EA-QSB-016
EA-QSB-016
    EMBEDDEDARTISTS
    BOARD QUICK START LPC4088
EA-QSB-016 数据手册
Art. EA-QSB-016 [High Resolution Photos] LPC4088 QUICKSTART BOARD   Embedded Artists' LPC4088 QuickStart Board is an easy to use ARM Cortex-M4 rapid prototyping board in a standard through hole DIP package (44-pin), targeted at high-performance as well as low-power applications. Communication interfaces, large on-board memories and LCD controller enables graphical user inteface applications. Introduction Video The LPC4088 QuickStart Board is not just a piece of hardware - it's much, much more: The module hardware, which is a professional quality hardware developed for integration and simplicity-of-use. The mbed Software Development Kit (SDK), which is an open source C/C++ microcontroller software platform designed for a suitable level of hardware abstraction to simplify microcontroller programming. The mbed Compiler is a powerful online IDE that is tightly integrated with the mbed SDK and Developer's Website (mbed.org, see below). The mbed Hardware Development Kit (HDK), which is an interface design that provides simple USB drag-n-drop programming and CMSIS-DAP debug interface for the LPC4088 microcontroller. The mbed.org community, with extensive documentation in the form of handbooks, cookbooks, project pages, User Forums for getting help and advice from other mbed users, etc. Take advantage of Embedded Artists' competence to minimize your work and risk! Volume Pricing from Quantity 1 The module is priced with integration in mind. Enjoy a price that is normally associated with much higher volumes from the first module you buy! Pinning Below is the pinning diagram (click for a larger picture), in typiclal mbed style. mbed The LPC4088 QuickStart Board is mbed Enabledmeaning that the board take full advantage of the mbed platform! The LPC4088 QuickStart Board is the most advanced mbed enabled board to date - it is the most integrated, has most memory, has graphical possibilties and highest speed! Some mbed information: mbed.org website - this is the official mbed community website. It contains a lot of documentation with many different topics and angles on the information. http://www.embeddedartists.com/products/boards/lpc4088_qsb.php[12/10/2013 9:41:18 AM] LPC4088 QuickStart Board | Embedded Artists AB Explore mbed - a four segment presentation of the mbed platform: Explore - Getting Started - Prototype Production mbed Developers website - an introduction to the mbed Developers website. Handbook - gives an overview of the platform with all features. Cookbook - a wiki for publishing user-controbuted libraries and resources. Documentation All documentation about the board has been put on the mbed.org site.   SPECIFICATION LPC4088 QuickStart Board Processor NXP's Cortex-M4 LPC4088 microcontroller in BGA package, running at up to 120 MHz Program Flash 8 MB QSPI + 512 KB on-chip Data Memory 32 MB SDRAM (x32 bit databus for high handwidth access) + 96 KB on-chip SRAM + 4 KB on-chip E2PROM Clock Crystals 12.000 MHz main and 32.768 kHz RTC crystals Interfaces / Connectors • • • • • • • • Dimensions 101 x 28 mm (104 x 28 mm with connectors) Power • 4.5 - 5.5V input on pin 2, or • via micro-B USB HDK connector, or • via trace connector (+5V) Other • • • • • • • 2x22 pin edge pins 10/100Mbps Ethernet (RJ45) USB-A (USB Host interface) USB-micro B (USB Device interface) USB-micro B (mbed HDG debug interface) 20 position SDW/Trace connector (ARM standard debug connector) 61 pos 0.3 mm pitch FPC connector for display expansion 20 pos XBee compatible connector for RF module add-on Proper ESD protection on communication interfaces CMSIS-DAP Interface On-board (debug interface functions) Supported by the mbed SDK and online tools Supported by professional tools and middleware Industrial temperature specified (-40 to +85 degrees Celsius) ISO 9001:2008 produced Production and shipping compensated for carbon dioxide emission http://www.embeddedartists.com/products/boards/lpc4088_qsb.php[12/10/2013 9:41:18 AM]
EA-QSB-016 价格&库存
很抱歉,暂时无法提供与“EA-QSB-016”相匹配的价格&库存,您可以联系我们找货
