2683
2683
    ADAFRUIT
    NETDUINO3ETHERNET
2683 数据手册
NETduino 3 Ethernet PRODUCT ID: 2683 DESCRIPTION - Netduino is an open source electronics platform using the .NET Micro Framework. Featuring a 32-bit microcontroller and a rich development environment, it is suitable for engineers and hobbyists alike. This combines the ease of high-level coding and the raw features of microcontrollers. Enjoy event-based programming, multi-threading, line-by-line debugging, breakpoints and more! The Netduino 3 has the same 168 MHz (Cortex-M4) processor as the Netduino 2 but almost four times the code storage at 1408 KB and almost double the ram at 164+ KB.  Check out the full specs here and more information about Netduino over at netduino.com Netduino 3 Ethernet has all the hardware features of the Netduino 3, plus MicroSD storage capabilities and an Ethernet jack for fast integrated IP networking! Features include: • • • • • • Works with most arduino shields (some require .net mf drivers) 1408 KB code storage 164+ KB RAM 6 ADC channels (12-bit) micro SD storage (up to 2gb) 3 gobus ports In the bag: • Netduino 3 Ethernet • Four sticky feet • 5 cm gobus cable https://www.adafruit.com/product/2683 1/21/2016 Technical Details STM32F427VI Datasheet Netduino 3 Ethernet Schematics  Operating Temperature: 0° - 70°C Power: Input: 7.5-12 VDC or USB powered Output: 5 VDC and 3.3 VDC regulated Max current: 25 For product support, replacement parts and warranty for Netduino products, click here. Product Dimensions: 80.3mm x 53.3mm x 12.7mm / 3.2" x 2.1" x 0.5" Product Weight: 27.0g/1.0oz
很抱歉,暂时无法提供与“2683”相匹配的价格&库存,您可以联系我们找货
