microcontrollers supported
Supports 3.3V and 5V devices
Easily add extra boards
Four connectors for each port
Fast USB 2.0 programmer and
The ultimate PIC® board
Dual Power Supply
mikroBUS™ sockets
Amazing Connectivity
In-Circuit Debugger
USER'S GUIDE
EasyPIC PRO
v7
To our valued customers
From the day one, we in MikroElektronika gave ourselves the highest possible goals in pursuit of excellence.
That same day, the idea of EasyPIC™ development board was born. And we all grew together with EasyPIC™.
In its each and tiniest piece we had put all of our energy, creativity and sense of what’s best for an engineer.
I’ve personally assembled hundreds of early EasyPIC™ boards myself with my home soldering iron.
EasyPIC PRO™ follows the same path. With the new 7th generation of high pin count PIC® boards it emerged
as a unified and clear concept, supporting both 5V and 3.3V microcontrollers. Now we proudly say that it's
one of a kind in the world - good looking, powerful and easy to use.
You made the right choice. But the fun has only just begun!
Nebojsa Matic,
Owner and General Manager
of MikroElektronika
Table of contents
Introduction
Communication
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
04
UART via RS-232 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
22
It's good to know . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
05
UART via USB . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
23
USB device communication . . . . . . . . . . . . . . . . . . . . . . . .
24
Ethernet communication . . . . . . . . . . . . . . . . . . . . . . . . . .
25
Power Supply
Dual power supply . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
06
Displays
Default MCU card
Supported microcontrollers . . . . . . . . . . . . . . . . . . . . . . . .
08
Programmer/debugger
LCD 2x16 characters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
26
GLCD 128x64px . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
27
Touchpanel controller . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
28
On-board programmer . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
12
Other modules
Installing programmer drivers . . . . . . . . . . . . . . . . . . . . . .
14
Piezo Buzzer . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
29
Programming software . . . . . . . . . . . . . . . . . . . . . . . . . . . .
15
DS1820 - Digital Temperature Sensor . . . . . . . . . . . . . .
30
mikroICD™ - In Circuit Debugger . . . . . . . . . . . . . . . . . . .
16
LM35 - Analog Temperature Sensor . . . . . . . . . . . . . . . .
31
ADC inputs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
32
I2C EEPROM . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
33
Connectivity
Input/Output Group . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
18
Output voltages . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
34
mikroBUS™ sockets . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Additional GNDs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
35
Click Boards™ are plug and play . . . . . . . . . . . . . . . . . . . .
21
What’s Next? . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
36
page 3
introruction
Introduction
For the first time in history we have managed to combine all the features
of BIGPIC6 and LV18F v6 boards, which supported high pin count PICs
into the unique EasyPIC™ PRO v7. Supporting microcontrollers in both 5V
and 3.3V power supply technology, this board is truly fantastic tool for
development. We have put a lot of effort into board design, making it
easy to use, and we have placed lots of modules that will help you in
your work. Newly redesigned MCU sockets are here to stay. They are
well organized and cover all high-pin-count PIC® microcontrollers in
TQFP packaging. We carefully picked high-quality components and
chose a 2.4mm PCB, which makes this board especially durable.
We hope you will enjoy it as much as we do.
EasyPIC PRO™ v7 Development Team
Two Connectors for each port
3.3V and 5V power supply
Amazing connectivity
Everything is already here
For easier connections
mikroProg on board
Multimedia peripherals
mikroBUS support
EasyPIC PRO™ v7 is all about
connectivity. Having two
different connectors for
each port, you can connect
accessory boards, sensors and
your custom electronics easier
then ever before.
Powerful on-board mikroProg™
programmer and In-Circuit
debugger can program
and debug nearly 100
microcontrollers. You will
need it, whether you are a
professional or a beginner.
EasyPIC PRO™ v7 is among few
development boards which
support both 3.3V and 5V
microcontrollers. This feature
greatly increases the number of
supported MCUs.It’s like having
two boards instead of one!
Just plug in your mikroBUS™
board, and it’s ready to work.
We picked up a set of the
most useful pins you need
for development and made a
pinout standard you will enjoy
using.
EasyPIC PRO
v7
page 4
introduction
It's good to know
PIC18F87K22 is the default microcontoller!
PIC18F87K22 is the default chip of EasyPIC PRO™ v7.
Featuring nanoWatt XLP technology, it has 16 MIPS
System Specification
- Great choice for both beginners and
professionals
operation, 128K bytes of linear program memory,
- Rich with modules
3896 bytes of linear data memory, and support for
- Comes with examples for mikroC,
a wide range of power supply from 1.8V to 5V. It’s
mikroBasic and mikroPascal compilers
loaded with great modules: 69 General purpose I/O
pins, 24 Analog Input pins (AD), internal Real time
power supply
7–23V AC or 9–32V DC
or via USB cable (5V DC)
power consumption
~90mA at 5V when all peripheral
modules are disconnected
board dimensions
266 x 220mm (10.47 x 8.66 inch)
clock and calendar (RTCC), support for Capacitive
Touch Sensing using Charge Time Measurement Unit
(CTMU), six 8-bit timers and five 16-bit timers. It
weight
475g (1.0472 lbs)
also has ten CCP modules, three Comparators and
two MSSP modules which can be either SPI or I2C.
Package contains
1
Damage resistant
protective box
EasyPIC PRO
2
EasyPIC PRO™ v7
board in antistatic bag
3
USB cable
4
User Manuals and
Board schematics
v7
page 5
power supply
Power supply
Board contains switching power supply
that creates stable voltage and
current levels necessary for
powering each part of the
board. Power supply section
contains two power regulators:
MC34063A, which generates
VCC-5V, and MC33269DT3.3 which
creates VCC-3.3V power supply, thus making
the board capable of supporting both 5V and 3.3V
microcontrollers. Power supply unit can be powered in
two different ways: with USB power supply, and using external
adapters via adapter connector (CN19) or additional screw terminals
(CN18). External adapter voltage levels must be in range of 9-32V DC and
7-23V AC. Use jumper J2 to specify which power source you are using, and jumper J1
to specify whether you are using 5V or 3.3V microcontroller. Upon providing the power using
either external adapter, or USB power source, you can turn the board on using SWITCH 1 (Figure 3-1).
Figure 3-1: Dual power supply unit of EasyPIC PRO™ v7
Figure 3-2: Dual power supply unit schematics
EasyPIC PRO
v7
page 6
power supply
Smart engineering of EasyPIC PRO™ v7 develop
ment board allowed us to support both 3.3V and
5V microcontrollers on a single board, which is
almost 100 high pin count PIC® devices.
Power supply:
via DC connector or screw terminals
(7V to 23V AC or 9V to 32V DC),
Power consumption:
up to 600mA (depending on how many
on-board modules are currently active)
How to power the board?
1. With USB cable
1
2
3
4
5
6
Set J2 jumper to
USB position
To power the board with USB cable, place jumper J2
in USB position, and place jumper J1 in 5V or 3.3V
position, depending on which microcontroller you are
using. You can then plug in the USB cable as shown on
images 1 and 2 , and turn the power switch ON.
2. Using adapter
Set J2 jumper to
EXT position
To power the board via adapter connector, place jumper
J2 in EXT position, and place jumper J1 in 5V or 3.3V
using. You can then plug in the adapter cable as shown
on images 3 and 4 , and turn the power switch ON.
3. With laboratory power supply
Set J2 jumper to
EXT position
To power the board using screw terminals, place jumper
on images 5 and 6 , and turn the power switch ON.
EasyPIC PRO
v7
page 7
supported MCUs
Default MCU card
Microcontrollers are supported using specialized MCU cards containing 104 pins, which
are placed into the on-board female MCU socket. Currently, there are three types of cards:
Standard 80-pin TQFP, Ethernet 80-pin TQFP card and Ethernet 100-pin TQFP
PF card. Standard card supports 80-pin PIC18Fxxxx, PIC18FxxJxx and PIC18FxxKxx
microcontrollers, with or without USB support. It contains several SMD jumpers, which
are supposed to be placed or removed, depending on the microcontroller.
2
Default MCU card that comes with the EasyPIC PRO™ v7 package is shown on Figure
4-1. It contains PIC18F87K22 microcontroller which is loaded with on-chip modules
and is a great choice for both beginners and professionals. After testing and building
the final program, this card can also be taken out of the board socket and used in your
final device.
1
PIC18F87K22 microcontroller. Featuring nanoWatt XLP™ technology, it has
16 MIPS operation, 128K bytes of linear program memory, 3896 bytes of linear
data memory, and support for a wide range of power supply from 1.8V to 5V.
2
16MHz crystal oscillator. We carefully chose the most convenient crystal
value that provides clock frequency which can be used directly, or with the PLL
multipliers and dividers to create higher MCU clock value.
3
VCAP jumper. Some PIC18FK and all PIC18FJ microcontrollers have cores that
work on 1.8V-2.5V voltage range, and peripherals that work with 3.3V and
5V voltages. Internally, those microcontrollers have power regulators which
adjust the core voltage levels. In order for those devices to have a stable
operation of the core, manufacturer recommends that decoupling capacitive
filters should be provided, and connected between specific microcontroller
pins designated with VCAP and GND. This MCU card provides a VCAP jumper
which is used for this purpose. Jumper is removed by default.
4
USB communication lines. These two jumpers, when in USB position, connect
D+ and D- lines of the on-board USB connector with RF3 and RF4 microcontroller
pins. Since PIC18F87K22 doesn't support USB, jumpers are in I/O position.
5
VUSB line jumper. For PIC18F8xJ5x devices, this jumper should be connected
to VCC for enabling internal USB controller. Since PIC18F87K22 doesn't support
USB, this jumper is in I/O position.
6
ENVREG selection jumper. PIC18FJ and PIC18FK microcontrollers are using
internal voltage regulator which is enabled by placing this jumper in VCC
position.
6
5
1
3
4
Figure 4-1: Default MCU card with PIC18F87K22
EasyPIC PRO
v7
page 8
supported MCUs
VCC
RJ3
RB1
RB3
RB5
RB7
RC4
RC2
RJ6
VCC
HD4D
103
101
99
97
95
93
91
89
87
85
83
81
79
GND 104
102
100
98
96
94
92
90
88
86
84
82
GND 80
RJ2
RB0
RB2
RB4
RB6
RC5
RC3
RJ7
VCC
VCC
E2
10uF
VCC
80
79
78
77
76
75
74
73
72
71
70
69
68
67
66
65
64
63
62
61
RD1
RD2
RD3
RD4
RD5
RD6
RD7
RJ0
RJ1
RH1
RH0
RE2
RE3
RE4
RE5
RE6
RE7
RD0
E1
10uF
RH1
RH0
RE2
RE3
RE4
RE5
RE6
RE7
RD0
VDD
GND
RD1
RD2
RD3
RD4
RD5
RD6
RD7
RJ0
RJ1
U1
GND
VCC
J1B
E3
10uF
HD1A
J3
VCC
RF4
RF4/DP
DP
RF3
RF3/DM
DM
J4
VCC
RF1
RF1/USB
VCC
RF0
ENR/RF0
RJ2
RJ3
RB0
RB1
RB2
RB3
RB4
RB5
RB6
C1
OSC2
OSC1
GND
RJ4
RC6
RC1
RA5
22pF
RA1
RA3
X1
16MHz
RB7
RC5
RC4
RC3
RC2
RJ7
RJ6
C2
RF1
RH5
GND
22pF
78
76
74
72
70
68
66
64
62
60
58
56
54
77
75
73
71
69
67
65
63
61
59
57
55
53
VCC
RJ5
RC7
RC0
RA4
RA0
RA2
RF0
RH4
VCC
HD3C
VCC
VCC
C3
100nF
VCC
C4
100nF
VCC
C5
100nF
E6
10uF
VCC
J5
E5
10uF
RF7
RF5
RF3
RH7
DP
VCC
VCC
RH3
RE0
RG1
RG3
RG4
27
29
31
33
35
37
39
41
43
45
47
49
51
HD2B
28
GND
30
RH2
32
RE1
34
RG0
36
RG2
38 MCLR#
40
42
RF6
44
RF4
46
RF2
48
RH6
50
DM
52
GND
E4
10uF
PIC18F87K22
80pin TQFP
60
59
58
57
56
55
54
53
52
51
50
49
48
47
46
45
44
43
42
41
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
J2
VCAP
RF7
RF6
RF5
RF4/DP
RF3/DM
RF2
RH7
RH6
RJ2
RJ3
RB0
RB1
RB2
RB3
RB4
RB5
PGC/RB6
GND
OSC2/RA6
OSC1/RA7
VDD
PGD/RB7
RC5
RC4
RC3
RC2
RJ7
RJ6
RA5
RA4
RC1
RC0
RC6
RC7
RJ4
RJ5
RJ0
RD6
RD4
RD2
RD0
RE6
RE4
RE2
RH1
GND
RA3
RA2
RA1
RA0
2
4
6
8
10
12
14
16
18
24
26
RH2
RH3
RE1
RE0
RG0
RG1
RG2
RG3
MCLR
RG4
GND
VCCcore/Vcap/VDD
RF7
RF6
RF5
RF4/D+
RF3/DRF2
RH7
RH6
RH5
RH4
RF1/VUSB
ENVREG/RF0
AVCC
AGND
RA3
RA2
RA1
RA0
GND
VDD
RA5
RA4
RC1
RC0
RC6
RC7
RJ4
RJ5
RJ1
RD7
RD5
RD3
RD1
RE7
RE5
RE3
RH0
VCC
1
3
5
7
9
11
13
15
17
19
21
23
25
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
RH5
RH4
RF1/USB
ENR/RF0
VCC
RH2
RH3
RE1
RE0
RG0
RG1
RG2
RG3
MCLR#
RG4
Figure 4-2: Default MCU card schematics
EasyPIC PRO
v7
page 9
supported MCUs
How to properly place your MCU card into the socket?
Before you plug the microcontroller card into
the socket, make sure that the power supply is
turned off. Images below show how to correctly
plug the card. First make sure that MCU card
orientation matches the silkscreen outline on the
1
Figure 4-2: On-board
MCU socket has silksreen
markings which will help
you to correctly orient the
MCU card before inserting.
EasyPIC PRO™ v7 board MCU socket. Place the MCU
card over the socket, so each male header encloses
the right angle with the female socket, as shown
in Figure 4-2. Then put the MCU card slowly down
until all the pins match the socket. Check again if
2
Figure 4-3: Place the
MCU card on the socket
so the pins are aligned
correctly.
everything is placed correctly and press the MCU
card until it is completely plugged into the socket
as shown in Figure 4-3. If done correctly, all pins
should be fully inserted. Only now you can turn on
the power supply.
3
Figure 4-4 Properly
placed MCU card will
have equally leveled
pins.
EasyPIC PRO
v7
page 10
supported MCUs
Other supported MCU cards
MikroElektronika currently offers total of five populated MCU cards with
different microcontrollers. You can also purchase empty PCB cards that you
can populate on your own and solder any supported microcontroller you need in
your development. This way your EasyPIC PRO™ v7 board becomes truly flexible and
reliable tool for almost any of your PIC® projects. MCU cards can also be used in your final
devices. For complete list of currently available MCU cards, please visit the board webpage:
http://www.mikroe.com/eng/products/view/815/easypic-pro-v7-development-system/
List of other available populated MCU cards
Besides default MCU card that comes with EasyPIC PRO™ v7, MikroElektronika offers three other standard 80-pin TQFP
cards with PIC18F87J50, PIC18F8520 and PIC18F8722 microcontrollers. Additional 80-pin TQFP Ethernet card with
PIC18F87J60 enables you to utilize the ethernet connector and build ethernet applications easily.
1
Figure 4-5: Standard 80-pin
MCU card with PIC18F87J50,
which supports USB.
EasyPIC PRO
2
Figure 4-6: Standard
80-pin MCU card with
PIC18F8520.
3
Figure 4-7: Standard
PIC18F8722.
with
Ethernet!
support
4
Figure 4-8: Ethernet
80-pin MCU card
with PIC18F87J60
microcontroller with
internal ethernet module.
v7
page 11
programming
On-board
programmer
What is mikroProg™?
mikroProg™ is a fast USB 2.0 programmer with mikroICD™ hardware In-Circuit Debugger. Smart engineering allows mikroProg™
to support all nearly 100 PIC18 devices in a single programmer. It also features a powerful mikroICD™ debugger which will be of
great help in your development. Outstanding performance and easy operation are among it's top features.
Why so many LEDs?
DATA BUS
Figure 5-1: mikroProg™ block schematics
Three LEDs indicate specific programmer
operation. Link LED lights up when USB
link is established with your PC, Active
LED lights up when programmer is active.
Data is on when data is being transfered
between the programmer and PC software
(compiler or mikroProg Suite™ for PIC®).
How do I start?
In order to start using mikroProg™, and program your
microcontroller, you just have to follow two simple
steps:
1. Install the necessary software
- Install USB drivers
- Install mikroProg Suite™ for PIC® software
2. Power up the board, and you are ready to go.
- Plug in the programmer USB cable
- LINK LED should light up.
EasyPIC PRO
v7
page 12
Here's the list of all microcontrollers which are supported with mikroProg™ programmer and debugger on EasyPIC PRO™ v7 board. The list may grow with each new
release of mikroProg Suite™ for PIC® software.
PIC18F83J90
PIC18F87J93
PIC18F8527
PIC18F8490
PIC18F65J15
PIC18F44J11
PIC18F84J90
PIC18F86J50
PIC18F6620
PIC18F8520
PIC18F66J10
PIC18F45J11
PIC18F85J90
PIC18F86J55
PIC18F6720
PIC18F8620
PIC18F66J15
PIC18F46J11
PIC18F83J11
PIC18F87J50
PIC18F6310
PIC18F8720
PIC18F67J10
PIC18F44J50
PIC18F84J11
PIC18F85J50
PIC18F6410
PIC18F8393
PIC18F66J11
PIC18F45J50
PIC18F85J11
PIC18F86J60
PIC18F6390
PIC18F8493
PIC18F66J16
PIC18F46J50
PIC18F85J10
PIC18F86J65
PIC18F6490
PIC18F63J90
PIC18F67J11
PIC18F67J60
PIC18F85J15
PIC18F87J60
PIC18F6585
PIC18F64J90
PIC18F65J50
PIC18LF43K22
PIC18F86J10
PIC18F96J60
PIC18F6680
PIC18F65J90
PIC18F66J55
PIC18F46K22
PIC18F86J15
PIC18F96J65
PIC18F8310
PIC18F63J11
PIC18F67J50
PIC18F45K22
PIC18F87J10
PIC18F97J60
PIC18F8410
PIC18F64J11
PIC18F43K20
PIC18F44K22
PIC18F86J11
PIC18F85K22
PIC18F8585
PIC18F65J11
PIC18F44K20
PIC18F43K22
PIC18F86J16
PIC18F86K22
PIC18F8680
PIC18F66J90
PIC18F45K20
PIC18F66J60
PIC18F87J11
PIC18F87K22
PIC18F8622
PIC18F67J90
PIC18F46K20
PIC18F66J65
PIC18F86J90
PIC18F85K90
PIC18F8627
PIC18F66J93
PIC18LF46K22
PIC18F87J90
PIC18F86K90
PIC18F8722
PIC18F67J93
PIC18LF45K22
PIC18F86J93
PIC18F87K90
PIC18F8390
PIC18F65J10
PIC18LF44K22
Programming with ICD2/ICD3
EasyPIC PRO™ v7 is equipped with RJ-12 connector
compatibile with Microchip® ICD2® and ICD3® external
programmers. This way you can override the on-board
mikroProg™ programmer and In-Circuit Debugger, and
use other programming tools with the board. Insert your
ICD programmer cable into connector CN8, as shown in
images 1 and 2 .
EasyPIC PRO
1
2
v7
page 13
programming
List of microcontrollers supported with mikroProg™
programming
On-board mikroProg™ requires drivers in order to work.
Drivers can be found on the link below:
http://www.mikroe.com/downloads/get/1201/
mikroprog_for_pic_drivers_v200.zip
When you locate the drivers, please extract files from
the ZIP archive. Folder with extracted files contains sub
folders with drivers for different operating systems.
Depending on which operating system you use, choose
adequate folder and open it.
In the opened folder you should
be able to locate the driver
setup file. Double click on setup
file to begin installation of the
programmer drivers.
Step 1 - Start Installation
Step 2 - Accept EULA
Welcome screen of the installation. Just click on Next
button to procede.
Carefully read End User License Agreement. If you
agree with it, click Next to procede.
Step 3 - Installing drivers
Drivers are installed automatically in a matter of
seconds.
Step 4 - Finish installation
You will be informed if the dirvers are installed correctly.
Click on Finish button to end installation process.
EasyPIC PRO
v7
page 14
On-board mikroProg™ programmer requires special programming software called
mikroProg Suite™ for PIC®. This software is used for programming all of Microchip®
microcontroller families, including PIC10, PIC12, PIC16, PIC18, dsPIC30/33, PIC24 and
PIC32. Software has intuitive interface and SingleClick™ programming technology.
To begin, first locate the installation archive on our website:
programming
Installation wizard - 6 simple steps
http://www.mikroe.com/downloads/get/1201/mikroprog_suite_for_pic_v229.zip
After downloading, extract the package and double click the executable setup
file, to start installation.
EasyPIC PRO
Step 2 - Accept EULA and continue
Step 3 - Install for All users
Step 4 - Choose destination folder
Step 5 - Installation in progress
Step 6 - Finish Installation
v7
page 15
programming
mikroICD - In Circuit Debugger
What is Debugging?
Every developer comes to a point where he has to monitor the
code execution in order to find errors in the code, or simply
to see if everything is going as planed. This hunt for bugs, or
errors in the code is called debugging. There are two ways
to do this: one is the software simulation, which enables
you to simulate what is supposed to be happening on the
microcontroller as your code lines are executed, and the other,
most reliable one, is monitoring the code execution on the
chip itself. And this latter one is called In-Circuit debugging.
"In-Circuit" means that it is the real deal - code executes right
on the target device.
How do I use the debugger?
When you build your project for debugging, and program
the microcontroller with this HEX file, you can start the
debugger using [F9] command. Compiler will change layout
to debugging view, and a blue line will mark where code
execution is currently paused. Use debugging toolbar in
the Watch Window to guide the program execution, and
stop anytime. Add the desired variables to Watch Window and
monitor their values. Complete guide to using mikroICD™ with
your compiler is provided with the EasyPIC PRO™ v7 package.
mikroICD
bugger
in-circuit de
Figure 5-2: mikroICD™ manual
explains debugging thoroughly
What is mikroICD™?
The on-board mikroProg™ programmer supports mikroICD™ - a
highly effective tool for a Real-Time debugging on hardware
level. The mikroICD™ debugger enables you to execute your
program on the host PIC microcontroller and view variable
values, Special Function Registers (SFR), RAM, CODE and
EEPROM memory along with the mikroICD™ code execution
on hardware. Whether you are a beginner, or a professional,
this powerful tool, with intuitive interface and convenient
set of commands will enable you to track down bugs quickly.
mikroICD™ is one of the fastest, and most reliable debugging
tools on the market.
Supported Compilers
All MikroElektronika compilers, mikroC, mikroBasic and
mikroPascal for PIC®, dsPIC® and PIC32® natively support
mikroICD™. Specialized mikroICD DLL module allows compilers to
exploit the full potential of fast hardware debugging. Along with
compilers, make sure to install the appropriate programmer
drivers and mikroProg Suite for PIC® programming software,
as described on pages 14 and 15.
Figure 5-3: mikroC PRO for PIC® compiler in debugging view, with SFR registers in Watch Window
EasyPIC PRO
v7
page 16
Here is a short overview of which debugging commands are supported in MikroElektronika compilers. You can see what each command does,
and what are their shortcuts when you are in debugging mode. It will give you some general picture of what your debugger can do.
Toolbar
Icon
Command Name
Shortcut
Description
Start Debugger
[F9]
Starts Debugger.
Run/Pause Debugger
[F6]
Run/Pause Debugger.
Stop Debugger
[Ctrl + F2]
Stops Debugger.
Step Into
[F7]
Executes the current program line, then halts. If the executed
program line calls another routine, the debugger steps into the
routine and halts after executing the first instruction within it.
Step Over
[F8]
Executes the current program line, then halts. If the executed program
line calls another routine, the debugger will not step into it. The whole
routine will be executed and the debugger halts at the first instruction
following the call.
Step Out
[Ctrl + F8]
Executes all remaining program lines within the subroutine. The
debugger halts immediately upon exiting the subroutine.
Run To Cursor
[F4]
Executes the program until reaching the cursor position.
Toggle Breakpoint
[F5]
Toggle breakpoints option sets new breakpoints or removes those
already set at the current cursor position.
Show/Hide breakpoints
[Shift+F4]
Shows/Hides window with all breakpoints
Clears breakpoints
[Shift+Ctrl+F5]
Delete’s selected breakpoints
Jump to interrupt
[F2]
Opens window with available interrupts (doesnt work in mikroICD™
mode)
EasyPIC PRO
v7
page 17
programming
mikroICD™ commands
connectivity
Input/Output Group
One of the most distinctive features of EasyPIC
PRO™ v7 are it’s Input/Output PORT groups. They
add so much to the connectivity potential of the
board.
Everything is groupped together
It took us a while to realize that having PORT headers, PORT buttons and
Figure 6-1: I/O group contains PORT headers, tri-state pull
PORT LEDs next to each other, and groupped together, makes development
up/down DIP switch, buttons and LEDs all in one place
easier, and the entire EasyPIC PRO™ v7 cleaner and well organized. We have also
provided an additional PORT headers on the right side of the board, so you can access any pin you want from that side of the board too.
Tri-state pull-up/down DIP switches
Figure 6-2:
Tri-state DIP
switch on PORTC
Tri-state DIP switches, like SW3 on Figure 6-2, are
used to enable 4K7 pull-up or pull-down resistor on
any desired port pin. Each of these switches has three
states:
1. middle position disables both pull-up and pulldown feature from the PORT pin
2. up position connects the resistor in pull-up state
to the selected pin
3. down position connects the resistor in pull-down
state to the selected PORT pin.
DATA BUS
Button press level tri-state DIP
switch is used to determine
which logic level will be
applied to port pins when
buttons are pressed
Figure 6-3: Schematic of the single I/O group connected to microcontroller PORTC
EasyPIC PRO
v7
page 18
connectivity
Headers Buttons
LEDs
With enhanced connectivity as one of the key features
of EasyPIC PRO™ v7, we have provided two connection
headers for each PORT. I/O PORT group contains one
male IDC10 2x5 header (like CN22 Figure 6-3). There
is one more IDC10 header available on the right side
of the board, next to DIP switches. These headers are
all compatible with over 70 MikroElektronika accessory
boards, and enable simple connection.
LED (Light-Emitting
Diode) is a highly
efficient electronic
light source. When
connecting
LEDs,
Microcontroller
it is neccessary
SMD resistor to place a current
limiting current limiting resistor in
through the LED series so that LEDs
are provided with
the current value specified by the manufacturer. The
current varies from 0.2mA to 20mA, depending on the
type of the LED and the manufacturer. The EasyPIC
PRO v7 board uses low-current LEDs with typical
current consumption of 0.2mA or 0.3mA, depending
of VCC voltage selection.
Board contains 69 LEDs
which can be used for visual
indication of the logic state
on PORT pins. An active LED
indicates that a logic high
(1) is present on the pin. In
order to enable PORT LEDs,
it is necessary to enable the
Figure 6-6: SW6.1
corresponding DIP switch on
through SW6.4
SW6 (Figure 6-6).
switches are used to
enable PORT LEDs
The logic state of all microcontroller
digital inputs may be changed using
push buttons. Tri-state DIP switch
SW13 is available for selecting
which logic state will be applied to
corresponding MCU pin when button is
pressed, for each I/O port separately.
If you, for example, place SW13.3 in
VCC position, then pressing of any
push button in PORTC I/O group will
Figure 6-5:
Button press apply logical one to the appropriate
microcontroller pin. The same goes for
level DIP
GND. If the DIP switch is in the middle
switches
position, then all push buttons of the
(tri-state)
associated PORT will be disconnected
from the microcontroller pin.
Reset Button
Figure 6-4: IDC10 male headers enable easy
connection with MikroElektronika accessory boards
EasyPIC PRO
In the far upper right section of the
board, there is a RESET button, which
can be used to manually reset the
microcontroller. This button is directly
connected to the microcontroller
MCLR pin.
v7
page 19
connectivity
mikroBUS sockets
Easier connectivity and simple configuration are imperative in modern electronic
devices. Success of the USB standard comes from it’s simplicity of usage and high
and reliable data transfer rates. As we in MikroElektronika see it, Plug-and-Play
devices with minimum settings are the future in embedded world too. This is why
our engineers have come up with a simple, but brilliant pinout with lines that most
of today’s accessory boards require, which almost completely eliminates the need
of additional hardware settings. We called this new standard the mikroBUS™.
EasyPIC PRO™ v7 is a development board which supports mikroBUS™ with three
on-board sockets. As you can see, there are no additional DIP switches, or jumper
selections. Everything is already routed to the most appropriate pins of the
microcontroller sockets.
mikroBUS™ host connector
Each mikroBUS™ host connector consists of two 1x8 female headers containing
pins that are most likely to be used in the target accessory board. There are three
groups of communication pins: SPI, UART and I2C communication. There are also
single pins for PWM, Interrupt, Analog input, Reset and Chip Select. Pinout
contains two power groups: +5V and GND on one header and +3.3V and GND on
the other 1x8 header.
mikroBUS™ pinout explained
AN - Analog pin
RST - Reset pin
CS - SPI Chip Select line
SCK - SPI Clock line
MISO - SPI Slave Output line
MOSI - SPI Slave Input line
+3.3V - VCC-3.3V power line
GND - Reference Ground
PWM - PWM output line
INT - Hardware Interrupt line
RX - UART Receive line
TX - UART Transmit line
SCL - I2C Clock line
SDA - I2C Data line
+5V - VCC-5V power line
DATA BUS
Figure 7-1: Connection schematics of on-board mikroBUS™ host sockets
EasyPIC PRO
v7
page 20
connectivity
ADC click™
RFiD click™
BlueTooth click™
MP3 click™
GSM click™
Click Boards are plug-n-play!
MikroElektronika portfolio of over 200 accessory boards is now enriched by
an additional set of mikroBUS™ compatible Click Boards™. Almost each month
several new Click boards™ are released. It is our intention to provide the
community with as much of these boards as possible, so you will be able to
expand your EasyPIC™ PRO v7 with additional functionality with literally zero
LightHz click™
microSD click™
EasyPIC PRO
hardware configuration. Just plug and play. Visit the Click boards™ webpage
for the complete list of available boards:
DAC click™
http://www.mikroe.com/click/
DIGIPOT click™
SHT1x click™
v7
page 21
communication
UART via RS-232
Enabling RS-232
In order to enable RS-232
communication, you must push
SW5.3 (RG1) and SW5.4 (RG2)
to ON position. This connects the
RX and TX lines to appropriate
microcontroller pins and its second
UART module.
The UART (universal asynchronous receiver/
transmitter) is one of the most common ways of
exchanging data between the MCU and peripheral
components. It is a serial protocol with separate
transmit and receive lines, and can be used for fullduplex communication. Both sides must be initialized
with the same baudrate, otherwise the data will not be
received correctly.
RS-232 serial communication is performed through a 9-pin
SUB-D connector and the microcontroller UART module. In
order to enable this communication, it is necessary
to establish a connection between RX and TX
lines on SUB-D connector and the same pins on
the target microcontroller using DIP switches.
Since RS-232 communication voltage levels
are different than microcontroller logic
levels, it is necessary to use a RS232 Transceiver circuit, such as
MAX3232 as shown on
Figure 8-1.
DATA BUS
Figure 8-1: RS-232 connection schematics
EasyPIC PRO
v7
page 22
Enabling USB-UART
communication
UART via USB
Modern PC computers, laptops and notebooks are
no longer equpped with RS-232 connectors and
UART controllers. They are nowdays replaced with USB
connectors and USB controllers. Still, certain technology
enables UART communication to be done over USB connection.
Controllers such as FT232RL from FTDI® convert UART signals to
the appropriate USB standard. In order to use USB-UART module on
EasyPIC PRO™ v7, you must first install FTDI drivers on your computer.
Drivers can be found on link bellow:
http://www.ftdichip.com/Drivers/VCP.htm
In order to enable USB-UART
SW5.1 (RC6) and SW5.2 (RC7)
microcontroller pins and its first
UART module.
USB-UART communication is being done through a FT232RL
controller, USB connector (CN12), and microcontroller UART
module. To establish this connection, you must connect RX
and TX lines of the microcontroller to the appropriate
input and output pins of the FT232RL. This
selection is done using DIP switches
SW5.1 and SW5.2.
DATA BUS
Figure 9-1: USB-UART connection schematics
EasyPIC PRO
v7
page 23
communication
USB device
communication
Enabling USB
DATA BUS
USB is the acronym for Universal Serial Bus.
This is a very popular industry standard that
defines cables, connectors and protocols used
for communication and power supply between
computers and other devices. EasyPIC PRO™ v7
contains USB DEVICE connector (CN9) which
enables microcontrollers that support USB
communication to establish a connection
with the target host (eg. PC, Laptop, etc). USB
data lines comming from the MCU socket are
dedicated to USB connector only, and are
not available via PORT headers. To enable
USB communication, you have to solder SMD
jumpers on the MCU card to the appropriate
USB position. This only makes sense if the
MCU card contains microcontroller with
integrated USB controller. One of these
cards is Standard 80-pin MCU card with
PIC18F87J50 microcontroller.
Microcontroller with USB support
should be soldered to the MCU
card with dedicated USB SMD
jumpers. Make sure to solder RF1,
RF3 and RF4 jumpers to USB
position in order to connect USB
lines to USB connector.
Figure 10-1: USB connection schematics
EasyPIC PRO
v7
page 24
communication
Ethernet is a popular computer networking
technology for local area networks (LAN).
Systems communicating over Ethernet
divide a stream of data into individual
packets called frames. Each frame contains
source and destination addresses and errorchecking data so that damaged data can be
detected and re-transmitted. EasyPIC PRO™
v7 features standard RJ-45 connector which
enables microcontrollers that support Ethernet
communication to establish a connection with
a computer, router or other devices. All four
ethernet lines (TPOUT+, TPOUT-, TPIN+ and
TPIN-) are routed to the MCU card socket.
Only microcontrollers containing embedded
ethernet module soldered to 100-pin or 80pin TQFP Ethernet MCU cards can use these
lines and utilize ethernet connector. Additional
signalization LEDs are available on the board.
EasyPIC PRO
Enabling Eth. LEDs
DATA BUS
Ethernet
communicaton
Figure 11-1:
Ethernet connection schematics
In order to enable ethernet LEDs,
you must enable SW5.5 (RA0) and
SW5.6 (RA1) DIP switches. This
connects the LEDA and LEDB lines
to appropriate microcontroller pins.
v7
page 25
displays
LCD 2x16 characters
Liquid Crystal Displays or LCDs are cheap and
popular way of representing information to the
end user of some electronic device. Character
LCDs can be used to represent standard and
custom characters in the predefined number of
fields. EasyPIC PRO™ v7 provides the connector
and the necessary interface for supporting 2x16
character LCDs in 4-bit mode. This type of display has
two rows consisted of 16 character fields. Each field is a
7x5 pixel matrix. Communication with the display module
is done through CN14 display connector. Board is fitted with
uniquely designed plastic display distancer, which allows the LCD
module to perfectly and firmly fit into place.
IMPORTANT: Make sure to turn off the power supply before placing LCD onto
the board. Otherwise your display can be permanently damaged.
DATA BUS
Figure 12-2: 2x16 LCD
Figure 12-1: On-board LCD 2x16 display connector
Connector pinout explained
GND and VCC - Display power supply lines
Vo - LCD contrast level from potentiometer P1
RS - Register Select Signal line
E - Display Enable line
R/W - Determines whether display is in Read or Write mode. It’s
always connected to GND, leaving the display in Write mode all
the time.
D0–D3 - Display is supported in 4-bit data mode, so lower half of
the data byte interface is connected to GND.
D4–D7 - Upper half of the data byte
LED+ - Connection with the backlight LED anode
LED- - Connection with the backlight LED cathode
Standard and PWM-driven backlight
We have allowed LCD backlight to be enabled in two different ways:
1. It can be turned on with full brightness using SW4.1 switch.
2. Brightness level can be determined with PWM signal from the
microcontroller, allowing you to write custom backlight controling
software. This backlight mode is enabled with SW4.3 switch.
IMPORTANT: In order to use PWM backlight both SW4.1 and SW4.3 switches must be
enabled at the same time.
EasyPIC PRO
v7
page 26
DATA BUS
Graphical Liquid Crystal Displays, or GLCDs are used to
display monochromatic graphical content, such as text,
images, human-machine interfaces and other content.
EasyPIC PRO™ v7 provides the connector and necessary
interface for supporting GLCD with resolution of 128x64
pixels, driven by the KS108 or similar display controller.
Communication with the display module is done through
CN16 display connector. Board is fitted with uniquely
displays
GLCD 128x64
GLCD module to perfectly and firmly fit into place.
Display connector is routed to PORTB (control lines)
and PORTD (data lines) of the microcontroller sockets.
Since PORTB is also used by 2x16 character LCD
display, you cannot use both displays simoutaneously.
You can control the display contrast using dedicated
potentiometer P4. Display backlight can be enabled with
SW4.2 switch, and PWM-driven backlight with SW4.3
switch.
Figure 13-1: GLCD 128x64 connection schematics
Connector
pinout explained
CS1 and CS2 - Controller Chip Select lines
VCC - +5V display power supply
GND - Reference ground
Vo - GLCD contrast level from potentiometer P4
RS - Data (High), Instruction (Low) selection line
D0–D7 - Data lines
RST - Display reset line
Vee - Reference voltage for GLCD contrast potentiometer P3
As for LCD, we have allowed GLCD backlight to be enabled in two
different ways:
1. It can be turned on with full brightness using SW4.2 switch.
IMPORTANT: In order to use PWM backlight both SW4.2 and SW4.3 switches must be
EasyPIC PRO
v7
page 27
displays
Touchpanel is a glass panel whose surface is covered
with two layers of resistive material. When the screen
is pressed, the outer layer is pushed onto the inner layer
and appropriate controllers can measure that pressure
and pinpoint its location. This is how touchpanels can be
used as an input devices. EasyPIC PRO™ v7 is equipped with
touchpanel controller and connector for 4-wire resistive
touchpanels. It can very accurately register pressure at a
specific point, representing the touch coordinates in the form
of analog voltages, which can then be easily converted to X
and Y values. Touchpanel is ment to be mounted onto the
GLCD display.
Correctly placing the touchpanel cable into the connector
DATA BUS
1
Figure 14-1: Put Touch Panel flat cable in
the connector
2
Figure 14-2: Use a tip of your finger
to push it inside
3
Figure 14-3: Now place GLCD with
Touch panel into GLCD socket
READ-X
READ-Y
Enabling Touch panel
Figure 14-4: Touch Panel
Touchpanel is enabled using SW4.5,
SW4.6, SW4.7 and SW4.8 switches.
They connect READ-X and READ-Y lines
of the touchpanel with RF5 and RF2
analog inputs, and DRIVEA and DRIVEB
with RE4 and RE5 digital outputs
on microcontroller sockets. Do not
connect additional boards or otherwise
interfere with these lines while you use
touchpanel, because you may corrupt the
results of the readings and get inacurate
touch coordinates.
Figure 14-5: Turn on switches
5 through 8 on SW4 to enable
Touch panel controller
EasyPIC PRO
v7
page 28
Piezoelectricity is the charge which accumulates in
certain solid materials in response to mechanical pressure,
but also providing the charge to the piezoelectric material
causes it to physically deform. One of the most widely
used applications of piezoelectricity is the production of
sound generators, called piezo buzzers. Piezo buzzer is
an electric component that comes in different shapes and
sizes, which can be used to create sound waves when
provided with analog electrical signal. EasyPIC PRO™ v7
comes with piezo buzzer which can be connected to RB6
microcontroller pin. Connection is established using SW4.4
DIP switch. Buzzer is driven by transistor Q1 (Figure 15-1).
Microcontrollers can create sound by generating a PWM
(Pulse Width Modulated) signal – a square wave signal,
which is nothing more than a sequence of logic zeros and
other modules
Piezo Buzzer
ones. Frequency of the square signal determines
the pitch of the generated sound, and duty cycle of
the signal can be used to increase or decrease the
volume in the range from 0% to 100% of the duty
cycle. You can generate PWM signal using hardware
capture-compare module, which is usually available in
most microcontrollers, or by writing a custom software
which emulates the desired signal waveform.
Supported sound frequencies
Piezo buzzer’s resonant frequency (where you can expect
it's best performance) is 3.8kHz, but you can also use it to
create sound in the range between 2kHz and 4kHz.
DATA BUS
TOP
VIEW
PERSPECTIVE
VIEW
Figure 15-1: Piezo
buzzer connected to
RB6 microcontroller
pin via SW4.4
Enabling Piezo Buzzer
In order to use the on-board Piezo Buzzer in
your application, you first have to connect the
transistor driver of piezo buzzer to the appropriate
microcontroller pin. This is done using SW4.4 DIP
switch. Once the switch is in ON position, it connects
the buzzer driver to RB6 microcontroller pin.
Freq = 3kHz, Duty Cycle = 50%
Freq = 3kHz,
Volume = 50%
Freq = 3kHz, Duty Cycle = 80%
Freq = 3kHz,
Volume = 80%
Freq = 3kHz, Duty Cycle = 20%
Freq = 3kHz,
Volume = 20%
EasyPIC PRO
How to make it sing?
Buzzer starts "singing" when you provide
PWM signal from the microcontroller
to the buzzer driver. The pitch of the
sound is determined by the frequency,
and amplitude is determined by the
duty cycle of the PWM signal.
Figure 15-2:
Turn ON
SW4.4 to
connect
Piezo buzzer
driver to
RB6 pin
v7
page 29
other modules
DS1820 - Digital
Temperature Sensor
DS1820 is a digital temperature sensor that uses 1-wire®
interface for it’s operation. It is
capable of measuring temperatures
within the range of -55 to 128°C,
and provides ±0.5°C accuracy for
temperatures within the range of -10 to
85°C. It requires 3V to 5.5V power supply
for stable operation. It takes maximum
of 750ms for the DS1820 to calculate
temperature with 9-bit resolution.
1-wire® serial communication enables data to be transfered over a single
communication line, while the process
itself is under the control of the master
microcontroller. The advantage of
such communication is that only one
microcontroller pin is used. Multiple
sensors can be connected on the same
line. All slave devices by default have
a unique ID code, which enables the
master device to easily identify all
devices sharing the same interface.
EasyPIC PRO™ v7 provides a separate so
cket (TS1) for the DS1820. Communica
tion line with the microcontroller is
selected with a J3 jumper.
Figure 16-5: DS1820 connected to RB7 pin
Enabling DS1820 Sensor
Figure 16-1:
DS1820 not
connected
2
Figure 16-2:
DS1820
placed in
socket
3
Figure 16-3:
DS1820
connected
to RB7 pin
4
Figure 16-4:
DS1820
connected
to RE6 pin
EasyPIC PRO™ v7 enables you to establish 1-wire® communication between DS1820
and the microcontroller over RE6 or RB7 pins. The selection of either of those two
lines is done using J3 jumper. When placing the sensor in the socket make sure that
half-circle on the board’s silkscreen markings matches the rounded part of the DS1820
sensor. If you accidently connect the sensor the other way, it may be permanently
damaged and you might need to replace it with another one. Make sure to disconnect
other peripherals (except 1-wire), LEDs and additional pull-up or pull-down resistors
from the interface lines in order not to interfere with signal/data integrity.
DATA BUS
1
EasyPIC PRO
v7
page 30
The LM35 is a low-cost precision
integrated-circuit temperature sensor,
whose output voltage is linearly
proportional to the Celsius (Centigrade)
temperature. The LM35 thus has an
advantage over linear temperature
sensors calibrated in ° Kelvin, as the
user is not required to subtract a large
constant voltage from its output to
obtain convenient Centigrade scaling.
The LM35 does not require any external
calibration or trimming to provide
typical accuracies of ±¼°C at room
temperature and ±¾°C over a full -55
to +150°C temperature range. It has
a linear + 10.0 mV/°C scale factor
and less than 60 μA current drain. As
it draws only 60 μA from its supply, it
other modules
LM35 - Analog
Temperature Sensor
has very low self-heating,
less than 0.1°C in still air.
separate socket (TS2) for the
LM35 sensor in TO-92 plastic
packaging. Readings are done
with microcontroller using single
analog input line, which is selected
with a J4 jumper.
Figure 17-5: LM35 connected to RA3 pin
Enabling LM35 Sensor
Figure 17-1:
LM35 not
connected
2
Figure 17-2:
LM35 placed
in socket
3
Figure 17-3:
LM35
connected
to RF6 pin
4
Figure 17-4:
LM35
connected
to RA3 pin
DATA BUS
1
EasyPIC PRO™ v7 enables you to get analog readings from the LM35 sensor
using RA3 or RF6 microcontroller pins. The selection of either of those two
lines is done using J4 jumper. When placing the sensor in the socket make sure
that half-circle on the board’s silkscreen markings matches the rounded part
of the LM35 sensor. If you accidently connect the sensor the other way, it can
be permanently damaged and you might need to replace it with another one.
During the readings of the sensor, make sure that no other device uses the
selected analog line, because it may interfere with the readings.
EasyPIC PRO
v7
page 31
other modules
ADC inputs
Digital signals have two discrete states, which are decoded
as high and low, and interpreted as logic 1 and logic 0.
Analog signals, on the other hand, are continuous, and can
have any value within defined range. A/D converters are
specialized circuits which can convert analog signals (voltages)
into a digital representation, usually in form of an integer
number. The value of this number is lineary dependent on the
input voltage value. Most microcontrollers nowdays internally have
A/D converters connected to one or more input pins. Some of the
most important parameters of A/D converters are conversion time
and resolution. Conversion time determines how fast can an analog
voltage be represented in form of a digital number. This is an important
parameter if you need fast data acquisition. The other parameter is resolution.
Resolution represents the number of discrete steps that supported voltage range
can be divided into. It determines the sensitivity of the A/D converter. Resolution is
represented in maximum number of bits that resulting number occupies. PIC18F87K22
microcontroller which comes on MCU card with the EasyPIC PRO v7™ board has 12-bit resolution,
meaning that maximum value of conversion can be represented with 12 bits, which converted to integer is
212=4096. This means that supported voltage range, for example from 0-5V, can be devided into 4096 discrete steps of
about 1.22mV.
EasyPIC PRO™ v7 provides an interface in form of two potentiometers for simulating analog input voltages that can be routed
to any of the 10 supported analog input pins.
Enabling ADC inputs
Figure 18-1: use J5 and J6 jumpers
to connect analog input lines with
potentiometers P2 and P3
DATA BUS
Figure 18-2:
Schematic of ADC
input
In order to connect the output of the
potentiometer P2 to RA0, RA1, RA2,
RA3 or RA5 analog microcontroller inputs,
you have to place the jumper J5 in the
desired position. If you want to connect
potentiometer P3 to any of the RF1 – RF5
analog microcontroller inputs, place jumper
J6 in the desired position. By moving
the potentiometer knob, you can create
voltages in range from GND to VCC.
EasyPIC PRO
v7
page 32
I C EEPROM
Enabling I2C EEPROM
Figure 19-1:
Activate
SW5.7 and
SW5.8
switches to
enable pull-up
resistors in I2C
lines of Serial
EEPROM.
In order to connect I2C EEPROM to the
microcontroller you must enable SW5.7 and
SW5.8 switches, as shown on Figure 19-1. 4K7
pull-up resistors necessary for I2C communication
are already provided on SDA and SCL lines once
switches are turned on. Prior to using EEPROM in
your application, make sure to disconnect other
peripherals, LEDs and additional pull-up or pulldown resistors from the interface lines in order
other modules
2
EEPROM is short for Electrically Erasable
Programmable Read Only Memory. It is
usually a secondary storage memory in devices
containing data that is retained even if the device
looses power supply. EEPROMs come with parallel
or serial interface to the master device. Because
of the ability to alter single bytes of data, EEPROM
devices are used to store personal preference and
configuration data in a wide spectrum of consumer,
automotive, telecommunication, medical, industrial, and
PC applications.
EasyPIC PRO™ v7 supports serial EEPROM which uses I2C
communication interface and has 1024 bytes of available
memory. Board contains socket for serial EEPROMs in DIP8 packaging,
so you can easily exchange it with different memory size EEPROM IC.
EEPROM itself supports single byte or 16-byte (page) write and read operations.
Data rates are dependant of power supply voltage, and go up to 1 MHz with 5V power
supply, and 400 kHz for 3.3V power supply.
What is I2C?
I2C is a multi-master serial single-ended bus that is used to attach low-speed peripherals to computer or embedded
systems. I²C uses only two open-drain lines, Serial Data Line (SDA) and Serial Clock (SCL), pulled up with
resistors. SCL line is driven by a master, while SDA is used as bidirectional line either by master or slave device.
Up to 112 slave devices can be connected to the same bus. Each slave must have a unique address.
DATA BUS
Figure 19-2:
Schematic of
I2C EEPROM
module
EasyPIC PRO
v7
page 33
other modules
Output voltages
EasyPIC PRO™ v7 contains two
additional pairs of screw
terminals which can be used
to get power supply output
for your external devices.
There are two available
output voltages: 5V and
3.3V. Depending on which power
source you use (adapter, laboratory
power supply, or USB), maximum output
currents can vary. Power consumption of the onboard modules can also affect maximum output power
which can be drawn out of the screw terminals. Big power
consumers, such as Ethernet, or even GLCD with backlight
can alone drastically reduce the maximum output power. On-board
switching power supply can give maximum of 600mA of current if used
with adapter or laboratory power supply. When used with USB
power supply it can give no more than 500mA.
Figure 20-1: Output
voltage terminals
Purpose of the output voltage terminals is not to be the main power source of big
consumers, but more a power source for remote small consumers.
Figure 20-2: Connecting
power lines to 5V output
Figure 20-3: Connecting
power lines to 3.3V output
EasyPIC PRO
v7
page 34
EasyPIC PRO™ v7 contains three GND pins located in three different
sections of the board, which allow you to easily connect oscilloscope GND
reference when you monitor signals on microcontroller pins, or signals of
on-board modules.
1
GND is located next to the RS-232 connector.
2
GND is located right to the piezo buzzer, next to PORTA header.
3
GND is located above PORTJ I/O group, next to PORTF header.
1
Figure 21-1:
3 oscilloscope GND
pins are conveniently
positioned so each part
of the board can be reached
2
with an oscilloscope probe
3
EasyPIC PRO
v7
page 35
other modules
Additional GNDs
What’s Next?
You have now completed the journey through each and every feature of EasyPIC PRO™ v7 board. You got to know it’s modules, organization, supported microcontrollers,
programmer and debugger. Now you are ready to start using your new board. We are suggesting several steps which are probably the best way to begin. We invite
you to join thousands of users of EasyPIC™ brand. You will find very useful projects and tutorials and can get help from a large ecosystem of users. Welcome!
Compiler
You still don’t have an appropriate compiler? Locate PIC® compiler
that suits you best on our website:
www.mikroe.com/pic/compilers/
Choose between mikroC™, mikroBasic™ and mikroPascal™, and
download fully functional demo version, so you can begin building
your PIC® applications.
Projects
Community
Support
Once you have chosen your compiler,
and since you already got the board,
you are ready to start writing your
first projects. We have equipped our
compilers with dozens of examples that
demonstrate the use of each and every
feature of the EasyPIC PRO™ v7 board,
and all of our accessory boards as well.
This makes an excellent starting point
for your future projects. Just load the
example, read well commented code,
and see how it works on hardware.
Browse
through
the
compiler
Examples available on this link:
If you want to find answers to your
questions on many interesting topics
we invite you to visit our forum at
http://www.mikroe.com/forum
and browse through more than 150
thousand posts. You are likely to find
just the right information for you.
On the other hand, if you want to
download free projects and libraries,
or share your own code, please visit
the Libstock website. With user
profiles, you can get to know other
programmers, and subscribe to receive
notifications on their code.
We all know how important it is that
we can rely on someone in moments
when we are stuck with our projects,
facing a deadline, or when we just
want to ask a simple, basic question,
that’s pulling us back for a while.
We do understand how important
this is to people and therefore our
Support Department is one of the
pillars upon which our company is
based. MikroElektronika offers Free
Tech Support to the end of product
lifetime, so if something goes wrong,
we are ready and willing to help!
www.mikroe.com/easypic-pro/
www.libstock.com/
www.mikroe.com/support/
EasyPIC PRO
v7
page 36
notes
EasyPIC PRO
v7
page 37
notes
EasyPIC PRO
v7
page 38
DISCLAIMER
All the products owned by MikroElektronika are protected by copyright law and international copyright treaty. Therefore, this manual is to be treated as any other copyright
material. No part of this manual, including product and software described herein, must not be reproduced, stored in a retrieval system, translated or transmitted in any form or
by any means, without the prior written permission of MikroElektronika. The manual PDF edition can be printed for private or local use, but not for distribution. Any modification
of this manual is prohibited.
MikroElektronika provides this manual ‘as is’ without warranty of any kind, either expressed or implied, including, but not limited to, the implied warranties or conditions of
merchantability or fitness for a particular purpose.
MikroElektronika shall assume no responsibility or liability for any errors, omissions and inaccuracies that may appear in this manual. In no event shall MikroElektronika, its
directors, officers, employees or distributors be liable for any indirect, specific, incidental or consequential damages (including damages for loss of business profits and business
information, business interruption or any other pecuniary loss) arising out of the use of this manual or product, even if MikroElektronika has been advised of the possibility of
such damages. MikroElektronika reserves the right to change information contained in this manual at any time without prior notice, if necessary.
HIGH RISK ACTIVITIES
The products of MikroElektronika are not fault – tolerant nor designed, manufactured or intended for use or resale as on – line control equipment in hazardous environments
requiring fail – safe performance, such as in the operation of nuclear facilities, aircraft navigation or communication systems, air traffic control, direct life support
machines or weapons systems in which the failure of Software could lead directly to death, personal injury or severe physical or environmental damage (‘High Risk
Activities’). MikroElektronika and its suppliers specifically disclaim any expressed or implied warranty of fitness for High Risk Activities.
TRADEMARKS
The MikroElektronika name and logo, the MikroElektronika logo, mikroC™, mikroBasic™, mikroPascal™, mikroProg™, EasyPIC™, EasyPIC PRO™, mikroBus™ and Click boards™ are
trademarks of MikroElektronika. All other trademarks mentioned herein are property of their respective companies.
All other product and corporate names appearing in this manual may or may not be registered trademarks or copyrights of their respective companies, and are only used for
identification or explanation and to the owners’ benefit, with no intent to infringe.
Copyright © MikroElektronika™, 2013, All Rights Reserved.
If you want to learn more about our products, please visit our website at www.mikroe.com
If you are experiencing some problems with any of our products or just need additional
information, please place your ticket at www.mikroe.com/support/
If you have any questions, comments or business proposals,
do not hesitate to contact us at office@mikroe.com
EasyPIC PRO v7 Manual
ver. 1.01
0 100000 024812
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Mikroe:
MIKROE-999 MIKROE-1003
