Product Brief
Intel® Edison
Intel® Edison
Development Platform
Introduction
The Intel® Edison development
platform is designed to lower the
barriers to entry for a range of
inventors, entrepreneurs, and
consumer product designers to
rapidly prototype and produce
“Internet of Things” (IoT) and
wearable computing products.
Intel® Edison Board for Arduino*
Supports Arduino Sketch, Linux,
Wi-Fi, and Bluetooth.
Board I/O: Compatible with
Arduino Uno (except 4 PWM
instead of 6 PWM):
• 20 digital input/output pins,
including 4 pins as PWM
outputs.
• 6 analog inputs.
• 1 UART (Rx/Tx).
• 1 I2C.
Intel® Edison Breakout Board
Slightly larger than the
Intel® Edison module, the
Intel® Edison Breakout Board has
a minimal set of features:
• 1 ICSP 6-pin header (SPI).
• Exposes native 1.8 V I/O of the
Edison module.
• Micro USB device connector OR
(via mechanical switch)
dedicated standard size USB
host Type-A connector.
• USB OTG with USB Micro
Type-AB connector.
• 0.1 inch grid I/O array of
through-hole solder points.
• Micro USB device (connected to
UART).
• USB OTG power switch.
• SD card connector.
• USB to device UART bridge with
USB micro Type-B connector.
• DC power jack (7 to15 VDC
input).
• Battery charger.
• DC power supply jack (7 to
15 VDC input).
Intel® IoT Analytics Platform
• Provides seamless Device-toDevice and Device-to-Cloud
communication.
• Ability to run rules on your data
stream that trigger alerts based
on advanced analytics.
• Foundational tools for
collecting, storing, and
processing data in the cloud.
• Free for limited and
noncommercial use.
Intel® Edison Development Platform
PHYSICAL
Form factor
Dimensions
C/M/F
Connector
Operating temperature
Board with 70-pin connector
35.5 × 25.0 × 3.9 mm (1.4 × 1.0 × 0.15 inches) max
Blue PCB with shields / No enclosure
Hirose DF40 Series (1.5, 2.0, or 3.0 mm stack height)
32 to 104°F (0 to 40°C)
EXTERNAL INTERFACES
Total of 40 GPIOs, which can be configured as:
1 interface
SD card
UART
2 controllers (1 full flow control, 1 Rx/Tx)
I2C
2 controllers
1 controller with 2 chip selects
SPI
I2S
1 controller
GPIO
Additional 12 (with 4 capable of PWM)
1 OTG controller
USB 2.0
Clock output
32 kHz, 19.2 MHz
MAJOR EDISON COMPONENTS
SoC
RAM
Flash storage
WiFi
Bluetooth
22 nm Intel® SoC that includes a dual-core, dual-threaded Intel® Atom™ CPU at 500 MHz and a 32-bit
Intel® Quark™ microcontroller at 100 MHz
1 GB LPDDR3 POP memory
(2 channel 32bits @ 800MT/sec)
4 GB eMMC (v4.51 spec)
Broadcom* 43340 802.11 a/b/g/n;
Dual-band (2.4 and 5 GHz)
Onboard antenna
Bluetooth 4.0
POWER
Input
Output
Power
3.3 to 4.5 V
100 ma @3.3 V and 100 ma @ 1.8 V
Standby (No radios): 13 mW
Standby (Bluetooth 4.0): 21.5 mW (BTLE in Q4-14)
Standby (Wi-Fi): 35 mW
FIRMWARE + SOFTWARE
CPU OS
Development environments
MCU OS
Yocto Linux* v1.6
Arduino* IDE
Eclipse supporting: C, C++, and Python
Intel XDK supporting: Node.JS and HTML5
RTOS
MCU SDK and IDE
Intel may make changes to specifications and product descriptions at any time, without notice. Designers must not rely on the absence or characteristics of any features or instructions
marked “reserved” or “undefined”. Intel reserves these for future definition and shall have no responsibility whatsoever for conflicts or incompatibilities arising from future changes to them.
The information here is subject to change without notice. Do not finalize a design with this information.
Contact your local Intel sales office or your distributor to obtain the latest specifications and before placing your product order.
Copies of documents which have an order number and are referenced in this document, or other Intel literature, may be obtained by calling 1-800-548-4725 or by visiting Intel’s website
at http://www.intel.com/design/literature.htm.
Intel processor numbers are not a measure of performance. Processor numbers differentiate features within each processor family, not across different processor families.
See http://www.intel.com/products/processor_number for details.
Intel, the Intel logo, Atom, Pentium, Quark, and Xeon are trademarks of Intel Corporation in the United States and other countries.
*Other names and brands may be claimed as the property of others.
Copyright © 2015 Intel Corporation. All rights reserved.
Please Recycle
331179-002
很抱歉,暂时无法提供与“102990283”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+528.159341+68.08993
