LPC-P1227
LPC-P1227
    OLIMEX
    LPC1227FBD64 LPC1200 MCU 32-Bit ARM® Cortex®-M0 Embedded Evaluation Board
LPC-P1227 数据手册
DEBUG INTERFACE: POWER SUPPLY 3.3V SWD-1 HN1x2(Close) VR1(3.3V) LM1117IMPX-ADJ 3.3V 1 2 IN OUT R34 ADJ/GND R1 C1 + C4 100nF 10uF/16V/tant C6 100nF R2 390R/1% GND + C5 R4 10k SWDIO SWCLK SWDIO SWCLK SWO RST RST +5V BH20S R3 560R NA(1R) 240R/1% C3 470uF/16V YDJ-1136 47uF/6.3V/tant (5-9)VDC GYX-SD-TC0805SURK(RED) PWR 3.3V_E D2 1N5819S D1 1N5819S 1 3 5 7 9 11 13 15 17 19 R5 10k 3.3V R6 10k R7 10k SWD-2 PWR_LED 1 3 5 7 9 GND. SWDIO SWCLK SWO 2 4 6 8 10 SWCLK RST RST NA(GPH127SMT-02x05(PIN7-CUT)) USER1 USER2 USER3 LPC1227FBD64/301 R33 R43 R44 33k 33k 33k C30 C2 33pF + #RES 3.3V R12 2K 100nF SCK MOSI D/#C #SS 3.3V TXD1 SCL MISO SCK 1 3 5 7 9 UEXT BH10S R13 2K 2 4 6 8 10 R14 DTE Device!!! 33k G1 3.3V VREF_CMP BUZ BUZZER NA D3 R37 R25 2K NA(22k/1%) C R SR1 NA(AP431SAG-7) 1N4148 3.3V A NA(51k/1%) BC817-40 USER2 USER3 R31 33k R32 1K USER3 R11 1K R10 33k USER2 T1157 C27 100nF T1157 100nF 3.3V USER1 R28 1K R27 33k T1157 C1- V- C2+ 13 8 T1OUT T2OUT R1IN R2IN ST3232CDR(SO16) C20 100nF C21 100nF 2 6 T1IN T2IN R1OUT R2OUT V+ C1- V- C2+ C2- DTE_DTR DTE_TD 14 7 DTE_RD DTE_DSR 13 8 T1OUT T2OUT R1IN R2IN 2 2 C18 1 3 100nF C19 4 5 100nF 11 10 #RTS0 330R 330R 12 9 U3 C1+ T1IN T2IN R1OUT R2OUT 3 100nF C23 4 5 100nF DTR0 TXD0 11 10 330R 330R 12 9 R30 1K R29 33k C25 C26 100nF 100nF R17 RXD0 R18 #DSR0 3.3V R21 1K R22 1K RST_E HN1x2(Open) R40 1K R23 10k RST R24 330R 10 k R15 #DCD0 R16 #CTS0 C22 1 3.3V D4 BAT54A T2 DTC114YKA 1 0k T3 DTC114YKA C24 NA WAKE_UP WAKE_UP IT1185AU2 USER1 C13 ISP 3.3V DTE_CD DTE_CTS DTE_CD DTE_RD DTE_TD DTE_DTR 1 2 3 4 5 R20 1K IT1185AU2 BUTTONS 3.3V 14 7 ISP_E HN1x2(Open) R19 10k 3.3V V+ 1 2 R26 33k U2 C1+ DB9-MALE T1 R38 6 DTE_RTS RS232 6 7 8 9 G2 PB1221P R39 DTE_DSR DTE_RTS DTE_CTS DTE_RI BUZZER R35 NA(560R) 2 C2- VIN COMPARATOR REFERENCE (OPTIONAL) C16 100nF C17 100nF RXD1 SDA MOSI SSEL 1uF/16V 3.3V SWDIO_ALT RS232 3.3V ST3232CDR(SO16) C29 ADG8448G(FPA-WZA-08-LF) P1.6 P1.5 P1.4 P1.3 P1.2 P1.1 P1.0 WAKE_UP SWDIO_ALT 3.3V VCC 3.3V BUZZER 54 53 52 51 50 49 48 3.3V TXD1,RXD1,SCL,SDA,SCK,MISO,MOSI,SSEL UEXT 3.3V NOKIA_3310 LCD PIO1_6/CT16B1_CAP1/CT16B1_MAT1 PIO1_5/AD7/CT16B1_CAP0/CT16B1_MAT0 PIO1_4/AD6 PIO1_3/AD5/WAKEUP PIO1_2/SWDIO/AD4 R/PIO1_1/AD3 R/PIO1_0/AD2 C14 100nF LCD PIO2_15 PIO2_14 PIO2_13/TXD1 PIO2_12/RXD1 PIO2_11/CT32B1_CAP3/CT32B1_MAT3 PIO2_10/CT32B1_CAP2/CT32B1_MAT2 PIO2_9/CT32B1_CAP1/CT32B1_MAT1 PIO2_8/CT32B1_CAP0/CT32B1_MAT0 PIO2_7/CT32B0_CAP3/CT32B0_MAT3/#DSR0 PIO2_6/CT32B0_CAP2/CT32B0_MAT2/#DCD0 PIO2_5/CT32B0_CAP1/CT32B0_MAT1/#RI0 PIO2_4/CT32B0_CAP0/CT32B0_MAT0/#CTS0 PIO2_3/CT16B1_CAP1/CT16B1_MAT1/#DTR0 PIO2_2/CT16B1_CAP0/CT16B1_MAT0/TXD0 PIO2_1/CT16B0_CAP1/CT16B0_MAT1/RXD0 PIO2_0/CT16B0_CAP0/CT16B0_MAT0/#RTS0 RST 3.3V 560R 16 15 14 13 62 61 60 59 36 35 34 33 32 31 30 29 D/#C,#SS,#RES 1 2 3 4 5 6 7 8 RTCXOUT R9 P2.15 P2.14 P2.13 P2.12 P2.11 P2.10 P2.9 P2.8 P2.7 P2.6 P2.5 P2.4 P2.3 P2.2 P2.1 P2.0 VDD SCK SDIN D/#C #SCE GND VOUT #RES RTCXIN VREF_CMP 3 VREF_CMP VREF_CMP D/#C #SS #RES 58 LED2 57 32.768kHz/2x6mm/20ppm/6pF SWCLK_ALT MOSI MISO SSEL SCK RST ISP_E SDA SCL TXD1 RXD1 #CTS0 #RI0 #DCD0 #DSR0 DTR0 TXD0 RXD0 #RTS0 GYX-SD-TC0805SGYK(YELLOW) Q2 GN D XTALOUT GYX-SD-TC0805SGCK(GREEN) 20pF XTALIN SWDIO_DEF RESET R41 10k #RI0 R42 1K 10 k IT1185AU2 47 k 20pF C12 2 1 560R C11 1 3 R8 Q12.000MHz/HC-49SM/SMD/20ppm/20pF SWCLK_DEF DIO_ALT/DIO_DEF ALT:Open;DEF:Close SWCLK_ALT LED1 Q1 33pF 1 SWDIO_ALT SWDIO D5 33pF C10 3 ALT:Open;DEF:Close CLK_ALT/CLK_DEF BAT54A C9 VSSIO 2 1 64 P0.31 P0.30 P0.29 P0.28 P0.27 P0.26 P0.25 P0.24 P0.23 P0.22 P0.21 P0.20 P0.19 P0.18 P0.17 P0.16 P0.15 P0.14 P0.13 P0.12 P0.11 P0.10 P0.9 P0.8 P0.7 P0.6 P0.5 P0.4 P0.3 P0.2 P0.1 P0.0 SWCLK_DEF SWDIO_DEF 4 7k 100nF VDD(IO) VCC 63 C8 VSS C15 100nF 55 47 46 18 17 12 11 10 9 8 7 6 5 4 45 44 43 42 41 40 39 38 37 28 27 26 25 24 23 22 21 20 19 GND 100nF R/PIO0_31/AD1 R/PIO0_30/AD0 PIO0_29/ROSC/CT16B0_CAP1/CT16B0_MAT1 PIO0_28/ACMP1_O/CT16B0_CAP0/CT16B0_MAT0 PIO0_27/ACMP0_O PIO0_26/ACMP1_I3/CT32B1_CAP3/CT32B1_MAT3/SWCLK PIO0_25/ACMP1_I2/CT32B1_CAP2/CT32B1_MAT2/SWDIO PIO0_24/ACMP1_I1/CT32B1_CAP1/CT32B1_MAT1 PIO0_23/ACMP1_I0/CT32B1_CAP0/CT32B1_MAT0 PIO0_22/ACMP0_I3 PIO0_21/ACMP0_I2/CT32B0_CAP3/CT32B0_MAT3 PIO0_20/ACMPO_I1/CT32B0_CAP2/CT32B0_MAT2 PIO0_19/ACMP0_I0/CT32B0_CAP1/CT32B0_MAT1 SWCLK/PIO0_18/CT32B0_CAP0/CT32B0_MAT0 PIO0_17/MOSI PIO0_16/MISO/CT16B1_CAP1/CT16B1_MAT1 PIO0_15/SSEL/CT16B1_CAP0/CT16B1_MAT0 PIO0_14/SCK #RESET/PIO0_13 PIO0_12/CLKOUT/CT16B0_CAP1/CT16B0_MAT1 PIO0_11/CT16B0_CAP0/CT16B0_MAT0/SDA PIO0_10/SCL PIO0_9/TXD1/CT32B1_CAP3/CT32B1_MAT3 PIO0_8/RXD1/CT32B1_CAP2/CT32B1_MAT2 PIO0_7/#CTS0/CT32B1_CAP1/CT32B1_MAT1 PIO0_6/#RI0/CT32B1_CAP0/CT32B1_MAT0 PIO0_5/#DCD0 PIO0_4/#DSR0/CT32B0_CAP3/CT32B0_MAT3 PIO0_3/DTR0/CT32B0_CAP2/CT32B0_MAT2 PIO0_2/TXD0/CT32B0_CAP1/CT32B0_MAT1 PIO0_1/RXD0/CT32B0_CAP0/CT32B0_MAT0 PIO0_0/#RTS0 15 U3PW R16 C7 VDD(3V3) GND R36 NA(1R) SWCLK_ALT SWCLK U1 56 47k MCU_E HN1x2(Close) 15 U2PWR16 1 2 3.3V RST,SWCLK,SWDIO ,SW DIO _ALT,SW CLK_ALT + - 2 4 6 8 10 12 14 16 18 20 3.3V VIN T4 DTC114YKA RST ISP_E LPC-P1227 Rev. B COPYRIGHT(C) 2011, OLIMEX Ltd. http://www.olimex.com/dev TXD0,RXD0,#RTS0,#CTS0,DTR0,#DSR0,#DCD0,#RI0,ISP_E,RST +5V
LPC-P1227 价格&库存
很抱歉,暂时无法提供与“LPC-P1227”相匹配的价格&库存,您可以联系我们找货
