PIC-LCD3310
PIC-LCD3310
    OLIMEX
    MICROCHIPDEVELOPMENTBOARD
PIC-LCD3310 数据手册
PIC-LCD-3310 development board Users Manual Rev.B, January 2011 Copyright(c) 2011, OLIMEX Ltd, All rights reserved Page 1 INTRODUCTION: PIC-LCD-3310 is development board with PIC18F67J50, NOKIA 3310 BW 84x48 pixels LCD, two LEDs and a joystick. The board has SD-MMC connector, mini USM and all PIC ports are available on two extension connectors. The board have 3-axis accelerometer MMA7260 (seen on the picture). It's perfect for motion datalogging/analyze, 3-d mouses etc application. BOARD FEATURES: − − − − − − − − − − − − MCU: PIC18F67J50 with 128KB Flash memory, 3904B SRAM, 10-bit 8-channel ADC module, PWM, SPI, I2C, EUSART, 2 Analog comparators and 8/16-bit Timer/Counters ICSP connector for PIC-ICD2/PIC-ICD2-POCKET debugger/programmer or PIC-PGx programmers LCD NOKIA 3310 black/white 84x48 pixels Two status LEDs Joystick with LEFT, RIGHT, UP, DOWN and CENTER action mini USB connector SD/MMC card connector MMA7260 accelerometer Extension connectors for all PIC ports +(4.5–6.0) battery connector PCB: FR-4, 1.5 mm (0,062''), soldermask, silkscreen component print Dimensions 65x65 mm (2.56 x 2.56") ELECTROSTATIC WARNING: The PIC-LCD3310 board is shipped in protective anti-static packaging. The board must not be subject to high electrostatic potentials. General practice for working with static sensitive devices should be applied when working with this board. BOARD USE REQUIREMENTS: Cables: 1.8 meter USB mini cable to connect to PC. Other cables might be required in case of other programming/debugging tools. Hardware: Programmer/Debugger – PIC-ICD2, PIC-ICD2-POCKET orother compatible programming/debugging tool. !!!Warning!!! When you want to program this microcontroller with PIC-ICD2, PICICD2-POCKET or PIC-ICD2-TINY, before connecting the programmer to your target board, you should first connect the programmer to your computer and open MPLAB. There, first from menu Configure – Select Device – choose the microcontroller you are about to program, then from menu Programmer – Select Programmer Page 2 – choose MPLAB ICD 2, wait while MPLAB is downloading operation system, and after ICD2 is connected – check in menu Programmer – Settings – Power – there is option – Power target circuit from MPLAB ICD 2 – this option should be forbidden, you could not select it. Now it is safe to connect the programmer to your target board. Software: MPLAB IDE (latest version), MPLAB C18 Compiler or any other compatible development/programming software. Page 3 PROCESSOR FEATURES: PIC-LCD3310 board use MCU PIC18F67J50 from Microchip with these features: - USB V2.0 Compliant SIE - Low Speed (1.5 Mb/s) and Full Speed (12 Mb/s) - Supports Control, Interrupt, Isochronous and Bulk Transfers - Supports up to 32 Endpoints (16 bidirectional) - Supports up to 32 Endpoints (16 bidirectional) - 3.9-Kbyte Dual Access RAM for USB - On-Chip USB Transceiver - High-Precision PLL for USB - Two External Clock modes, up to 48 MHz - Internal 31 kHz Oscillator, Tunable Internal Oscillator, 31 kHz to 8 MHz - Secondary Oscillator using Timer1 @ 32 kHz - Fail-Safe Clock Monitor: o Allows for safe shutdown if any clock stops - High-Current Sink/Source 25 mA/25mA (PORTB and PORTC) - Four Programmable External Interrupts - Four Input Change Interrupts - Two Capture/Compare/PWM (CCP) modules - Three Enhanced Capture/Compare/PWM (ECCP) modules: o One, two or four PWM outputs o Selectable polarity o Programmable dead time o Auto-shutdown and auto-restart - Two Master Synchronous Serial Port (MSSP) modules supporting 3-Wire SPI (all 4 modes) and I2C. Master and Slave modes - 8-Bit Parallel Master Port/Enhanced Parallel Slave Port with 16 Address Lines - Dual Analog Comparators with Input Multiplexing - 10-Bit, up to 12-Channel Analog-to-Digital (A/D) Converter module: o Auto-acquisition capability o Conversion available during Sleep - Two Enhanced USART modules: o Supports RS-485, RS-232 and LIN 1.2 o Auto-wake-up on Start bit o Auto-Baud Detect - Address Capability of up to 2 Mbytes - 8-Bit or 16-Bit Interface - 12-Bit, 16-Bit and 20-Bit Addressing modes - 5.5V Tolerant Inputs (digital-only pins) - Low-Power, High-Speed CMOS Flash Technology - C Compiler Optimized Architecture for Re-Entrant Code - Power Management Features: o Run: CPU on, peripherals on Page 4 o Idle: CPU off, peripherals on o Sleep: CPU off, peripherals off - Priority Levels for Interrupts - Self-Programmable under Software Control - 8 x 8 Single-Cycle Hardware Multiplier - Extended Watchdog Timer (WDT): o Programmable period from 4 ms to 131s - Single-Supply In-Circuit Serial Programming. (ICSP™) via Two Pins - In-Circuit Debug (ICD) with 3 Breakpoints via Two Pins - Operating Voltage Range of 2.0V to 3.6V - On-Chip 2.5V Regulator - Flash Program Memory of 10000 Erase/Write Cycles and 20-Year Data Retention Page 5 BLOCK DIAGRAM: Page 6 MEMORY MAP: Page 7 100nF 100nF Page 8 CON6PR6-2.54MM 3.3V RB7/PGD RB6/PGC RG4/PMCS2/CCP5/P1D RG3/PMCS1/CCP4/P3D RG2/PMA6/RX2/DT2 RG1/PMA7/TX2/CK2 RG0/PMA8/ECCP3/P3A PIC18F67J50LPTQFP64 RB0/FLT0/INT0 RB1/INT1/PMA4 RB2/INT2/PMA3 RB3/INT3/PMA2 RB4/KBI0/PMA1 RB5/KBI1/PMA0 RB6/KBI2/PGC RB7/KBI3/PGD RF2/PMA5/AN7/C2INB RF3/DRF4/D+ RF5/AN10/C1INB/CVREF RF6/AN11/C1INA RF7/#SS1/C1OUT D/#C #SS1 RG 4 RG 3 RG 2 RG 1 RG 0 8 6 5 4 3 RF 2 DD+ RF5 16 15 14 13 12 11 MIS O 1 R31 3.3V BH10 C13 NA NA R28 NA C12 R27 NA 2 4 6 R29 8 330R/5% 10 100nF UEXT C11 1 RC6/T X 1 3 S CK 2/S CL2 5 330R/5% 7 S CK 1 9 R25 4.7k/5% 3.3V R16 330R/5% 3.3V 3.3V C14 RC7/RX 1 MIS O 2/S DA 2 MO S I1 RE 4/CS _UE X T R2 4.7k/5% R1 33k/5% 3.3V 1uF C15 3.3V_E 3.3V 47uF/6.3V 1x15 EXT2 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 + RST 48 47 46 45 44 43 42 37 CE NTE R LE F T RB 2 RB 3 UP DO W N RB 6/P G C RB 7/P G D RA0/AN0 RA1/AN1 RA2/AN2/VREFRA3/AN3/VREF+ RA4/T0CKI RA5/AN4/C2INA R18 330R/5% LED2 red RC2 RC6/TX 1 RC7/RX 1 RE 2/LE D1 RE 3/LE D2 RE 4/CS _UE X T US B _S E NS RE 6 RE 7 RF2 RF5 SD-CARD CP1 CP2 3 UP 2 NOKIA_3310_LCD UP #RES VDD SCK SDIN D/#C #SCE GND VOUT #RES LCD GND VOUT VIN 1 2 RIGHT 5 3 7.1 BAT R33 100k/5% R32 100k/5% US B _S E NS DD+ (4.5-6.0)V 1 2 D1 BAT54C R35 180k/5% R34 100k/5% +5V 330R/5% R19 RIGHT http://www.olimex.com/dev COPYRIGHT(C) 2009, OLIMEX Ltd. Rev. A PIC-LCD3310 B A T _S E NS 1uF C16 VR1 MCP1702-3302E/MB Center push DOWN Common JOYSTICK_IT-1502 4 6 DOWN 1 LEFT CENTER LEFT 3.3V 3.3V + 1 2 3 4 5 6 7 8 3.3V 3.3V 3.3V J1 1uF/16V C18 100nF SCK1 MOSI1 D/#C #SS1 R9 33k/5% VBUS DD+ ID GND 10nF C17 GND3 1 2 3 4 5 6 24 23 22 21 28 27 Z Y X RA 3 RIG HT B A T_S E NS 10uF/10V RE 2/LE D1 RE 3/LE D2 RE 4/CS _UE X T US B _S E NS RE 6 RE 7 WP CP 2 1 64 63 62 61 60 59 LED1 red 3.3V +5V 3.3V 13 15 C19 R26 33k/5% 3.3V USB ICSP 100nF RE0/PMRD/P2D RE1/PMWR/P2C RE2/PMBE/P2B RE3/PMA13/P3C/REFO RE4/PMA12/P3B RE5/PMA11/P1C RE6/PMA10/P1B RE7/PMA9/ECCP2/P2A #SM GS1 GS2 #RES MOSI2 MISO2/SDA2 SCK2/SCL2 #SS2 58 55 54 53 52 51 50 49 RC6/TX 1 RC7/RX 1 SCK1 MISO1 MOSI1 C26 15pF C27 15pF 330R/5% 33k/5% 33k/5% CP 33k/5% 2k/5% CD/DAT3/CS CMD/DI VSS1 VDD CLK/SCLK VSS2 DAT0/DO DAT1/RES DAT2/RES 3.3V MINI_USB USB GND4 GND2 GND1 1x15 3.3V AVDD AVSS VSS VSS1 VSS2 VSS3 Q2 32768/6pF RC2 GND R5 R6 R30 R8 R7 1 2 3 4 5 6 7 8 9 WP1 WP2 SD/MMC 1 +5V RA 3 B A T_S E NS RB 2 RB 3 RB 6/P G C RB 7/P G D RG 0 RG 1 RG 2 RG 3 RG 4 RS T 19 20 25 41 56 9 VDD VDD1 VDD2 RD0/PMD0 RD1/PMD1 RD2/PMD2 RD3/PMD3 RD4/PMD4/SDO2 RD5/PMD5/SDI2/SDA2 RD6/PMD6/SCK2/SCL2 RD7/PMD7/#SS2 30 29 33 34 35 36 31 32 3.3V 3.3V 3.3V MISO2/SDA2 SCK2/SCL2 #SS2 MOSI2 10 14 2 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 100nF 26 38 57 VDDCORE/VCAP VUSB OSC2/CLKO/RA6 OSC1/CLKI/RA7 ENVREG RC0/T1OSO/T13CKI RC1/T1OSI/ECCP2/P2A RC2/ECCP1/P1A RC3/SCK1/SCL1 RC4/SDI1/SDA1 RC5/SDO1/C2OUT RC6/TX1/CK1 RC7/RX1/DT1 C20 47uF/6.3V 470nH L1 WP 33k/5% 2k/5% R20 C10 100nF 100nF C8 10 17 40 39 #MCLR U3 C21 100nF 3.3V R3 R4 R21 33k/5% C9 C7 C6 10uF/10V C5 100nF C4 7 18 100nF X R15 1k/5% 3.3V R14 33k/5% R22 33k/5% 3.3V 3.3V 15pF C3 Q1 20MHz RST 15pF 1k/5% 3.3V 100nF C22 Y Z C23 R13 1k/5% R12 1k/5% + C2 5 6 7 8 9 10 11 16 R10 33k/5% R23 100nF R17 3.3V MMA7260Q VSS VDD NC1 NC2 NC3 NC4 NC5 NC6 NC7 NC8 XOUT YOUT ZOUT 15 14 13 3.3V 33k/5% R24 33k/5% C1 R11 10k 4 #SM G-SEL1 G-SEL2 3.3V 33k/5% EXT1 C24 C25 3 12 #SM 3.3V 1 2 GS1 GS2 U2 SCHEMATIC: BOARD LAYOUT: POWER SUPPLY CIRCUIT: PIC-LCD-3310 takes power from a battery +(4.5-6)VDC or from the mini USB port. The board power consumption at 5-6VDC the consumption is about 20mA. RESET CIRCUIT: PIC-LCD-3310 doesn't have reset circuit. The MCU resets if you apply logical zero (GND) to EXT1.pin 15 or to ICSP.pin 1. CLOCK CIRCUIT: Quartz crystal 20 MHz is connected to PIC18F67J50 pin 39 (OSC1/CLKI/RA7) and pin 40 clock out (OSC2/CLKO/RA6). Page 9 clock in Quartz crystal 32.768 kHz is connected to PIC18F67J50 pin 29 (RC1/T1OSI/ECCP2/P2A) and pin 30 (RC0/T1OSO/T13CKI) and supplies the Timer1 which could function as a Real Time Clock. JUMPER DESCRIPTION: 3.3V_E enables 3.3 V power supply for the PIC18F67J50 and all other devices. Default state is closed. INPUT/OUTPUT: Status red LED with name LED1 connected to PIC18F67J50 pin 64 (RE2/PMBE/P2B). Status red LED with name LED2 connected to PIC18F67J50 pin 63 (RE3/PMA13/P3C/REFO). Joystick with name J1 and with five positions – left, right, up, down and center. Accelerometer MMA7260. NOKIA-LCD 3310. EXTERNAL CONNECTORS DESCRIPTION: ICSP: Pin # PGD I/O PGC Input for the Signal Name 1 RST 2 +3.3V 3 GND 4 RB7/PGD 5 RB6/PGC 6 NC Program Data. Serial data for programming. Program Clock. Clock used for transferring the serial data (output from ICSP, input MCU). Page 10 EXT1: Pin # Signal Name Pin # Signal Name 1 +3.3V 2 GND 3 +5V 4 RA3 5 BAT_SENS 6 RB2 7 RB3 8 RB6/PGC 9 RB7/PGD 10 RG0 11 RG1 12 RG2 13 RG3 14 RG4 15 RST BAT_SENS Input battery. PGD I/O PGC Input input for the MCU). Battery Power Supply. This signal tells the processor that it is powered by the Program Data. Serial data for programming. Program Clock. Clock used for transferring the serial data (output from ICSP, Page 11 EXT2: Pin # TX1 RX1 LED1 LED2 USB_SENS through the Signal Name Pin # Signal Name 1 +3.3V 2 GND 3 +5V 4 GND 5 RC2 6 RC6/TX1 7 RC7/RX1 8 RE2/LED1 9 RE3/LED2 10 RE4/CS_UEXT 11 USB_SENS 12 RE6 13 RE7 14 RF2 15 RF5 Output Input Input Input Input Transmit Data 1. This is the output data line for the UART1. Receive Data 1. This is the input data line for the UART1. This signal controls LED1. This signal controls LED2. USB power supply. This signal tells the processor that it receives power mini USB port. Page 12 UEXT: Pin # Signal Name 1 +3.3V 2 GND 3 RC6/TX1 4 RC7/RX1 5 SCK2/SCL2 6 MISO2/SDA2 7 MISO1 8 MOSI1 9 SCK1 10 RE4/CS_UEXT TX1 Output Transmit Data 1. This is the output data line for the UART1. RX1 Input Receive Data 1. This is the input data line for the UART1. SCK2/SCL2 I/O Serial (Synchronization) Clock 2. This is the synchronization clock for the data transfer. When the pin is used for communication through SPI2, the name of the signal is SCK2 and when the communication is through is through I2C, the name of the signal is SCL2. This could be either input or output depending on whether the MCU is master or slave. MISO2/SDA2 I/O Master In Slave Out 2/Serial Data 2. When this pin is used for communication through SPI2 interface, its name is MISO and if the communication is through I2C interface its name is SDA. In case of SPI this could be either input (MCU is master) or output (MCU is slave). In case of I2C this could be used as both input and output depending on the data flow direction. MOSI1 I/O Master Out Slave In 1. This pin could be used for communication through SPI1 interface, in which case this is either data output from the MCU (when it is master) or data input for the MCU (when it is slave). SCK1 I/O Serial (Synchronization) Clock 1. This is the synchronization clock for the data transfer. If this pin is used for communication through SPI1, it could be either input or output depending on whether the MCU is master or slave. Page 13 BAT: Pin # Signal Name 1 +(4.5-6.0)VDC 2 GND Mini USB: Pin # Signal Name 1 +5V 2 D- 3 D+ 4 NC 5 GND D- and D+ both form differential input or output depending on the direction of the data flow. Page 14 SD/MMC card slot: Pin # Signal Name Pin # Signal Name 1 #SS2 2 MOSI2 3 GND 4 VDD (+3.3V) 5 SCK2/SCL2 6 GND 7 MISO2/SDA2 8 +3.3V 9 +3.3V 10 WP 11 - 12 - 13 CP 14 GND 15 GND #SS2 Output Slave Select 2. This signal is Slave Select for the SPI2 interface. As the MSU is master, this signal is output from it. MOSI2 Output Master Out Slave In 2. When the access to the memory is via SPI2 interface, this is data output from the MCU (which is master) and input for the memory card (which is slave). SCK2/SCL2 Output Serial (Synchronization) Clock 2. This is the synchronization clock for the data transfer. When the access to the memory card is via SPI2, the name of the signal is SCK2 and when the access is via I2C, the name of the signal is SCL2. MISO2/SDA2 I/O Master In Slave Out 2/Serial Data 2. When the access to the memory card is via SPI2 interface, this is data input for the MCU(which is master) and data output from the memory card (which is slave). If the access to the memory card is via I2C this is both data input and output to the MCU. WP Input Write Protect. This signal is input for the MCU. CP Input Card Present. This signal is input for the MCU. MECHANICAL DIMENSIONS: Page 15 Page 16 AVAILABLE DEMO SOFTWARE: – – Test demo code (C source and HEX) GPS compass with MOD-GPS and PIC-LCD3310 (C source and HEX) You could find information about PIC-LCD-3310 demo software at www.olimex.com/dev. Page 17 ORDER CODE: PIC-LCD-3310 – assembled and tested (no kit, no soldering required) How to order? You can order to us directly or by any of our distributors. Check our web www.olimex.com/dev for more info. All boards produced by Olimex are RoHS compliant Revision history: REV.A REV. B - created July 2008 - created January 2011 – added more detailed mechanical dimensions, latest revision of the scheme and page number. Page 18 Disclaimer: © 2011 Olimex Ltd. All rights reserved. Olimex®, logo and combinations thereof, are registered trademarks of Olimex Ltd. Other terms and product names may be trademarks of others. The information in this document is provided in connection with Olimex products. No license, express or implied or otherwise, to any intellectual property right is granted by this document or in connection with the sale of Olimex products. Neither the whole nor any part of the information contained in or the product described in this document may be adapted or reproduced in any material from except with the prior written permission of the copyright holder. The product described in this document is subject to continuous development and improvements. All particulars of the product and its use contained in this document are given by OLIMEX in good faith. However all warranties implied or expressed including but not limited to implied warranties of merchantability or fitness for purpose are excluded. This document is intended only to assist the reader in the use of the product. OLIMEX Ltd. shall not be liable for any loss or damage arising from the use of any information in this document or any error or omission in such information or any incorrect use of the product. Page 19
PIC-LCD3310 价格&库存
很抱歉,暂时无法提供与“PIC-LCD3310”相匹配的价格&库存,您可以联系我们找货
