AVR-H128-C
AVR-H128-C
    OLIMEX
    ATMega128 AVR® ATmega MCU 8-Bit AVR Embedded Evaluation Board
AVR-H128-C 数据手册
AVR- H128 development board Users Manual All boards produced by Olimex are ROHS compliant Rev.A, June 2009 Copyright(c) 2009, OLIMEX Ltd, All rights reserved INTRODUCTION AVR-H128 is inexpensive way to develop and prototype circuits with ATMEGA128 microcontroller without need to deal with SMD soldering. All microcontroller pins are available on extension header with 0.1" and power supply, oscillators, ICSP, JTAG are wired, so all you need to do is to connect your additional components to the AVR ports, as the step is 0.1" these headers perfectly fit the prototype sea of pad boards with 0.1" step. BOARD FEATURES – ATMega128-16AU microcontroller with 128 KB Flash, 4KB RAM, 4 KB EEPROM – ICSP 5x2 pin connector for in-circuit programming with AVR-PG1 or AVR-PG2 – JTAG 5x2 pin connector for in-circuit debugging with AVR-JTAG or AVRJTAG-USB – 16MHz scillator circuit – 32768 Hz oscillator circuit – Reset IC ZM33064 – +5V voltage regulator LM78L05 – power supply filtering capacitors – extension pin headers for each uC pin – FR-4, 1.5 mm (0,062"), green soldermask, white silkscreen component print – dimensions 47x47 mm (1.85x1.85") ELECTROSTATIC WARNING The AVR-H128 board is shipped in protective anti-static packaging. The board must not be subject to high electrostatic potentials. General practice for working with static sensitive devices should be applied when working with this board. BOARD USE REQUIREMENTS Cables: The cable you will need depends on the programmer/debugger you use. If you use AVR-JTAG or AVR-PG1 you will need RS232, if you use AVR-USB-JTAG or AVR-ISP500/TINY/ISO you will need 1.8 m A-B USB cable, if you use AVRPG2, you will need LPT cable. Hardware: One of OLIMEX Programmers/Debuggers – AVR-JTAG, AVR-USBJTAG, AVR-ISP500, AVR-ISP500-TINY, AVR-ISP500-ISO, AVR-PG1, AVR-PG2. Software: AVR C compiler. PROCESSOR FEATURES AVR-H128 board use High-performance, Low-power AVR® 8-bit Microcontroller – Atmega128 from Atmel Corporation with these features: – – – – Advanced RISC Architecture – 133 Powerful Instructions – Most Single Clock Cycle Execution – 32 x 8 General Purpose Working Registers + Peripheral Control Registers – Fully Static Operation – Up to 16 MIPS Throughput at 16 MHz – On-chip 2-cycle Multiplier High Endurance Non-volatile Memory segments – 128K Bytes of In-System Self-programmable Flash program memory – 4K Bytes EEPROM – 4K Bytes Internal SRAM – Write/Erase cycles: 10,000 Flash/100,000 EEPROM – Data retention: 20 years at 85°C/100 years at 25°C – Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation – Up to 64K Bytes Optional External Memory Space – Programming Lock for Software Security – SPI Interface for In-System Programming JTAG (IEEE std. 1149.1 Compliant) Interface – Boundary-scan Capabilities According to the JTAG Standard – Extensive On-chip Debug Support – Programming of Flash, EEPROM, Fuses and Lock Bits through the JTAG Interface Peripheral Features – Two 8-bit Timer/Counters with Separate Prescalers and Compare Modes – Two Expanded 16-bit Timer/Counters with Separate Prescaler, Compare Mode and Capture Mode – Real Time Counter with Separate Oscillator – Two 8-bit PWM Channels – 6 PWM Channels with Programmable Resolution from 2 to 16 Bits – Output Compare Modulator – 8-channel, 10-bit ADC – 7 Differential Channels – 8 Single-ended Channels – – – – Byte-oriented Two-wire Serial Interface – Dual Programmable Serial USARTs – Master/Slave SPI Serial Interface – Programmable Watchdog Timer with On-chip Oscillator – On-chip Analog Comparator Special Microcontroller Features – Power-on Reset and Programmable Brown-out Detection – Internal Calibrated RC Oscillator – External and Internal Interrupt Sources – Six Sleep Modes: Idle, ADC Noise Reduction, Power-save, Powerdown, Standby, and Extended Standby – Software Selectable Clock Frequency – ATmega103 Compatibility Mode Selected by a Fuse – Global Pull-up Disable Operating Voltages – – 2 Differential Channels with Programmable Gain at 1x, 10x, or 200x 4.5 - 5.5V Speed Grades – 0 - 16 MHz BLOCK DIAGRAM MEMORY MAP: SCHEMATIC POWER 2 1 IN C6 100n R1 EPWR U2 78L05 D1 1N4148 +5V +5V ICSP 2 1 +5V PE0 OUT C7 100n GND C3 100n C4 100n RESET PB1 PE1 4.7K 1 3 5 7 9 2 4 6 8 10 +5V +5V JTAG 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 CON2 C2 22pF PEN PE0 PE1 PE2 PE3 PE4 PE5 PE6 PE7 PB0 PB1 PB2 PB3 PB4 PB5 PB6 1 PB7 2 T OSC2 3 T OSC1 4 RESET 5 +5V 6 GND 7 XT AL2 8 XT AL1 PD0 9 PD1 10 PD2 11 PD3 12 PD4 13 PD5 14 PD6 15 PD7 16 Q1 XTAL2 T OSC1 T OSC2 Q2 C932KHz/6pF opt CON1 C1 22pF C8 opt GND RESET XT AL1 +5V 20 24 23 19 18 PE0 PE1 PE2 PE3 PE4 PE5 PE6 PE7 2 3 4 5 6 7 8 9 PD0 PD1 PD2 PD3 PD4 PD5 PD6 PD7 25 26 27 28 29 30 31 32 PF0 PF1 PF2 PF3 TCK TMS TDO TDI 61 60 59 58 57 56 55 54 +5V 64 C5 AREF 62 100n GND 63 RESET/ VCC XTAL1 XTAL2 TOSC1 TOSC2 RXD-PE0 TXD-PE1 AC+_PE2 AC-_PE3 INT4-PE4 INT5-PE5 INT6-PE6 INT7-PE7 PD0-INT0 PD1-INT1 PD2-INT2 PD3-INT3 PD4-IC1 PD5 PD6-T1 PD7-T2 ADC0-PF0 ADC1-PF1 ADC2-PF2 ADC3-PF3 ADC4-PF4 ADC5-PF5 ADC6-PF6 ADC7-PF7 T DI PA0 PA1 PA2 PA3 PA4 PA5 PA6 PA7 35 36 37 38 39 40 41 42 PC0 PC1 PC2 PC3 PC4 PC5 PC6 PC7 17 16 15 14 13 12 11 10 PB7 PB6 PB5 PB4 PB3 PB2 PB1 PB0 43 ALE 34 RD/ 33 WR/ 1 PEN/ ALE RD WR PEN A8-PC0 A9-PC1 A10-PC2 A11-PC3 A12-PC4 A13-PC5 A14-PC6 A15-PC7 OC2-PB7 OC1B-PB6 OC1A-PB5 OC0-PB4 MISO-PB3 MOSI-PB2 SCK-PB1 SS-PB0 AVREF AGND 51 50 49 48 47 46 45 44 AD0-PA0 AD1-PA1 AD2-PA2 AD3-PA3 AD4-PA4 AD5-PA5 AD6-PA6 AD7-PA7 AVCC ATMEGA128 T CK T DO T MS 21 52 IC1 RESET 3 1 2 VCC GND 53 22 U1 ZM33064 1 3 5 7 9 2 4 6 RESET 8 10 CON4 PA2 PA1 PA0 +5V GND T DI T DO T MS T CK PF3 PF2 PF1 PF0 AREF GND +5V 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 WR RD PC0 PC1 PC2 PC3 PC4 PC5 PC6 PC7 ALE PA7 PA6 PA5 PA4 PA3 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 CON3 +5V R2 1K AVR-H128 Rev. A COPYRIGHT(C), 2005 http://www.olimex.com/dev BOARD LAYOUT POWER SUPPLY CIRCUIT The board is power supplied from POWER connector pin 1 and pin 2 with 9-12 V DC. RESET CIRCUIT AVR-H128 reset circuit includes pin 6 of JTAG connector, pin 5 of ICSP connector, Extension connector CON2 – pin 4 and ATmega128 pin 20. CLOCK CIRCUIT Quartz crystal 8MHz is connected to ATmega128 pin 23 (XTAL2) and pin 24 (XTAL1). Quartz crystal 32kHz is connected to Atmega128 pin 18 (TOSC2) and pin 19 (TOSC1). JUMPER DESCRIPTION EPWR Enable target power supply. CONNECTOR DESCRIPTIONS JTAG Pin # Signal Name 1 TCK 2 GND 3 TDO 4 +5V 5 TMS 6 RESET 7 +5V 8 NC 9 TDI 10 GND ICSP Pin # Signal Name 1 PE0 2 +5V 3 NC 4 GND 5 RESET 6 GND 7 PB1 8 GND 9 PE1 10 GND CON1 Pin # Signal Name Pin # Signal Name 1 PEN 2 PE0 3 PE1 4 PE2 5 PE3 6 PE4 7 PE5 8 PE6 9 PE7 10 PB0 11 PB1 12 PB2 13 PB3 14 PB4 15 PB5 16 PB6 Pin # Signal Name Pin # Signal Name 17 PB7 18 TOSC2 19 TOSC1 20 RESET 21 +5V 22 GND 23 XTAL2 24 XTAL1 25 PD0 26 PD1 27 PD2 28 PD3 29 PD4 30 PD5 31 PD6 32 PD7 CON2 CON3 Pin # Signal Name Pin # Signal Name 33 WR 34 RD 35 PC0 36 PC1 37 PC2 38 PC3 39 PC4 40 PC5 41 PC6 42 PC7 43 ALE 44 PA7 45 PA6 46 PA5 47 PA4 48 PA3 Pin # Signal Name Pin # Signal Name 49 PA2 50 PA1 51 PA0 52 +5V 53 GND 54 TDI 55 TDO 56 TMS 57 TCK 58 PF3 59 PF2 60 PF1 61 PF0 62 AREF 63 GND 64 +5V CON4 POWER CONNECTOR Pin # Signal Name 1 (+) VCC 2 (-) GND MECHANICAL DIMENSIONS AVAILABLE DEMO SOFTWARE – – Blinking LED (C source and HEX) UART initialization (C source and HEX) ORDER CODE AVR-H128 – assembled and tested How to order? You can order to us directly or by any of our distributors. Check our web www.olimex.com/dev for more info. Revision history: REV.A - create June 2009 Disclaimer: © 2009 Olimex Ltd. All rights reserved. Olimex®, logo and combinations thereof, are registered trademarks of Olimex Ltd. Other terms and product names may be trademarks of others. The information in this document is provided in connection with Olimex products. No license, express or implied or otherwise, to any intellectual property right is granted by this document or in connection with the sale of Olimex products. Neither the whole nor any part of the information contained in or the product described in this document may be adapted or reproduced in any material from except with the prior written permission of the copyright holder. The product described in this document is subject to continuous development and improvements. All particulars of the product and its use contained in this document are given by OLIMEX in good faith. However all warranties implied or expressed including but not limited to implied warranties of merchantability or fitness for purpose are excluded. This document is intended only to assist the reader in the use of the product. OLIMEX Ltd. shall not be liable for any loss or damage arising from the use of any information in this document or any error or omission in such information or any incorrect use of the product.
AVR-H128-C 价格&库存
很抱歉,暂时无法提供与“AVR-H128-C”相匹配的价格&库存,您可以联系我们找货
