SDK-LH75401-11-0204
SDK-LH75401-11-0204
    BEACONEMBEDDEDWORKS
    KIT DEV ZOOM START FOR LH75401
SDK-LH75401-11-0204 数据手册
WWW.LOGICPD.COM A B C LH75401 CARD ENGINE (PRELIMINARY) The LH75401 Card Engine is a compact, product-ready hardware and software solution for developing embedded products with less time, less cost, less risk ... more innovation. Developing embedded solutions is as simple as A B C The LH75401 Card Engine is a complete single board computer offering essential features for handheld and embedded networking applications in the industrial, consumer and medical markets. The use of custom peripheral boards makes the Card Engine the ideal foundation for OEMs developing handheld and compact products. provides a common reference pin-out on its expansion connectors, which enables customers to easily scale to next generation micro controller Card Engines when new functionality or performance is required. A Application Development Kits B Board Support Packages C Card Engines LH75401 Custom Card Engine Peripheral Board Final Product Actual Size (2.37” x 2.67”) H A R D WA R E H I G H L I G H T S CAN Ready Processor integrated touch screen controller 5 Capture/Compare Timers, 2 Capture Timers S T R AT E G I C PA R T N E R APPLICATION DEVELOPMENT KITS Processor Sharp LH75401 16/32 bit ARM7TDMI RISC microprocessor running up to 51.6 MHz SRAM Memory Up to 2 Mbytes Flash Memory Up to 16 Mbytes on board Display Programmable color LCD controller - Built in driver supports up to 320 x 240 (QVGA) x 12 bit color - Supports STN, Color STN, HR-TFT, AD-TFT, TFT Touch Screen Processor integrated four or five wire resistive touch screen controller Network Support 10/100 BASE-T Ethernet controller (application/debug) - SMSC LAN 91C111 (MAC & PHY) Audio Audio Codec Stereo Output (TI TLV320DAC23) PC Card Expansion Compact Flash Type 1 card (memory storage only) Serial Ports 3 X UARTS - 2 X 16C550 like, standard UARTS - 1 CAN Version 2.0b or 1 82510 UART SSP Supports either Motorola SPITM, National Semiconductor MICROWIRETM, TI SSI GPIO Programmable depending on peripheral requirements Software - LogicLoaderTM (bootloader/monitor) in executable format Mechanical - Compact Size: 2.37”(60.2 mm) long x 2.67”(67.8 mm) wide x 0.17”(4.4 mm) high - 144 pin SODIMM connector for connection to custom peripheral board - Two high density 80-pin expansion connectors for peripheral access Application Development Kits - ZoomTM Starter Development Kit - available Q1 ‘03 - ZoomTM Integrated Development Kit - available Q2 ‘03 BSPS & SOFTWARE CARD ENGINES PRODUCT DEVELOPMENT SERVICES © 2002 LOGIC PRODUCT DEVELOPMENT 411 WASHINGTON AVE N SUITE 101 MINNEAPOLIS MN 55401 TEL: 612.672.9495 FAX: 612.672.9489 WWW.LOGICPD.COM DN: 70000029 Rev C WWW.LOGICPD.COM A Zoom B C TM S TA R T E R D E V E L O P M E N T K I T (PRELIMINARY) The ZoomTM Starter Development Kit is a low-cost Application Development Kit for evaluating the functionality of the Card Engine. This results in an embedded product development cycle with Less time, less cost, less risk ... More innovation. Developing embedded solutions is as simple as A B C Application development is performed right on the product-ready Card Engine and software Board Support Package included in the kit, which enables customers to seamlessly transfer their application code and hardware into production. The Application Board has connections to all of the Card Engine specific peripherals via standard connectors or expansion headers. This allows easy connection for application development, prototyping, and debugging. A Application Development Kits B Board Support Packages C Card Engines S H A R P D I S P L AY K I T S Integrated LCD/Touch/Inverter Connector Logic offers the following display kits (bezel, inverter, touch panel, and cable assemblies included): LQ035Q7DB02 3.5", QVGA, A-TFT LQ64D343 6.4", VGA, TFT LQ121S1DG31 12.1", SVGA, TFT Cable assemblies are also available for other Sharp displays. Expansion Headers: Access to all Card Engine signals Standard 100-mil pitch for prototyping CUSTOMER SUPPORT Logic provides technical support for Application Development Kits. Various support packages are available; contact us for more information. C O N TA C T For more information on our embedded platform solutions, please contact Logic Sales at www.logicpd.com or 612.672.9495. S T R AT E G I C PA R T N E R APPLICATION DEVELOPMENT KITS Card Engine LH75401 Card Engine included LCD Display Connector 60 pin integrated LCD, touch & backlight connector (see Sharp Display Kits sidebar for ready-to-use LCD display options) Network Support One RJ45 Ethernet jack with magnetics (application/debug) Audio Stereo input and output jacks - 3.5mm diameter (stereo in not supported by LH75401) PC Card Expansion Compact Flash Type 1 (card slot memory storage only) Serial Port 115.2Kbps RS-232 debug serial port Expansion Headers - Standard 100 mil pitch header - Access to all Card Engine signals Software - LogicLoaderTM (bootloader/monitor) in executable format Mechanical - 4”(102 mm) long x 6”(152 mm) wide x .66”(16.8 mm) high Cables - Serial cable (null modem) - Power supply and power adapters (UK, Europe, Japan, and USA) Model Number SDK-LH75401-10 BSPS & SOFTWARE CARD ENGINES PRODUCT DEVELOPMENT SERVICES © 2002 LOGIC PRODUCT DEVELOPMENT 411 WASHINGTON AVE N SUITE 101 MINNEAPOLIS MN 55401 TEL: 612.672.9495 FAX: 612.672.9489 WWW.LOGICPD.COM
SDK-LH75401-11-0204 价格&库存
很抱歉,暂时无法提供与“SDK-LH75401-11-0204”相匹配的价格&库存,您可以联系我们找货
