ROB-12097
ROB-12097
    SPARKFUNELECTRONICS
    REDBOT MAINBOARD
ROB-12097 数据手册
Page 1 of 2  SparkFun RedBot Mainboard ROB-12097 ROHS       2  images are CC BY-NC-SA 3.0 Description: The SparkFun RedBot Mainboard is a robotic development platform that works with the Arduino IDE. The RedBot is a motor driver and Ardiuno combination with various headers and connections, eliminating the need to stack multiple shields. By using the RedBot accessory boards and your own chassis, you can design a robot to suit your needs. The RedBot comes pre-programmed with the Optiboot (Uno) bootloader. By simply connecting a USB mini-B cable, you can program it in the Arduino IDE using our example code, or your own. The optional add-on sensors attach to the main board via 6-pin headers or jumper cables to increase capabilities. Check out the entire RedBot family of products! Page 2 of 2 Features: • • • • • • • • • 5V Logic 6-9V Input Voltage via Barrel Jack or 2-Pin Header ATmega328P (pre-programmed) TB6612FNG Dual DC Motor Driver USB Programmable via FTDI XBee Port with HW/SW Serial Switch 2x 3-Pin Female Motor Port 2x 6-Pin Male Optional Servo Header 4x 6-Pin Male Optional Sensor Header https://www.sparkfun.com/products/12097 10/14/2015
ROB-12097 价格&库存
很抱歉,暂时无法提供与“ROB-12097”相匹配的价格&库存,您可以联系我们找货
