A000046
A000046
    ARDUINO
    DIP
    ATmega328 Arduino Uno AVR® ATmega MCU 8-Bit AVR Embedded Evaluation Board
A000046 数据手册
... The Arduino Uno is a microcontroller board based on the ATmega328 (datasheet). It has 14 digital input/output pins (of which 6 can be used as PWM outputs), 6 analog inputs, a 16 MHz crystal oscillator, a USB connection, a power jack, an ICSP header, and a reset button. It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with a AC-to-DC adapter or battery to get started. The Uno differs from all preceding boards in that it does not use the FTDI USB-to-serial driver chip. Instead, it features the Atmega8U2 programmed as a USB-to-serial converter. "Uno" means "One" in Italian and is named to mark the upcoming release of Arduino 1.0. The Uno and version 1.0 will be the reference versions of Arduino, moving forward. The Uno is the latest in a series of USB Arduino boards, and the reference model for the Arduino platform; for a comparison with previous versions, see the index of Arduino boards. Techinal Specifications Microcontroller ATmega328 Operating Voltage 5V Supply Voltage (recommended) 7-12V Maximum supply voltage (not recommended) 20V Digital I/O Pins 14 (of which 6 provide PWM output) Analog Input Pins 6 DC Current per I/O Pin 40 mA DC Current for 3.3V Pin 50 mA Flash Memory 32 KB (ATmega328) of which 0.5 KB used by bootloader SRAM 2 KB (ATmega328) EEPROM 1 KB (ATmega328) Clock Speed 16 MHz If you want to give a closer look to this board we advice you to visit the official Arduino UNO page in the Hardware Section. 1 2
A000046 价格&库存
很抱歉,暂时无法提供与“A000046”相匹配的价格&库存,您可以联系我们找货
