RASPBERRYPIB+
RASPBERRYPIB+
    RASPBERRYPI(树莓派)
    SINGLEBOARDCOMPUTER700MHZ
RASPBERRYPIB+ 数据手册
RASPBERRY PI 1 MODEL B+ The Model B+ is the final revision of the original Raspberry Pi. It replaced the Model B in July 2014 and was superseded by the Raspberry Pi 2 Model B in February 2015. Compared to the Model B it has: • More GPIO. The GPIO header has grown to 40 pins, while retaining the same pinout for the first 26 pins as the Model A and B. • More USB. We now have 4 USB 2.0 ports, compared to 2 on the Model B, and better hotplug and overcurrent behaviour. • Micro SD. The old friction-fit SD card socket has been replaced with a much nicer push-push micro SD version. • Lower power consumption. By replacing linear regulators with switching ones we’ve reduced power consumption by between 0.5W and 1W. • Better audio. The audio circuit incorporates a dedicated low-noise power supply. • Neater form factor. We’ve aligned the USB connectors with the board edge, moved composite video onto the 3.5mm jack, and added four squarelyplaced mounting holes. https://www.raspberrypi.org/products/model-b-plus/ 10/19/2016
RASPBERRYPIB+ 价格&库存
很抱歉,暂时无法提供与“RASPBERRYPIB+”相匹配的价格&库存,您可以联系我们找货
