PIM110
PIM110
    PIMORONI
    PICADEPCB-ARDUINOCOMPATIBLE
PIM110 数据手册
    Picade PCB - Arduino Compatible with 3W Amp PIM110    This is an Arduino-compatible board with integrated 3W stereo amplifier designed for use in arcade projects (like our Picade). It behaves like a keyboard when plugged in via USB and has a default key-mapping (though you can reprogram it using the Arduino IDE). Connections are made using screw terminals for a solid, permanent installation. It uses the same micro-controller as the Arduino Leonardo (the ATmega32U4) and is preinstalled with the Arduino bootloader and our software. Features:         Powered by an ATmega32U4 (32KB, 2.5K RAM @ 16MHz) 6-pin ISP header for direct programming (also pre-loaded with Arduino bootloader) Includes a stereo 3W amplifier (PAM8407) for use with 4Ω speakers Appears as a USB HID device (keyboard) to the host Screw terminal contacts for four-direction Joystick, 12 buttons, and two speakers Reset button Mounting holes Power, Bootload, TX, and RX LED indicators   https://shop.pimoroni.com/products/picade-controller-board 3/31/2017
PIM110
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种晶体管输出的光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚发射极,4脚集电极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,适用于需要电气隔离的场合。
6. 应用信息:常用于电源、通信、工业控制等领域。
7. 封装信息:采用DIP6封装。
PIM110 价格&库存
很抱歉,暂时无法提供与“PIM110”相匹配的价格&库存,您可以联系我们找货
PIM110
  • 6+227.900736+29.48505
