DEV-14058
DEV-14058
    SPARKFUNELECTRONICS
    TEENSY3.6(HEADERS)
DEV-14058 数据手册
Teensy 3.6 (Headers) DEV‐14058 RoHS  Description: The Teensy is a breadboard-friendly development board with loads of features in a, well, teensy package. Each Teensy 3.6 comes with headers already attached and pre-flashed with a bootloader so you can program it using the onboard USB connection; no external programmer needed! You can program for the Teensy in your favorite program editor using C, or you can install the Teensyduino add-on for the Arduino IDE and write Arduino sketches for it! The processor on the Teensy also has access to the USB and can emulate any kind of USB device you need it to be, making it great for USB-MIDI and other HID projects. The 32-bit, 180MHz processor brings a few other features to the table as well, such as multiple channels of Direct Memory Access, several high-resolution ADCs and even an I 2S digital audio interface! There are also four separate interval timers, plus a delay timer! Oh yeah, and all digital pins have interrupt capability and are 3.3V tolerant. All of this functionality is jammed into a 62.3mm x 18mm board with all headers on a 0.1" grid so you can  slap it on a breadboard and get to work! The Teensy 3.6 (as well as its sibling, the Teensy 3.5) is larger,  faster and capable of more complex projects, especially with its onboard microSD card port. An upgraded  ARM Cortex MCU (180MHz from 72MHz), more memory (1M from 256K)—as well as more RAM,  EEPROM and accessible pins—make up the key new features of this board. The Teensy 3.6 is slightly  scaled up from the Teensy 3.5. Note: This does not come with a USB cable. Dimensions: 62.3mm x 18mm x 4.2mm (2.5in x 0.7in x 0.2in) Features: 180 MHz ARM Cortex-M4 with Floating Point Unit 1M Flash, 256K RAM, 4K EEPROM Microcontroller Chip MK66FX1M0VMD18 USB High Speed (480Mbit/sec) Port 2 CAN Bus Ports 32 General Purpose DMA Channels 22 PWM Outputs 4 I2C Ports 11 Touch-Sensing Inputs 62 I/O Pins (42 breadboard friendly) 25 Analog Inputs to 2 ADCs with 13-bit resolution 2 Analog Outputs (DACs) with 12-bit resolution USB Full-Speed (12Mbit/sec) Port Ethernet mac, capable of full 100Mbit/sec speed Native (4-bit SDIO) microSD card port I2S Audio Port, 4-Channel Digital Audio Input and Output 14 Hardware Timers Cryptographic Acceleration Unit Random Number Generator CRC Computation Unit 6 Serial Ports (2 with FIFO and Fast Baud Rates) 3 SPI Ports (1 with FIFO) Real-Time Clock (RTC) Pre-soldered Headers SparkFun Electronics ®
DEV-14058 价格&库存
很抱歉,暂时无法提供与“DEV-14058”相匹配的价格&库存,您可以联系我们找货
