DEV-11781
DEV-11781
    SPARKFUNELECTRONICS
    AT90USB1286 Teensy++ AVR® MCU 8-Bit AVR Embedded Evaluation Board
DEV-11781 数据手册
Teensy++ 2.0 DE V-11 781 RO HS       1  images are CC BY-NC-SA 3.0 Description: The Teensy is a breadboard-friendly development board with loads of features in a, well, teensy package. The Teensy++ breaks out all of the IO available on the AT90USB1286 to breadboard-friendly 0.1" spaced headers so you can hook up a load of peripherals. The Teensy++ comes pre-flashed with a bootloader so you can program it using the on-board USB connection: No external programmer needed! You can program the Teensy in your favorite IDE using C or you can install the Teensyduino add-on for the Arduino IDE and write Arduino sketches for Teensy! Note: This does not come with a USB cable, please check below for an appropriate one. Dimensions: 2" x 0.7" (50.8 x 17.8 mm) Features: • • • • • • • • • 8-Bit AVR Processor (AT90USB1286) 128K Flash Memory, 8K RAM, 4K EEPROM USB Can Emulate Any Type of Device Single Pushbutton Programming Arduino Compatible 8 Analog Inputs 46 Digital I/O Pins 9 PWM outputs SPI and I2C https://www.sparkfun.com/products/11781 10/22/2015
DEV-11781 价格&库存
很抱歉,暂时无法提供与“DEV-11781”相匹配的价格&库存,您可以联系我们找货
