102990162
102990162
    SEEED(矽递科技)
    INTELEDISONFORARDUINO
102990162 数据手册
Intel® Edison for Arduino SKU: 102990162 (images/product/102990162 15_02.jpg) (https://www.kickstarter.com/projects/seeed/wiolink-3-steps-5-minutes-build-your-iotapplicat/description?ref=banner_depot) Description Brief Introduction: This kit includes an Arduino Breakout, which essentially gives your Edison the ability to interface with Arduino shields or any board with the Arduino footprint. Dimensions:127mm x 72mm x 12mm The Intel Edison module is included.  Main Features: • Uses a 22nm Intel® SoC that includes a dual core, dual threaded Intel® Atom™ CPU at 500MHz and a 32bit Intel® Quark™ microcontroller at 100 MHz. It supports 40 GPIOs and includes 1GB LPDDR3, 4 GB EMMC, and dual-band WiFi and BTLE on a module slightly larger than a postage stamp. • The Intel Edison module will initially support development with Arduino* and C/C++, followed by Node.JS, Python, RTOS, and Visual Programming support in the near future. • It includes a device-to-device and device-to-cloud connectivity framework to enable cross-device communication and a cloud-based, multi-tenant, time-series analytics service. • Has an SD card connector, micro USB or standard sized USB host Type-A connector(via mechanical switch), Micro USB device, 6 analog inputs, and 20 ditial input/output pins, 1x UART, 1x I2C, and 1x ICSP 6-pin header (SPI) Power jack with 7V-15V DC input. Specification: Physica  Form factor Dimensions Board with 70-pin connector 127.0 x 72.0 x 12.0 mm Operating temperature 0 to 40 degC Connector Hirose DF40 Series (1.5mm, 2.0mm, or  3.0mm stack height) Memory   Max Memory size Memory type 4GB DDR3, Nand Flash Physical add. Ext. # of  DIMMs ECC Memory supported:  32-bit 0 NO External Interfaces Total of 40 GPIOs which can be configured as: SD Card 1 Interface UART 2 Controllers I2C 2 Controllers SPI 1 Controller with 2 chip selects I2S 1 Controller GPIO Additional 12 (with 4 capable of PWM) USB 2.0 1 OTG Controller Clock Output 32 KHz, 19.2 MHz Major Edison Components   SoC RAM Flash Storage WiFi Bluetooth 22nm Intel SoC includes: a dual core, dual threaded Intel Atom CPU at 500MHz, and a 32-bit Intel Quark microcontroller at 100 MHz 1 GB LPDDR3 POP memory 4 GB eMMC Broadcom 43340 802.11 a/b/g/n Dual-band (2.4 and 5 GHz) On board antenna or external antenna SKU configurations BT 4.0 Power Input 3.3V – 4.5V Output 100ma @3.3V and 100ma @ 1.8V Standby (No radios): 13mW Standby (BT 4.0): 21.5mW Standby (WiFi): 35 mW Power Firmware + Software CPU OS Yocto Linux v1.6 Arduino IDE Development Environments Eclipse supporting: C, C++ & Python Intel XDK supporting: Node.JS & HTML5 MCU OS Development Environments RTOS MCU SDK and IDE http://www.seeedstudio.com/depot/Intel-Edison-for-Arduino-p-2149.html?cPath=6_7 12/3/2015
102990162 价格&库存
很抱歉,暂时无法提供与“102990162”相匹配的价格&库存,您可以联系我们找货
  • 1+989.171051+127.92672
