410-300
410-300
    DIGILENT(迪芝伦)
    Kintex-7 FPGA Evaluation Board
410-300 数据手册
Digilent FPGA Genesys 2 Kintex-7 FPGA Development Board SKU:  410‐300 Product Description The Digilent Genesys 2 board is an advanced, high‐performance, ready‐to‐use digital circuit  development platform based on the powerful Kintex‐7™ Field Programmable Gate Array (FPGA) from  Xilinx. With its high‐capacity, high‐speed FPGA, fast external memories, high‐speed digital video ports,  and wide expansions options, the Genesys 2 is well suited for data and video processing applications.  Several built‐in peripherals, including Ethernet, audio and USB 2.0 allow a wide range of additional  applications. The fully‐populated high‐speed FMC HPC connector opens the door to great expansion  possibilities. The Kintex‐7 FPGA offers more capacity, higher performance, and more resources than the Virtex‐5  from the first‐generation Genesys.  Features: Xilinx Kintex‐7™ FPGA (XC7K325T‐2FFG900C) 50,950 logic slices (up 7x), each with four 6-input LUTs and 8 flip-flops Close to 16 Mbits of fast block RAM (up 7x) Ten clock management tiles, each with phase-locked loop (PLL) 840 DSP slices (up 17x) Internal clock speeds exceeding 450MHz On-chip analog-to-digital converter (XADC) Up to 10.3125Gbps gigabit transceivers 1800Mbps DDR3 data rate with 32-bit data width Commercial -2 speed grade The Genesys 2 also offers an improved collection of ports and peripherals, including: Fully-populated 400-pin FMC HPC connector w/ ten GTX lanes USB-UART Bridge 128x32 pixel OLED 16-bit VGA connector Pmod connector for XADC signals Two four-lane DisplayPort connectors HDMI Sink and HDMI Source 10/100/1000 Ethernet PHY 1GB 1800Mbps on-board DDR3 USB 2.0 Host/Device/OTG PHY Dedicated USB port for JTAG programming and data transfers Micro SD card connector Audio codec w/ four 3.5mm jacks Serial Flash Five Pmod ports USB HID Host for mice, keyboards and USB MSD Host for storage The Genesys 2 can be programmed from various sources, like USB thumb drive, microSD, the on-board non-volatile Flash or the on-board USB-JTAG programmer circuit. The Genesys 2 is compatible with Xilinx’s new high-performance Vivado® Design Suite as well as the ISE toolset, which includes ChipScope and EDK. Vivado comes with all the required cable drivers, so no separate installation is required. The free “WebPACK” versions of these toolsets do not support the Kintex-7 325T, however for a limited time a voucher with Design Edition will be included with no additional cost. What's Included: Genesys 2 Kintex-7 FPGA Digilent custom cardboard box with protective foam USB A to Micro‐B programming cable and one 12V, 3A wall power supply with US and EU adapters Vivado Design Suite voucher http://store.digilentinc.com/genesys‐2‐kintex‐7‐fpga‐development‐board/
410-300 价格&库存
很抱歉,暂时无法提供与“410-300”相匹配的价格&库存,您可以联系我们找货
  • 1+10661.466881+1380.01577
库存:66
