XK-1A-BRD
XK-1A-BRD
    XMOS
    DEV KIT EVENT-DRIVEN PROC XS1-L1
XK-1A-BRD 数据手册
XK-1A Development Board Quick Start Guide Document Revision 1.1 Publication Date: 2011/03/29 Copyright © 2010 XMOS Limited, All Rights Reserved. XK-1A Development Board Quick Start Guide 1 2/4 Introduction The XK-1A is a low cost development board intended for exploring event-driven processor designs. It comprises a single XS1-L1 device, 128KBytes SPI FLASH memory, four LEDs and two press-button switches. Two XSYS Connectors let you link multiple XK-1A boards together in a chain and two banks of 0.1" IDC connectors are provided for connecting additional components to the XK-1A. An XTAG-2 debug adapter can be used to connect the XK-1A to a USB 2.0 port on a PC, providing a JTAG interface that can be used to load and debug programs on the board. The XK-1A can be powered directly from the XTAG-2 debug adapter or from an external 5V power supply. To program the XK-1A you need to download a set of free Development Tools from the XMOS website. The tools let you write, load and debug programs on your development board using the XTAG-2. Further information on using the XK-1A and additional resources including the development tools is available from http://www.xmos.com/xk1a. 2 XK-1A Demos A set of demonstrations is pre-installed on the XK-1A board which you can use to test the hardware. Additional demonstrations can be downloaded from the XMOS web site, including an XK-1A tutorial which introduces the key concepts you need to understand when programming the XK-1A board. We recommend that you install the XMOS Development Tools before you connect the XK-1A to your development system—see Section 3. 1. Connect the 20-way IDC header on the XTAG-2 to the left XSYS connector on the XK-1A board. 2. Plug the XTAG-2 into a USB 2.0 connector on your development system. The XK-1A board starts up and flashes the four LEDs in sequence across the top of the board. 3. Press Switch A on the XK-1A to increase the speed that the LEDs flash. 4. Press Switch B to change the order that the LEDs flash. Document Revision 1.1 XK-1A Development Board Quick Start Guide 3/4 XK-1A Development Kit 16 x 0.1” IDC Connectors (Male) Yellow LEDs Yellow LEDs 20-way XSYS Connector (Male) 20-way XSYS Connector (Female) XS1-L1 TQ128 A B Optional External 5V Power Supply Push Button Switches 16 x 0.1” IDC Connectors (Male) XTAG-2 Connector 20-way IDC XSYS Connector XS1-L1 LQ64 Standard A-Type USB 2.0 Connector USB Transceiver Document Revision 1.1 XK-1A Development Board Quick Start Guide 3 4/4 XMOS Tools Support The XMOS Development Tools are provide in a single platform-specific downloadable file from http://www.xmos.com/tools Instructions on installing and using the XMOS Tools can be found in the XMOS Tools User Guide http://www.xmos.com/published/xtools_en. The following table provides a summary tools support for the XK-1 development board. Minimum tools version required 9.9 Board support file XK-1A.xn USB-to-JTAG adaptor XTAG-2 USB-to-JTAG driver XMOS Board Tutorial Integrated into XDE and available as PDF Hardware Guide http://www.xmos.com/published/xk1hw 4 Document History Date Release Comment 2009-11-03 1.0 First release 2010-05-10 1.1 Added tools support section Copyright © 2010 XMOS Limited, All Rights Reserved. XMOS Limited is the owner or licensee of this design, code, or Information (collectively, the “Information”) and is providing it to you “AS IS” with no warranty of any kind, express or implied and shall have no liability in relation to its use. XMOS Limited makes no representation that the Information, or any particular implementation thereof, is or will be free from any claims of infringement and again, shall have no liability in relation to any such claims. XMOS and the XMOS logo are registered trademarks of XMOS Limited in the United Kingdom and other countries, and may not be used without written permission. All other trademarks are property of their respective owners. Where those designations appear in this book, and XMOS was aware of a trademark claim, the designations have been printed with initial capital letters or in all capitals.
XK-1A-BRD 价格&库存
很抱歉,暂时无法提供与“XK-1A-BRD”相匹配的价格&库存,您可以联系我们找货
