NUTINY-SDK-M051
NUTINY-SDK-M051
    NUVOTON(新唐)
    KIT EVAL NUMICRO M051
NUTINY-SDK-M051 数据手册
NuTiny-SDK-M051 User’s Manual NuTiny-SDK-M051 User’s Manual For NuMicro M051™ Series The information described in this document is the exclusive intellectual property of Nuvoton Technology Corporation and shall not be reproduced without permission from Nuvoton. Nuvoton is providing this document only for reference purposes of NuMicro™ microcontroller based system design. Nuvoton assumes no responsibility for errors or omissions. All data and specifications are subject to change without notice. For additional information or questions, please contact: Nuvoton Technology Corporation. 1 NuTiny-SDK-M051 User’s Manual 1 Overview ..................................................................................................... 3 2 NuTiny-SDK-M051 introduction ....................................................................... 3 2.1 2.2 2.3 NuTiny -SDK-M051 Jumper Description .................................................................... 4 Pin Assignment for Extended Connector.................................................................... 5 NuTiny-SDK-M051 PCB Placement ........................................................................... 5 How to start NuTiny -SDK-M051 on the Keil uVision® IDE ................................... 6 3 3.1 3.2 3.3 3.4 4 Keil uVision® IDE Software Download & Install .......................................................... 6 Nuvoton Nu-Link Driver Download & Install............................................................... 6 Hardware Setup.................................................................................................... 6 Smpl_NuTiny-M051 Example Program...................................................................... 7 How to start NuTiny-SDK-M051 on the IAR Embedded Workbench ....................... 8 4.1 4.2 4.3 4.4 IAR Embedded Workbench Software Download &Install .............................................. 8 Nuvoton Nu-Link Driver Download & Install............................................................... 8 Hardware Setup.................................................................................................... 8 Smpl_NuTiny-M051 Example Program...................................................................... 9 5 M052_TINY-EVB Schematic .......................................................................... 10 6 To Download NuMicro™ Family Releated Files From Nuvoton Company ............... 11 6.1 6.2 6.3 7 To Download NuMicro™ Keil uVision® IDE driver ...................................................... 11 To Download NuMicro™ IAR EWARM driver .............................................................. 12 To Download NuMicro™ M051 series BSP Software Library ........................................ 13 Revision History.......................................................................................... 13 2 NuTiny-SDK-M051 User’s Manual 1 Overview NuTiny-SDK-M051 is the specific development tool for NuMicro M051™ series –M052/M054/M058/M0516. Users can use NuTiny-SDK-M051 to develop and verify the application program easily. NuTiny-SDK-M051 includes 2 portions. One is M052_Tiny-EVB and the other is Nu-Link-Me. M052_Tiny-EVB is evaluation board and Nu-Link-Me is its Debug Adaptor. Thus, users do not need additional ICE equipment. 2 NuTiny-SDK-M051 introduction NuTiny-SDK-M051 can support NuMicro M051™ series. Figure 2-1 is NuTiny-SDK-M051 for M051 series and the left portion is called M052-TINY-EVB and the right portion is Debug Adaptor called Nu-Link-Me. M052-TINY-EVB is similar to other development board. Users can use it to develop and verify applications to emulate the real behavior. In fact, the real chip M0516LAN is mounted on the board. The on board chip covers M052, M054 and M058’s features. The M052_Tiny-EVB can be a real system controller to design user target system. Nu-Link-Me is a Debug Adaptor. The Nu-Link-Me Debug Adaptor connects your PC's USB port to your target system (via Serial Wired Debug Port) and allows you to program and debug embedded programs on the target hardware. To use Nu-Link-Me Debug adaptor with Keil or IAR Please refer to “Nuvoton NuMicro™ IAR ICE driver user manual “ or Nuvoton NuMicro™ Keil ICE driver user manual” in detail. Figure 2-1 NuTiny-SDK-M051 (Green Color PCB Board) 3 NuTiny-SDK-M051 User’s Manual 2.1 NuTiny -SDK-M051 Jumper Description 2.1.1 Power Setting z z JP2: VCC5 Voltage connecter in M052_TINY-EVB J2: USB port in Nu-Link-Me POWER model J1 USB port J2 USB port JP2 VCC5 MCU Voltage Model 1 X Connect to PC DC 5V output DC 5V Model 2 X X DC 2.8-5.5V input Voltage by VCC input X: Not use. 2.1.2 Debug Connector z z JP4: Target ICE Connector in M052_TINY-EVB JP8: Nuvoton ICE Connector in Nu-Link-Me 2.1.3 USB Connecter z z J1: mini USB Connecter in M052_TINY-EVB J2: mini USB Connecter in Nu-Link-Me 2.1.4 Extended Connecter z JP1, JP5, JP6 and JP7: Show all of chip pins in M052_TINY-EVB 2.1.5 Reset Button z SW1: Reset button in M052_TINY-EVB 2.1.6 Power Connecter z z JP2: VCC connecter in M052_TINY-EVB JP3: GND connecter in M052_TINY-EVB 4 NuTiny-SDK-M051 User’s Manual Pin Assignment for Extended Connector M052_TINY-EVB provides M0516LAN on board and the extended connector for LQFP-48 pin. Table 2-1 is the pin assignment for M0516LAN. 2.2 Pin No 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 Pin Name MOSI_0,AIN5,P1.5 MISO_0,AIN6,P1.6 SCLK0,AIN7,P1.7 /RST P3.0,RXD AVSS P3.1,TXD P3.2,/INT0,STADC P3.3,/INT1,MCLK P3.4, T0,SDA P3.5,T1,SCL P4.3,PWM3 P3.6,/WR,CKO P3.7,/RD XTAL2 XTAL1 VSS LDO_CAP P2.0,AD8,PWM0 P2.1,AD9,PWM1 P2.2,AD10,PWM2 P2.3,AD11,PWM3 P2.4,AD12,PWM4 P4.0,PWM0 Pin No 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 Pin Name P2.5,AD13,PWM5 P2.6,AD14,PWM6 P2.7,AD15,PWM7 P4.4,/CS P4.5,ALE P4.6,ICE_CLK P4.7,ICE_DATA P0.7,AD7,SCLK1 P0.6,AD6,MISO_1 P0.5,AD5,MOSI_1 P0.4,AD4,/SS1 P4.1,PWM1 P0.3,AD3,RTS0 P0.2,AD2,CST0 P0.1,AD1,RTS1 P0.0,AD0,CTS1 VDD AVDD P1.0,AIN0,P1.0 P1.1,AIN1,T3 P1.2,AIN2,RXD1 P1.3AIN3,TXD1 P1.4,AIN4,/SS0 P4.2,PWM2 Table 2-1 pin assignment for M0516LAN 2.3 NuTiny-SDK-M051 PCB Placement Users can refer Figure 2-2 for the NuTiny -SDK-M051 PCB placement. Figure 2-2 NuTiny-SDK-M051 PCB Placement 5 NuTiny-SDK-M051 User’s Manual 3 How to start NuTiny -SDK-M051 on the Keil uVision® IDE 3.1 Keil uVision® IDE Software Download & Install Please connect to Keil company website (http://www.keil.com) to download the Keil uVision® IDE and install the RVMDK. 3.2 Nuvoton Nu-Link Driver Download & Install Please connect to Nuvoton company NuMicro™ website ( http://www.nuvoton.com/NuMicro ) to download “NuMicro™ Keil uVision® IDE driver” file. Please refer the Chapter 6.1 for the detail download flow. When the download had finished, please unzip the file and execute the “Nu-Link_Keil_Driver.exe” to install the driver. 3.3 Hardware Setup The hardware setup is shown as Figure 3-1 Figure 3-1 NuTiny-SDK-M051 Hardware Setup 6 NuTiny-SDK-M051 User’s Manual 3.4 Smpl_NuTiny-M051 Example Program This example demonstrates the ease of downloading and debugging an application on a NuTiny-SDK-M051 board. The example can be found on the Figure 3-2 list directory. Directory Project File Figure 3-2 Smpl_NuTiny-M051 Example Directory To use this example: „ Start uVision „ Open the Smpl_NuTiny-M051.uvproj project file Project-Open „ Compile and link the Smpl_NuTiny-M051 application Start debug mode Using the debugger commands, you may: „ „ Single step through code Run the application\ Project - Build „ Program the application into on-chip Flash ROM Flash – Download The LED will toggle on the M052_TINY-EVB board. 7 „ Review variables in the watch window „ Reset the device to re-run the application NuTiny-SDK-M051 User’s Manual 4 How to start NuTiny-SDK-M051 on the IAR Embedded Workbench 4.1 IAR Embedded Workbench Software Download &Install Please connect to IAR company website (http:// www.iar.com) to download the IAR Embedded Workbench and install the EWARM. 4.2 Nuvoton Nu-Link Driver Download & Install Please connect to Nuvoton company NuMicro™ website ( www.nuvoton.com/NuMicro) to download “NuMicro™ IAR ICE driver user manual” file. Please refer the 6.2 for the detail download flow. When the download had finished, please unzip the file and execute the “Nu-Link_IAR_Driver.exe” to install the driver. 4.3 Hardware Setup The hardware setup is shown as Figure 3-1 Figure 4-1 NuTiny- SDK-M051 Hardware Setup 8 NuTiny-SDK User’s Manual 4.4 Smpl_NuTiny-M051 Example Program This example demonstrates the ease of downloading and debugging an application on a NuTiny-SDK-M051 board. The example can be found on the Figure 3-2 list directory. (Samples code can be download from Nuvoton website) Directory Project File Figure 4-2 Smpl_NuTiny-M051 Example Directory To use this example: „ Start IAR Embeded Workbench „ Open the Smpl_NuTiny-M051.eww workspace file File-Open-Workspace „ Compile and link the Smpl_NuTiny-M051 application Project - Make „ Program the application into on-chip Flash ROM Project – Download and Debug The I/O will toggle on the M052_TINY-EVB board. 9 NuTiny-SDK-M051 User’s Manual M052_TINY-EVB Schematic SW1 PUSH BOTTOM SW R1 10K 0805R PIN47 PIN45 PIN43 PIN41 PIN39 PIN37 VCC DAVDD TICERST C1 10uF/10V CB1 TICEDAT TICECLK TICERST 0.1u C0603 JP1 HEADER 6X2 HEADER6X2 12 10 8 6 4 2 TICEDAT TICECLK TICERST 11 9 7 5 3 1 TANT-A From ICE Bridge's USB Power VCC PIN48 PIN46 PIN44 PIN42 PIN40 PIN38 PIN48 PIN47 PIN46 PIN45 PIN44 PIN43 PIN42 PIN41 PIN40 PIN39 PIN38 PIN37 Reset Circuit TICEDAT TICECLK TICERST U1 NCU120_LQFP_48 P4.2 AIN3/SS0/P1.4 AIN3/TXD1/P1.3 AIN2/RXD1/P1.2 AIN1/T2/P1.1 AIN0/T2/P1.0 AVDD VDD P0.0/AD0/CTS1 P0.1/AD1/RTS1 P0.2/AD2/CTS0 P0.3/AD3/RTS0 2 4 6 8 10 HEADER 5X2 HEADER5x2 R2 33 NET1 XTAL3-1 R4 1M 0805R D12MO PIN2 PIN4 PIN6 PIN8 PIN10 PIN12 2 4 6 8 10 12 TICERST HEADER 6X2 HEADER6X2 0805R PIN1 PIN2 PIN3 PIN4 PIN5 PIN6 PIN7 PIN8 PIN9 PIN10 PIN11 PIN12 1 2 3 4 5 6 7 8 9 10 11 12 MOSI_0/AIN5/P1.5 MISO_0/AIN6/P1.6 SCLK0/AIN7/P1.7 RST RXD/P3.0 AVSS TXD/P3.1 INT0/P3.2 MCLK/INT1/P3.3 SDA/T0/P3.4 SCL/T1/P3.5 PWM3/P4.3 P4.1 P0.4/AD4/SS1 P0.5/AD5/MOSI_1 P0.6/AD6/MISO_1 P0.7/AD7/SCLK1 P4.7/ICE_DAT P4.6/ICE_CLK P4.5/ALE P4.4/CS P2.7/AD15/PWM7 P2.6/AD14/PWM6 P2.5/AD13/PWM5 M052 LQFP 48 36 35 34 33 32 31 30 29 28 27 26 25 PIN36 PIN35 PIN34 PIN33 PIN32 PIN31 TICEDAT PIN30 TICECLK PIN29 PIN28 PIN27 PIN26 PIN25 D12MI 12 10 8 6 4 2 PIN35 PIN33 PIN31 PIN29 PIN27 PIN25 11 9 7 5 3 1 HEADER 6X2 HEADER6X2 13 14 15 16 17 18 19 20 21 22 23 24 0805C JP6 PIN36 PIN34 PIN32 PIN30 PIN28 PIN26 Crystal TICERST VCC JP2 1 2 HEADER 2 HEADER2 JP3 VCC 1 2 R11 HEADER 2 HEADER2 10K 0805R C2 10uF TANT-B TP2 SIP/1P TP3 SIP/1P NET2 VCC 2 4 6 8 10 12 2 TP1 SIP/1P DAVDD JP7 HEADER 6X2 VCC DAVDD PR 10K 0805R 2 POWER KPT-2012 1 KP-2012 1 3 5 7 9 11 PIN13 IO KPT-2012 1 KP-2012 D12MO D12MI 1 PIN13 PIN14 PIN15 PIN16 PIN17 PIN18 PIN19 PIN20 PIN21 PIN22 PIN23 PIN24 PIN18 1 C5 20p X2 12MHz 1 3 5 7 9 11 1 0805C JP5 ADAVSS C3 20p PIN1 PIN3 PIN5 PIN7 PIN9 PIN11 P3.6/WR/CKO P3.7/RD XTAL2 XTAL1 VSS LDO_CAP P2.0/AD8/PWM0 P2.1/AD9/PWM1 P2.2/AD10/PWM2 P2.3/AD11/PWM3 P2.4/AD12/PWM4 P4.0 ICE INTERFACE PIN14 PIN16 PIN18 PIN20 PIN22 PIN24 1 3 5 7 9 48 47 46 45 44 43 42 41 40 39 38 37 JP4 L1 L0603 L2 NET3 HEADER6X2 PIN13 PIN15 PIN17 PIN19 PIN21 PIN23 5 L0603 ADAVSS Title Nuvoton M052_TINY-EVB Board Versin 002 Size Document Number Date: Tuesday , August 10, 2010 Rev 004 M052_TINY _V002.DSN 10 Sheet 1 of 1 NuTiny-SDK-M051 User’s Manual To Download NuMicro™ Family Releated Files From Nuvoton Company 6 6.1 To Download NuMicro™ Keil uVision® IDE driver Step1 To connect to the Nuvoton NuMicro™ Website: http://www.nuvoton.com/NuMicro Step2 Step 3 Step 4 To download the :uMicro Keil uVision® IDE driver 11 NuTiny-SDK-M051 User’s Manual 6.2 To Download NuMicro™ IAR EWARM driver Step1 To connect to the Nuvoton NuMicro™ Website: http://www.nuvoton.com/NuMicro Click here to enter Devlopment Tools page Step2 Step 3 Step 4 To download the NuMicro™ IAR Embeded Workbench® driver 12 NuTiny-SDK-M051 User’s Manual 6.3 To Download NuMicro™ M051 series BSP Software Library Step1 To connect to the Nuvoton NuMicro™ Website: http://www.nuvoton.com/NuMicro Step2 Step 3 7 To download the NuMicro M051™ series software library Revision History Version Date Page Description 1.0 Aug. 20, 2010 -- Initial Issued 13 NuTiny-SDK-M051 User’s Manual Important Notice Nuvoton products are not designed, intended, authorized or warranted for use as components in systems or equipment intended for surgical implantation, atomic energy control instruments, airplane or spaceship instruments, transportation instruments, traffic signal instruments, combustion control instruments, or for other applications intended to support or sustain life. Further more, Nuvoton products are not intended for applications wherein failure of Nuvoton products could result or lead to a situation wherein personal injury, death or severe property or environmental damage could occur. Nuvoton customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Nuvoton for any damages resulting from such improper use or sales. Please note that all data and specifications are subject to change without notice. All the trademarks of products and companies mentioned in this datasheet belong to their respective owners. 14
NUTINY-SDK-M051 价格&库存
很抱歉,暂时无法提供与“NUTINY-SDK-M051”相匹配的价格&库存,您可以联系我们找货
