DFR0004
DFR0004
    DFROBOT
    ROMEOARDUINOBOARDW/MTRDRVR
DFR0004 数据手册
    DFRduino Romeo‐All in one Controller V1.1(SKU:DFR0004)   DFRduino RoMeo V1.1 Contents        1 Introduction 2 Specification 3 DFRduino RoMeo Pinout 4 Before you start 4.1 Applying Power 4.2 Software 5 Romeo Configuration 5.1 Servo Power Select Jumper 5.2 Motor Control Pin Jumper 6 Tutorial 6.1 Button Press 6.2 Example use of Button 1-5 7 Dual DC Motor Speed Control 7.1 Hardware Setting 7.2 Pin Allocation 7.3 PWM Control Mode 7.4 PLL Control Mode Introduction RoMeo is an All-in-One microcontroller especially designed for robotics application. Benefit from Arduino open source platform, it is supported by thousands of open source codes, and can be easily expanded with most Arduino Shields. The integrated 2 way DC motor driver and wireless socket gives a much easier way to start your robotic project. Note: A. Please read this manual carefully before applying power on the device. B. Do not use this device for military or medical purpose as they are not des igned to. Specification                  Atmega 168/328 14 Channels Digital I/O 6 PWM Channels (Pin11,Pin10,Pin9,Pin6,Pin5,Pin3) 8 Channels 10-bit Analog I/O USB interface Auto sensing/switching power input ICSP header for direct program download Serial Interface TTL Level Support AREF Support Male and Female Pin Header Integrated sockets for APC220 RF Module and DF-Bluetooth Module Five I2C Interface Pin Sets Two way Motor Drive with 2A maximum current 5 key inputs DC Supply:USB Powered or External 7V~12V DC。 DC Output:5V /3.3V DC and External Power Output Dimension:90x80mm DFRduino RoMeo Pinout Fig1: Romeo Pin Out The picture above shows all of the I/O lines and Connectors on the Romeo, which includes:           One Regulated Motor Power Input Terminal (6v to12v) One Unregulated Servo Power Input Terminal (you supply regulated 4v to 7.2v) One Servo input power selection jumper One Serial Interface Module Header for APC220/Bluetooth Module Two DC Motor Terminals – Handles motor current draw up to 2A, each terminal One I2C/TWI Port – SDA, SCL, 5V, GND One Analog Port with 8 analog inputs – Analog input 7 will be occupied when connecting "A7" jumper One General Purpose I/O Port with 13 I/O lines – 4,5,6,7 can be used to control motors One Reset Button Jumper bank to Enable/Disable Motor Control Before you start Applying Power This is one of the most important steps in getting the Romeo up and communicating with your host controller. You MUST make sure that you apply power to the Power Terminal using the correct polarity. Reverse Polarity will damage the Romeo. We are not responsible for such damage, nor do we warranty against such damage. Make sure you take time to apply power correctly. Otherwise, it could get costly for you! Power from USB: Simply plug USB cable, and the Romeo is able to work. Please notice that the USB can only supply 500 mA current. It should be able to meet the most requirements for LED lit application. However it is not enough to power DC motors or servo. Power from Motor Power Input: Simply connect the ground wire from your supply to the screw terminal labeled “GND”, and then connect the positive wire from your supply to the screw terminal labeled “VIN". NOTE: Maximum supply voltage cannot exceed 14V DC. Software RoMeo can be programmed by Arduino IDE 0022 and above. It can be downloaded at Arduino.cc, Please select “Arduino UNO” as the hardware. Romeo Configuration Servo Power Select Jumper As most servos draw more current than the USB power source can supply. A separate servo power terminal is provided to power the servo individually. This option can be Enabled/Disabled by the Servo Power Select Jumper. When the Servo Power Select Jumper is applied, the servo is powered by internal 5V. When the Servo Power Select Jumper is not applied, the servo is powered by external power source. The Romeo V1.0 uses an automatic switcher for the power source selection. When the external power source has been applied, the servo will be automatically powered by the external power instead of USB power. Motor Control Pin Jumper Applying the Motor Control Pin Jumpers will allocate Pin 5,6,7,8 for motor control. Removing the jumpers will release the above Pins, and the motor controller will be disabled. Tutorial Button Press RoMeo has 5 build in buttons S1-S5 (Figure 2). S1-S5 use analog input 7, "Button Pin Map" Pin Function Analog Pin 7 Fig2: Romeo Buttons Example use of Button 1‐5 char msgs[5][15] = { "Right Key OK ", "Up Key OK ", "Down Key OK ", "Left Key OK ", "Select Key OK" }; Button S1-S5 char start_msg[15] = { "Start loop "}; int adc_key_val[5] ={ 30, 150, 360, 535, 760 }; int NUM_KEYS = 5; int adc_key_in; int key=-1; int oldkey=-1; void setup() { pinMode(13, OUTPUT); //we'll use the debug LED to output a heartbeat Serial.begin(9600); /* Print that we made it here */ Serial.println(start_msg); } void loop() { adc_key_in = analogRead(7); // read the value from the sensor digitalWrite(13, HIGH); /* get the key */ key = get_key(adc_key_in); if (key != oldkey) { delay(50); // convert into key press // if keypress is detected // wait for debounce time adc_key_in = analogRead(7); key = get_key(adc_key_in); // read the value from the sensor // convert into key press if (key != oldkey) { oldkey = key; if (key >=0){ Serial.println(adc_key_in, DEC); Serial.println(msgs[key]); } } } digitalWrite(13, LOW); } // Convert ADC value to key number int get_key(unsigned int input) { int k; for (k = 0; k < NUM_KEYS; k++) { if (input < adc_key_val[k]) { return k; } } if (k >= NUM_KEYS) k = -1; // No valid key pressed return k; }   Dual DC Motor Speed Control Hardware Setting Connect four motor wires to Motor Terminal. And apply power through motor power terminal (Figure 4). Fig3: Romeo Motor Connection Diagram Pin Allocation "PWM Mode" Pin Function Digital 4 Motor 1 Direction control Digital 5 Motor 1 PWM control Digital 6 Motor 2 PWM control Digital 7 Motor 2 Direction control "PLL Mode" Pin Function Digital 4 Motor 1 Enable control Digital 5 Motor 1 Direction control Digital 6 Motor 2 Direction control Digital 7 Motor 2 Enable control PWM Control Mode Fig4: PWM Motor Control Pin Allocation The PWM DC motor control is implemented by manipulating two digital IO pins and two PWM pins. As illustrated in the diagram above (Figure 5), Pin 4,7 (7,8 for old Romeo version) are motor direction control pins, Pin 5,6 (6,9 for old Romeo version) are motor speed control pins. For previous Romeo board, the pins used to control the motor is Pin 7,8 (Direction), Pin 6,9 (Speed). You can find the information at the right side of the Motor Control Pin Jumpers. Sample Code: //Standard PWM DC control int E1 = 5; //M1 Speed Control int E2 = 6; //M2 Speed Control int M1 = 4; //M1 Direction Control int M2 = 7; //M1 Direction Control ///For previous Romeo, please use these pins. //int E1 = 6; //M1 Speed Control //int E2 = 9; //M2 Speed Control //int M1 = 7; //M1 Direction Control //int M2 = 8; //M1 Direction Control void stop(void) //Stop { digitalWrite(E1,LOW); digitalWrite(E2,LOW); } void advance(char a,char b) //Move forward { analogWrite (E1,a); //PWM Speed Control digitalWrite(M1,HIGH); analogWrite (E2,b); digitalWrite(M2,HIGH); } void back_off (char a,char b) //Move backward { analogWrite (E1,a); digitalWrite(M1,LOW); analogWrite (E2,b); digitalWrite(M2,LOW); } void turn_L (char a,char b) //Turn Left { analogWrite (E1,a); digitalWrite(M1,LOW); analogWrite (E2,b); digitalWrite(M2,HIGH); } void turn_R (char a,char b) //Turn Right { analogWrite (E1,a); digitalWrite(M1,HIGH); analogWrite (E2,b); digitalWrite(M2,LOW); } void setup(void) { int i; for(i=4;i
DFR0004 价格&库存
很抱歉,暂时无法提供与“DFR0004”相匹配的价格&库存,您可以联系我们找货
