410-146
410-146
    DIGILENT(迪芝伦)
    KIT STARTER COOLRUNNER-II
410-146 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com CoolRunner-II™ Starter Board Reference Manual Revised April 8, 2016 This manual applies to the CoolRunner-II rev. F Overview The CoolRunner-II Starter Board is a complete USB-powered circuit development platform for Xilinx's CoolRunnerII CPLD. The board includes highly-efficient power supplies, a programmable oscillator, several I/O devices, and a USB2 port for board power and CPLD programming. The board also includes five expansion connectors that make 64 CPLD signals available to external circuits. Features include:      A 256-macrocell CoolRunner-II CPLD in a TQ144 package An on-board USB2 port for board power, JTAG programming, and data transfers An 8MHz fixed-frequency oscillator and a socket for a crystal oscillator Expansion connectors for 64 I/O signals (32 on the Pmod ports and 32 on the parallel connector) a one-wire DS28E01Q EEPROM The CoolRunner-II Starter Board. A large collection of board-support IP, reference designs, and add-on peripheral module boards (Pmods) is available at www.digilentinc.com. DOC#: 502-146 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 4 CoolRunner-II™ Starter Board Reference Manual JTAG Header 12 JTAG 2 Atmel USB Controller USB 2 Parallel User I/O 4 XC2C256 TQ144 8 8 En Vio1 (3.3V) Maxim Regulators JP2 Vio1 (3.3V) 8 Vcore (1.8V) 8 JA JB JC Pmod Connectors JD Discera Oscillator External Power Connector 32 JP3 1 User I/O: Seven-Segment LED Display, Pushbuttons, Slide Switches, and LEDs 14 4 SPI ROM Expansion Hole Pattern Configuration The CoolRunner-II board's CPLD must be configured (or programmed) by the user before it can perform any functions. Files can be created from schematics or HDL source files using the free ISE WebPack software from Xilinx. Configuration files can be transferred to the CoolRunner-II board using a USB cable and Xilinx's iMPACT software or using an external programming cable (not included). Once configured, the CPLD retains its state indefinitely. When the CoolRunner-II board is powered on, the most recently loaded CPLD configuration is available immediately. A new configuration can be loaded at any time, and as soon as a new configuration is loaded, it defines the CPLD's behavior. 2 Power Supplies The CoolRunner-II board can be powered from its integral USB port or from an external supply attached at connector JP3. Jumper JP2 selects whether the board uses USB power or external power. External power, from any source, is routed through a Maxim LT3028 regulator to produce the two voltage supplies (3.3V I/O and 1.8V core) required by the CPLD. Whenever board power is applied, the power-on LED glows. To use an external power source, set jumper JP2 to BAT and apply power to the JP3 pins (see the board's silkscreen for orientation). Any 4.5V to 9V power supply can be used (for example, a transistor battery or a series arrangement of AA cells). The CoolRunner-II board uses a four-layer PCB, with the inner layers dedicated to VCC and GND. The Maxim regulators, together with good power supply routing and ample bypass capacitors on all IC pins, results in a lownoise power supply. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 4 CoolRunner-II™ Starter Board Reference Manual 3 Clocks The CoolRunner-II board includes a fixed-frequency oscillator that produces an 8MHz clock signal. This primary oscillator output, labeled PCLK in the schematic, is connected to the GCLK2 pin of the CPLD (at P38) so that it can be routed to the internal clock divider. An unloaded socket for a standard half-size DIP oscillator is also provided at location IC3. 4 Fixed Freq Oscillator 38 DSC1033 CoolRunner-II Oscillator Socket 32 User I/O The CoolRunner-II board provides two pushbuttons and two slide switches for inputs, and four red LEDs and a fourdigit LED display for outputs. The active-low pushbuttons and slide switches include series resistance for short-circuit protection. The LEDs are active low, and the seven-segment display uses decoupled-transistor active-high common anode signals and active-low cathodes. Three additional LEDs indicate USB power good (LD4), board power good (LD5), and USB link status (LD6). Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 3 of 4 CoolRunner-II™ Starter Board Reference Manual 5 Expansion Connectors The CoolRunner-II board provides four 12-pin peripheral module ports. Each port provides two VDD and GND connections and eight unique CPLD signals. Each port can accommodate a single 12-pin Pmod or two 6-pin Pmods. Digilent makes several 6-pin Pmods that can attach to these ports, including speaker boards, H-bridge boards, sensor boards, etc. See www.digilentinc.com for more information. The CoolRunner-II board also provides a 40-pin expansion connector that includes three power-supply signals and 37 individual I/O signals. 6 Demonstration Design The design pre-programmed onto the CPLD contains several functions that can be seen when the appropriate peripheral modules are inserted into the relevant ports. In this sample design, the switch Pmod goes in port J8, the PS/2 Pmod goes in port J7, and the seven-segment display Pmod goes in ports J5 and J6. Of course, the design can be changed to use different ports. The CPLD implements both a counter as well as a PS/2 keyboard decoder. The display switches between the two based on the value of SW4. SW1, 2, and 3 are not used in the design. BTN0 is the system reset for the design. When SW4 has the PS/2 decoder selected, the output on the display is the scan code for that letter. Here are some scan codes, the rest can be found on the Internet. Keyboard Key F1 F2 F3 F4 7 Scan Code 05 06 04 0C Keyboard Key F5 F6 F7 F8 Scan Code 03 0B 83 0A Design Recommendations    The regulator provides Vccio of 3.3V, so set the Default I/O Standard appropriately. Unused I/O should be set to Ground to minimize power. Input Termination should be set to Keeper to minimize power consumption on any potentially floating input pins. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 4 of 4
410-146 价格&库存
很抱歉,暂时无法提供与“410-146”相匹配的价格&库存,您可以联系我们找货
  • 1+325.629691+42.14813
