STM32-H405
STM32-H405
    OLIMEX
    STM32F405 HEADER BOARD
STM32-H405 数据手册
STM32-H405 Page 1 of 2 STM32-H405 HEADER BOARD FOR STM32F405RGT6 ARM CORTEX M4 1024KB FLASH 168 MHZ 192KB SRAM The ARM Cortex-M4 processor is the latest generation of ARM processors for embedded systems. It has been developed to provide a low-cost platform that meets the needs of MCU implementation, with a reduced pin count and lowpower consumption, while delivering an outstanding computational performance and an advanced system response to interrupts. The ARM Cortex-M4 32-bit RISC processor features exceptional code-efficiency, delivering the high-performance expected from an ARM core in the memory size usually associated with 8- and 16-bit devices. The STM32F405RGT6 performance line family has an embedded ARM core and is therefore compatible with all ARM tools and software. It combines the high performance ARM Cortex-M3 CPU with an extensive range of peripheral functions and enhanced I/O capabilities. STM32-H405 is a good start-up board for learning the new ST Cortex-M4 based microcontrollers STM32F405RGT6. It has RS232 and both USB and CAN. It also features a prototype area with all microcontroller signals near it, giving the customer an easy way to implement his own schematics and add-ons. FEATURES MCU: STM32F405RGT6 ARM Cortex M4 1024KB FLASH 168 Mhz 192kB SRAM USB, CAN, x2 I2C, x2 ADC 12 bit, x3 UART, x2 SPI, x3 TIMERS, up to 168Mhz Standard JTAG connector with ARM 2x10 pin layout for programming/debugging with ARMJTAG USB connector User button RESET button Status LED Power supply LED On board voltage regulator 3.3V with up to 800mA current single power supply: takes power from USB port or extension connector pin 8 Mhz crystal oscillator Page 2 of 2 32768 Hz crystal and RTC backup battery connector Extension headers for all uC ports PCB: FR-4, 1.5 mm (0,062"), soldermask, silkscreen component print Dimensions: 61x 34mm (2.4 x 1.3") Distance between the exntension connectors: 25.4 mm (1") https://www.olimex.com/Products/ARM/ST/STM32-H405/ 4/30/2015
STM32-H405 价格&库存
很抱歉,暂时无法提供与“STM32-H405”相匹配的价格&库存,您可以联系我们找货
