ABX00012
ABX00012
    ARDUINO
    MKRZEROBRDWITHHEADERSMOUNTED
ABX00012 数据手册
      ARDUINO MKR ZERO (I2S BUS &  S D   F O R   S O U N D,   M U S I C   &   D I G I TA L   AU D I O   DATA )   Code: ABX00012    MKR ZERO has an on‐board SD connector with dedicated SPI  interfaces (SPI1) that allows you to play with MUSIC files with no  extra hardware!    Watch out music makers, we’ve got some news for you! We have  released two libraries for your enjoyment:    Arduino Sound library – a simple way to play and analyze audio data  using Arduino on SAM D21‐based boards.  https://arduino.cc/en/Reference/ArduinoSound    I2S library – to use the I2S protocol on SAMD21‐based boards. For  those who don’t know, I2S (Inter‐IC Sound) is an electrical serial bus  interface standard for connecting digital audio devices.  https://arduino.cc/en/Reference/I2S    The MKR ZERO brings you the power of a Zero in the smaller format established by  the MKR form factor. The MKR ZERO board acts as a great educational tool for  learning about 32‐bit application development. It has an on‐board SD connector  with dedicated SPI interfaces (SPI1) that allows you to play with MUSIC files with  no extra hardware!  The board is powered by Atmel’s SAMD21 MCU, which  features a 32‐bit ARM Cortex® M0+ core.    Warning: Unlike most Arduino & Genuino boards, the MKRZero runs at 3.3V. The  maximum voltage that the I/O pins can tolerate is 3.3V. Applying voltages higher  than 3.3V to any I/O pin could damage the board.    The board contains everything needed to support the microcontroller; simply  connect it to a computer with a micro‐USB cable or power it by a LiPo battery. The  battery voltage can also be monitored since a connection between the battery and  the analog converter of the board exists.   TECH SPECS  Microcontroller  Board Power Supply (USB/VIN)  Supported Battery(*)  DC Current for 3.3V Pin  DC Current for 5V Pin  Circuit Operating Voltage  Digital I/O Pins  PWM Pins  UART  SPI  I2C  Analog Input Pins  Analog Output Pins  External Interrupts  DC Current per I/O Pin  Flash Memory  Flash Memory for Bootloader  SRAM  EEPROM  Clock Speed  LED_BUILTIN  Full‐Speed USB Device and embedded  Host  SAMD21 Cortex‐M0+ 32bit low power ARM  MCU  5V  Li‐Po single cell, 3.7V, 700mAh minimum  600mA  600mA  3.3V  22  12 (0, 1, 2, 3, 4, 5, 6, 7, 8, 10, A3 ‐ or 18 ‐,  A4 ‐or 19)  1  1  1  7 (ADC 8/10/12 bit)  1 (DAC 10 bit)  8 (0, 1, 4, 5, 6, 7, 8, A1 ‐or 16‐, A2 ‐ or 17)  7 mA  256 KB  8 KB  32 KB  no  32.768 kHz (RTC), 48 MHz  32  OSH: Schematics  The MKR ZERO is open‐source hardware! You can build your own board using the  following files:    EAGLE FILES IN .ZIP  https://www.arduino.cc/en/uploads/Main/ArduinoMKRZero‐reference.zip   SCHEMATICS IN .PDF  https://www.arduino.cc/en/uploads/Main/ArduinoMKRZero‐schematic.pdf  Li‐Po batteries, Pins, SD and board LEDs  On‐board SD   The on‐ board SD connector allows you to play with files without adding any extra  hardware to the board. Furthermore SD card is driven by a dedicated SPI interface  (SPI1) and so any of the pins of the header is busy during SD usage. The SD library  automatically recognizes the MKR ZERO and so any modification to the sketch is  needed to use it aprat from choosing the right SS pin (SDCARD_SS_PIN).     Battery capacity   Li‐Po batteries are charged up to 4,2V with a current that is usually half of the  nominal capacity (C/2). For Arduino MKR ZERO we use a specialized chip that has a  preset charging current of 350mAh. This means that the MINIMUM capacity of the  Li‐Po battery should be 700 mAh. Smaller cells will be damaged by this current and  may overheat, develop internal gasses and explode, setting on fire the  surroundings. We strongly recommend that you select a Li‐Po battery of at least  700mAh capacity. A bigger cell will take more time to charge, but won't be harmed  or overheated. The chip is programmed with 4 hours of charging time, then it goes  into automatic sleep mode. This will limit the amount of charge to max 1400 mAh  per charging round.     Battery connector   If you want to connect a battery to your MKRZero be sure to search one with  female 2 pin JST PHR2 Type connector.  Polarity : looking at the board connector  pins, polarity is Left = Positive, Right = GND  Connector datasheet  On the  MKRZero, connector is a Male 2pin JST PH Type    http://www.jst‐mfg.com/product/pdf/eng/ePH.pdf        Additional I2C Port   The MKRZero has an additional connector meant as an extension of the I2C bus.  It's a small form factor 5‐pin connector with 1.0mm pitch. The mechanical details  of the connector can be found in the connector datasheet.  The I2C port in addition  to the SDA and SCL signals includes the GND and +5V power rails and a digital pin  that might be useful when designing an expansion.  The pinout is shown in the  following image:   http://www.jst‐mfg.com/product/pdf/eng/eSH.pdf        Vin   This pin can be used to power the board with a regulated 5V source. If the power is  fed through this pin, the USB power source is disconnected. This is the only way  you can supply 5v (range is 5V to maximum 6V) to the board not using USB. This  pin is an INPUT.     5V   This pin outputs 5V from the the board when powered from the USB connector or  from the VIN pin of the board. It is unregulated and the voltage is taken directly  from the inputs. As an OUTPUT, it should not be used as an input pin to power the  board.     VCC   This pin outputs 3.3V through the on‐board voltage regulator. This voltage is the  same regardless the power source used (USB, Vin and Battery).     LED ON   This LED is connected to the 5V input from either USB or VIN. It is not connected to  the battery power. This means that it lits up when power is from USB or VIN, but  stays off when the board is running on battery power. This maximizes the usage of  the energy stored in the battery. It is therefore normal to have the board properly  running on battery power without the LED ON being lit.     CHARGE LED   The CHARGE LED on the board is driven by the charger chip that monitors the  current drawn by the Li‐Po battery while charging. Usually it will lit up when the  board gets 5V from VIN or USB and the chip starts charging the Li‐Po battery  connected to the JST connector.  There are several occasions where this LED will  start to blink at a frequency of about 2Hz. This flashing is caused by the following  conditions maintained for a long time (from 20 to 70 minutes): ‐ No battery is  connected to JST connector.  ‐ Overdischarged/damaged battery is connected. It  can't be recharged.  ‐ A fully charged battery is put through another unnecessary  charging cycle. This is done disconnecting and reconnecting either VIN or the  battery itself while VIN is connected.     Onboard LED   On MKR ZERO the onboard LED is connected to a dedicated pin (32) and not to 13  as on other boards. It is so suggested to use the LED_BUILTIN define .     (*) Note : DO NOT CONNECT to the male JST connector present on the board  anything else than a Li‐Po battery whose characteristics are compliant with those  indicated above. Please DO NOT POWER VIN with more than 5V.                                                         https://store.arduino.cc/usa/arduino‐mkrzero 12‐7‐17
ABX00012 价格&库存
很抱歉,暂时无法提供与“ABX00012”相匹配的价格&库存,您可以联系我们找货
ABX00012
  • 1+273.563401+34.21652
  • 10+268.1241510+33.53619
  • 25+263.4771525+32.95496
  • 50+256.4644450+32.07783
  • 100+244.80314100+30.61927
  • 250+233.93014250+29.25930
库存:259
ABX00012
    • 1+268.19940
    • 10+263.63578
    • 25+259.43150
    库存:47
