MIKROE-1984
MIKROE-1984
    MIKRO
    ATSAM3X8E Flip & click Platform AT91SAM3 Series MCU 32-Bit ARM® Cortex®-M3 Core Embedded Evaluation ...
MIKROE-1984 数据手册
click boards™ meet Arduino To our valued customers I want to express my thanks to you for being interested in our products and for having confidence in MikroElektronika. The primary aim of our company is to design and produce high quality electronic products and to constantly improve the performance thereof in order to better suit your needs. Nebojsa Matic General Manager Table of Contents Introduction to Flip & click 4 1. What’s on board? 5 2. Programming Flip & click 6 3. Code examples 7 4. Blue side 8 5. USB ports 9 6. White side 10 7. click boards™ 11 8. Schematic Page 3 12 A maker’s sidekick Meet Flip & click, Arduino’s close cousin. This board shares a lot of Arduino DNA — Atmel’s 32-bit AT91SAM3X8E MCU, the familiar pinout, firmware to program it like a regular Arduino — but it has a tendency to flip. When it does, you’ll get to see its other side — four mikroBUS™ sockets for connecting click boards™. With more than 160 bite-sized clicks to pick from (and more coming out every week), anything goes. All sorts of sensors, transceivers, encoders, displays, connection ports are at your disposal. Separate communication lines allow for thousands of click board combinations, with no need for unsightly stacking or wire jumping. Flip & click is a perfect sidekick for your adventures in Maker land. Page 4 1. What’s on board? 1 3 2 1 4 2 3 1 7-20V DC connector 6 12 MHz Crystal oscilator 2 Programming USB port 7 32.768 MHz Crystal oscilator 3 Signal LEDs 8 SPI header 4 AT91SAM3X8E MCU 9 host/device USB port 5 Arduino UNO pinout 1 mikroBUS™ socket (one of 4) 3 LED (one of 4) 2 Reset button 5 5 System specification 6 7 5 5 8 9 Page 5 power supply board dimensions weight mikroBUS™ via USB cable 73 x 73 mm 30 g (0.066 lbs) 4 sockets (5V DC) (2.87 x 2.87 inch) 2. Programing Flip & click To program the Flip & click, download the latest version of the open-source Arduino IDE. The software is available for Windows, Mac, and Linux. Once you connect the board to a PC (using the microUSB port next to the power connector) your system will recognize it as an Arduino Due. Just compile your sketch and you’re good to go. www.arduino.cc/en/Main/Software Page 6 3. Code examples We made several examples to show off the potentials of Flip & click and click board™ combinations. All the code is available on MikroElektronika’s GitHub channel. Keep visiting the link, as more code will be added in the future: www.github.com/mikroe/Flip_n_Click_Examples Page 7 4. Blue side On the blue side, Flip & click features a standard Arduino Uno pinout (with additional SPI pins) which makes it compatible with a range of Arduino shields. All the pins operate on 3.3V logic, just like with Arduino Due. The four LEDs are the same as on Arduino Due. From left to right: indicating power supply (PWR), signaling programming is in progress (TX, RX), and one connected to MCU pin 13 (L). POWER PINS DIGITAL (~PWM) PINS ANALOG PINS SPI PINS Page 8 5. USB ports The board has two micro-USB ports. One is for programming, the other lets you connect your Flip & click to other hardware. Depending on what you are making, you can set the board to be a USB device or a host. host/ device port programming port Page 9 6. White side On the white side, Flip & click has four mikroBUS™ sockets along with four LEDs and a reset button. The silkscreen markings clearly denote which microcontroller pins are used on each socket. The pinout provides both 3.3V and 5V power supplies. Page 10 7. click boards™ Buzzer, Relays, WiFi, RFid, GSM, GPS, OLED, Speech recognition — you name it, we got it! There are more than 160 click boards™ available. Many of the chips on clicks already have their own Arduino libraries you can reuse. More and more will be coming out in the future. See them all, on: www.mikroe.com/click click boards™ Page 11 8. Schematic VCC-5V VCC-3.3V VCC-5V VCC-3.3V VCC-5V VCC-3.3V VCC-5V VCC-3.3V R12 U2_RX_LED 1K RX R13 U2_TX_LED 1K C21 100nF 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 I2C0_SDA TX INTA INTB INTC TXD3 RXD3 INTD PWM11 PWM12 VCC-3.3V Q1 ERASE FDN340P R14 10K RX JTAG_TCK JTAG_TDI JTAG_TDO JTAG_TMS CMD_ERASE USB MICRO VCC-USB FP5 MH2029-300Y 1 2 3 4 5 C22 CR3 CR4 E5 CR5 10uF 10nF VDDPLL XOUT XIN VCC-3.3V USBD_N USBD_P UOTGID X1 C14 CMD_RESET R15 10K 12MHz 10nF R11 1K C10 MRST VBUS DD+ ID GND 22pF C11 VCC-3.3V RSTD ERASE UOTGID UOTGVBOF PWM3 PA29 SPI0_CS0 SPI0_SCK SPI0_MOSI R17 100K SPI0_MISO 0R RSTA USBD_P USBD_N XUSB VBG VDDOUTMI USBD_P 27R USBD_N 27R UOTGVBOF 1K R18 100K R19 100K U4 1IN+ 2 C29 3 100nF VCC 1IN- OUT VCC-5V VCC-USB SPI0_CS2 C30 100nF 4 Q2 FDN340P I2C1_SCL I2C1_SDA AD5 AD4 AD3 AD2 AD1 AD0 VDDANA 1 2 3 4 5 6 7 8 9 10 PWM13 PWM12 PWM11 PWM10 PWM9 PWM8 100nF R36 1K8 R37 1K8 R24 100K 1 3 5 7 9 I2C0_SCL I2C0_SDA I2C1_SCL I2C1_SDA 1 2 3 4 5 6 7 8 R28 22pF VCC-5V LEDB VCC-5V 1 3 5 SPI0_MISO SPI0_SCK MRST 1 3 2 JJ Jack Power FP7 MH2029-300Y R30 LEDA 1K E16 10uF JJ HDR 1x6 VCC-3.3V R31 LEDC 1K C R32 LEDD D4 CD1206-S01575 VCC-3.3V E1 C1 C2 C3 C4 C5 C6 C7 E2 C8 E3 C9 E4 E7 C23 C24 C25 C26 C27 C28 10uF 100nF 100nF 100nF 100nF 100nF 100nF 100nF VDDANA 10uF VCC-3.3V 100nF VDDOUTMI 10uF 100nF 10uF 10uF 100nF 100nF 100nF 100nF 100nF 100nF FP2 MH2029-300Y VDDOUT VDDPLL FP3 MH2029-300Y VDDOUT VCC-5V REG2 2 GND Vin Vout 1 1 3 5 VCC-3.3V FP6 MH2029-300Y 3 LD29080DT33 Page 12 VCC-5V R33 10K U2_MISO U2_SCK U2_RESET 1K D R1 1K FP1 MH2029-300Y SPI0_MOSI A 1 2 3 4 5 6 7 8 VCC-3.3V PWR 2 4 6 VCC-5V D3 PMEG3010ER SPI B VIN POWER R27 100K 1K JP4 VBG C13 R26 100K JTAG_TMS JTAG_TCK JTAG_TDO JTAG_TDI MRST PWM13 R29 1 2 3 4 5 6 VCC-3.3V 100nF R25 100K 2 4 6 8 10 1K L JP3 AD0 AD1 AD2 AD3 AD4 AD5 C33 JTAG JP2 JJ HDR 1x8 C32 VCC-3.3V R35 1K8 JJ HDR 1x10 PWM7 PWM6 PWM5 PA29 PWM3 PWM2 TXD0 RXD0 AVREF FP8 R34 1K8 JJ HDR 1x8 22pF Q3 FDN340P LMV321IDBVR VCC-3.3V JP1 I2C0_SCL I2C0_SDA 32.768KHz C12 U2_VCC-USB 5 GND PWM10 VIN R3 6K8 1% Q4 BC846 R20 X2 22pF E11 10uF VCC-5V 1 108 107 106 105 104 103 102 101 100 99 98 97 96 95 94 93 92 91 90 89 88 87 86 85 84 83 82 81 80 79 78 77 76 75 74 73 MRST C15 D2 PMEG3010ER VIN 22pF T1 10uH 10uF VCC-3.3V PA25 PA21 GND VDDIO VDDCORE PC30 PC29 PC19 PC18 PC17 PC16 PC15 PC14 PC13 PC12 PC11 PB21 PB20 PB19 PB18 PB17 PB13 PB12 PA2 PA3 PA4 PA6 PA22 PA23 PA24 PA16 PB16 PB15 ADVREF GNDANA VDDANA AT91SAM3X8E L1 E10 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 XUSB CN2 PB26 PA9 PA10 PA11 PA12 PA13 PA14 PA15 PA17 VDDCORE VDDIO GND PD0 PD1 PD2 PD3 PD4 PD5 PD6 PD7 PD8 PD9 PA0 PA1 PA5 PA7 PA8 PB28 PB29 PB30 PB31 PD10 GNDPLL VDDPLL XOUT XIN R21 10K 6 5 4 BOOST SW GND VIN FB EN U1 TX RXD0 TXD0 RXD1 TXD1 U2_MISO Flash erase: Low level at startup. Datasheet page 29 PWM5 PWM6 PWM7 PWM8 PWM9 PWM2 RX REG1 LM2734 VDDOUT 4 SN74LVC1G125 9 10 11 12 13 14 15 16 VCC-5V 1 2 3 CD1206-S01575 R23 10K I2C0_SCL TX Y FM4 R22 52K3 5 A GND FM3 PWM6 INTA RXD0 TXD0 I2C0_SCL I2C0_SDA PWM INT RX TX SCL SDA 5V GND PWM13 22pF RST PC6 PC7 PB7 PB6 PB5 PB4 PB3 U2_RESET CMD_ERASE CMD_RESET A LEDB LEDA LEDC LEDD C19 22pF 2 3 24 23 22 21 20 19 18 17 VCC PD3 PD4 PD5 PD6 PD7 PB0 PB1 PB2 C18 OE AN RST CS SCK MISO MOSI 3.3V GND 100K 16MHz CR2 U2 U3 AD0 RSTA SPI0_CS0 SPI0_SCK SPI0_MISO SPI0_MOSI MRST XIN32 XOUT32 CR1 10nF 1 C20 1uF 10K C16 XTAL1 XTAL2 GND VCC PC2 PD0 PD1 PD2 PWM7 INTB RXD1 TXD1 I2C0_SCL I2C0_SDA PWM INT RX TX SCL SDA 5V GND RSTB RSTC X3 B VCC-3.3V 100nF 1 2 3 4 5 6 7 8 AN RST CS SCK MISO MOSI 3.3V GND FM2 144 143 142 141 140 139 138 137 136 135 134 133 132 131 130 129 128 127 126 125 124 123 122 121 120 119 118 117 116 115 114 113 112 111 110 109 U2_USBD_N U2_USBD_P 22R AVCC UVCC DD+ UGND UCAP PC4 PC5 22R AD1 RSTB PA29 SPI0_SCK SPI0_MISO SPI0_MOSI SPI0_CS3 VCC-USB R10 1K 32 31 30 29 28 27 26 25 C17 PWM8 INTC RXD3 TXD3 I2C1_SCL I2C1_SDA PWM INT RX TX SCL SDA 5V GND PB25 PB24 PB23 PB22 PB14 PC28 PC27 PC26 PC25 PC24 PC23 PC22 PC21 PC20 PC0 PB11 PB10 PB9 GND VDDIO VDDCORE PB8 PB7 PB6 PB5 PB4 PB3 PC10 PC4 PB2 PB1 PB0 PA29 PA28 PA27 PA26 C DHSDP DHSDM VBUS VBG VDDUTMI DFSDP DFSDM GNDUTMI VDDCORE JTAGSEL NRSTB XIN32 XOUT32 SHDN TST VDDBU FWUP GNDBU PC1 VDDOUT VDDIN GND PC2 PC3 VDDCORE VDDIO PC5 PC6 PC7 PC8 PC9 PB27 NRST PA18 PA19 PA20 AN RST CS SCK MISO MOSI 3.3V GND U2_TX FP4 MH2029-300Y R6 100K AD2 RSTC SPI0_CS2 SPI0_SCK SPI0_MISO SPI0_MOSI U2_SCK U2_MOSI USB MICRO 1 2 3 4 5 U2_VCC-USB PWM9 INTD RXD3 TXD3 I2C1_SCL I2C1_SDA PWM INT RX TX SCL SDA 5V GND U2_TX U2_RX_LED U2_TX_LED VBUS DD+ ID GND VCC-5V D U2_USBD_N U2_USBD_P U2_VCC-USB CN1 AN RST CS SCK MISO MOSI 3.3V GND VCC-5V 10nF D1 FM1 AD3 RSTD SPI0_CS3 SPI0_SCK SPI0_MISO SPI0_MOSI VIN C31 VCC-5V E8 E9 10uF 10uF ICSP 2 4 6 U2_MOSI DISCLAIMER All the products owned by MikroElektronika are protected by copyright law and international copyright treaty. Therefore, this manual is to be treated as any other copyright material. No part of this manual, including product and software described herein, may be reproduced, stored in a retrieval system, translated or transmitted in any form or by any means, without the prior written permission of MikroElektronika. The manual PDF edition can be printed for private or local use, but not for distribution. Any modification of this manual is prohibited. MikroElektronika provides this manual ‘as is’ without warranty of any kind, either expressed or implied, including, but not limited to, the implied warranties or conditions of merchantability or fitness for a particular purpose. MikroElektronika shall assume no responsibility or liability for any errors, omissions and inaccuracies that may appear in this manual. In no event shall MikroElektronika, its directors, officers, employees or distributors be liable for any indirect, specific, incidental or consequential damages (including damages for loss of business profits and business information, business interruption or any other pecuniary loss) arising out of the use of this manual or product, even if MikroElektronika has been advised of the possibility of such damages. MikroElektronika reserves the right to change information contained in this manual at any time without prior notice, if necessary. HIGH RISK ACTIVITIES The products of MikroElektronika are not fault – tolerant nor designed, manufactured or intended for use or resale as on – line control equipment in hazardous environments requiring fail – safe performance, such as in the operation of nuclear facilities, aircraft navigation or communication systems, air traffic control, direct life support machines or weapons systems in which the failure of Software could lead directly to death, personal injury or severe physical or environmental damage (‘High Risk Activities’). MikroElektronika and its suppliers specifically disclaim any expressed or implied warranty of fitness for High Risk Activities. TRADEMARKS The MikroElektronika name and logo, mikroC™, mikroBasic™, mikroPascal™, Visual TFT™, Visual GLCD™, mikroProg™, Ready™, MINI™, mikroBUS™, EasyPIC™, EasyAVR™, Easy8051™, click™ boards and mikromedia™ are trademarks of MikroElektronika. All other trademarks mentioned herein are property of their respective companies. All other product and corporate names appearing in this manual may or may not be registered trademarks or copyrights of their respective companies, and are only used for identification or explanation and to the owners’ benefit, with no intent to infringe. Copyright © 2015 MikroElektronika. All Rights Reserved. Page 13 If you want to learn more about our products, please visit our web site at www.mikroe.com. If you are experiencing some problems with any of our products or just need additional information, please place your ticket at www.mikroe.com/helpdesk. If you have any questions, comments or business proposals, do not hesitate to contact us at o  ffice@mikroe.com Flip & click Manual ver 1.00
MIKROE-1984 价格&库存
很抱歉,暂时无法提供与“MIKROE-1984”相匹配的价格&库存,您可以联系我们找货
