114990494
114990494
    SEEED(矽递科技)
    HIKEYBOARD
114990494 数据手册
  HiKey Board SKU 114990494   High performance development platform supporting AOSP,Debian,OpenEmbedded HiSilicon Kirin 6220 eight-core ARM Cortex-A53 64-bit SoC running at 1.2GHz   Description The HiKey board was the first board to be certified 96Boards Consumer Edition compatible. This is a new version in 2GB variants from LeMaker. The board is based around the HiSilicon Kirin 6220 eight-core ARM Cortex-A53 64-bit SoC running at 1.2GHz and delivering over 10,000 Dhrystone VAX MIPS total performance. The SoC also delivers high performance 3D graphics support with its ARM Mali 450-MP4 GPU. 800MHz LPDDR3 DRAM, 8GB eMMC Flash Storage and the standard 96Boards microSD v3.0 socket provide high performance. Flexible storage options and connectivity are available through 802.11a/b/g/n WiFi, Bluetooth 4.0 LE, three high speed USB 2.0 ports (1 OTG), an HDMI 1.3 1080p video output with audio, and Maker, DSI display and CSI camera interfaces. The board is the standard 96Boards credit-card form factor powered by an 8-18V DC 2A power supply. Specification SoC Kirin 620 CPU ARM® CortexTM-A53 Octa-core 64-bit up to 1.2GHz (ARM v8 instruction set) GPU ARM Mali 450-MP4, supporting 3D graphics processing, OpenGL ES 1.1/2.0, OpenVG 1.1, 2000Mega@500 MHz, 110M triangle@500 MHz, and 32G flops@500MHz RAM 2GB LPDDR3 SDRAM @ 800MHz PMU HI6553V100, MicroSD card slot Storage 8GB eMMC on board storage Ethernet Port USB2.0 expansion Wireless Wi-Fi 802.11 b/g/n 2.4GHz, Dual-mode bluetooth and bluetooth low energy, HDMI output up to FHD 1080P USB 2 x USB2.0 Host, 1 x USB 2.0 OTG Display 1 x HDMI 1.4 (Type A - full), 1 x MIPI-DSI Video 1080p@30 fps HD video encoding, supporting 1080p@30 fps HD camera, 1080p@30 fps HD video decoding, Supports H.264, SVC, MPEG1/2/4, H.263, VC-1, WMV9, DivX, RV8/9/10, AVS, VP8 Audio HDMI output Camera 1 x MIPI-CSI Expansion 40 pin low speed expansion connector: +1.8V, +5V, SYS_DCIN, GND, UART, I2C, SPI, PCM, Interface PWM,GPIO x12, 60 pin high speed expansion connector: SDIO, MIPI_DSI, MIPI_CSI LED 1 x WiFi activity LED(Yellow), 1 x BT activity LED (Blue), 4 x User LEDs (Green) Power Button Button Power on/off Reset the system Power Source 8V~18V@3A, Plug specification is inner diameter 1.7mm and outer diameter 4.8mm OS Support Android 4.2/Linux Size 85mm x 55mm Part List   1 x Hikey 1 x Power Jack Convertor                                         Copyright © 2008-2016 Seeed Development Limited All rights reserved
114990494 价格&库存
很抱歉,暂时无法提供与“114990494”相匹配的价格&库存,您可以联系我们找货
  • 1+1233.299691+159.49919
