7-3,J7-4 J8-1,J8-2 J8-3.J8-4 N/A 52 53 54 55 56 57 58 59 RG13 RG14 RG15 RA02 RA03 RA14 RA15 RB05 TRD0/RG13 TRD2/RG14 AERXERR/RG15 SCL2/RA2 SDA2/RA3 AETXCLK/SCL1/INT3/RA14 AETXEN/SDA1/INT4/RA15 AN5/C1IN+/VBUSON/CN7/RB5 80 N/A 60 RD13 ETXD3/PMD13/CN19/RD13 LED2 LED3 LED4 I2C2 I2C2 I2C1 I2C1 USB VBUSON USB Overcurrent detect 91 25 24 35 41 42 N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A RA06 RB00 RB01 RB11 RB12 RB13 TRCLK/RA6 PGED1/AN0/CN2/RB0 PGEC1/AN1/CN3/RB1 AN11/ERXERR/AETXERR/PMA12/RB11 AN12/ERXD0/AECRS/PMA11/RB12 AN13/ERXD1/AECOL/PMA10/RB13 Ethernet PHY Reset debug PGC debug PGD Ethernet PHY Ethernet PHY Ethernet PHY 7 8 63 73 74 64 83 68 71 87 N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A RC02 RC03 RC12 RC13 RC14 RC15 RD06 RD08 RD11 RF00 T3CK/AC2TX/RC2 T4CK/AC2RX/RC3 OSC1/CLKI/RC12 SOSCI/CN1/RC13 SOSCO/T1CK/CN0/RC14 OSC2/CLKO/RC15 ETXEN/PMD14/CN15/RD6 RTCC/EMDIO/AEMDIO/IC1/RD8 EMDC/AEMDC/IC4/PMCS1/PMA14/RD11 C1RX/ETXD1/PMD11/RF0 CAN2 CAN2 Primary Oscillator Secondary Oscillator Secondary Oscillator Primary Oscillator Ethernet PHY Ethernet PHY Ethernet PHY Ethernet PHY 88 51 57 56 N/A N/A N/A N/A N/A N/A N/A N/A RF01 RF03 RG02 RG03 C1TX/ETXD0/PMD10/RF1 USBID/RF3 D+/RG2 D-/RG3 Ethernet PHY USBID (USB-4) D+ (USB-3) D- (USB-2) www.digilentinc.com also CAN1 (JP-1) also CAN1 (JP-2) BTN1 BTN2 BTN3 LED1 page 30 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual 12 14 N/A N/A www.digilentinc.com N/A N/A RG08 RG09 .../SCL2A/SDO2A/U2ATX/PMA3/CN10/RG8 .../SS2A/U2BRX/U2ACTS/PMA2/CN11/RG9 Ethernet PHY Ethernet PHY page 31 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual Arranged by Microcontroller I/O Port Name and Bit Number PIC32 Pin # Connector Pin chipKIT Pin # MCU Port Bit PIC32 Signal Name Notes 17 BTN3 50 RA00 TMS/RA0 BTN3 38 58 JF-08 J7-1,J7-2 45 55 RA01 RA02 TCK/RA1 SCL2/RA2 I2C2 59 60 61 91 92 28 J7-3,J7-4 JF-09 JF-10 N/A JE-08 JE-09 56 46 47 N/A 37 38 RA03 RA04 RA05 RA06 RA07 RA09 SDA2/RA3 TDI/RA4 TDO/RA5 TRCLK/RA6 TRD3/RA7 Vref-/CVref-/AERXD2/PMA7/RA9 29 66 67 25 24 23 JE-10 J8-1,J8-2 J8-3.J8-4 N/A N/A JA-01 39 57 58 N/A N/A 0 RA10 RA14 RA15 RB00 RB01 RB02 Vref+/CVref+/AERXD3/PMA6/RA10 AETXCLK/SCL1/INT3/RA14 AETXEN/SDA1/INT4/RA15 PGED1/AN0/CN2/RB0 PGEC1/AN1/CN3/RB1 AN2/C2IN-/CN4/RB2 22 21 JA-02 JA-03 1 2 RB03 RB04 AN3/C2IN+/CN5/RB3 AN4/C1IN-/CN6/RB4 20 26 N/A JA-04 59 3 RB05 RB06 AN5/C1IN+/VBUSON/CN7/RB5 PGEC2/AN6/OCFA/RB6 27 32 33 34 35 41 JA-07 JA-08 JA-09 JA-10 N/A N/A 4 5 6 7 N/A N/A RB07 RB08 RB09 RB10 RB11 RB12 PGED2/AN7/RB7 AN8/C1OUT/RB8 AN9/C2OUT/RB9 CVrefout/PMA13/AN10/RB10 AN11/ERXERR/AETXERR/PMA12/RB11 AN12/ERXD0/AECRS/PMA11/RB12 42 43 44 6 7 8 9 63 73 74 N/A JC-10 JC-07 JC-01 N/A N/A JD-03 N/A N/A N/A N/A 23 20 16 N/A N/A 26 N/A N/A N/A RB13 RB14 RB15 RC01 RC02 RC03 RC04 RC12 RC13 RC14 AN13/ERXD1/AECOL/PMA10/RB13 AN14/ERXD2/AETXD3/PMALH/PMA1/RB14 AN15/.../OCFB/PMALL/PMA0/CN12/RB15 T2CK/RC1 T3CK/AC2TX/RC2 T4CK/AC2RX/RC3 T5CK/SDI1/RC4 OSC1/CLKI/RC12 SOSCI/CN1/RC13 SOSCO/T1CK/CN0/RC14 Ethernet PHY 64 72 76 77 N/A JD-02 JD-07 JD-08 N/A 25 28 29 RC15 RD00 RD01 RD02 OSC2/CLKO/RC15 SDO1/OC1/INT0/RD0 OC2/RD1 OC3/RD2 Primary Oscillator www.digilentinc.com I2C2 Ethernet PHY Reset I2C1 I2C1 debug PGC debug PGD USB VBUSON Ethernet PHY Ethernet PHY CAN2 CAN2 Primary Oscillator Secondary Oscillator Secondary Oscillator page 32 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual 78 81 82 JD-09 JC-09 JC-08 30 22 21 RD03 RD04 RD05 OC4/RD3 OC5/PMWR/CN13/RD4 PMRD/CN14/RD5 83 84 68 69 70 71 79 N/A JC-04 N/A JD-01 JD-04 N/A JD-10 N/A 19 N/A 24 27 N/A 31 RD06 RD07 RD08 RD09 RD10 RD11 RD12 ETXEN/PMD14/CN15/RD6 ETXCLK/PMD15/CN16/RD7 RTCC/EMDIO/AEMDIO/IC1/RD8 SS1/IC2/RD9 SCK1/IC3/PMCS2/PMA15/RD10 EMDC/AEMDC/IC4/PMCS1/PMA14/RD11 ETXD2/IC5/PMD12/RD12 80 47 N/A JE-01 60 32 RD13 RD14 ETXD3/PMD13/CN19/RD13 AETXD0/SS1A/U1BRX/U1ACTS/CN20/RD14 48 93 94 98 99 100 3 4 5 18 JE-04 JB-01 JB-02 JB-03 JB-04 JB-07 JB-08 JB-09 JB-10 JE-07 35 8 9 10 11 12 13 14 15 36 RD15 RE00 RE01 RE02 RE03 RE04 RE05 RE06 RE07 RE08 AETXD1/SCK1A/U1BTX/U1ARTS/CN21/RD15 PMD0/RE0 PMD1/RE1 PMD2/RE2 PMD3/RE3 PMD4/RE4 PMD5/RE5 PMD6/RE6 PMD7/RE7 AERXD0/INT1/RE8 19 87 88 52 51 49 JF-07 N/A N/A JE-03 N/A JF-03 44 N/A N/A 34 N/A 42 RE09 RF00 RF01 RF02 RF03 RF04 AERXD1/INT2/RE9 C1RX/ETXD1/PMD11/RF0 C1TX/ETXD0/PMD10/RF1 SDA1A/SDI1A/U1ARX/RF2 USBID/RF3 SDA3A/SDI3A/U3ARX/PMA9/CN17/RF4 50 53 40 39 90 89 57 56 10 11 JF-02 JE-02 JF-01 JF-04 JC-02 JC-03 N/A N/A BTN1 BTN2 41 33 40 43 17 18 N/A N/A 48 49 RF05 RF08 RF12 RF13 RG00 RG01 RG02 RG03 RG06 RG07 SCL3A/SDO3A/U3ATX/PMA8/CN18/RF5 SCL1A/SDO1A/U1ATX/RF8 AC1RX/SS3A/U3BRX/U3ACTS/RF12 AC1TX/SCK3A/U3BTX/U3ARTS/RF13 C2RX/PMD8/RG0 C2TX/ETXERR/PMD9/RG1 D+/RG2 D-/RG3 .../SCK2A/U2BTX/U2ARTS/PMA5/CN8/RG6 .../SDA2A/SDI2A/U2ARX/PMA4/CN9/RG7 12 14 96 97 N/A N/A LD1 LD2 N/A N/A 51 52 RG08 RG09 RG12 RG13 .../SCL2A/SDO2A/U2ATX/PMA3/CN10/RG8 .../SS2A/U2BRX/U2ACTS/PMA2/CN11/RG9 TRD1/RG12 TRD0/RG13 www.digilentinc.com Ethernet PHY Ethernet PHY Ethernet PHY USB Overcurrent detect Ethernet PHY Ethernet PHY USBID (USB-4) also CAN1 (JP-1) also CAN1 (JP-2) D+ (USB-3) D- (USB-2) BTN1 BTN2 Ethernet PHY Ethernet PHY LED1 LED2 page 33 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual 95 1 LD3 LD4 www.digilentinc.com 53 54 RG14 RG15 TRD2/RG14 AERXERR/RG15 LED3 LED4 page 34 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual Declaration of Conformity In accordance with EN ISO/IEC 17050-1:2010 Manufacturers Name: Manufacturers Address: Application of Council Directives: EMC Standards: EMC Digilent, Inc. 1300 NE Henley Court Pullman, WA 99163 U.S.A. 2004/108/EC EN55022:2010 EN55024:2010 Product Name: Cerebot MX7cK Product Model Number: Digilent Product Category: Digilent P/N 210-223 Large Form Factor Microcontroller Boards We, the undersigned, hereby declare that the equipment specified above conforms to the above Directives and Standards. Location: Date: _Pullman, WA______ _August 23, 2012 ___ www.digilentinc.com Signature: __________ Full Name (print): Clint Cole page 35 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Cerebot MX7cK Reference Manual Title: www.digilentinc.com President___________ page 36 of 36 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners.
410-296 价格&库存
很抱歉,暂时无法提供与“410-296”相匹配的价格&库存,您可以联系我们找货
