UHex Low‐power Controller SKU: DFR0343
μHex
Contents
1 Introduction
2 Specification
3 Pin Definition
4 Programming
5 Sample Code
5.1 Low power Consumption Application
5.1.1 -Wake up by Interrupt
5.1.2 -Wake up by Timer
5.1.3 -Integrated Application
5.2 General Application
Introduction
μHex is the first low-power controller which is compatible with Arduino. It is very suitable for the
battery power supply environment. A 210mAh CR2032 cell battery can support it standing by 60
days with using PIR sensor (SEN0171) as a trigger.
As it is using Atmega 328 Microcontroller, it has good general and powerful performance. It has 14
GPIO and 7 power ports (4 of them could be controlled) which could meet most of your project.
NOTE
1. Please don't update the bootloader since it is different from the Arduino Pro
or Pro Mini one.
2. Please connect an external power supply, if you want to make some large curre
nt application such as servo control.
Specification
Microcontroller: ATmega328P (board type: Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328
Operating Voltage: 2.7 - 5V
Clock Frequency: 8MHz (RC)
Sleep Current: 0.12uA@3V3, 0.16uA@5V (watchdog OFF)
Flash: 32 KB ( 0.5KB used by bootloader)
SRAM: 2 KB
EEPROM: 1 KB
Digital I/O Pins: 14 (PWM: 3,5,9,10,11)
Analog I/O Pins: 6
UART Interface: 1
I2C Interface: 1
Interrupt interface: 2
Power in Port: 1
Power out Port: 6 (4 of them are controllable power port)
Maximum Current from Controllable Power out: 2A
Dimension: 28 x 31 x 2.3 (mm)
Weight: 10g
Pin Definition
uHex
Silkscreen
Digital
Interface
RX
PWM
Interface
Analog
Interface
Proprietary Function
Serial
TX
1
2
2
3
3
3
INT1
5
5
5
9
9
9
10
10
10
11
11
11
A0
A0
A0
A1
A1
A1
A2
A2
A2
A3
A3
A3
SDA
SDA
A4
INT0
I2C
SCL
SCL
A5
DTR
DTR
VCC
GND
Controllable power
port
Programming
The board type of uHex is same to Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328, you could
select it in the board menu, and program it with FTDI programmer. (Note: The bootloader of uHex
is different from Arduino Pro or Pro Mini one. Please don't update bootloader by this one.)
uHex_FTDI_connection_diagram
Sample Code
Please download the Arduino library microPoly Library first.
https://github.com/LeoYan/ArduinoLib/tree/master/microPoly
Code: pinTrigger.ino
Function: The uHex is in sleep state until pin2=LOW and pin3=HIGH. Once waked, the LED on the
board will flash for some seconds and then go to sleep again.
-Wake up by Timer
Code: timerTrigger.ino
Function:The uHex is waked by period timer (using watchdog timer). Once waked, the LED on the
Code: measure.ino
Function:
1. The uHex is in sleep state until Timer is overtime or Button is pressed
2. The uHex sample data every 1 minute. If button is pressed the average data will be display on the
LCD screen. After some seconds, it will go to sleep again.
General Application
In the scope of uHex ports, the program from Arduino UNO/Pro Mini can be run on the uHex.
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“DFR0343”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+87.371671+11.30386
