A000088
A000088
    ARDUINO
    ARDUINO MINI 05 LIGHT
A000088 数据手册
Arduino Mini 05 Light [A000088] : MAGYC-NOW Page 1 of 1 Product 14/19 Arduino Mini 05 Light Price Unavailable larger image The Arduino Mini is a small microcontroller board intended for use on breadboards and when space is at a premiumand. The revision 05 has a new package for the ATmega328 (datasheet), which enables all components to be on the top of the board. It also has an onboard reset button. The 05 version has the same pin configuration as revision 04. Additional features coming with the 05 version are: • new PCB layout and design • onboard reset button The Arduino Mini has 14 digital input/output pins (of which 6 can be used as PWM outputs), 8 analog inputs, and a 16 MHz crystal oscillator. It can be programmed with the USB Serial adapter or other USB or RS232 to TTL serial adapter. See the page on getting started with the Arduino Mini for instructions. The light version is sold without the pre-soldered. Technical Specifications • • • • • • • • • • Microcontroller ATmega328 Operating Voltage 5V Input Voltage 7-9 V Digital I/O Pins 14 (of which 6 provide PWM output) Analog Input Pins 8 (of which 4 are broken out onto pins) DC Current per I/O Pin 40 mA Flash Memory 32 KB (of which 2 KB used by bootloader) SRAM 2 KB EEPROM 1 KB Clock Speed 16 MHz If you want to give a closer look to this board we advice you to visit the official Arduino Mini 05 page in the Hardware Section. • Model: A000088 • Shipping Weight: 0.01Kg http://www.magyc-now.com/catalog/index.php?main_page=product_info&cPath=13_15&products_id=181 7/3/2012
A000088 价格&库存
很抱歉,暂时无法提供与“A000088”相匹配的价格&库存,您可以联系我们找货
A000088
  • 1+116.385671+15.08580
