SDK-PXA270-520-10-6432R
    BEACONEMBEDDEDWORKS
    KIT DEV ZOOM STARTER FOR PXA270
SDK-PXA270-520-10-6432R 数据手册
WWW.LOGICPD.COM A Zoom B C TM S TA R T E R D E V E L O P M E N T K I T The ZoomTM Starter Development Kit is a low-cost Application Development Kit for evaluating the functionality of the Card Engine. This results in an embedded product development cycle with less time, less cost, less risk ... more innovation. Developing products is as simple as A B C Application development is performed right on the product-ready Card Engine and software Board Support Package included in the kit, which enables customers to seamlessly transfer their application code and hardware into production. The Application Board has connections to all of the Card Engine specific peripherals via standard connectors or expansion headers. This allows easy connection for application development, prototyping, and debugging. A Application Development Kits B Board Support Packages C Card Engines Z O O M D I S P L AY K I T S Integrated LCD/Touch/Inverter Connector Logic offers the following display kits (bezel, inverter, touch panel, and cable assemblies included): LCD-3.5-QVGA-10 3.5", QVGA, AD-TFT LCD-6.4-QVGA-10 6.4", VGA, TFT LCD-10.4-VGA-10 10.4", VGA, TFT LCD-12.1-SVGA-10 12.1", SVGA, TFT Cable assemblies are also available for other Sharp displays. CUSTOMER SUPPORT Logic provides technical support for Application Development Kits. Various support packages are available; contact us for more information. C O N TA C T For more information on our Embedded Platform Solutions, please contact Logic Sales at www.logicpd.com or 612.672.9495. APPLICATION DEVELOPMENT KITS Expansion Headers: Access to all Card Engine signals Standard 100-mil pitch for prototyping Card Engine Included based on Development Kit purchased LCD Display Connector 60 pin integrated LCD, touch & backlight connector (see Sharp Display Kits sidebar for ready-to-use LCD display options) Network Support One RJ45 Ethernet jack (application/debug) Audio Stereo input and output jacks -3.5mm diameter (stereo in not supported by LH79520) PC Card Expansion Compact Flash Type 1 (card slot memory storage only) Serial Port 115.2Kbps RS-232 debug serial port USB 1 Host and 1 Client port Expansion Headers - Standard 100 mil pitch header - Access to all Card Engine signals Software - Windows™ CE and Linux Board Support Packages (BSP) available - Software Development Kits (SDK) available for Linux and Windows CE development depending on Card Engine MMU support - GNU cross development tools (compiler, linker, assembler, and debugger) - Microsoft Windows CE.NET 120-day evaluation software - Example source code and sample applications available - LogicLoaderTM (bootloader/monitor) Mechanical - 4”(102 mm) long x 6”(152 mm) wide x .66”(16.8 mm) high Cables - Serial cable (null modem) BSPS & SOFTWARE CARD ENGINES PRODUCT DEVELOPMENT SERVICES © 2002 LOGIC PRODUCT DEVELOPMENT 411 WASHINGTON AVE N SUITE 101 MINNEAPOLIS MN 55401 TEL: 612.672.9495 FAX: 612.672.9489 WWW.LOGICPD.COM PN: 70000021 Rev D
SDK-PXA270-520-10-6432R 价格&库存
很抱歉,暂时无法提供与“SDK-PXA270-520-10-6432R”相匹配的价格&库存,您可以联系我们找货
