Beetle SKU:DFR0282
From Robot Wiki
Beetle
Contents
1 Introduction
2 Specification
3 PinOut
4 Tutorial
o 4.1 Power
o 4.2 Programming
o 4.3 Example Code
5 Trouble shooting
Introduction
The “Beetle” is a minimalized version of Arduino Leonardo, and has same powerful
functionalities as Leonardo. It is ideal for DIY projects, wearable projects and etc. Its key
features are:
20mm X 22mm compact size
Direct downloading and testing via Micro USB
V‐shaped large‐size gold‐plated IO ports make it convenient for the user to twist wires upon,
and can also be directly sewn on clothes with conductive thread.
Two honeycomb shape gold‐plated power interface
Magic light blue soft BLINK indicator
Beetle is fully compatible with Arduino,please select “Arduino Leonardo” when using.
Specification
Microcontroller: ATmega32u4
Clock Speed: 16 MHz
Operating Voltage: 5V DC
Digital I/O Pins: 10
PWM Channels: 4
Analog Input Channels:5
UART: 1
I2C: 1
|Micro USB: 1
Power interfaces: 2
Flash Memory: 32 KB of which 4KB used by bootloader
SRAM: 2.5 KB
EEPROM: 1 KB
Physical Dimension: 20mm*22mm*3.8mm
PinOut
Beetle front look
Beetle back look
IO Port Mapping in correspondence with Arduino Port:
Silkscreen
Digital Pin
PWM Channel
Analog Channel
RX
UART
I2C
Serial1
TX
1
SDA
2
SDA
SCL
3
3
SCL
9
9
9
A9
10
10
10
A10
11
11
11
A0
A0
A0
A1
A1
A1
A2
A2
A2
Power interface description:
Silkscreen
Description
VCC
GND
Tutorial
Power
Power supply via micro USB or power interface.
Programming
Beetle is fully compatible with Arduino Leonardo,see link for more details in connection:
http://arduino.cc/en/Guide/Windows#toc4, the only difference is to select "Arduino Leonardo "
("tools 〉 board 〉 Arduino Leonardo" in Arduino IDE).
Example Code
All codes for Arduino Leonardo can apply to Beetle.
Note:
#This product uses DC power supply with a working voltage of 5V. 6V will dama
ge the product by overvoltage. This product works reliably between
4.5V-5V; it may work under 3V-4.5V, but the reliability is not guaranteed.
#For large load applications (such as motor control), you need to connect the
loaded VCC and GND directly with power supply, and parallel with
capacitor over 10uF, in order to prevent restart or malfunction caused by lar
ge load transient.
#In Arduino environment, Beetle has the same features as Leonardo with multip
le serial ports, Serial used for USB virtual port; Serial1
used for RX/TX port.
Trouble shooting
Sometimes Leonardo Uart port will be locked by the sketch. It will lost its COM Port in Device
Manager.There is a method to wake it up.
Step1: There are 6 dots on the back of the module. This is ICSP interface. Please plug beetle to
your usb cable. And watch your device manager. Using a cable to touch Pin 5 and Pin 6, then
Beetle will reset. and Device manager should appear a COM port named "Arduino Leonardo
bootloader (COM x)". After a few seconds, it will disappear. If you see this information you
could go Step 2.
Step2: Open your arduino IDE, and open any sketch like "Blink", select the board to "Leonardo".
There is no COM port now. Just click "Upload". After IDE has completed verifying, touch the
Pin 5 and Pin 6 immediately. You need try several times, because the correct time is not easy to
be caught.
Use has been normal, after loading a new program, the computer can not find the virtual serial
Beetle?
After eliminating the cable connection problems, then this question is that t
he new program is loaded affect the USB communication.
Beetle / Leonardo USB is implemented by the appropriate software (Arduino IDE
implemented),it and the user program are on the ATMEGA32U4,
If the user program affects the USB-related operations will lead to see the U
SB virtual serial port. At this time we need to reload the
available user program(such as blink).If the Beetle / Leonardo has lost cont
act with computer,it can't automatically reset,it needs
to be loaded manually reset mode,Beetle resets through a short jumper
and GND of ICSP interface to achieve.
Beetle‐ICSP interface
More question and cool idea,visit DFRobot Forum
Powered By DFRobot © 2008-2017
RESET
很抱歉,暂时无法提供与“DFR0282”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+87.341051+11.29990
