MCB1343
MCB1343
    ARM(安谋控股)
    LPC1343 LPC1300 Series MCU 32-Bit ARM® Cortex®-M3 Core Embedded Evaluation Board
MCB1343 数据手册
Keil MCB1343 Evaluation Board Overview Page 1 of 1 MCB1343 Evaluation Board The Keil MCB1343 Evaluation Board introduces the new LPC134x family of ARM Cortex-M3 processor-based devices, allowing you to create and test working programs for this advanced architecture. The MCB1343 has a wide range of interfaces making it a great starting point for your next Cortex-M3 project. MCB1343 Features ◾ 72MHz LPC1343FBD48 ARM Cortex™-M3 processor-based MCU in 48-pin LQFP ◾ On-Chip Memory: 32KB Flash & 8KB RAM ◾ External Memory: 8KB EEPROM accessible via I2C bus ◾ Solar Power - can optionally provide power to the board ◾ Temperature Sensor - digital sensor for monitoring board temperature ◾ USB 2.0 Full Speed interface and USB Micro AB connector ◾ SPI Port via 20-pin Molex connector ◾ 42 GPIO pins ◾ 10 pin Cortex debug (0.05 inch connector) Ordering Information Part numbers are: ◾ MCB1343: MCB1343 Evaluation Board Evaluation Software The MCB1343 Evaluation Board includes the MDK-ARM Evaluation Tools. These tools help you get started writing programs and testing the microcontroller and its capabilities. Sample applications that run on the MCB1000 and a Quickstart guide are included. For programming and application debugging a ULINK family USB-JTAG Adapter is required. ◾ The MCB1343 will be available during the second-half of 2010. Contact Us | Site Feedback | Terms of Use | Privacy Policy Copyright © 2013 ARM Ltd and ARM Germany GmbH. All rights reserved. http://www.keil.com/mcb1000/mcb1343.asp 4/20/2015
MCB1343 价格&库存
很抱歉,暂时无法提供与“MCB1343”相匹配的价格&库存,您可以联系我们找货
