EA-OEM-509
EA-OEM-509
    EMBEDDEDARTISTS
    KIT DEV LPC1788-32
EA-OEM-509 数据手册
Embedded Artists’ LPC1788 OEM Board DS rev E DS The Art of Embedded Systems Development – made Easy™ Document status: Preliminary LPC1788-32 OEM Board Feature Highlights The LPC1788-32 OEM Board provides a quick and easy solution for implementing a high-performance ARM Cortex-M3 based design around the LPC1788 from NXP.  Build around NXP's ARM Cortex-M3 LPC1788 microcontroller with 512Kbyte internal FLASH and 96Kbyte internal SRAM  32MByte external SDRAM, via 32-bit databus  128 Mbyte NAND FLASH  100/10Mbps Ethernet interface based on SMSC LAN8720  12.000 MHz and 32.768 kHz crystals for LPC1788  32Kbyte I2C E2PROM for storing non-volatile parameters  Buffered 32-bit data bus  +3.3V powering  200 pos expansion connector (as defined in popular SO-DIMM industry standard), 0.6mm pitch  Compact design with dimensions: 68 x 50 mm Support Highlights     Access to Embedded Artists support page containing o Schematics o User’s Manual o Sample software applications o OEM Board Integration Guide Supported by Developer’s Kit, see picture to right Volume discount available Customization service available for optimized high-volume design Block Diagram of LPC1788-32 OEM Board 12MHz crystal 32-bit SDRAM LPC1788 Parallel NAND 32.768kHz crystal EthernetPHY I2CE2PROM Buffers ETH, USB, I2C, GPIO, Buffered memory bus, power, etc. NXP Partner Embedded Artists is a partner of NXP. Together we give engineers an excellent base to work from when creating advanced embedded systems. We have a close co-operation and know everything there is to know about the NXP processors. Take advantage of our unique knowledge! For further information, please contact: support@EmbeddedArtists.com Embedded Artists AB Jörgen Ankersgatan 12 SE-211 45 Malmö Sweden Phone/Fax: +46 (0)40-611 00 93 http://www.embeddedartists.com © Copyright 2018 Embedded Artists AB. All rights reserved. All other products or service names mentioned herein are trademarks of their respective holders and should be treated as such. Privacy policy: http://www.embeddedartists.com/privacy.php Legal: http://www.embeddedartists.com/legal.php Embedded Artists’ LPC1788 OEM Board DS rev E DS The Art of Embedded Systems Development – made Easy™ Document status: Preliminary Absolute Maximum Ratings Parameter Rating VDD to GND (Supply voltage) General for Digital/Analog Input/Output Voltage +5V tolerant pins on LPC1788 Storage temperature -0.5V to +3.6V -0.5V to VDD+0.5V -0.5V to +6.0V (see LPC1788 DS for details) -40°C to 100°C Stress above these limits may cause permanent damage to the board. Technical Data Parameter Supply voltage (VDD to GND) Ripple with frequency contents < 100kHz Ripple with frequency contents ≥ 100kHz Supply current - idle, 32kHz RTC active - low-power mode - executing from internal flash (100MHz) - executing from external sdram (100MHz) - Ethernet+usb active VBAT current Operating temperature[1] Relative Humidity (RH) 0°C < TA ≤ 50°C, non-condensing 50°C < TA ≤ 60°C, non-condensing 60°C < TA ≤ 70°C, non-condensing [1] [2] Min Typical Max 3.15V 3.30V 3.50V 40mV 10mV Max observed TBD[2] TBD[2] TBD[2] TBD[2] TBD[2] TBD[2] -40 ºC +85 ºC 5% 5% 5% 80% 50% 35% Extended temperature range applied on LPC1788 OEM board rev E and later. Will be defined after a characterization process. Mechanical Dimensions Board width according to SO-DIMM standard: 67.6 mm. Board height and depth according to picture below: 2.0 mm Top side components 5.0 mm Bottom side components 2.0 mm 49.5 mm ESD CAUTION ESD (electrostatic discharge) sensitive device. Charged devices and circuit boards can discharge without detection. Although this product features ESD protection damages may occur on devices subjected to high energy ESD. Therefore, proper ESD precaution should be taken to avoid performance degradation or loss of functionality. Embedded Artists AB Jörgen Ankersgatan 12 SE-211 45 Malmö Sweden Phone/Fax: +46 (0)40-611 00 93 http://www.embeddedartists.com © Copyright 2018 Embedded Artists AB. All rights reserved. All other products or service names mentioned herein are trademarks of their respective holders and should be treated as such. Privacy policy: http://www.embeddedartists.com/privacy.php Legal: http://www.embeddedartists.com/legal.php Embedded Artists’ LPC1788 OEM Board DS rev E DS The Art of Embedded Systems Development – made Easy™ Document status: Preliminary Pin Information SODIMM pins 1 2 3 4 5 6 7 8 9 10 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 I/O, Application Details Connected to A, Ethernet TXP A, Ethernet RXP A, Ethernet TXN A, Ethernet RXP P, VDD3_3A P, GND OD, ETH-LED1 OD, ETH-LED2 P, VBAT-IN O, RTC-ALARM I, RESET-IN O, RESET-OUT NC B, GPIO O, TCK/SWDCLK B, GPIO I, TRST B, TMS/SWDIO I, TDI O, TDO/SWO P, V3A P, VREF P, VSSA P, GND B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO P, VCC P, GND P, VCC P, GND A, USB1-DP A, USB2-DP A, USB1-DM A, USB2-DM B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO Ethernet-PHY Ethernet-PHY Ethernet-PHY Ethernet-PHY Embedded Artists AB Jörgen Ankersgatan 12 SE-211 45 Malmö Sweden Ethernet-PHY Ethernet-PHY LPC1788, vbat LPC1788, rtc-alarm LPC1788, rst-in LPC1788, rst-out LPC1788, P5.0 SPIFI CS control LPC1788, tck/swdclk LPC1788, P5.4 LPC1788, trst LPC1788, tms/swdio LPC1788, tdi LPC1788, tdo/swo LPC1788, v3a LPC1788, vref LPC1788, vssa LPC1788, P2.0 LPC1788, P2.1 LPC1788, P2.2 LPC1788, P2.3 LPC1788, P2.4 LPC1788, P2.5 LPC1788, P2.6 LPC1788, P2.7 LPC1788, P2.8 LPC1788, P2.9 LPC1788, P2.10 LPC1788, P2.11 LPC1788, USB-D+1 LPC1788, USB-D+2 LPC1788, USB-D-1 LPC1788, USB-D-2 LPC1788, P2.12 LPC1788, P2.13 LPC1788, P0.0 LPC1788, P0.1 LPC1788, P0.2 LPC1788, P0.3 LPC1788, P0.4 LPC1788, P0.5 LPC1788, P0.6 Phone/Fax: +46 (0)40-611 00 93 http://www.embeddedartists.com SODIMM pins 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 I/O, Application Details P, GND P, GND NC NC NC NC B, GPIO B, GPIO B, GPIO NC B, GPIO NC O, Buffered CS1 (internal NAND) B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO NC NC NC NC P, GND P, GND O, Buffered Address bus 15 O, Buffered CS2 O, Buffered Address bus 14 O, Buffered CS0 O, Buffered Address bus 13 O, Buffered BLS3 O, Buffered Address bus 12 O, Buffered BLS2 O, Buffered Address bus 11 O, Buffered BLS1 O, Buffered Address bus 10 O, Buffered BLS0 O, Buffered Address bus 9 O, Buffered WE O, Buffered Address bus 8 O, Buffered OE O, Buffer Address bus 7 O, Buffer Address bus 23 O, Buffer Address bus 6 O, Buffer Address bus 22 O, Buffer Address bus 5 O, Buffer Address bus 21 O, Buffer Address bus 4 Connected to LPC1788, P5.4 LPC1788, P5.3 LPC1788, P5.2 LPC1788, P1.16 LPC1788, P4.31 via buffer LPC1788, P4.30 LPC1788, P1.16 LPC1788, P2.14 LPC1788, P2.15 LPC1788, P2.19 LPC1788, P2.21 LPC1788, P2.22 LPC1788, P2.23 LPC1788, P2.25 LPC1788, P2.26 LPC1788, P2.27 LPC1788, P4.15 via buffer LPC1788, P2.14 via buffer LPC1788, P4.14 via buffer LPC1788, P4.30 via buffer LPC1788, P4.13 via buffer LPC1788, P4.29 via buffer LPC1788, P4.12 via buffer LPC1788, P4.28 via buffer LPC1788, P4.11 via buffer LPC1788, P4.27 via buffer LPC1788, P4.10 via buffer LPC1788, P4.26 via buffer LPC1788, P4.9 via buffer LPC1788, P4.25 via buffer LPC1788, P4.8 via buffer LPC1788, P4.24 via buffer LPC1788, P4.7 via buffer LPC1788, P4.23 via buffer LPC1788, P4.6 via buffer LPC1788, P4.22 via buffer LPC1788, P4.5 via buffer LPC1788, P4.21 via buffer LPC1788, P4.4 via buffer © Copyright 2018 Embedded Artists AB. All rights reserved. All other products or service names mentioned herein are trademarks of their respective holders and should be treated as such. Privacy policy: http://www.embeddedartists.com/privacy.php Legal: http://www.embeddedartists.com/legal.php Embedded Artists’ LPC1788 OEM Board DS rev E DS The Art of Embedded Systems Development – made Easy™ 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, I2C-SDA B, I2C-SCL P, GND P, GND B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO B, GPIO OD, NandFlashRdy LPC1788, P0.7 LPC1788, P0.8 LPC1788, P0.9 LPC1788, P0.10 LPC1788, P0.11 LPC1788, P0.12 LPC1788, P0.13 LPC1788, P0.14 LPC1788, P0.15 LPC1788, P0.16 LPC1788, P0.17 LPC1788, P0.18 LPC1788, P0.19 LPC1788, P0.20 LPC1788, P0.21 LPC1788, P0.22 LPC1788, P0.23 LPC1788, P0.24 LPC1788, P0.25 LPC1788, P0.26 LPC1788, P0.27 LPC1788, P0.28 LPC1788, P1.2 LPC1788, P1.3 LPC1788, P1.5 LPC1788, P1.6 LPC1788, P1.7 LPC1788, P1.11 LPC1788, P1.12 LPC1788, P1.13 LPC1788, P1.18 LPC1788, P1.19 LPC1788, P1.20 LPC1788, P1.21 LPC1788, P1.22 LPC1788, P1.23 LPC1788, P1.24 LPC1788, P1.25 LPC1788, P1.26 LPC1788, P1.27 LPC1788, P1.28 LPC1788, P1.29 LPC1788, P1.30 LPC1788, P1.31 Internal NAND flash I/O legend O: output I: input B: Bidirectional P: Power A: Analog Embedded Artists AB Jörgen Ankersgatan 12 SE-211 45 Malmö Sweden Document status: Preliminary 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 O, Buffer Address bus 20 O, Buffer Address bus 3 O, Buffer Address bus 19 O, Buffer Address bus 2 O, Buffer Address bus 18 O, Buffer Address bus 1 O, Buffer Address bus 17 O, Buffer Address bus 0 O, Buffer Address bus 16 O, Buffered CS3 I, ABUF_EN P, Buffer-VCC P, GND B, Buffer Data bus 15 B, Buffer Data bus 31 B, Buffer Data bus 14 B, Buffer Data bus 30 B, Buffer Data bus 13 B, Buffer Data bus 29 B, Buffer Data bus 12 B, Buffer Data bus 28 B, Buffer Data bus 11 B, Buffer Data bus 27 B, Buffer Data bus 10 B, Buffer Data bus 26 B, Buffer Data bus 9 B, Buffer Data bus 25 B, Buffer Data bus 8 B, Buffer Data bus 24 B, Buffer Data bus 7 B, Buffer Data bus 23 B, Buffer Data bus 6 B, Buffer Data bus 22 B, Buffer Data bus 5 B, Buffer Data bus 21 B, Buffer Data bus 4 B, Buffer Data bus 20 B, Buffer Data bus 3 B, Buffer Data bus 19 B, Buffer Data bus 2 B, Buffer Data bus 18 B, Buffer Data bus 1 B, Buffer Data bus 17 B, Buffer Data bus 0 B, Buffer Data bus 16 P, Buffer-VCC P, GND LPC1788, P4.20 via buffer LPC1788, P4.3 via buffer LPC1788, P4.19 via buffer LPC1788, P4.2 via buffer LPC1788, P4.18 via buffer LPC1788, P4.1 via buffer LPC1788, P4.17 via buffer LPC1788, P4.0 via buffer LPC1788, P4.16 via buffer LPC1788, P2.15 via buffer Connected to GND on board LPC1788, P3.15 via buffer LPC1788, P3.31 via buffer LPC1788, P3.14 via buffer LPC1788, P3.30 via buffer LPC1788, P3.13 via buffer LPC1788, P3.29 via buffer LPC1788, P3.12 via buffer LPC1788, P3.28 via buffer LPC1788, P3.11 via buffer LPC1788, P3.27 via buffer LPC1788, P3.10 via buffer LPC1788, P3.26 via buffer LPC1788, P3.9 via buffer LPC1788, P3.25 via buffer LPC1788, P3.8 via buffer LPC1788, P3.24 via buffer LPC1788, P3.7 via buffer LPC1788, P3.23 via buffer LPC1788, P3.6 via buffer LPC1788, P3.22 via buffer LPC1788, P3.5 via buffer LPC1788, P3.21 via buffer LPC1788, P3.4 via buffer LPC1788, P3.20 via buffer LPC1788, P3.3 via buffer LPC1788, P3.19 via buffer LPC1788, P3.2 via buffer LPC1788, P3.18 via buffer LPC1788, P3.1 via buffer LPC1788, P3.17 via buffer LPC1788, P3.0 via buffer LPC1788, P3.16 via buffer OD: Open-drain output GPIO: General purpose I/O GPI: General purpose input GPO: General purpose output Phone/Fax: +46 (0)40-611 00 93 http://www.embeddedartists.com © Copyright 2018 Embedded Artists AB. All rights reserved. All other products or service names mentioned herein are trademarks of their respective holders and should be treated as such. Privacy policy: http://www.embeddedartists.com/privacy.php Legal: http://www.embeddedartists.com/legal.php Embedded Artists’ LPC1788 OEM Board DS rev E DS The Art of Embedded Systems Development – made Easy™ Document status: Preliminary Disclaimers Embedded Artists reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Customer is responsible for the design and operation of their applications and products using Embedded Artists’ products, and Embedded Artists accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Embedded Artists’ product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Embedded Artists does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Embedded Artists’ products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Embedded Artists does not accept any liability in this respect. Embedded Artists does not accept any liability for erratas on individual components. All Embedded Artists’ products are sold pursuant to Embedded Artists’ terms and conditions of sale: http://www.embeddedartists.com/sites/default/files/docs/General_Terms_and_Conditions.pdf No license, express or implied, by estoppel or otherwise, to any intellectual property rights is granted under this document. If any part of this document refers to any third party products or services it shall not be deemed a license grant by Embedded Artists for the use of such third party products or services, or any intellectual property contained therein or considered as a warranty covering the use in any manner whatsoever of such third party products or services or any intellectual property contained therein. UNLESS OTHERWISE SET FORTH IN EMBEDDED ARTISTS’ TERMS AND CONDITIONS OF SALE EMBEDDED ARTISTS DISCLAIMS ANY EXPRESS OR IMPLIED WARRANTY WITH RESPECT TO THE USE AND/OR SALE OF EMBEDDED ARTISTS PRODUCTS INCLUDING WITHOUT LIMITATION IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE (AND THEIR EQUIVALENTS UNDER THE LAWS OF ANY JURISDICTION), OR INFRINGEMENT OF ANY PATENT, COPYRIGHT OR OTHER INTELLECTUAL PROPERTY RIGHT. UNLESS EXPRESSLY APPROVED IN WRITING BY THE CEO OF EMBEDDED ARTISTS, PRODUCTS ARE NOT RECOMMENDED, AUTHORIZED OR WARRANTED FOR USE IN MILITARY, AIR CRAFT, SPACE, NUCLEAR, LIFE SAVING, OR LIFE SUSTAINING APPLICATIONS, NOR IN PRODUCTS OR SYSTEMS WHERE FAILURE OR MALFUNCTION MAY RESULT IN PERSONAL INJURY, DEATH, OR SEVERE PROPERTY OR ENVIRONMENTAL DAMAGE. Resale of Embedded Artists’ products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by Embedded Artists for the Embedded Artists’ product or service described herein and shall not create or extend in any manner whatsoever, any liability of Embedded Artists. This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Definition of Document Status Preliminary – The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Embedded Artists does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. The document is in this state until the product has passed Embedded Artists product qualification tests. Approved – The information and data provided define the specification of the product as agreed between Embedded Artists and its customer, unless Embedded Artists and customer have explicitly agreed otherwise in writing. Embedded Artists AB Jörgen Ankersgatan 12 SE-211 45 Malmö Sweden Phone/Fax: +46 (0)40-611 00 93 http://www.embeddedartists.com © Copyright 2018 Embedded Artists AB. All rights reserved. All other products or service names mentioned herein are trademarks of their respective holders and should be treated as such. Privacy policy: http://www.embeddedartists.com/privacy.php Legal: http://www.embeddedartists.com/legal.php
EA-OEM-509 价格&库存
很抱歉,暂时无法提供与“EA-OEM-509”相匹配的价格&库存,您可以联系我们找货
