STM32-P152
STM32-P152
    OLIMEX
    ST M3 STM32L152 PROTOTYPE BOARD
STM32-P152 数据手册
STM32-P152 development board user's manual All boards produced by Olimex are ROHS compliant Revision C, April 2012 Copyright(c) 2011, OLIMEX Ltd, All rights reserved Page 1 INTRODUCTION: STM32-P152 is a development board with STM32L152VBT6 ARM Cortex M3 microcontroller made by STMicroelectronics. This microcontroller supports various communication interfaces such as USB, three USARTs, two SPIs, two I2Cs. There are USB, JTAG and UEXT connectors, three buttons – WKUP, USER and RESET, four status LEDs, potentiometer and pin holes for most of the microcontroller's pins. The board features low power segment LCD that uses the built in LCD controller in this specialized microcontroller. Due to its low power capabilities the board can run battery powered applications via the battery connector. All this allows you to build different projects for a wide range of applications. BOARD FEATURES:  MCU: STM32L152VBT6 – 128 KB Flash, 16 KB Data RAM  USB  3.7V-LI_BAT connector  Battery charger  JTAG/SWD connector  UEXT connector  RS232 connector  LCD  Four status LEDs  Reset circuit  RESET button  WKUP button  USER button  Potentiometer  Power jack  Power-on LED  Pin holes for most of the microcontroller pins  FR-4, 1.5 mm, soldermask, component print  Dimensions: 120.00 x 80.00 mm (4.72 x 3.15") Page 2 ELECTROSTATIC WARNING: The STM32-P152 board is shipped in protective anti-static packaging. The board must not be subject to high electrostatic potentials. General practice for working with static sensitive devices should be applied when working with this board. BOARD USE REQUIREMENTS: Cables: The cable you will need depends on the programmer/debugger you use. If you use ARM-JTAG-EW, ARM-USB-TINY or ARM-USB-TINY-H, you will need USB A-B cable, if you use ARM-USB-OCD or ARM-USB-OCD-H, you will need USB A-B cable and RS232 cable. Hardware: Programmer/Debugger ARM-USB-OCD, ARM-USB-OCD-H, ARMUSB-TINY, ARM-USB-TINY-H, ARM-JTAG-COOCOX or other compatible programming/debugging tool if you work with EW-ARM. It is a good practice to first consider the software tools you are going to use and check if they support the debuggers. It is good idea to use SWD interface for debugging/programming because of the multiplexing of the JTAG signal lines with the display lines. If using a debugger that supports only JTAG layout you might need to disable display or write a routine that disables it. PROCESSOR FEATURES: STM32-P152 board uses ARM 32-bit Cortex™-M3 microcontroller STM32L152VBT6 from STMicroelectronics has these features:    Operating conditions  Operating power supply range: 1.65 V to 3.6 V (without BOR) or 1.8 V to 3.6 V (with BOR option)  Temperature range: –40 to 85 °C Low power features  4 modes: Sleep, Low-power run (9 μA at 32 kHz), Low-power sleep (4.4 μA), Stop with RTC (1.45 μA), Stop (570 nA), Standby (300 nA)  Dynamic core voltage scaling down to 233 μA/MHz  Ultra low leakage per I/O: 50 nA  Fast wakeup from Stop: 8 μs  Three wakeup pins Core: ARM 32-bit Cortex™-M3 CPU  32 MHz maximum frequency, 33.3 DMIPS peak (Dhrystone 2.1) Page 3     Reset and supply management  Low power, ultrasafe BOR (brownout reset) with 5 selectable thresholds  Ultralow power POR/PDR  Programmable voltage detector (PVD) Clock management  1 to 24 MHz crystal oscillator  32 kHz oscillator for RTC with calibration  Internal 16 MHz factory-trimmed RC  Internal 37 kHz low consumption RC  Internal multispeed low power RC, 64 kHz to 4 MHz with a consumption down to 1.5 μA  PLL for CPU clock and USB (48 MHz) Low power calendar RTC   Memory protection unit Alarm, periodic wakeup from Stop/Standby Memories  128 Kbyte of Flash memory with ECC  4 Kbyte of data EEPROM with ECC  16 Kbyte of RAM  83 fast I/Os (73 of which are 5 V-tolerant) all mappable on 16 external interrupt vectors  Development support  Serial wire debug, JTAG and trace  DMA: 7-channel DMA controller, supporting timers, ADC, SPIs, I2Cs and USARTs  LCD 8 × 40 or 4 × 44 with step-up converter  12-bit ADC up to 1 Msps/24 channels  Temperature sensor and internal voltage reference  Operates down to 1.8 V  2× 12-bit DACs with output buffers  2 ultralow power comparators   Window mode and wakeup capability 10 timers:  6 × 16-bit general-purpose timers, each with up to 4 IC/OC/PWM channels  2 × 16-bit basic timers Page 4    2 × watchdog timers (independent and window) 8 communication interfaces:  2 × I2C interfaces (SMBus/PMBus)  3 × USARTs (ISO 7816 interface, LIN, IrDA capability, modem control)  2 × SPIs (16 Mbit/s)  USB 2.0 full speed interface CRC calculation unit, 96-bit unique ID Page 5 BLOCK DIAGRAM: AF = Alternate Function function on I/O port pin. Page 6 MEMORY MAP: Page 7 Page 8 1 1uF/10V SEG36 SEG37 T 11 03NE-12x1 2x4.3 3 .3V RS232_EN T1 47k 12 9 11 10 5 DTA11 4YKA 330R 33 0R SEG34 SEG35 USART2 _RX R2 6 USART2_CTS R43 USART2_TX USART2_RTS 3 C26 4 100n F C27 1 10 0nF GND15 U4PWR C30 100n F 16VCC R1IN R2IN T1OUT T2OUT V- V+ CTS RTS 6 7 8 9 NC RS2 32_2 1 2 3 4 5 C1 100n F C25 100nF R14 g a d RS232 DRIVERS 13 8 14 7 6 2 ST3232 CDR(SO 16) R1OUT R2OUT T1IN T2IN C2- C2+ C1- C1+ U4 OLIMEX e 24 100nF umHF SEG32 SEG33 C28 48 2 RESET COM2 COM3 3 R40 100k 4 46 C31 100 nF 45 COM0 COM1 SEG30 SEG31 330R R11 100R/1% 5 GND 6 44 W KUP 43 TRACED0/SEG39 TRACECK/SEG38 SEG28 SEG29 R39 7 330R 42 33 0R SEG0 SEG1 SEG26 SEG27 R13 1 00R/1% RST 8 R44 9 41 SEG16 TDI/SEG17 R12 100R/1 % 40 SEG24 SEG25 3.3V 10 R8 1 0k 11 39 SEG14 SEG15 NA (S TM1001R W X 6F) 2 VCC RESET 1 12 38 U2 37 SEG22 SEG23 C24 100n F 13 SEG20 SEG21 W KUP OLIMEX_LTD LCD AG ND 14 36 SEG18 SEG19 USER 2 35 SEG3 SEG2 SEG42 f 15 SENSE_E BAT 1 CLO SE G NDA_E C1 0 1uF/10 V 34 18 RESET CIRCUIT C33 100 nF DW 02R G ND GND 3 SEG10 SEG11 19 R41 R52 10k - VIN VOUT 3.3V 16 20 C35 2.2u F/6.3 V R9 33 k 1 2 BAT 3.7 V-L I_BAT 1 2 MCP1702T-3302E/MB VR(3 .3V) 17 33 21 USER R42 10k 2.2uF/6.3V appr. 70 mA charge current 15 k VSSPROG 5 1 3 D1 BAT54C 32 22 3.3V VDDVBAT BATTERY CE CHARGER + R51 2 4 R53 4.7k FET1 IRLML6402 470R TRST/SEG8 SEG9 23 BUTTONS C34 U5 MCP73812T-420I/OT +5V Battery Charger +5V R45 PW R_LED RED(G YX-SD-TC080 5SYRK) C14 10pF C15 10p F GND 30 47 BZV55 C6 V2 C4 VIN 3.3V PC10 PC11 Q2 NA 32768 Hz/6 pF RS232_ EN TRIMER_ EN SEG 43 USART2_CTS USART2_RTS USART2 _TX USART2_RX SENSE_E PD7 SEG 2 8 SEG 29 SEG 30 SEG 3 1 SEG 32 SEG 33 SEG 34 SEG 35 R33 SEG 1 8 SEG 19 SEG 20 SEG 2 1 SEG 22 SEG 23 SEG 24 SEG 2 5 SEG 26 SEG 27 USART3_TX USART3 _RX SEG 42 USER TMS/SWDIO TCK/SWCLK SEG6 TDO/TRACESWO/SEG7 31 Z2 D4 BAT54C D2 BAT54 C PWR_L ED_E HN1x2 81 82 83 84 85 86 87 88 55 56 57 58 59 60 61 62 SEG [0..6],SEG [9 ..16],SEG [18..37 ],SEG 42,SEG 43 ,CO M[0..3] OSC_IN/PD0/SPI2_NSS/TIM9_CH1 OSC_OUT/PD1/SPI2_SCK PD2/TIM3_ETR/LCD_SEG31/LCD_SEG43/LCD_COM7 PD3/USART2_CTS/SPI2_MISO PD4/USART2_RTS/SPI2_MOSI PD5/USART2_TX PD6/USART2_RX PD7/USART2_CK/TIM9_CH2 PD8/USART3_TX/LCD_SEG28 PD9/USART3_RX/LCD_SEG29 PD10/USART3_CK/LCD_SEG30 PD11/USART3_CTS/LCD_SEG31 PD12/TIM4_CH1/USART3_RTS/LCD_SEG32 PD13/TIM4_CH2/LCD_SEG33 PD14/TIM4_CH3/LCD_SEG34 PD15/TIM4_CH4/LCD_SEG35 15 16 17 18 33 34 63 64 65 66 78 79 80 7 8 9 PB2 DAC_O UT1 DAC_ O UT2 SEG 5 SEG 6 PB2 /BO O T1 TDO /TRACESW O /SEG 7 TRST/SEG 8 SEG 9 PB6 I2 C1 _SCL PB7 I2C1_SDA SEG 16 CO M3 SEG 10 SEG 1 1 SEG 12 SEG 13 SEG 1 4 SEG 15 W KUP SEG 0 SEG 1 SEG 2 DAC_O UT1 DAC_O UT2 SEG 3 SEG 4 CO M0 CO M1 CO M2 USB_ DM USB_DP TMS/SWDIO TCK/SWCLK TDI/SEG 17 28 3.3V STM32L 152VBT6 PE0/TIM4_ETR/LCD_SEG36/TIM10_CH1 PE1/LCD_SEG37/TIM11_CH1 PE2/TRACECK/LCD_SEG38/TIM3_ETR PE3/TRACED0/LCD_SEG39/TIM3_CH1 PE4/TRACED1/TIM3_CH2 PE5/TRACED2/TIM9_CH1 PE6/TRACED3/WKUP3/TIM9_CH2 PE7/ADC_IN22/COMP1_INP PE8/ADC_IN23/COMP1_INP PE9/ADC_IN24/TIM2_CH1_ETR/COMP1_INP PE10/ADC_IN25/TIM2_CH2/COMP1_INP PE11/TIM2_CH3 PE12/TIM2_CH4/SPI1_NSS PE13/SPI1_SCK PE14/SPI1_MISO PE15/SPI1_MOSI NRST PH2/I2C2_SMBA OSC_OUT/PH1 OSC_IN/PH0 PC0/ADC_IN10/LCD_SEG18/COMP1_INP PC1/ADC_IN11/LCD_SEG19/COMP1_INP PC2/ADC_IN12/LCD_SEG20/COMP1_INP PC3/ADC_IN13/LCD_SEG21/COMP1_INP PC4/ADC_IN14/LCD_SEG22/COMP1_INP PC5/ADC_IN15/LCD_SEG23/COMP1_INP PC6/TIM3_CH1/LCD_SEG24 PC7/TIM3_CH2/LCD_SEG25 PC8/TIM3_CH3/LCD_SEG26 PC9/TIM3_CH4/LCD_SEG27 PC10/USART3_TX/LCD_SEG28/LCD_SEG40/LCD_COM4 PC11/USART3_RX/LCD_SEG29/LCD_SEG41/LCD_COM5 PC12/USART3_CK/LCD_SEG30/LCD_SEG42/LCD_COM6 PC13/RTC_AF1/WKUP2 PC14/OSC32_IN PC15/OSC32_OUT 35 36 37 89 90 91 92 93 95 96 47 48 51 52 53 54 23 24 25 26 29 30 31 32 67 68 69 70 71 72 76 77 26 SEG4 SEG5 29 G ND_ PIN 97 98 1 2 3 4 5 38 39 40 41 42 43 44 45 46 SEG 36 SEG 3 7 TRACECK/SEG 38 TRACED0/SEG 39 TRACED1 TRACED2 TRACED3 TRIM BAT STAT3 STAT4 SPI1 _NSS SPI1_SCK SPI1_MISO SPI1 _MO SI 14 73 RST +5V_ USB R7 4.7k 13 12 BOOT0 VLCD PB0/ADC_IN8/TIM3_CH3/LCD_SEG5/COMP1_INP/VREF_OUT PB1/ADC_IN9/TIM3_CH4/LCD_SEG6/COMP1_INP/VREF_OUT PB2/BOOT1 JTDO/TIM2_CH2/PB3/TRACESWO/SPI1_SCK/COMP2_INM/LCD_SEG7 JNTRST/TIM3_CH1/PB4/SPI1_MISO/COMP2_INP/LCD_SEG8 PB5/I2C1_SMBAL/TIM3_CH2/SPI1_MOSI/COMP2_INP/LCD_SEG9 PB6/I2C1_SCL/TIM4_CH1/USART1_TX/LCD_SEG8 PB7/I2C1_SDA/TIM4_CH2/USART1_RX/PVD_IN PB8/TIM4_CH3/I2C1_SCL/LCD_SEG16/TIM10_CH1 PB9/TIM4_CH4/I2C1_SDA/LCD_COM3/TIM11_CH1 PB10/I2C2_SCL/USART3_TX/TIM2_CH3/LCD_SEG10 PB11/I2C2_SDA/USART3_RX/TIM2_CH4/LCD_SEG11 PB12/SPI2_NSS/I2C2_SMBA/USART3_CK/LCD_SEG12/ADC_IN18/COMP1_INP/TIM10_CH1 PB13/SPI2_SCK/USART3_CTS/LCD_SEG13/ADC_IN19/COMP1_INP/TIM9_CH1 PB14/SPI2_MISO/USART3_RTS/LCD_SEG14/ADC_IN20/COMP1_INP/TIM9_CH2 PB15/SPI2_MOSI/TIM1_CH3N/LCD_SEG15/ADC_IN21/COMP1_INP/TIM11_CH1/RTC_50_60HZ PA0/WKUP1/USART2_CTS/ADC_IN0/TIM2_CH1_ETR/COMP1_INP PA1/USART2_RTS/ADC_IN1/TIM2_CH2/LCD_SEG0/COMP1_INP PA2/USART2_TX/ADC_IN2/TIM2_CH3/TIM9_CH1/LCD_SEG1/COMP1_INP PA3/USART2_RX/ADC_IN3/TIM2_CH4/TIM9_CH2/LCD_SEG2/COMP1_INP PA4/SPI1_NSS/USART2_CK/ADC_IN4/DAC_OUT1/COMP1_INP PA5/SPI1_SCK/ADC_IN5/DAC_OUT2/TIM2_CH1_ETR/COMP1_INP PA6/SPI1_MISO/ADC_IN6/TIM3_CH1/TIM1_BKIN/LCD_SEG3/TIM10_CH1/COMP1_INP PA7/SPI1_MOSI/ADC_IN7/TIM3_CH2/TIM1_CH1N/LCD_SEG4/TIM11_CH1/COMP1_INP PA8/USART1_CK/MCO/LCD_COM0 PA9/USART1_TX/LCD_COM1 PA10/USART1_RX/LCD_COM2 PA11/USART1_CTS/USBDM/SPI1_MISO PA12/USART1_RTS/USBDP/SPI1_MOSI JTMS/SWDIO/PA13 JTCK/SWCLK/PA14 JTDI/TIM2_CH1_ETR/PA15/SPI1_NSS/LCD_SEG17 SEG13 SEG12 27 +5V_JTAG +5V_JTAG EXT_PWR 6 94 VREF- VREF+ VSSA VDDA VSS_5 VSS_4 VSS_3 VSS_2 VSS_1 2 1 +5V_ USB Q1 B0_1 /B0_ 0 10 k R15 20 21 U1 VDD_1 VDD_2 VDD_3 VDD_4 VDD_5 SEG43 +5V_USB +5V_J-TRACE PE8 PE9 PE1 0 PE11 PE12 PE1 3 PE14 PE15 RST VREF- NA 1 00nF 19 22 10 27 99 74 49 50 75 100 28 11 POWER SUPPLY CIRCUIT C13 27pF C9 10 0nF VREF+ C20 1u F/10V HN1x3 0 C21 C29 Q8.000MHz/HC-49SM(SMD)/20pF C12 27pF 0 R(NA) 3.3 V 0R 0R 0 R(NA) 3.3V_A C11 1uF/10 V C19 1u F/10V 3.3V_A 3 .3V 25 YDJ-1136 5 -6VDC 6VDC MAX!!! PW R 1 2 3 +5V_JTRACE R5 R20 R50 PB2/BO O T1 1 1 2 3 B1_ 1/B1 _0 HN1x3 2 FB0805/600R/200mA(201209-601) C23 100nF 10k C8 4.7uF 0 C7 100nF FB1 CLO SE 1 SHUNT_E 2 C6 100nF 3.3 V 1R R6 C5 100nF CLO SE 2 1 USB_DP,USB_DM c b SPI1 _MO SI SPI1_MISO SPI1_ SCK SPI1 _NSS USART3_TX USART3_RX I2C1_SCL I2 C1 _SDA TMS/SWDIO ,TCK/SW CLK R2 R1 100 k VIN UEXT R49 270R T2 BC817-40 100n F C32 1 3 5 7 9 0R 0R 1 2 3 (NA)USBL C6 -2P6 6 5 4 R4 100 k 270R R3 3 .3V R32 4.7k DAC_O UT2 10k 10k BZV55C6V2 +5V_JTAG 2 4 6 8 10 12 14 16 18 20 1 3 5 7 9 11 13 15 17 19 1 3 5 7 9 11 13 15 17 19 TRACE BH20S 2 4 6 8 10 12 14 16 18 20 JTAG /SWD C3 10 0nF 3 .3V 3 30R R24 3 .3V R47 4 70R STAT3 RED(GYX-SD-TC0805SYRK) STAT3 R46 4 70R C18 100nF TRIM 10nF(NA) C2 STAT4 SPI1_SCK,SPI1_MOSI,SPI1_MISO,SPI1_NSS,I2C1_SDA,I2C1_SCL,USART3_RX,USART3_TX 1 0k T1107A(6x3,8x2,5mm) 3 T1103NE-12x12x4.3 http ://www.o limex.co m/dev STAT4 GREEN(GYX-SD-TC0805SGC) CO PYRIG HT(C) 2011, O LIMEX Ltd . Rev. B STM32-P152 R48 270R T3 BC817-40 YELLOW(GYX-SD-TC0805SYC) STAT2 1 0k(NA) R10 STATUS LEDS TRIMER_EN AN_TR 10 k 3.3V S HIE L D R38 1M 1 2 3 4 USB USB_B +5V_J-TRACE 3 .3V 3.3V C22 10 0nF +5V_ USB TRIMMER G PH127 -SMT02x10 (pin7-CUT)/(NA) TRACED2 TRACED3 10k R18 R17 R16 NA R23 R25 NA 0R(NA) NA 0 R(NA) NA NA R29 NA USART3 _TX I2C1_ SCL SPI1_MISO SPI1_SCK 3 .3V R37 R36 R35 R3 4 R27 R28 NA GREEN(GYX-SD-TC0805SGC) STAT1 BH10S 2 4 6 8 10 UEXT USART3 _RX I2C1_ SDA SPI1_MO SI SPI1_NSS 270R R3 1 4.7k DAC_O UT1 R3 0 33k O PEN TMS/SWDIO TCK/SWCLK TDO /TRACESW O /SEG 7 TDI/SEG 1 7 RST TRACECK/SEG 38 TRACED0/SEG 39 TDO /TRACESWO /SEG 7 TRACED1 TRST/SEG 8 3 .3V R19 NA R22 R21 U3 Z1 JTAG/SWD/TRACE 47pF(NA) TDO /TRACESWO /SEG 7 RST R-T TRST/SEG 8 1 2 TRST/SEG 8 TDI/SEG 17 TMS/SWDIO TCK/SWCLK 47pF(NA) 22 R C17 USB_ DM C16 22R USB_DP 3 .3V USB CIRCUIT USB 3.3VA_MCU_E 3.3V_ MCU_E HN1x2 SCHEMATIC: BOARD LAYOUT: POWER SUPPLY CIRCUIT: STM32-P152 can take power from: –PWR_JACK (5-6) VDC –USB - +5V_USB. –JTAG - +5V_JTAG. –TRACE - +5V_J-TRACE –Battery connector – +3.7V lithium battery. –Pin Hole VIN – (5÷6) VDC. The programmed board power consumption is about 50 mA with all peripherals enabled. The minimal current consumption is a few uA(up to 10) Note that if the battery is connected to 3,7V-Li BAT connector and some of other power sources(USB, JTAG, TRACE, PWR_JACK) are present and the battery is discharged then the battery will be charge until the charge complete. RESET CIRCUIT: STM32-P152 reset circuit includes R8 (10k), R44 (330Ω), R11 (100Ω/1%), C28 (100nF), STM32L152VBT6 pin 14 (NRST) and RESET button. Page 9 CLOCK CIRCUIT: Quartz crystal (Q1) 8 MHz is connected to STM32L152VBT6 pin 12 (OSC_IN/PH0) and pin 13 (OSC_OUT/PH1). Quartz crystal (Q2) 32.768 kHz is connected to STM32L152VBT6 pin 8 (PC14/OSC32_IN) and pin 9 (PC15/OSC32_OUT). JUMPER DESCRIPTION: R-T When this jumper is closed, RST and TRST/SEG8 are connected. When this jumper is opened, RST and TRST/SEG8 are separated. Default state is opened. SHUNT_E When this jumper is closed, 1 Ohm shunt is enabled. When this jumper is opened, 1 Ohm shunt is disabled. Default state is closed. GNDA_E When this jumper is closed, the board analog ground is enabled. When this jumper is opened, the board analog ground is disabled. Default state is closed. 3.3VA_MCU_E When this jumper is closed, the microcontroller analog power is enabled. When this jumper is opened, the microcontroller analog power is not enabled. Default state is closed. 3.3V_MCU_E When this jumper is closed, STM32L152VBT6 power supply is enabled. When this jumper is opened, STM32L152VBT6 power supply is disabled. Default state is closed. PWR_LED_E When this jumper is closed, the PWR_LED is enabled. When this jumper is opened, the PWR_LED is disabled. Default state is closed. B0_1/B0_0 This jumper, when is in position B0_1 – connects STM32L152VBT6 pin 94 (BOOT0) via R15 (10k) to 3.3V, when the jumper is in position B0_0 – connects STM32L152VBT6 pin 94 (BOOT0) via R15 (10k) to GND. Default state is closed in position B0_0. Page 10 B1_1/B1_0 This jumper, when is in position B1_1 – connects STM32L152VBT6 pin 37 (PB2/BOOT1) via R7 (10k) to 3.3V, when the jumper is in position B1_0 – connects STM32L152VBT6 pin 37 (PB2/BOOT1) via R7 (10k) to GND. Default state is closed in position B1_0. The boot mode is selected depending on jumpers B0_1/B0_0 and B1_1/B1_0 configuration: - When B0_1/B0_0 is closed in position B0_0 and B1_1/B1_0 position doesn't matter the boot mode is Main Flash Memory. - When B0_1/B0_0 is closed in position B0_1 and B1_1/B1_0 is closed in position B1_0 – the boot mode is System Memory. - When B0_1/B0_0 is closed in position B0_1 and B1_1/B1_0 is closed in position B1_1 – the boot mode is Embedded SRAM. INPUT/OUTPUT: Status led (green), with name STAT1 is connected to STM32L152VBT6 pin 29 (PA4/DAC_OUT1), allowing current through it to be adjusted smoothly. Status led (yellow), with name STAT2 is connected to STM32L152VBT6 pin 30 (PA5/DAC_OUT2), allowing current through it to be adjusted smoothly. Status led (red), with name STAT3 is connected to STM32L152VBT6 pin 41 (PE10). Status led (green), with name STAT4 is connected to STM32L152VBT6 pin 42 (PE11). Power-on led, with name PWR_LED – this led shows that the board is power supplied. User button with name WKUP is connected to STM32L152VBT6 pin 23 (PA0/WKUP1). User button with name USER is connected to STM32L152VBT6 pin 7 (PC13/WKUP2). User button with name RESET is connected to STM32L152VBT6 pin 14 (NRST). Trimmer with name AN_TR is connected to STM32L152VBT6 pin 82 (PD1/SPI2_SCK) – signal “TRIMER_EN”. Page 11 EXTERNAL CONNECTORS DESCRIPTION: UEXT: Pin # Signal Name 1 VCC (3.3V) 2 GND 3 USART3_TX 4 USART3_RX 5 I2C1_SCL 6 I2C1_SDA 7 SPI1_MISO 8 SPI1_MOSI 9 SPI1_SCK 10 SPI1_NSS USB: Pin # Signal Name 1 +5V_USB 2 USB_DM 3 USB_DP 4 GND 3.7V-LI_BAT: Pin # Signal Name 1 VBAT 2 GND Page 12 JTAG/SWD: Pin # Signal Name Pin # Signal Name 1 VCC (3.3V) 2 VCC (3.3V) 3 TRST/SEG8 4 GND 5 TDI/SEG17 6 GND 7 TMS/SWDIO 8 GND 9 TCK/SWCLK 10 GND 11 Via 10k to GND 12 GND 13 TDO/TRACESWO/SEG7 14 GND 15 RST 16 GND 17 Via 10k to GND 18 GND 19 +5V_JTAG 20 GND Important: The default demo software blocks the JTAG communication. A workaround is to press and hold button B2, then press RST, then release B2. This will shut down the display allowing you to erase the demo via JTAG and after that the JTAG should be available. SWD debuggers/programmers would not have such a problem. Page 13 PWR_JACK: Pin # Signal Name 1 EXT_PWR 2 GND RS232_2: Pin # Signal Name 1 Not Connected 2 T1OUT (U4 pin 14) 3 R1IN (U4 pin 13) 4 Not Connected 5 GND 6 Not Connected 7 CTS 8 RTS 9 Not Connected TRACE: Pin # Signal Name Pin # Signal Name 1 VCC (3.3V) 2 TMS/SWDIO 3 GND 4 TCK/SWCLK 5 GND 6 TDO/TRACESWO/SEG7 7 Not Connected 8 TDI/SEG17 9 GND 10 RST Page 14 11 +5V_J-TRACE 12 TRACECK/SEG38 13 +5V_J-TRACE 14 TRACED0/SEG39 15 GND 16 TRACED1 17 GND 18 TRACED2 19 GND 20 TRACED3 Page 15 PIN HOLES: Page 16 MECHANICAL DIMENSIONS: Page 17 AVAILABLE DEMO SOFTWARE:  Demo software USB mouse and Blinking LED for EW-ARM  Setup GCC+Eclispse for STM32 on MAC Page 18 ORDER CODE: STM32-P152 - assembled and tested board How to order? You can order to us directly or by any of our distributors. Check our web https://www.olimex.com/ or more info. Revision history: Board's revision: Rev. B, June 2011 Manual's revision: Rev. Initial, September 2011 Manual's revision: Rev. B, March 2013 Manual's revision: Rev. C, April 2013 Page 19 Disclaimer: © 2013 Olimex Ltd. Olimex®, logo and combinations thereof, are registered trademarks of Olimex Ltd. Other product names may be trademarks of others and the rights belong to their respective owners. The information in this document is provided in connection with Olimex products. No license, express or implied or otherwise, to any intellectual property right is granted by this document or in connection with the sale of Olimex products. The Hardware project is not released under the Creative Commons Attribution-Share Alike 3.0 United States License. The software is released under GPL. It is possible that the pictures in this manual differ from the latest revision of the board. The product described in this document is subject to continuous development and improvements. All particulars of the product and its use contained in this document are given by OLIMEX in good faith. However all warranties implied or expressed including but not limited to implied warranties of merchantability or fitness for purpose are excluded. This document is intended only to assist the reader in the use of the product. OLIMEX Ltd. shall not be liable for any loss or damage arising from the use of any information in this document or any error or omission in such information or any incorrect use of the product. This evaluation board/kit is intended for use for engineering development, demonstration, or evaluation purposes only and is not considered by OLIMEX to be a finished end-product fit for general consumer use. Persons handling the product must have electronics training and observe good engineering practice standards. As such, the goods being provided are not intended to be complete in terms of required design-, marketing-, and/or manufacturing-related protective considerations, including product safety and environmental measures typically found in end products that incorporate such semiconductor components or circuit boards. Olimex currently deals with a variety of customers for products, and therefore our arrangement with the user is not exclusive. Olimex assumes no liability for applications assistance, customer product design, software performance, or infringement of patents or services described herein. THERE IS NO WARRANTY FOR THE DESIGN MATERIALS AND THE COMPONENTS USED TO CREATE STM32-P152. THEY ARE CONSIDERED SUITABLE ONLY FOR STM32-P152. Page 20
STM32-P152 价格&库存
很抱歉,暂时无法提供与“STM32-P152”相匹配的价格&库存,您可以联系我们找货
