STM32-P405
STM32-P405
    OLIMEX
    PROTOBDSTMICROM4STM32F405
STM32-P405 数据手册
Page 1 of 2 STM32-P405 HEADER BOARD FOR STM32F405RGT6 ARM CORTEX M4 1024KB FLASH 168 MHZ 192KB SRAM The ARM generation Cortex-M4 of ARM processor processors is the latest for embedded systems. It has been developed to provide a low-cost platform that meets the needs of MCU implementation, with a reduced pin count and lowpower consumption, while delivering an outstanding computational performance and an advanced system response to interrupts. The ARM Cortex-M4 32-bit RISC processor features exceptional code-efficiency, delivering the high-performance expected from an ARM core in the memory size usually associated with 8- and 16-bit devices. The STM32F405RGT6 performance line family has an embedded ARM core and is therefore compatible with all ARM tools and software. It combines the high performance ARM Cortex-M3 CPU with an extensive range of peripheral functions and enhanced I/O capabilities. STM32-P4053 is a good start-up board for learning the new ST Cortex-M4 based microcontrollers STM32F405RGT6. It has RS232 and both USB and CAN. It also features a prototype area with all microcontroller signals near it, giving the customer an easy way to implement his own schematics and add-ons. FEATURES MCU: STM32F405RGT6 ARM Cortex M4 1024KB FLASH 168 Mhz 192kB SRAM USB, CAN, x2 I2C, x2 ADC 12 bit, x3 UART, x2 SPI, x3 TIMERS, up to 72Mhz operation Standard JTAG connector with ARM 2x10 pin layout for programming/debugging with ARMJTAG USB connector CAN driver and connector RS232 driver and connector UEXT connector which allows different modules to be connected (as MOD-MP3, MOD-NRF24LR, etc) SD-MMC connector Backup battery connector RESET button Status LED Power supply LED On-board voltage regulator 3.3V with up to 800mA current Single power supply: takes power from USB port or power supply jack 8 Mhz crystal oscillator 32768 Hz crystal and RTC backup battery connector HARDWARE STM32-P405 latest schematic Page 2 of 2 Extension headers for all uC ports PCB: FR-4, 1.5 mm (0,062"), red soldermask, silkscreen component print Dimensions: 100 x 90mm (3.94 x 3.5") UEXT Modules Interface LCD Video Ethernet MP3 Adapters LED RF Time Biofeedback Sensors IO RFID GPS Related Products RS232-CABLE USB-A-B-CABLE https://www.olimex.com/Products/ARM/ST/STM32-P405/ 1/17/2014
STM32-P405 价格&库存
很抱歉,暂时无法提供与“STM32-P405”相匹配的价格&库存,您可以联系我们找货
