AVR-CAN
AVR-CAN
    OLIMEX
    AT90CAN128 RS232CAN BRIDGE
AVR-CAN 数据手册
AVR-CAN development board Users Manual Rev.A, January 2010 Copyright(c) 2011, OLIMEX Ltd, All rights reserved Page 1 INTRODUCTION: AVR-CAN is inexpensive way to learn AT90CAN128 microcontroller from Atmel. It's in very compact form 60x55mm and the presence of both CAN and RS232 allows the customer to make a bridge between UART and CAN networks. All AVR pins are available on extension connectors and the board can be easily a snap-on prototype or other mother board where additional circuits are built. BOARD FEATURES: − − − − − − − − − − − − − − − MCU: AT90CAN128 – 128Kb Flash, 4Kb EEPROM, 4Kb SRAM, 52 GPIO, 32 working registers, a CAN controller, Real Time Clock, four Timer/Counters with PWM, 2 UARTs, Two-wire Serial Interface, an 8-channel 10-bit ADC, Watchdog Timer, SPI serial port, JTAG interface, five selectable power saving modes 5x2 pin JTAG connector for programming and debugging with AVR-JTAG-L or AVR-JTAG-USB RS232 DB9 female connector and driver CAN controller and interface User button Status LED 16 MHz oscillator circuit 32768 Hz oscillator circuit Reset button and circuit On board voltage regulator (+5V) Power supply LED Power supply connector Extension pin headers for every uC pin FR-4, 1.5 mm (0.062''), soldermask, white silkscreen component print Dimension 60x50 mm (2.36x1.96'') ELECTROSTATIC WARNING: The AVR-CAN board is shipped in protective anti-static packaging. The board must not be subject to high electrostatic potentials. General practice for working with static sensitive devices should be applied when working with this board. BOARD USE REQUIREMENTS: Cables: RS232 cable in case you want to use the RS232 and/or CAN interface. You might need other cables depending on the programming/debugging tool you use. Hardware: Programmer/Debugger – AVR-JTAG-L or AVR-JTAG-USB or other compatible programming/debugging tool. AVR Studio 4.13 (or later) + WinAVR (latest version) or IAR AVR. AVR Studio and WinAVR are free to download and use. Take a note that AVR Studio 4.13 has a bug and doesn't read the fuses correctly. On our request to Atmel support they had confirmed the bug and Software: Page 2 had suggested to fix the bug by “AVR Studio 4.13 SP2 JTAGICE Fix” available from http://www.atmel.no/beta_ware/ PROCESSOR FEATURES: AVR-CAN board use MCU AT90CAN128 from Atmel with these features:  High-performance, Low-power AVR® 8-bit Microcontroller  Advanced RISC Architecture - 133 Powerful Instructions – Most Single Clock Cycle Execution - 32 x 8 General Purpose Working Registers + Peripheral Control Registers - Fully Static Operation - Up to 16 MIPS Throughput at 16 MHz - On-chip 2-cycle Multiplier  Non volatile Program and Data Memories - 128K Bytes of In-System Reprogrammable Flash o Endurance: 10,000 Write/Erase Cycles - Optional Boot Code Section with Independent Lock Bits o Selectable Boot Size: 1K Bytes, 2K Bytes, 4K Bytes or 8K Bytes o In-System Programming by On-Chip Boot Program (CAN, UART, ...) o True Read-While-Write Operation - 4K Bytes EEPROM (Endurance: 100,000 Write/Erase Cycles) - 4K Bytes Internal SRAM (AT90CAN32/64/128) - Up to 64K Bytes Optional External Memory Space - Programming Lock for Software Security  JTAG (IEEE std. 1149.1 Compliant) Interface - Boundary-scan Capabilities According to the JTAG Standard - Programming Flash (Hardware ISP), EEPROM, Lock & Fuse Bits - Extensive On-chip Debug Support  CAN Controller 2.0A & 2.0B - ISO 16845 Certified - 15 Full Message Objects with Separate Identifier Tags and Masks - Transmit, Receive, Automatic Reply and Frame Buffer Receive Modes - 1Mbits/s Maximum Transfer Rate at 8 MHz - Time stamping, TTC & Listening Mode (Spying or Autobaud)  Peripheral Features - Programmable Watchdog Timer with On-chip Oscillator - 8-bit Synchronous Timer/Counter-0 o 10-bit Prescaler o External Event Counter o Output Compare or 8-bit PWM Output - 8-bit Asynchronous Timer/Counter-2 o 10-bit Prescaler o External Event Counter o Output Compare or 8-Bit PWM Output o 32Khz Oscillator for RTC Operation - Dual 16-bit Synchronous Timer/Counters-1 & 3 o 10-bit Prescaler o Input Capture with Noise Canceler o External Event Counter o 3-Output Compare or 16-Bit PWM Output Page 3 o Output Compare Modulation 8-channel, 10-bit SAR ADC o 8 Single-ended Channels o 7 Differential Channels o 2 Differential Channels With Programmable Gain at 1x, 10x, or 200x - On-chip Analog Comparator - Byte-oriented Two-wire Serial Interface - Dual Programmable Serial USART - Master/Slave SPI Serial Interface o Programming Flash (Hardware ISP) Special Microcontroller Features - Power-on Reset and Programmable Brown-out Detection - Internal Calibrated RC Oscillator - 8 External Interrupt Sources - 5 Sleep Modes: Idle, ADC Noise Reduction, Power-save, Power-down & Standby - Software Selectable Clock Frequency - Global Pull-up Disable I/O and Packages - 53 Programmable I/O Lines - 64-lead TQFP and 64-lead QFN Operating Voltages: 2.7 - 5.5V Operating temperature: Industrial (-40°C to +85°C) Maximum Frequency: 8 MHz at 2.7V, 16 MHz at 4.5V -      Page 4 BLOCK DIAGRAM: MEMORY MAP: Page 5 Page 6 20pF C4 Page 7 C5 AVCC ADC0/PF0 ADC1/PF1 ADC2/PF2 ADC3/PF3 ADC4/TCK/PF4 ADC5/TMS/PF5 ADC6/TDO/PF6 ADC7/TDI/PF7 AT90CAN128 AGND NA 1 AVREF 62 AVREF AVREF_E 63 2 64 61 60 59 58 57 56 55 54 G ND PG2/ALE PG1/#RD PG0/#WR NC PB7/OC0A/OC1C PB6/OC1B PB5/OC1A PB4/OC2A PB3/MISO PB2/MOSI PB1/SCK PB0/#SS 43 34 33 1 17 16 15 14 13 12 11 10 35 36 37 38 39 40 41 42 51 50 49 48 47 46 45 44 EXT1-32 EXT1-33 EXT1-34 EXT2-27 EXT2-28 EXT2-29 EXT2-30 EXT2-31 EXT2-32 EXT2-33 EXT2-34 EXT2-18 EXT2-17 EXT2-16 EXT2-15 EXT2-14 EXT2-13 EXT2-12 EXT2-11 EXT1-24 EXT1-25 EXT1-26 EXT1-27 EXT1-28 EXT1-29 EXT1-30 EXT1-31 16 VCC R1OUT R2OUT T1IN T2IN 100n +5V AGND VDDA TXD1_OUT RXD1_IN AVREF VIN SCL SDA 330 RXD0 RXD1 NA C9 LED IN OUT BUT R2 10K +5V +5V R6 2 4 6 8 10 JTAG 2 VCC GND http://www.olimex.com/dev RST RESET 1 U2 10K MCP120-T(NA) +5V RESET 0 COPYRIGHT(C) 2010, OLIMEX Ltd. Rev. A L1 C18 1 3 5 7 9 RESET +5V TDI TCK TDO TMS NA C8 R15 560 PWR_LED +5V ferrite_bead0805 R7 AGND 100n +5V C16 VDDA C15 R9 330/1% STAT R1 560 +5V +5V R49 220/1% R8 330/1% ADJ/GND AVR-CAN 560 R3 R4 4.7k +5V BUT R5 4.7k +5V EXT2-1 EXT2-2 EXT2-3 EXT2-4 EXT2-5 EXT2-6 EXT2-7 EXT2-8 EXT2-9 EXT2-10 EXT1-1 EXT1-2 EXT1-3 EXT1-4 EXT1-5 EXT1-6 +5V 12 9 R17 11 10 TXD0 TXD1 100n 5 4 C14 3 PWR CON2PV2-2.54MM C41 100n U4PWR 15GND R1IN R2IN T1OUT T2OUT C2- C2+ C1- VIN 3 AGND 100nF VDDA CAN_D TCK TMS TDO TDI TD1 RD1 SCL/INT0/PD0 SDA/INT1/PD1 RXD1/INT2/PD2 TXD1/INT3/PD3 ICP1/PD4 TXCAN/XCK1/PD5 RXCAN/T1/PD6 T0/PD7 PC0/A8 PC1/A9 PC2/A10 PC3/A11 PC4/A12 PC5/A13 PC6/A14 PC7/A15/CLK0 PA0/AD0 PA1/AD1 PA2/AD2 PA3/AD3 PA4/AD4 PA5/AD5 PA6/AD6 PA7/AD7 TXD1_OUT RXD1_IN RS232 13 8 14 7 +5V EXT1-16 EXT1-17 EXT1-18 EXT1-19 EXT1-20 EXT1-21 EXT1-22 EXT1-23 25 26 27 28 29 30 31 32 SCL SDA RXD1 TXD1 LED BUT RXD0/PDI/PE0 TXD0/PDO/PE1 XCK0/AIN0/PE2 OC3A/AIN1/PE3 OC3B/INT4/PE4 OC3C/INT5/PE5 T3/INT6/PE6 ICP3/INT7/PE7 TOSC1/PG4 TOSC2/PG3 XTAL1 XTAL2 6 7 8 9 1 2 3 4 5 V- V+ 2 1 EXT2-26 EXT2-25 EXT2-24 EXT2-23 EXT2-22 EXT2-21 EXT2-20 EXT2-19 EXT1-15 EXT1-14 EXT1-13 EXT1-12 EXT1-11 EXT1-10 EXT1-9 EXT1-8 2 3 4 5 6 7 8 9 19 18 RXD0 TXD0 Q2 32768/6pF 1 GND 20pF C3 24 23 100nF C10 NC R14 6 1 C13 220uF/25V C17 20pF V CC 21 52 #RESET U1 +5V C6 100n C7 100n 1 TD1 2 3 4 RD1 +5V C11 100n C12 100n C1+ 47uF/6.3VDC C2 20 TXD VSS VDD RXD MCP2551(SO-8) RS CANH CANL VREF CAN_D 2 VR1(5V) LM1117 100nF Q1 16MHz 2 RESET R10 120 8 7 6 5 2 CAN_D 1 U3 NA R12 10K NC CAN_T 0 CAN 5 4 3 2 1 R11 0 U4 MAX232(5V) + EXT1-7 C1 20pF 9 8 7 6 R16 0 VIN SCHEMATIC: R13 53 22 BOARD LAYOUT: POWER SUPPLY CIRCUIT: Power should be applied to CON2PV2-2.5MM connector. AVR-CAN could be powered by applying up to 12VDC (7 to 12 VDC) to EXT1-1 and EXT1-2 and GND to EXT1-3 and EXT1-4 or if you supply 7 to 12 VDC to CON2PV2-2.5MM pin 2 (VIN) and GND to CON2PV2-2.5MM pin 1 . The consumption of AVR-CAN is about 40-50 mA. RESET CIRCUIT: AVR-CAN reset circuit is made with R6 (10k) pull-up and button RST. On the board there is a place for the voltage supervisory device MCP120-T, but we sell it without MCP120-T. Page 8 CLOCK CIRCUIT: Quartz crystal 16 MHz is connected to AT90CAN128 pin 24 (XTAL1) and pin 23 (XTAL2). Quartz crystal 32.768 kHz is connected to AT90CAN128 pin 19 (TOSC1/PG4) and pin 18 (TOSC2/PG3) and supplies the internal Asynchronous Timer/Counter (Timer/Counter2 in asynchronous operation). JUMPER DESCRIPTION: CAN_D CAN Disable. If this Default state is open. CAN_T jumper is closed, the CAN is disabled. This jumper assures correct work of the CAN. At each end of the bus it should be closed. This means that if you have only two devices with CAN, the jumpers of both devices should be closed. If you have more than two devices, only the two end-devices should be closed. Default state is closed. AVREF_E This jumper when closed supplies VDDA reference to the AVREF. If this jumper is open the desired reference voltage should be applied at EXT2-3. Default state is open. INPUT/OUTPUT: Status LED (red) with name STAT connected to AT90CAN128 pin 6 (OC3B/INT4/PE4). Power-on LED (red) with name PWR_LED – this LED shows that +5V is applied to the board. User button with name BUT connected to AT90CAN128 pin 7 (OC3C/INT5/PE5). Reset button with name RST connected to AT90CAN128 pin 20 (#RESET). Page 9 EXTERNAL CONNECTORS DESCRIPTION: JTAG: Pin # TDI TDO the TMS TCK Signal Name 1 TCK 2 GND 3 TDO 4 +5V 5 TMS 6 RESET 7 +5V 8 NC 9 TDI 10 GND Input Test Data In. This is the serial data input for the shift register. Output Test Data Out. This is the serial data output for the shift register. Data is shifted out of device on the negative edge of the TCK signal. Input Test Mode Select. The TMS pin selects the next state in the TAP state machine. Input Test Clock. This allows shifting of the data in, on the TMS and TDI pins. It is a positive edge triggered clock with the TMS and TCK signals that define the internal state of the device. JTAG is used to to program and debug the MCU. PWR: Pin # Signal Name 1 GND 2 VIN VIN (Voltage In) – you should supply +7 to + 12 VDC. RS232: Page 10 Pin # Signal Name 1 NC 2 TXD0 3 RXD0 4 NC (not connected through R14 to pin 6) 5 GND 6 NC (not connected through R14 to pin 4) 7 NC (not connected through R13 to pin 8) 8 NC (not connected through R13 to pin 7) 9 NC TXD0 Output Transmit Data. This is the asynchronous serial data output (RS232) for the shift register on the UART controller. RXD0 Input Receive Data. This is the asynchronous serial data input (RS232) for the shift register on the UART controller. Page 11 CAN: Pin # Signal Name 1 NC 2 CANL 3 GND 4 NC 5 NC 6 GND 7 CANH 8 NC 9 VIN CANL and CANH are either deferential input, or differential output depending on the function of the MCP2551 CAN controller (receiving or transmitting data). Page 12 EXT1: Pin # Signal Name Pin # Signal Name 1 VIN 2 VIN 3 GND 4 GND 5 +5V 6 +5V 7 - 8 ICP3/INT7/PE7 9 T3/INT6/PE6 10 OC3C/INT5/PE5 11 OC3B/INT4/PE4 12 OC3A/AIN1/PE3 13 XCK0/AIN0/PE2 14 TXD0/PDO/PE1 15 RXD0/PDI/PE0 16 ADC0/PF0 17 ADC1/PF1 18 ADC2/PF2 19 ADC3/PF3 20 ADC4/TCK/PF4 21 ADC5/TMS/PF5 22 ADC6/TDO/PF6 23 ADC7/TDI/PF7 24 PA0/AD0 25 PA1/AD1 26 PA2/AD2 27 PA3/AD3 28 PA4/AD4 29 PA5/AD5 30 PA6/AD6 31 PA7/AD7 32 PG2/ALE 33 PG1/#RD 34 PG0/#WR EXT2: Page 13 Pin # Signal Name Pin # Signal Name 1 VDDA 2 VDDA 3 AVREF 4 AGND 5 AGND 6 +5V 7 GND 8 GND 9 TXD1_OUT 10 RXD1_IN 11 PC7/A15/CLK0 12 PC6/A14 13 PC5/A13 14 PC4/A12 15 PC3/A11 16 PC2/A10 17 PC1/A9 18 PC0/A8 19 T0/PD7 20 RXCAN/T1/PD6 21 TXCAN/XCK1/P5 22 ICP1/PD4 23 TXD1/INT3/PD3 24 RXD1/INT2/PD2 25 SDA/INT1/PD1 26 SCL/INT0/PD0 27 PB7/OC0A/OC1C 28 PB6/OC1B 29 PB5/OC1A 30 PB4/OC2A 31 PB3/MISO 32 PB2/MOSI 33 PB1/SCK 34 PB0/#SS Page 14 MECHANICAL DIMENSIONS: Page 15 AVAILABLE DEMO SOFTWARE: You could download AVR-CAN software form    www.olimex.com/dev : AVR-CAN Blinking LED demo code (C source and HEX) AVR-CAN Button read demo code (C source and HEX) AVR-CAN RS232 demo code (C source and HEX) ORDER CODE: AVR-CAN – assembled and tested (no kit, no soldering required) How to order? You can order to us directly or by any of our distributors. Check our web www.olimex.com/dev for more info. All boards produced by Olimex are RoHS compliant Revision history: Board - REV.A Users Manual – Rev. A - created - created January 2010 February 2011 – added latest revision of the scheme – changed supply voltage – add page numbers – added more detailed mechanical dimensions Page 16 Disclaimer: © 2011 Olimex Ltd. All rights reserved. Olimex®, logo and combinations thereof, are registered trademarks of Olimex Ltd. Other terms and product names may be trademarks of others. The information in this document is provided in connection with Olimex products. No license, express or implied or otherwise, to any intellectual property right is granted by this document or in connection with the sale of Olimex products. Neither the whole nor any part of the information contained in or the product described in this document may be adapted or reproduced in any material from except with the prior written permission of the copyright holder. The product described in this document is subject to continuous development and improvements. All particulars of the product and its use contained in this document are given by OLIMEX in good faith. However all warranties implied or expressed including but not limited to implied warranties of merchantability or fitness for purpose are excluded. This document is intended only to assist the reader in the use of the product. OLIMEX Ltd. shall not be liable for any loss or damage arising from the use of any information in this document or any error or omission in such information or any incorrect use of the product. Page 17
AVR-CAN 价格&库存
很抱歉,暂时无法提供与“AVR-CAN”相匹配的价格&库存,您可以联系我们找货
