Arduino Pro 328 - 5V/16MHz - DEV-10915 - SparkFun Electronics
images are CC BY-NC-SA 3.0
Description: It’s blue! It’s skinny! It’s the Arduino Pro! SparkFun’s minimal design
approach to Arduino. This is a 5V Arduino running the 16MHz bootloader in a supersleek form factor that will fit easily into your next small project.
Arduino Pro does not come with connectors populated so that you can solder in any
connector or wire with any orientation you need. We recommend first time Arduino
users start with the Uno R3. It’s a great board that will get you up and running quickly.
The Arduino Pro series is meant for users that understand the limitations of this lack
of connectors and USB off board.
To keep things affordable and low profile, we’ve chosen to make the DC power jack
footprint available, but not to populate it. We recommend running the board with a
LiPo battery for better portability. Also, to keep the cost low, we made changes like
using all SMD components and switching to a two layer PCB.
This board connects directly to the FTDI Basic Breakout board and supports autoreset. The Arduino Pro also works with the FTDI cable but the FTDI cable does not
bring out the DTR pin so the auto-reset feature will not work. In this latest version of
the Arduino Pro we’ve also moved the FTDI headers back just a skoach so that the
pins don’t hang over the edge of the board. We’ve also populated it with a sturdier
power selection switch.
Not sure which Arduino or Arduino-compatible board is right for you? Check out our
Page 1 of 2
Page 2 of 2
Arduino Buying Guide!
Note: A portion of this sale is given back to Arduino LLC to help fund continued
development of new tools and new IDE features.
Features:
ATmega328 running at 16MHz external resonator
USB connection off board
5V regulator
Max 150mA output
Over current protected
Reverse polarity protected
DC input 5V up to 12V
Resettable fuse prevents damage to board in case of short
Power select switch acts as on/off switch
Dimensions: 2.1x2.05" (53.34x52.08mm)
https://www.sparkfun.com/products/10915
2/12/2015
很抱歉,暂时无法提供与“DEV-10915”相匹配的价格&库存,您可以联系我们找货
