STM32-P107
STM32-P107
    OLIMEX
    ST M3 STM32F107 PROTOTYPE BOARD
STM32-P107 数据手册
STM32-P107 development board User's manual All boards produced by Olimex are ROHS compliant Document revision M, October 2021 OLIMEX Ltd, All rights reserved Page 1 of 23 DISCLAIMER © 2021 Olimex Ltd. Olimex®, logo and combinations thereof, are registered trademarks of Olimex Ltd. Other product names may be trademarks of others and the rights belong to their respective owners. The information in this document is provided in connection with Olimex products. No license, express or implied or otherwise, to any intellectual property right is granted by this document or in connection with the sale of Olimex products. This hardware design of STM32-P107 is neither public nor open-source. Any copying of the product would result in copyright infringement. The software written by Olimex is released under open source terms. Every other piece of code (libraries, ready-to-usefiles, etc) follow their owner's copyright. It is possible that the pictures in this manual differ from the latest revision of the board. The product described in this document is subject to continuous development and improvements. All particulars of the product and its use contained in this document are given by OLIMEX in good faith. However all warranties implied or expressed including but not limited to implied warranties of merchantability or fitness for purpose are excluded. This document is intended only to assist the reader in the use of the product. OLIMEX Ltd. shall not be liable for any loss or damage arising from the use of any information in this document or any error or omission in such information or any incorrect use of the product. This evaluation board/kit is intended for use for engineering development, demonstration, or evaluation purposes only and is not considered by OLIMEX to be a finished end-product fit for general consumer use. Persons handling the product must have electronics training and observe good engineering practice standards. As such, the goods being provided are not intended to be complete in terms of required design-, marketing-, and/or manufacturing-related protective considerations, including product safety and environmental measures typically found in end products that incorporate such semiconductor components or circuit boards. Olimex currently deals with a variety of customers for products, and therefore our arrangement with the user is not exclusive. Olimex assumes no liability for applications assistance, customer product design, software performance, or infringement of patents or services described herein. THERE IS NO WARRANTY FOR THE DESIGN MATERIALS AND THE COMPONENTS USED TO CREATE STM32-P107. THEY ARE CONSIDERED SUITABLE ONLY FOR STM32-P107. Page 2 of 23 INTRODUCTION STM32-P107 prototype board provides easy way for developing and prototyping with the new STM32F107VCT6 connectivity line microcontroller, produced by STMicroelectronics. STM32P107 has JTAG port for programming and debugging, USB_OTG, user button, two status LEDs, and most of the GPIOs are on extension headers where you can connect your additional circuits. BOARD FEATURES - CPU: STM32F107VCT6 32 bit ARM-based microcontroller with 256 KB Flash, 64 KB RAM, USB OTG, Ethernet, 10 timers, 2 CANs, 2 ADCs, 14 communication interfaces - JTAG connector with ARM 2×10 pin layout for programming/debugging - Power jack for external power supply: suitable for (6.5-9)VDC or 6VAC - USB mini connector (OTG), capable of powering the board - USB host connector - 100 Mbit/s Ethernet driver with RJ-45 connector - RS232 driver with DE-09 female connector - MiniSD card connector - UEXT connector - Two user-programmable buttons - Reset button and circuit - Two user-programmable LEDs - Power-on LED - 25 Mhz quartz crystal - Extension port connectors for many of microcontrollers pins - Prototype area - Easy-to-change PTH jumpers - Compatible with the bootloader tools provided by STM: "Flash Loader Demo" and "DfuSe Demo" - PCB: FR-4, 1.5mm ~ (0.062)", red solder mask, white silkscreen component print - Dimensions: (5.2×3.8)'' ~ (132×97)mm ELECTROSTATIC WARNING The STM32-P107 board is shipped in protective anti-static packaging. The board must not be subject to high electrostatic potentials. General practice for working with static sensitive devices should be applied when working with this board. Page 3 of 23 BOARD USE REQUIREMENTS Cables: The cable you will need depends on the programmer/debugger you use. If you use ARMJTAG, you will need LPT cable, if you use ARM-USB-OCD, ARM-USB-OCD-H, ARM-USBTINY, or ARM-USB-TINY-H you will need 1.8 meter USB A-B cable, for ARM-USB-OCD and ARM-USB-OCD-H you will need RS232 cable, too. Hardware: Programmer/Debugger – one of the Olimex ARM Programmers: ARM-JTAG, ARMJTAG-EW, ARM-USB-OCD, ARM-USB-OCD-H, ARM-USB-OCD-TINY, ARM-USB-OCD-H. Note that Olimex OpenOCD debuggers lack SWD interface by default. There is the adapter ARMJTAG-SWD that adds SWD to any of the programmers/debuggers mentioned above. Note the board can be programmed without a debugger using the serial port (the one with the DE-9 connector). Software: Any software that has support for ARM chips and more specifically for STM32F107. Page 4 of 23 PROCESSOR FEATURES STM32-P107 board uses the ARM-based 32-bit microcontroller STM32F107VCT6 with the following features: – Core: ARM 32-bit Cortex™-M3 CPU – 72 MHz maximum frequency, 1.25 DMIPS/MHz (Dhrystone 2.1) performance at 0 wait state memory access – Single-cycle multiplication and hardware division – Memories – 256 Kbytes of Flash memory – 64 Kbytes of SRAM – Clock, reset and supply management – 2.0 to 3.6 V application supply and I/Os – POR, PDR, and programmable voltage detector (PVD) – 25 MHz crystal oscillator – Internal 8 MHz factory-trimmed RC – Internal 40 kHz RC with calibration – 32 kHz oscillator for RTC with calibration – Low power – Sleep, Stop and Standby modes – VBAT supply for RTC and backup registers – 2 × 12-bit, 1 µs A/D converters (16 channels) – Conversion range: 0 to 3.6 V – Sample and hold capability – Temperature sensor – up to 2 MSps in interleaved mode – 2 × 12-bit D/A converters – DMA: 12-channel DMA controller – Supported peripherals: timers, ADCs, DAC, I2Ss, SPIs, I2Cs and USARTs – Debug mode – Serial wire debug (SWD) & JTAG interfaces – Cortex-M3 Embedded Trace Macrocell™ – 80 fast I/O ports – 80 I/Os, all mappable on 16 external interrupt vectors and almost all 5 V-tolerant – 10 timers – four 16-bit timers, each with up to 4 IC/OC/PWM or pulse counter and quadrature (incremental) encoder input – 1 × 16-bit motor control PWM timer with dead-time generation and emergency stop – 2 × watchdog timers (Independent and Window) – SysTick timer: a 24-bit downcounter – 2 × 16-bit basic timers to drive the DAC – 14 communication interfaces – 2 × I2C interfaces (SMBus/PMBus) – 5 USARTs (ISO 7816 interface, LIN, IrDA capability, modem control) – 3 SPIs (18 Mbit/s), 2 with a multiplexed I2S interface that offers audio class accuracy via advanced PLL schemes – 2 × CAN interfaces (2.0B Active) with 512 bytes of dedicated SRAM – USB 2.0 full-speed device/host/OTG controller with on-chip PHY that supports HNP/SRP/ID with 1.25 Kbytes of dedicated SRAM – 10/100 Ethernet MAC with dedicated DMA and SRAM (4 Kbytes): IEEE1588 hardware support, MII/RMII available on all packages Page 5 of 23 STM32F107 BLOCK DIAGRAM Page 6 of 23 STM32F107 MEMORY MAP Page 7 of 23 SCHEMATIC 22R 21 20 R9 0R(Board_Mounted) VREF+ VREF- PC15/OSC32_OUT 9 PE1 40 41 42 43 44 45 46 1 GND PE8/TIM1_CH1N PE9/TIM1_CH1 PE11/TIM1_CH2 PE12/TIM1_CH3N PD13/TIM4_CH2 60 PD14/TIM4_CH3 61 PHY_SOFT_RST PD15/TIM4_CH4 62 PE13/TIM1_CH3 PE14/TIM1_CH4 PE15/TIM1_BKIN RM1G3 TDO RST 10pF TRST RM1G1 D7 JTAG RM2G1 RA1206_(4x0603)_4B8_10k RM2G3 +5V_JTAG RM2G4 R-T 1 2 R64 D+ ID C1- 2 V- 6 100nF C34 100nF ETH_RMII_MDINT ETH_RMII_MDINT ETH_RMII_TXD0 ETH_RMII_TXD1 ETH_RMII_TXD0 ETH_RMII_TXD1 R20 R21 T1OUT14 T2OUT7 T1IN 2.2k 330R T2IN 12 2 R1IN 13 R2IN 8 R1OUT 9 R2OUT 3.3V 16 VCC PC_TXD PC_CTS 3 4 1N4148 47k 7 8 5 9 R42 NA GND 15 U5PWR C39 100nF 17 18 19 20 C20 22uF/6.3V 6 VDDCR 11 RXD0/MODE0 10 RXD1/MODE1 RA1206_(4X0603)_4B8_4.7k RMIISEL PHYAD2 9 RXD2/RMIISEL 8 RXD3/PHYAD2 100nF 26 RXDV 7 RXCLK/PHYAD1 EXP_PAD GND 13 RXER/RXD4/PHYAD0 4 XTAL2 17 MDC 16 MDIO ETH_RMII_MDC ETH_RMII_MDIO 3.3V LAN ETH_RMII_REF_CLK 5 XTAL1/CLKIN RM3G4 1 3 2 RA1206_(4X0603)_4B8_4.7k 14 CRS RM3G3 15 COL/CRS_DV/MODE2 ETH_RMII_CRS_DV PHY_SOFT_RST 3.3V R29 R28 R31 ETH_RMII_REF_CLK 3.3V L5 FB0805/600R/2A NA 10k 19 NRST 32 RBIAS 2 LED2/NINTSEL 3 LED1/REGOFF AG 29 TXP 28 TXN 31 RXP 30 RXN KY 12.1k/1% KG AY 7 6 8 LAN8710A-EZC ETH_RMII_REF_CLK R33 330R 1:1 TD+ COM AG 75 75 75 AY YELLOW KY 1:1 RD+ NC RD- 1nF/2kV R37 CD1 4 VDD E/D 3.3V 1 3.3V 3.3V UEXT 3 2 VSS OUT RM4G2 RM4G4 RM4G3 RM4G1 RA1206_(4X0603)_4B8_4.7k RA1206_(4X0603)_4B8_4.7k RA1206_(4X0603)_4B8_4.7k RA1206_(4X0603)_4B8_4.7k PHYAD0 PHYAD1 PHYAD2 RMIISEL R43 4.7k UEXT_PWR_E CLOSE USART3_TX I2C1_SCL SPI3_MISO SPI3_SCK UEXT 1 2 3 4 5 6 7 8 9 10 USART3_RX I2C1_SDA SPI3_MOSI CS_UEXT BH10S 3.3V R46 3.3VA 3.3V 3.3VA SPI3_SCK,SPI3_MOSI,SPI3_MISO,CS_UEXT,I2C1_SCL,I2C1_SDA,USART3_TX,USART3_RX,SPI1_NSS,SPI1_SCK,SPI1_MISO,SPI1_MOSI,USART2_TX,USART2_RX,USART2_RTS,USART2_CTS 2.2k PWR_LED LED/RED/0603 VO 2 D6 +5V_EXT 1N5819S IN NA(10uF/6.3V) GND_PIN C52 R56 R55 300R/1% 2 R47 PB2/BOOT1 10k NA(STM1001RWX6F) R52 2.2k 2 VCC RESET R53 1 330R GND R54 100R/1% 100nF GND C53 GNDA_E 2 AGND CLOSE Page 8 of 23 1 0 R48 10k U6 R51 2.2k C42 1 390R/1% RESET CIRCUIT 3 22uF/6.3V C51 2.2uF/6.3V C41 240R/1% 3.3V 3.3V STAT2 STAT1 CLOSE R50 22uF/6.3V C49 22uF/6.3V C48 100nF C47 22uF/6.3V C46 22uF/6.3V C45 470uF/16VDC 1 OUT ADJ/GND R49 100R/1% 100nF C44 + 1 GND/ADJ 22uF/6.3V C50 VI C43 100nF STATUS LEDS 3.3VA_E NA(10uF/6.3V) 3 C40 3.3V_E CLOSE VR2(3.3V) LM1117IMPX-ADJ STAT1 STAT2 LED/GREEN/0603 LED/YELLOW/0603 RESET C54 100nF RST 3 1N5819S 2 1N5819S D5 1 D4 +5V_OTG_PWR 1 VR1(5.0V) AME1085 T1107A(6x3,8x2,5mm) +5V_JTAG G1 2 PWR_JACK PWRJ_2.0mm(YDJ-1134) 3 7 8 6 WKUP 330R +5V GND C56 1nF/2kV/X7R/1206 33k R41 33k +5V 1 4 5 2 GREEN KG RJLBC-060TC1 C37 100nF 75 TD- 3.3V NA(6NC2-50MHz/5032) POWER SUPPLY CIRCUIT R15 R17 R18 L4 100nF C24 1 VDD2A 18 NINT/TXER/TXD4 RA1206_(4X0603)_4B8_4.7k ETH_RMII_RXD0 ETH_RMII_RXD1 R35 100R/1% 100nF 33k 33k 33k FB0805/600R/2A TAMPER C38 R12 R13 C22 22uF/6.3V 27 VDD1A RM3G2 R38 1M 10k Ethernet 12 VDDIO 3.3V 6VAC (6.5-9)VDC GND2 4.7k SPI3_SCK SPI3_MISO SPI3_MISO 13 21 TXEN 20 TXCLK RM3G1 3.3V ETH_RMII_RXD0 ETH_RMII_RXD1 ETH_RMII_CRS_DV PHY_SOFT_RST R36 100R/1% TAMPER 16 U4 ETH_RMII_TX_EN 100nF 330R 6 12 14 15 24 TXD2 25 TXD3 C55 10uF/6.3V R34 10 11 13 3.3V C35 1 6 8 9 RA1206_(4X0603)_4B8_4.7k R30 10k RS1 PC_DCD PC_RXD PC_RTS 5 7 3.3V CS_MMCCS_MMC SPI3_MOSI SPI3_MOSI 2 CD/DAT3/CS 3 CMD/DI 6 VSS 4 VDD 5 CLK/SCLK 7 DAT0/DO 8 DAT1/RES 1 DAT2/RES 9 22 TXD0 23 TXD1 3.3V WKUP C2- 11 10 10k R32 C2+ 5 DTC114YKA C33 4 MICRO_SD/TFC-WPAPR-08 3.3V T1103NE-DTSM-21R(12x12x4.3mm) 4 100nF 3.3V T2 V+ D2 1N4148 C1+ 3 2.2k 1 2 3 BH20S ETH_RMII_TX_EN T1103NE-DTSM-21R(12x12x4.3mm) 2 1 U5 ST3232BDR(SO16) 1 OPEN 10pF ETH_RMII_MDIO HN1x2(Open) RST DB104(SMD) USB 100nF C6 10uF/6.3V C7 R60 4.7k BAT54C GND GND SD/MMC NA ETH_RMII_MDC BUTTONS RST_E RS232 2 L3 SD/MMC 3.3V R11 PHYAD1 PHYAD0 1 6.81k/1% 10k RM1G4 USART3_TX USART3_RX PD8 PD9 PD10 PD11 PD12 PD13 PD14 PD15 PD10/USART3_CK/ETH_MII_RX_D1 57 PD11/USART3_CTS/ETH_MII_RX_D2 58 PD12/TIM4_CH1/USART3_RTS/ETH_MII_RX_D3 59 PE10/TIM1_CH2N SPI3_SCK SPI3_MISO SPI3_MOSI USART2_CTS USART2_RTS USART2_TX USART2_RX PD6 PD7 PD7/USART2_CK 88 USB_VBUSON PD8/USART3_TX/ETH_MII_RX_DV USART3_TX 55 PD9/USART3_RX/ETH_MII_RX_D0 56 USART3_RX PE7/TIM1_ETR C21 Q2 32768Hz/6pF C23 PD4/USART2_RTS 85 USART2_RTS PD5/USART2_TX 86 USART2_TX PD6/USART2_RX USART2_RX 87 PE6/TRACED3 RM1G2 RA1206_(4x0603)_4B8_10k TRST TDI TMS TCK PD1 PD2 PD3 PD4 PD5 PD2/TIM3_ETR/UART5_RX 83 PD3/USART2_CTS USART2_CTS 84 PE5/TRACED2 38 39 RM2G2 JTAG STM32F107VCT6 HN1x2(Open) 100nF FB0805/600R/2A ETH_RMII_RXD0 ETH_RMII_RXD1 PC4 PC5 PC6 PC7 R19 PD0/OSC_IN/CAN1_RX 81 PD1/OSC_OUT/CAN1_TX 82 PE0/TIM4_ETR PE4/TRACED1 5 R40 330R 10uF/6.3V 22uF/6.3V C26 3 D3 D- MICRO_AB RJ45 SIDE NC PE3/TRACED0 4 BOOT0_E C16 GND2 NRST ETH_RMII_MDC PC2 PC3 PC8 PC9 PC10 PC11 PC12/UART5_TX/USART3_CK/SPI3_MOSI 80 SPI3_MOSI PC13/TAMPER-RTC 7 TAMPER PC14/OSC32_IN 8 PE2/TRACECK 2 ETH_RMII_MDINT USB_FAULT BOOT0 VBUS GND C15 GND1 98 1 USART2_RX USART2_CTS USB_OTG +5V_OTG_PWR USB_OTG_DUSB_OTG_D+ OTG_ID OTG_ID 22uF/6.3V C25 PC9/TIM3_CH4 66 PC10/UART4_TX/USART3_TX/SPI3_SCK 78 SPI3_SCK PC11/UART4_RX/USART3_RX/SPI3_MISO SPI3_MISO 79 OSC_OUT NA 97 R39 330R USB_OTG USB_OTG_DUSB_OTG_D+ R27 14 PE1 PE2 PE3 PE4 PE5 PE6 PE7 PE8 PE9 PE10 PE11 PE12 PE13 PE14 C36 R6 1M +5V_OTG_PWR USB_HOST_DUSB_OTG_D- 0R 13 73 USART2_TX USART2_RTS R57 3 H USB_FAULT 2 1 PC7/I2S3_MCK/TIM3_CH2 STAT2 64 PC8/TIM3_CH3 65 2 R16 150R RST C32 100nF 22uF/6.3V 0R(Board_Mounted) PC4/ADC12_IN14/ETH_MII_RXD0/ETH_RMII_RXD0 33 ETH_RMII_RXD0 PC5/ADC12_IN15/ETH_MII_RXD1/ETH_RMII_RXD1 ETH_RMII_RXD1 34 PC6/I2S2_MCK/TIM3_CH1 63 STAT1 OSC_IN NA Q25.000MHz/HC-49SM(SMD)/20pF ISET3 1 R14 Q1 RST O NA(USBLC6-2P6) 100nF SHIELD CS_UEXT PC1 PC2/ADC12_IN12/ETH_MII_TXD2 17 PC3/ADC12_IN13/ETH_MII_TX_CLK 18 3.3V 12 C19 27pF 2 2 PB11 PC0/ADC12_IN10 15 PC1/ADC12_IN11/ETH_MII_MDC/ETH_RMII_MDC 16 ETH_RMII_MDC BOOT0 B0_0/B0_1 HN1x3(B0_0:Close/B0_1:Open) 3 HN1x3(O:Close,H:Open) R63 2.2k OUT1 EN PB11/I2C2_SDA/USART3_RX/ETH_MII_TX_EN/ETH_RMII_TX_EN/TIM2_CH4 48 ETH_RMII_TX_EN ETH_RMII_TX_EN PB12/SPI2_NSS/I2S2_WS/I2C2_SMBAL/USART3_CK/TIM1_BKIN/CAN2_RX/ETH_MII_TXD0/ETH_RMII_TXD0 51 ETH_RMII_TXD0 ETH_RMII_TXD0 VBAT 94 1 4 C13 C12 NA(47pF) NA(47pF) SY6280 IN 49.9R/1% R22 49.9R/1% R23 49.9R/1% R24 49.9R/1% R25 330R R26 3 2 0 I2C1_SCL I2C1_SDA 2 4 C64 22uF/6.3V C29 6 R1010k 1 2 C11 5 U13 5 USB_D- 4 PB13/SPI2_SCK/I2S2_CK/USART3_CTS/TIM1_CH1N/CAN2_TX/ETH_MII_TXD1/ETH_RMII_TXD1 52 ETH_RMII_TXD1 ETH_RMII_TXD1 PB10 PB14/SPI2_MISO/TIM1_CH2N/USART3_RTS 53 BOOT0 BAT54C 1 C18 27pF PB5 PB6/I2C1_SCL/TIM4_CH1/USART1_TX/CAN2_TX 92 PB6 PB7/I2C1_SDA/TIM4_CH2/USART1_RX 93 PB7 PB8/TIM4_CH3/ETH_MII_TXD3/I2C1_SCL/CAN1_RX 95 I2C1_SCL PB8 PB9/TIM4_CH4/I2C1_SDA/CAN1_TX 96 I2C1_SDA PB10/I2C2_SCL/USART3_TX/ETH_MII_RX_ER/TIM2_CH3 PB9 47 PB15/SPI2_MOSI/I2S2_SD/TIM1_CH3N CS_UEXT 54 D1 3V_BAT WF2S R7 PB3/JTDO/SPI3_SCK/TRACESWO/TIM2_CH2/SPI1_SCK 89 TDO TDO PB4/JNTRST/SPI3_MISO/TIM3_CH1/SPI1_MISO 90 TRST TRST PB4 PB5/I2C1_SMBAL/SPI3_MOSI/ETH_MII_PPS_OUT/ETH_RMII_PPS_OUT/TIM3_CH2/SPI1_MOSI/CAN2_RX 91 VREFVBAT 3.3V 22R 1 100nF C28 NA OTG_DM 6 100nF C27 C17 R3 C31 2.2uF/6.3V 100nF 22R C30 C14 OTG_DP 3 USB_A GND1 VSSA +5V 2 USB 19 PB0/ADC12_IN8/TIM3_CH3/ETH_MII_RXD2/TIM1_CH2N PB1 35 PB1/ADC12_IN9/TIM3_CH4/ETH_MII_RXD3/TIM1_CH3N PB2 36 PB2/BOOT1 PB3 37 PB2/BOOT1 VREF+ USB_HOST_D+ USB_OTG_D+ 1 L1 GND4 C9 C10 10uF/6.3V 100nF VDDA H U2 R61 PA14/JTCK/SWCLK TCK 76 PA15/JTDI/SPI3_NSS/TIM2_CH1_ETR/SPI1_NSS 77 3.3V 2 VSS TMS TCK TDI +5V_HOST_PWR USB_HOST_DUSB_HOST_D+ FB0805/600R/2A 6.81k/1% 22 HN1x3(O:Close,H:Open) O PA12/USART1_RTS/CAN1_TX/TIM1_ETR/OTG_FS_DP 71 OTG_DP PA13/JTMS/SWDIO 72 TMS VSS 33k VSS EN ISET3 R5 L2 22R PA10/USART1_RX/TIM1_CH3/OTG_FS_ID 69 OTG_ID PA11/USART1_CTS/CAN1_RX/TIM1_CH4/OTG_FS_DM OTG_DM 70 VSS 3 PA8/USART1_CK/OTG_FS_SOF/TIM1_CH1/MCO R2 67 PA9/USART1_TX/TIM1_CH2/OTG_FS_VBUS 68 OTG_VBUS VSS USB_VBUSON 49 R59 2.2k OUT1 IN 22uF/6.3V 2.2k 2 74 SY6280 C62 47k USB_D+ R4 99 0R 4 2 CLOSE 27 1 3.3VA_MCU_E 10 R8 DTA114YKA PA6/SPI1_MISO/ADC12_IN6/TIM3_CH1/TIM1_BKIN 31 PA7/SPI1_MOSI/ADC12_IN7/TIM3_CH2/ETH_MII_RX_DV/ETH_RMII_CRS_DV/TIM1_CH1N ETH_RMII_CRS_DV 32 ETH_RMII_CRS_DV 3.3VA FB0805/600R/2A USB CIRCUIT CS_MMC 5 T1 1 100nF C5 PA2 PA3/USART2_RX/TIM5_CH4/ADC12_IN3/TIM2_CH4/ETH_MII_COL 26 PA3 PA4/SPI1_NSS/DAC_OUT1/USART2_CK/ADC12_IN4 29 CS_MMC PA4 PA5/SPI1_SCK/DAC_OUT2/ADC12_IN5 30 PA5 USB_HOST +5V U3 3 VDD 100 VDD 28 VDD 11 VDD 100nF C4 10uF/6.3V C3 100nF C2 100nF C1 PA0/WKUP/USART2_CTS/ADC12_IN0/TIM2_CH1_ETR/TIM5_CH1/ETH_MII_CRS_WKUP PA1 23 WKUP PA1/USART2_RTS/ADC12_IN1/TIM5_CH2/TIM2_CH2/ETH_MII_RX_CLK/ETH_RMII_REF_CLK ETH_RMII_REF_CLK ETH_RMII_REF_CLK 24 PA2/USART2_TX/TIM5_CH3/ADC12_IN2/TIM2_CH3/ETH_MII_MDIO/ETH_RMII_MDIO ETH_RMII_MDIO ETH_RMII_MDIO 25 VDD +5V_HOST_PWR USB_HOST_DUSB_HOST_D+ 3.3V +5V_OTG_PWR 2 50 +5V_HOST_PWR 0R(Board_Mounted) 2 2 U1 75 USB_HOST H 0R 1 1 O R1 OTG_VBUS CLOSE 1 VBUS HN1x3(O:Close,H:Open) 3.3V_MCU_E GND3 3.3V B1_0/B1_1 HN1x3(B1_0:Close/B1_1:Open) R44 R45 4.7k 33k BOARD LAYOUT POWER SUPPLY CIRCUIT STM32-P107 can be powered from: – PWR JACK connector, where (6.5-9.0)V DC or 6.0V AC is applied from an external power source – USB OTG connector; 5V voltage is provided via a mini USB cable – JTAG connector; 5V voltage is provided by a compatible third party tool The programmed board power consumption is about 70 mA. RESET CIRCUIT STM32-P107 reset circuit includes JTAG connector pin 15, U2 (STE101P) pin 28 (RESET), R73 (10k), R74 (330Ohm), R75 (100Ohm/1%), C55 (100nF), STM32F107 pin 14 (NRST) and RESET button. CLOCK CIRCUIT Quartz crystal 25 MHz is connected to STM32F107 pin 12 (OSC_IN) and pin 13 (OSC_OUT). Quartz crystal 32.768kHz is connected to STM32F107 pin 8 (PC14/OSC32_IN) and pin 9 (PC15/OSC32_OUT). Page 9 of 23 JUMPER DESCRIPTION STM32-P107 has a number of jumpers. They control the behavior of the board and allow modification of the default hardware connections. There are two types of jumpers – PTH ones (big ones, easy to change using a plastic cap) and SMT ones (pads that require cutting and soldering). It is safe to change the position of the PTH jumpers as long as you use one of the legal positions of the jumper. Changing the SMT jumpers, on the other hand, is not recommended – misconfiguration of the SMT jumpers might damage the board. There are jumper tables printed at the back of the board! PTH jumpers: B0_0/B0_1 and B1_0/B1_1 control the boot mode. B0_0/B0_1 When this jumper is in position B0_1 – BOOT0 is connected to 3.3V, and when the jumper is in position B0_0 – BOOT0 is connected to GND. Default state is B0_0. B1_0/B1_1 When this jumper is in position B1_1 – BOOT1 is connected to 3.3V, and when the jumper is in position B1_0 – BOOT1 is connected to GND. Default state is B1_0. VBUS, USB_D+, and USB_D- are responsible for the USB host control. The host can be routed to either the USB_OTG or the USB_HOST control. VBUS When is in position “H” - connects +5V_HOST_PWR to OTG_VBUS. When is in position “O” - connects +5V_OTG_PWR to OTG_VBUS. Default state is “O”. USB_D+ When is in position “H” - connects USB_HOST_D+ to OTG_DP. When is in position “O” - connects USB_OTG_D+ to OTG_DP. Default state is “O”. USB_DWhen is in position “H” - connects USD_HOST_D- to OTG_DM. When is in position “O” - connects USB_OTG_D- to OTG_DM. Default state is “O”. RST_E and BOOT0_E jumpers are responsible for the system memory boot mode via UART protocol. Page 10 of 23 RST_E, BOOT0_E jumpers Note that it is recommended to move those jumpers together – either both should be open or both should be closed. When both are closed RS232 boot is enabled (and also B0_0/B0_1 should be in B0/1 position). You can use Flash Load Demonstrator program provided for free by STMicroelectronics: http://www.st.com/web/en/catalog/tools/PF257525 Default states are RST_E – open; BOOT_E – open. SMT jumpers: The SMT jumpers are typically used for hardware measurements and hardware debugging. Please do not attempt to change the jumpers if you lack the soldering skills required. 3.3V_MCU_E Enable microcontroller 3.3V power supply Default state is closed. 3.3V_E Enable regulator VR2 (3.3V) - LM1117 Default state is closed. 3.3VA_E Enables board 3.3V analog power supply. Default state is closed. 3.3VA_MCU_E Enables microcontroller 3.3V analog power supply. Default state is closed. GNDA_E Enables board analog GND. Default state is closed. R-T Connects RST to TRST Default state is open. INPUT/OUTPUT Status LED1 (green) with name STAT1 connected to STM32F107 pin 63 (PC6/I2S2_MCK/TIM3_CH1). Status LED2 (yellow) with name STAT2 connected to STM32F107 pin 64 (PC7/I2S3_MCK/TIM3_CH2). Power-on LED (red) with name PWR – this led shows that +3.3V is applied to the board. User button with name WKUP connected to STM32F107 pin 23 (PA0/WKUP). User button with name TAMPER connected to STM32F107 pin 7 (PC13/TAMPER-RTC). Reset button with name RESET connected to STM32F107 pin 14 (NRST). Page 11 of 23 CONNECTOR DESCRIPTIONS JTAG The JTAG connector is used to program and debug the board via a third-party tool. It can be used for JTAG and SWD programming and debugging. It is recommended to use with tools that have a compatible 20-pin 0.1 step connector. The JTAG connector allows the software debugger to talk via a JTAG (Joint Test Action Group) port directly to the core. Instructions may be inserted and executed by the core thus allowing STM32F107 memory to be programmed with code and executed step by step by the host software. For more details please refer to IEEE Standard 1149.1 – 1990 Standard Test Access Port and Boundary Scan Architecture and STM32F107's datasheet and user's manual. Pin # Signal name Pin # Signal name 1 3.3V 2 3.3V 3 TRST 4 GND 5 TDI 6 GND 7 TMS 8 GND 9 TCK 10 GND 11 PULL-DOWN 12 GND 13 TDO 14 GND 15 RST 16 GND 17 PULL-DOWN 18 GND 19 +5V_JTAG 20 GND Page 12 of 23 PWR_JACK The board has a standard Olimex DC barrel jack with 2.0mm inner pin and 6.3mm hole. More information about the exact component might be found here: https://www.olimex.com/wiki/PWRJACK You can supply either DC or AC voltage to power the board however be careful – if you provide more than the maximum voltage suggested, you would permanently damage the board. The suggested voltage ranges for powering the board from the PWR_JACK are: If you are powering the board from a DC power source – you need to provide between 6.5V and 9.0V of voltage. If you are powering the board from an AC power source – you need to provide 6.0V of voltage. Pin # Signal name 1 Power input 2 GND USB_HOST If you intend to use the USB_HOST connector pay attention to the position of VBUS, USB_D+, and USB_D- jumpers. There is multiplexing between the USB_HOST connector and USB_OTG connector. Pin # Signal name 1 +5V_HOST_PWR 2 USB_HOST_D- 3 USB_HOST_D+ 4 GND USB_OTG If you intend to use the USB_OTG connector in host mode pay attention to the position of VBUS, USB_D+, and USB_D- jumpers. There is multiplexing between the USB_OTG connector and USB_HOST connector. Pin # Signal name 1 +5V_OTG_PWR 2 USB_OTG_D- 3 USB_OTG_D+ 4 OTG_ID 5 GND The port can be used for DFU USB mode of the STM32F107 processor. To be able to upload data you would need a mini USB cable connected to a personal computer that runs the proper software supplied by Page 13 of 23 ST. To enter the DFU mode you would also need to set the STM32-P107's jumpers properly. Make sure all jumpers are set as per default and then change the jumper B0_0/B0_1 to position B0_1 – which means boot from system memory. More information about the DFU USB mode might be found at the ST's web-site. By the time of writing this document more information and required files can be found at this link: http://www.st.com/web/en/catalog/tools/PF257916 You can download the archive that contains the graphical user interface for DFU connection. It is called “DfuSe Demo”. Extract it and install the software. Set the jumpers of STM32-P107 to boot from system memory. Leave the rest of the jumpers as per default. Connect the STM32-P107 board to the computer using a mini USB cable. This would show an unrecognized device in “Windows Device Manager”. Point the driver updater to the folder where “DfuSe Demo” was installed. After the driver installation the board would be recognized as “STM Device in DFU Mode”. At this point launch “DfuSe Demo” and restart the board. A properly connected board looks like in the picture below: For more information about DFU mode refer to the official USB and ST web-sites. Page 14 of 23 RS232 The board can be programmed via the RS232 connector (serial interface). This is done without the need of an additional programming tool. However, you would need a proper serial cable or adapter to access it. You would also need to change the positions of three PTH jumpers (the rest of the jumpers should be as per default): 1. B0_0/B0_1 should be set to position B0_1 – which means boot from system memory 2. RST_E should be closed 3. BOOT_E should be closed Do not confuse B0_0/B0_1 with B1_0/B1_1. After you set the jumpers and establish the hardware connection you need to download the software provided by STMicroelectronics. It is called “Flash Loader Demonstrator”. It might be found here: http:// www.st.com/web/en/catalog/tools/PF257525 – after you install the software and establish connection you can upload hex files to the board without the need of an expensive debugger. A properly recognized board in “Flash Loader Demonstrater” is shown below: Note that this method of programming is much slower than working with a debugger. Not only the upload speed is low – you would need to perform hardware debugging routines to be able to track what is going on. Page 15 of 23 The layout of the port is shown on the next page: Pin # 1 2 3 4 5 6 7 8 9 Signal name NC T1OUT R1IN NC GND NC CTS RTS NC UEXT The UEXT connector is typically used to attach additional modules to the board. It nests three popular interfaces – UART, I2C, and SPI. You can also find 3.3V power output and GND (respectively, pin #1 and pin #2). Pin # 1 2 3 4 5 6 7 8 9 10 Signal name 3.3V GND USART2_TX USART2_RX I2C1_SCL I2C1_SDA SPI3_MISO SPI3_MOSI SPI3_SCK CS_UEXT SD/MMC Pin # Signal name 1 2 3 4 5 6 7 8 9 10 11 12 MCIDAT2 CS_MMC SPI3_MOSI 3.3V SPI3_SCK GND SPI3_MISO MCIDAT1 Not connected Not connected Not connected Not connected Page 16 of 23 LAN Pin # Signal name chip side Pin # Signal name chip side 1 TX+ 5 Not connected (NC) 2 TX- 6 VDD 3 VDD 7 RX+ 4 Not connected (NC) 8 RX- LED Color Usage Right Green Link status Left Yellow Activity status 3V_BAT Pin # Signal name 1 VBAT 2 GND Page 17 of 23 MECHANICAL DIMENSIONS All measures are in mils. Page 18 of 23 Proto area pad pinout table: # WHITE PRINT ROW #1 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 3.3V 3.3VA AGND +5V VBAT PA4 PA2 PE14 PE12 PE10 PE8 PE6 PE4 PE2 PC1 PC2 PC4 PC6 PC8 PC10 PB1 PB3 PB5 PB7 PB9 PB10 PD15 PD13 PD11 PD9 PD6 PD4 PD2 VREF+ VREFRST GND PORT PROCESSOR WHITE PRINT ROW #2 PORT PROCESSOR PA5 PA3 PE13 PE11 PE9 PE7 PE5 PE3 PE1 PC0 PC2 PC6 PC8 PC11 PC13 PB0 PB2 PB6 PB8 PB10 PB14 PD15 PD13 PD11 PD9 PD5 PD3 PD1 - 3.3V PA5 PA3 PA1 PE13 PE11 PE9 PE7 PE5 PE3 PE1 PC3 PC5 PC7 PC9 PC11 PB2 PB4 PB6 PB8 PB11 PD14 PD12 PD10 PD8 PD7 PD5 PD3 PD10 GND PA6 PA4 PA0 PE12 PE10 PE8 PE6 PE4 PE2 PE0 PC3 PC7 PC9 PC12 PC14 PB1 PB5 PB7 PB9 PB15 PD14 PD12 PD10 PD8 PD6 PD4 PD2 PD10 - Page 19 of 23 AVAILABLE DEMO SOFTWARE All demo examples are available at the board's web-page (https://www.olimex.com/Products/ARM/ST/STM32-P107/) and wiki article (https://www.olimex.com/wiki/STM32-P107). Make sure that the demo you download is compatible with the board revision you have! The board revision is printed on STM32-P107 itself. Page 20 of 23 REVISIONS AND ORDERING INFORMATION STM32-P107 – fully assembled and tested You can purchase directly from our online shop or from any of our distributors. Note that usually it is faster and cheaper to purchase Olimex products from our distributors. List of confirmed Olimex LTD distributors and resellers: https://www.olimex.com/Distributors. Please visit https://www.olimex.com/ for more info. User's manual revision history: REV. I REV. A REV. B REV. C REV. D REV. E REV. F REV.G REV.H REV.I REV.J REV.K REV.L REV.M - created December 2009 - edited by TU December 2010 - demo software added and mechanical dimensions detail - rev. A schematic and added more programmers in BOARD USE REQUIREMENTS. - edited June 2011 – changed schematic - changed schematics to rev. B, added board revision history - added BOOT0_E, RST_E description, changed dimensions, updated revision B pictures, updated disclaimer - updated the information to fit board revision C, updated schematics, improved document layout, added product support information, updated links - improved information about bootloader - changed the schematic on page 8 - added picture of the protoarea pads with their respective labels - added new information about DFU mode, hardware revision D changelog - February 2018 – added table that details the protoarea pinout - October 2021 – added latest revision schematics, fixed proto area table Board revision history: rev. A ======== 1. ST2052BD changed with LM3526-L; 2. SD/MMC signals changed: SPI1_MOSI→SPI3_MOSI SPI1_SCK→SPI3_SCK SPI1_MISO→SPI3_MISO and SPI1_NSS renamed to CS_MMC; 3. Changed the polarity of C36 to positive (+). rev. B ======== 1. Ethernet PHY changed from STE101P to MICREL one – KS8721BLMM; 2. All 10uF/6.3V/TANT changed to 0805 and a lot of components labels changed; 3. PWR_SEL jumpers replaced by diodes; 4. USART3 connected to UEXT while USART2 connected to RS232 and bootloader functionality is Page 21 of 23 enabled! Two additional jumpers are added!!! 5. Added UEXT_PWR_E jumper! 6. A lot of jumpers added in the jumpers description table rev. C ======== 1. L2 now placed further away from USB_HOST connector to avoid contact; 2. Ethernet PHY Micrel KS8721 changed to LAN8710A-EZC in RMII; 3. Changed C18 to 4.7uF/6.3V from 100n in accordance with the datasheet. C18 is now renamed C3; 4. STAT1, STAT2 and PWR_LED changed to 0603 size and its resistors to 2.2k; 5. SD/MMC capacitor was replaced by 2×22uF/6.3V capacitors; 6. LM3526 changed to MIC2026-1YM and connection between pin 1 and pin 4 swapped because the default EN level is opposite; 7. All tantalum capacitors changed to ceramic; 8. Optimizations in the values of few other elements as well; 9. R28(0R) changed to 10k, C55=10uF/6.3V added and RST connection removed from the PHY! rev. D ======== 1. All libraries updated; 2. SD/MMC package changed to TFC-WPAPR-08; 3. CD1 package changed from 7×5mm to 5032; 4. 1nF/2kV/X7R/1206 capacitor added to the LAN's connector and the routing changed a little; 5. L1,L2,L3 and L5 values changed from FB0805/600R/200mA(201209-601) to FB0805/600R/2A; 6. L4 changed from CL470nH/0805/1.76R/250mA to FB0805/600R/2A; 7. C7 and C9 changed from 0805 to 0603; 8. C53's package changed from 0805 to 0603. rev. E ======== 1. U3(MIC2026-1YM) replaced by 2xSY6280 and their corresponding elements, because MIC2026-1YM is obsolete; 2. All libraries updated and many packages changed: MCU, SD_card, PWR_JACk, LED and USB_OTG. 3. Optimizations: C15 changed from 2.2uF/6.3V to 10uF/6.3V R26 and R33 changed from 549R/1% to 330R C3 changed from 4.7uF/6.3V to 10uF/6.3V to reserve a feeder. Q1's value corrected from HC-49 to Q25.000MHz/HC-49SM(SMD)/20pF. Written default positions for the jumpers B0_0/B0_1 and B1_0/B1_1. Page 22 of 23 WARRANTY AND SUPPORT For product support, hardware information and error reports mail to: support@olimex.com. All document or hardware feedback is welcome. Note that we are primarily a hardware company and our software support is limited. Please consider reading the paragraph below about the warranty of Olimex products. All goods are checked before they are sent out. In the unlikely event that goods are faulty, they must be returned, to OLIMEX at the address listed on your order invoice. OLIMEX will not accept goods that have clearly been used more than the amount needed to evaluate their functionality. If the goods are found to be in working condition, and the lack of functionality is a result of lack of knowledge on the customers part, no refund will be made, but the goods will be returned to the user at their expense. All returns must be authorized by an RMA Number. Email support@olimex.com for authorization number before shipping back any merchandise. Please include your name, phone number and order number in your email request. Returns for any unaffected development board, programmer, tools, and cables permitted within 7 days from the date of receipt of merchandise. After such time, all sales are considered final. Returns of incorrect ordered items are allowed subject to a 10% restocking fee. What is unaffected? If you hooked it to power, you affected it. To be clear, this includes items that have been soldered to, or have had their firmware changed. Because of the nature of the products we deal with (prototyping electronic tools) we cannot allow returns of items that have been programmed, powered up, or otherwise changed post shipment from our warehouse. All returned merchandise must be in its original mint and clean condition. Returns on damaged, scratched, programmed, burnt, or otherwise 'played with' merchandise will not be accepted. All returns must include all the factory accessories which come with the item. This includes any InCircuit-Serial-Programming cables, anti-static packing, boxes, etc. With your return, enclose your PO#. Also include a brief letter of explanation of why the merchandise is being returned and state your request for either a refund or an exchange. Include the authorization number on this letter, and on the outside of the shipping box. Please note: It is your responsibility to ensure that returned goods reach us. Please use a reliable form of shipping. If we do not receive your package we will not be held liable. Shipping and handling charges are not refundable. We are not responsible for any shipping charges of merchandise being returned to us or returning working items to you. The full text might be found at https://www.olimex.com/wiki/GTC#Warranty for future reference. Page 23 of 23
STM32-P107 价格&库存
很抱歉,暂时无法提供与“STM32-P107”相匹配的价格&库存,您可以联系我们找货
