6015-410-001
6015-410-001
    DIGILENT(迪芝伦)
    NETFPGA 1G CML
6015-410-001 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com NetFPGA-1G-CML™ Board Reference Manual Revised April 8, 2016 This manual applies to the NetFPGA-1G-CML rev. F Overview The NetFPGA-1G-CML is a versatile, low-cost network hardware development platform featuring a Xilinx® Kintex®7 XC7K325T FPGA and includes four Ethernet interfaces capable of negotiating up to 1 GB/s connections. 512 MB of 800 MHz DDR3 can support high-throughput packet buffering while 4.5 MB of QDRII+ can maintain low-latency access to high demand data, like routing tables. Rapid boot configuration is supported by a 128 MB BPI Flash, which is also available for non-volatile storage applications. The standard PCIe form factor supports high speed x4 Gen 2 interfacing. The FMC carrier connector provides a convenient expansion interface for extending card functionality via Select I/O and GTX serial interfaces. The FMC connector can support SATA-II data rates for network storage applications. The FMC connector can also be used to extend functionality via a wide variety of other cards designed for communication, measurement, and control.              The NetFPGA-1G-CML board.   Xilinx Kintex-7 XC7K325T-1FFG676 FPGA Low-jitter 200 MHz oscillator Four 10/100/1000 Ethernet PHYs with RGMII X4 Gen 2 PCI Express X16 4.5 MB QDRII+ static RAM (450 MHz) X8 512 MB DDR3 dynamic RAM (800 MHz) 1-Gbit BPI Flash SD card slot 32-bit PIC microcontroller USB microcontroller Real time clock Crypto-authentication chip High pin count FMC connector (VITA 57) with 100 Select-IO and 4 GTX serial pairs Two Pmod ports Four on-board LEDs and four on-board general-purpose buttons The NetFPGA-1G-CML is designed to support the Stanford NetFPGA architecture with reference designs available through the NetFPGA GitHub Organization (www.github.com/organizations/NetFPGA). It is fully compatible with Xilinx Vivado™ and ISE® Design Suites as well as Xilinx SDK for embedded software design. DOC#: 6015-502-001 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 21 NetFPGA-1G-CML™ Board Reference Manual The Kintex-7 XC7K325T-1FFG676 FPGA has ample logic and I/O capacity for supporting a wide range of designs with the following capabilities:         1 50,950 slices, each containing four 6input LUTs and eight flip-flops Over 16 Mbit of fast on-chip block RAM Ten clock management tiles with one PLL and one mixed-mode clock manager each 840 DSP slices Integrated PCI Express Integrated AES bitstream encryption and SHA-256 authentication with batterybacked encryption key 400 Select I/O ports (250 high range, 150 high speed) Eight 6.6 Gb/s GTX serial transceivers FPGA Configuration The system logic configuration is stored within the FPGA in SRAM-based memory cells. This data defines the FPGA's logic functions and circuit connections, but it is volatile since it remains valid only as long as power is applied. Because of this, the device is configured (i.e., programmed) every time it is turned-on. In addition, it may also be re-configured at any time power is applied. Once power is removed, the most recently programmed logic configuration is lost. The configuration data is commonly called a bitstream which is most often contained in files of type ".bit" or ".mcs". These files may be created several different ways using Xilinx development software. The FPGA may be configured from three different sources. These include the on-board BPI flash, an off-board USB flash drive, or via a PC. The NetFPGA-1G follows a specific configuration sequence when it powers up and comes out of reset. If a valid "download.bit" file is detected on an attached UBS flash drive, that bitstream will be used to program the FPGA. The flash drive must be FAT formatted, contain a single "download.bit" file, and be attached to the USB-HOST port (J13) with jumper JP4 in place. If no flash drive bitstream is detected, an attempt will be made to configure the device from the on-board BPI flash address 0x0. If no flash bitstream is available, the board idles until it is programmed from a PC. PC programming can be done either via a USB cable connected to the USB PROG port (J12), or a JTAG programming cable connected to the Xilinx PROG CABLE port (J15). Any flash drive bitstreams that are not built for the Xilinx XC7K325T FPGA will be ignored. This power-on programming sequence can be reinitiated at any time after power is applied by depressing the red PROG button (BTN5). Both Digilent and Xilinx distribute free software that can be used to transfer bitstreams from a PC as well as create bitstream files to load via a flash drive. Digilent's Adept and Xilinx's iMPACT applications can directly program the FPGA using a .bit file a standard USB A to Micro B cable connected to J12 or through any of several Digilent JTAG programming cables connected to J15. The on-board BPI flash is programmed via similar means. When Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 21 NetFPGA-1G-CML™ Board Reference Manual programming the BPI, iMPACT transfers a .mcs format bitstream to the flash in a two-step process. iMPACT first programs the FPGA directly with a special purpose BPI flash interface. It will then transfer the .mcs bitstream to the flash through that interface. This process is fully automated by the iMPACT program, so a designer only needs to be concerned with the creation of the .mcs file using Xilinx's design software. More details on configuring the XC7K325T FPGA via the on-board BPI (using Master BPI mode), via the PIC USBHOST (using Slave Serialmode), and via the JTAG mode can be found in the Xilinx 7 Series FPGAs Configuration User Guide (UG470). 2 Power Supplies The NetFPGA-1G requires a 12V, 5A, or greater power source. Power is supplied via the J17 Molex connector at the rear of the PCB, as is often done with high performance PC graphics cards. No power is supplied via the PCIe motherboard bus connector. The NetFPGA-1G can be powered using the 6-pin PCIe power supply connector (Fig. 1) of any standard ATX power supply. When installed on a PC motherboard, you can directly plug the 6-pin PCIe power supply connector of your PC power supply into J17. When used standalone (without a motherboard), you need to short pins 15 and 16 (pulling down PS_ON signal) of the main 20-pin connector of the standard ATX power supply to power-on the ATX unit (Fig.1). Figure1. Left: NetFPGA-1G can be powered by plugging the 6-pin PCIe power connector in J17; Right: Pin 16 and 17 are shorted using a jumper to power on a standard ATX power supply when used standalone. Analog Devices voltage regulators provide a number of on-board power and reference voltages that are derived from the main 12V supply, as shown in Table 1. Supply power-on and power-off sequencing follows manufacturer recommendations. The on-board battery that supports encryption key storage and the real-time clock is charged when the PCB is powered on and should not need to be replaced during the lifetime of the board. VADJ controls the signal levels used between the FMC connector and two FPGA Select I/O banks and can be set to 1.2 V, 1.8 V, 2.5 V, or 3.3 V as needed. The board is shipped with the VADJ supply turned off. To turn on VADJ, jumper JP5 is installed and the FPGA is configured to drive the VADJ_EN pin (AD16) high. The VADJ voltage is selected via the FPGA configuration using pins AF19 and AF20 as shown in Table 1. When jumper JP4 is in place, the USB HID connector provides 5V at up to 0.5 A to external USB devices, including keyboards, mice, and thumb drives. An Analog Devices ADM1177 hot swap controller and power monitor is used to allow safe device attachment and removal while the board is powered up. The PIC can also measure USB current and voltage by accessing the on-chip power monitor via the PIC I2C peripheral bus. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 3 of 21 NetFPGA-1G-CML™ Board Reference Manual The Xilinx Kintex-7 Data Sheet: DC and AC Switching Characteristics (DS182) provides more information on the power supply requirements of the FPGA board. Supply 5.0 V Derived From 12.0 V 3.3 V 12.0 V 2.0 V 5.0 V 1.8 V 1.8 V 1.5 V 1.2 V 1.0 V 1.0 V 0.9 V 0.75 V 12.0 V 3.3 V 12.0 V 12.0 V 12.0 V 3.3 V 3.3 V 3.3 V Application USB HID; FMC SD Card; Ethernet PHYs; Cypress FX2LP; Microchip PIC; BPI Flash; FPGA I/O Banks 14,15; FMC; Pmods FPGA auxiliary supply, VCCBAT; Backup battery; Real-time clock backup. QDRII+ supply FPGA GTX transceiver Quad PLL DDR3; FPGA I/O Bank 34 FPGA GTX transceiver termination FPGA GTX analog supply FPGA Core QDRII+ reference DDR3 reference FPGA I/O Banks 12, 13; FMC; Configurable. VADJ 12.0 V SET_VADJ2 FPGA AF20 0 0 1 1 SET_VADJ1 FPGA AF19 0 1 0 1 VADJ 1.2 V 1.8 V 2.5 V 3.3 V Table 1. On-board power supplies. 3 Oscillators and Clocks On-board oscillators support various board subsystems. A low-jitter 125 MHz oscillator is provided for the Ethernet PHYs and a 50 MHz oscillator drives the FPGA master configuration clock. The Cypress FX2LF and Microchip PIC microcontroller each contain on-chip oscillators running at 24 MHz and 8 MHz, respectively. The main FPGA system clock is provided by an ultra-low-jitter 200 MHz differential oscillator connected to pins AA2 and AA3 in I/O bank 34. This can drive up to ten internal PLLs (Phase Locked Loops) and MMCMs (MixedMode Clock Managers) on the FPGA for high-performance multi-clock-domain designs. Please refer to the Xilinx 7Series Clock Resources User Guide (UG472) for more details on FPGA internal clocking resources. 4 FPGA Memory The XC7K325T FPGA includes 445 on-chip Block RAMs (BRAMs) of 36Kb, or 4096 bytes with two-bit error correction, which amounts to a total of 1.78 MB of on-chip, error-corrected static RAM that can be used for a variety of purposes ranging from program storage for deeply embedded "bare metal" applications to data Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 4 of 21 NetFPGA-1G-CML™ Board Reference Manual buffering and table lookup. Each 36Kb BRAM can be partitioned into two completely independent 18Kb RAMs to help facilitate more efficient hardware utilization. Furthermore, each BRAM can be configured for dual-port operation and includes register infrastructure tp support FIFO functionality. These BRAM ports can be organized in either single or dual-clock configurations. The Xilinx tool chain includes a rich selection of resources for on-chip BRAM configuration and initialization. Further information is provided in the Xilinx 7-Series FPGAs Memory Resources User Guide (UG473). 5 DDR3 Memory The NetFPGA-1G includes a Micron MT41K512M8 512 MB DDR3 SDRAM which employs an 800 MHz byte-wide data bus capable of operating at a data rate of 1600 MT/s. Project development with the SDRAM involves using the Xilinx Memory Interface Generator (MIG) in either the XPS design tool or the Vivado Design Suite. The MIG is an interface generation wizard for selecting part types and configuring FPGA Select I/O resources for the memory hardware interface. The interface is automatically configured by the MIG for use with the AXI4 system bus and provides options for 2:1 or 4:1 memory-to-bus clock ratios. The NetFPGA-1G uses a VCCAUX-IO of 2.0V to support high performance DDR3 frequency settings. Please see the Xilinx 7 Series FPGAs Memory Interface Solutions User Guide (UG586) and the Micron 4Gb:x4,x8,x16 DDR3L SDRAM data sheet for more details. 6 QDRII+ Memory A 4.5 MB Cypress CY7C2263KV18 QDRII+ Quad Data Rate SRAM is provided for applications that require high speed, low-latency memory. Common applications include FIFO buffers and table lookups. The notion of "Quad" data rate comes from the ability to simultaneously read from a unidirectional read port and write to a unidirectional write port on both clock edges. The NetFPGA-1G QDRII+ is capable of operating at up to 450MHz to yield data transfer rates of up to 900 MT/s per 2-byte port. This yields a peak bandwidth of up to 3.6 GB/s. The Xilinx Memory Interface Generator (MIG) is able to generate and configure an AXI4 based interface into the QDRII+ via the user friendly wizard tool. More information regarding the QDRII+ memory part and the Xilinx MIG tool can be found in the Cypress CY7C2263KV18/CY7C2265KV18 data sheet, the Cypress Application Note QDR-II, QDR-II+, DDR-II, DDR-II+ Design Guide (AN4065), and the Xilinx 7 Series FPGAs Memory Interface Solutions User Guide (UG586). 7 BPI Flash Memory A 1-Gbit Numonyx BPI (Byte Peripheral Interface) flash memory in a 128 MB x16 configuration is provided to support high-speed FPGA configuration after board reset. High-speed single-step configuration enables enumeration via the PCIe interface within 100 mS, as required by the PCI specification. In BPI configuration mode, the FPGA acts as the bus master, driving the flash address and control signals to transfer previously stored bitstream data into the configuration SRAM. The BPI flash has enough capacity to store multiple device configurations. This facilitates multi-stage configuration boot as well as applications that utilize dynamic reconfiguration. Configuration bitstreams are not the only data which can be stored in the BPI flash. After configuration is complete, the BPI programming pins may be used as normal Select I/O within the design. As a result, non-volatile data of any type can also be stored to and retrieved from the BPI after device configuration is complete. More information regarding BPI based device configuration is Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 5 of 21 NetFPGA-1G-CML™ Board Reference Manual available in the Xilinx 7-Series FPGAs Configuration User Guide (UG470) and application note XAPP587 BPI Fast Flash Memory data sheet for more specifics regarding device operation. 8 SD Card The NetFPGA-1G SD card connector supports a second non-volatile storage resource which is also removable. This connector supports a standard size SD memory card and meets all physical layer requirements of both SPI and SD bus protocols. It supports the UHS-I pin assignment standard (but not UHS-II) and provides high speed signaling at 3.3V to support SC, HC, and XC class SD cards. Please see SD Specifications Part 1 Physical Layer Simplified Specification by the Technical Committee of the SD Card Association for more details regarding the use of SD memory cards with this connector. 9 PCIe Interface The NetFPGA-1G is designed with a PCI-Express form factor to support interconnection with common processor motherboards. Four of the FPGA's eight high speed serial GTX transceivers are dedicated to implementing up to four-lanes of Gen. 2.0 (5 GB/s) PCIe communications with a host processing system. These transceivers work in conjunction with the on-chip 7 Series Integrated PCI Express Block and synthesizable on-chip logic to provide a scalable, high performance PCI Express I/O core. This core is configured and incorporated into designs using either the Xilinx ISE Coregen tool or via instantiation and customization from the Vivado Design Suite IP catalog. Please refer to the Xilinx 7 Series FPGAs Integrated Block for PCI Express V2.0 (PG054) product guide and 7 Series FPGAs GTX/GTH Transceivers (UG476) user guide for more information. 10 Ethernet PHYs Four Realtek RTL8211 Ethernet transceivers (PHYs) are provided to interface to network connections via on-board RJ-45 connectors. Each RJ-45 has two LEDs to indicate link status and activity. Each PHY controls three LEDs: two on an associated RJ-45 and a third on-board (LD5-LD8). The Phys are programmed via a shared MDIO bus and are accessed via MDIO addresses 1 through 4: corresponding to connectors ETH1 through ETH4 on the PCB. At reset, each PHY defaults to 1Gbps with the LED configuration shown in Table 2. On each RJ45, the bottom LED is the one that is closest to the PCIe connector. The default behavior of the onboard LED is to mimic that of the top RJ45 LED. The default auto-negotiation behavior allows each PHY to independently adjust its rate to 10/100 Mbps or 1Gbps as needed. Data is transferred to and from the PHYs via a Reduced Gigabit Media Independent Interface (RGMII). This is similar to the Gigabit Media Independent Interface (GMII), which uses eight bits for both transmit and receive data. RGMII achieves the same data rate with half the number of data bits and double-data-rate clocking. 1 Gbps data transfers are thereby achieved using a 125MHz clock with four bits transferred on each clock edge for both send and receive. This provides a significant reduction in the number of FPGA I/O pins required to support the four Ethernet interfaces. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 6 of 21 NetFPGA-1G-CML™ Board Reference Manual Xilinx provides Ethernet MAC IP that will support 10/100/1000 Mb/s via the ISE Design Suite Coregen tool and the Vivado design suite. Please refer to Xilinx Product Guide PG051 LogiCORE IP Tri-Mode Ethernet MAC for more information. LED Action Meaning Connection Negotiation Complete Link activity present No link activity Link activity present Slow blink RJ45 Top On Off Fast blink RJ45 Bottom Table 2. RJ-45 Ethernet Connector LED Function. 11 PIC Subsystem NetFPGA-1G includes a 32-bit PIC microcontroller for managing USB OTG, real-time clock, and secure storage interfacing. The PIC is pre-programmed with manufacturing test code and an ability to load FPGA bitstreams from a USB memory stick. It is possible to re-program the PIC to support end-user applications that make use of various other PIC subsystem features. This may be done via J14 using a PICKit 3 In-Circuit Debugger (Digilent p/n PG164130). To run the pre-programmed manufacturing test, first set up the NetFPGA-1G and host PC as described in Appendix A: Manufacturing Test. When the board is powered on, the factory-loaded PIC firmware will search for the bitstream "mfg_test.bit" on the USB flash drive and use it to configure the FPGA in slave serial mode. After the FPGA has been configured, a test menu will be displayed on the terminal emulator window connected to the PmodUSBUART, and the user can run the tests by following the menu prompts. If the board is set up as described in Appendix A, all tests should pass. The address map of the PIC I2C peripherals is shown in Table 3. The PIC is also connected to an MX25L12835E SPI Serial Flash using general-purpose I/O ports for increased data storage. The flash's pins are connected to the PIC ports as shown in Table 4. To program the PIC device, connect a PICkit 3 to the NetFPGA-1G by placing a 1x6 pin header in the zig-zag connector J14 and connect it to the PICkit 3 using a 6-pin cable. If Digilent's 6-pin Pmod cable is used, the white indicator dot on the NetFPGA-1G side should be above pin 6, and the dot on the PICkit 3 side will be face-up and opposite the white arrow on the PICkit 3. The PIC can then be programmed from Microchip's MPLAB X or MPLAB IPE by selecting the PICkit 3 as the programming tool. Component Name AD5274 Digital Rheostat ADM1177 Hot Swap Controller ATSHA204 CryptoAuthentication M41T62 Real-Time Clock 24LC128 Serial EEPROM PIC I2C Controller I2C2 I2C2 I2C2 I2C2 I2C1 I2C 7-bit Address 0101110 1011011 1100100 1101000 1010001 Table 3. PIC I2C peripheral address map. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 7 of 21 NetFPGA-1G-CML™ Board Reference Manual Flash Pin CS SCLK SI SO WP HOLD PIC Port RB10 RB11 RB12 RB13 RB14 RB15 Table 4. PCI Flash connections. 12 On-Board I/O Built-in on-board I/O includes four LEDs and six buttons. Four of the buttons are general-purpose and two are set aside for special functions. The red special function buttons are reserved for use as an on-chip reset (BTN4 - RESET) to reset the design logic and a configuration reset (BTN5 – PROG) which initiates a new FPGA configuration sequence like that which occurs at power-on. It is important to note that the buttons and LEDs are not all constrained to the same IOSTANDARD on their associated ports, since they are connected to otherwise unallocated ports in different FPGA IO banks. Please refer to Appendix B for specific details regarding the button and LED IO port constraints. 13 Pmod Expansion Connectors The NetFPGA-1G has two 12-pin ports to support I/O expansion via Digilent Pmods. Digilent manufactures Pmod accessories that support a large variety of external interfaces that increase system flexibility. The Pmod ports are 2x6 right-angle 100-mil female connectors that work with the standard 2x6 headers available from a variety of distributors. On the NetFPGA-1G, each 12-pin Pmod ports provides two 3.3V VCC supply connections (pins 6 and 12), two Ground connections (pins 5 and 11), and eight logic signals (Fig. 2). The supply pins can provide up to 1A of current to connected Pmod devices. The logic signals are not matched pairs. They are routed without impedance control or delay matching. Note also that the ports are not keyed, so care should be taken to verify that any connected devices have Pin 1 aligned with Pin 1 on the connector. Pin 1, VCC, and GND are clearly labeled on the PCB to help simplify proper connection. Figure 2. Pmod ports, end view. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 8 of 21 NetFPGA-1G-CML™ Board Reference Manual 14 Expansion Connector The NetFPGA-1G includes a VITA-57 compatible FMC (FPGA Mezzanine Card) carrier connector. A High Pin Count (HPC) connector is used to provide the maximum possible compatibility with a variety of commercially available mezzanine cards. Select I/O ports on the XC7K325T are connected to all of the standard Low Pin Count (LPC) signals on the connector, but only 22 of the HPC signals are supported due to the limitations of the FF676 package. Up to four differential send/receive pairs for GTX transceivers are also supported. The FMC interface signals are driven by two Select I/O banks within the FPGA. Signal drive voltages within these banks are configured together to match the various requirements of different mezzanine cards. These banks are disabled on the board when shipped, but jumper JP5 (VADJ ENABLE) can be installed to prepare these I/O banks for use with the FMC connector. Three control outputs are then included in the FPGA design configuration to set the FMC signaling voltage and enable it. Those signals are VADJ_EN, SET_VADJ1, SET VADJ2, and are set according to Table 1. Keep in mind that the IOSTANDARD required by the pin constraints associated with the FMC interface will depend upon the VADJ selected, and that these VADJ programming signals should be set to constants within the design. Please refer to the American National Standards Institute ANSI/VITA 57.1 FPGA Mezzanine Card (FMC) Standard for additional detail regarding standard FMC module and carrier requirements. Refer to Appendix B for specific I/O constraints relating FPGA pins to their associated FMC control and connector pins. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 9 of 21 NetFPGA-1G-CML™ Board Reference Manual Appendix A: Manufacturing Test The following hardware is required to run all NetFPGA-1G Manufacturing tests: • • • • • • • • • • • • • 1x HiTechGlobal PCI Express Test/SMA Breakout Board 8x SMA to SMA cable, 24" 2x Ethernet cables 1x NetFGPA-7 FMC Test Card 1x SD card, any size, loaded with an ASCII text file named "message.txt" 1x Micro (male) to Type A (female) USB adapter 1x USB thumb drive loaded with the production test bitstream, "mfg_test.bit" 1x PmodUSBUART 2x 6 pin connector cable, 6" 1x Micro (male) to Type A (male) USB cable 2x 1x6 pin headers 46x 2 pin block jumpers 12 V power supply If debug information in addition to pass/fail messages regarding manufacturing tests related to the FPGA is desired, an additional PmodUSBUART, 6 pin connector cable, and micro (male) to type A (male) USB cable is needed. The following summary describes how to set up the manufacturing test hardware with the NetFPGA-1G: a) Load jumpers JP4 (USB HOST) and JP5 (VADJ ENABLE) b) For both Pmod headers JA and JB, plug a 1x6 pin header in the bottom row (pins 7-12) and place a jumper across pins 7-8 and another across pins 9-10 c) Connect the NetFPGA-7 FMC Test Card to the FMC connector J11 and load all the jumper blocks horizontally (1 2, 3 4, 5 6, etc.) d) Connect one Ethernet cable between ETH1 and ETH2, and another between ETH3 and ETH4 e) Connect the USB thumb drive containing "nf7_test.bit" to J13 using the micro to type A adapter cable f) Plug the SD card containing "message.txt" into the SD connector J10 g) Connect a PmodUSBUART to pins 1-6 of JA using a 6 pin connector cable, and connect the PmodUSBUART to a host machine using a micro to type A USB cable h) Plug the NetFPGA-7 into the HTG PCIe test card. Loop the RX0-3 pairs on the HTG card to the TX0-4 pairs using SMA cables (RX0P TX0P, RX0N TX0N, etc.). Set switches 1-3 on the HTG card to 000. Additionally, power the HTG card with a Molex connector from a standard PC power supply, and ensure the power switch is set to ATX i) Plug a PCIe power connector from a standard PC power supply into J17 on the NetFPGA-7 j) If FPGA debug information is desired, connect the additional PmodUSBUART, 6 pin connector cable, and micro (male) to type A (male) USB cable to pins 1-6 of Pmod port JB and a host machine Many tests can be run independently without the need for additional hardware. For example, the HiTech Global Breakout Board is only needed to test the PCIe edge connector. More details regarding individual tests are provided in the NetFPGA-1G Manufacturing Test Reference Manual available on the Digilent web site. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 10 of 21 NetFPGA-1G-CML™ Board Reference Manual Appendix B: FPGA Pin Constraints The following list provides LOC and IOSTANDARD constraints for the main peripheral pins connected to the FPGA. This information can be used in a design UCF file with Xilinx ISE Design Suite, a design XDC file with Xilinx Vivado Design Suite, or with various interface generators included with Xilinx Coregen and MIG. Please see the Xilinx Constraints Guide (UG625) for ISE Design Suite based designs and Xilinx Vivado Design Suite User Guide: Using Constraints (UG903) for Vivado based designs. Depending upon the design suite selected, this information can be expressed in either a UCF file or an XDC file as follows: UCF format used with ISE Design Suite NET LOC= | IOSTANDARD=; XDC format used with Vivado Design Suite set_property IOSTANDARD [get_ports { }] set_property LOC [get_ports ] The information is presented in UCF format to express a clear association between the pin and the desired IO standard for the NetFPGA-1G, although it can be readily translated into the XDC format. LOC information is provided here for all pins. IOSTANDARD information is provided for SelectIO pins. Other useful properties are suggested where appropriate. System Clock and Reset Port Name IO Location NET reset LOC = AA8 NET system_clk_p NET system_clk_n LOC = AA3 LOC = AA2 IO Standard Type IOSTANDARD=LVCMOS18; # RESET button (BTN4) IOSTANDARD=LVDS; IOSTANDARD=LVDS; DDR3 SDRAM Port Name IO Location IO Standard Type NET ddr3_dq[0] LOC = AE5 IOSTANDARD = SSTL15_T_DCI; NET ddr3_dq[1] LOC = AE3 IOSTANDARD = SSTL15_T_DCI; NET ddr3_dq[2] LOC = AD4 IOSTANDARD = SSTL15_T_DCI; NET ddr3_dq[3] LOC = AF3 IOSTANDARD = SSTL15_T_DCI; NET ddr3_dq[4] LOC = AE1 IOSTANDARD = SSTL15_T_DCI; NET ddr3_dq[5] LOC = AF2 IOSTANDARD = SSTL15_T_DCI; NET ddr3_dq[6] LOC = AD1 IOSTANDARD = SSTL15_T_DCI; NET ddr3_dq[7] LOC = AE2 IOSTANDARD = SSTL15_T_DCI; NET ddr3_addr[0] LOC = Y3 IOSTANDARD = SSTL15; NET ddr3_addr[1] LOC = Y2 IOSTANDARD = SSTL15; NET ddr3_addr[2] LOC = W3 IOSTANDARD = SSTL15; Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 11 of 21 NetFPGA-1G-CML™ Board Reference Manual NET ddr3_addr[3] LOC = W5 IOSTANDARD = SSTL15; NET ddr3_addr[4] LOC = AB2 IOSTANDARD = SSTL15; NET ddr3_addr[5] LOC = W1 IOSTANDARD = SSTL15; NET ddr3_addr[6] LOC = AC2 IOSTANDARD = SSTL15; NET ddr3_addr[7] LOC = U2 IOSTANDARD = SSTL15; NET ddr3_addr[8] LOC = AB1 IOSTANDARD = SSTL15; NET ddr3_addr[9] LOC = V1 IOSTANDARD = SSTL15; NET ddr3_addr[10] LOC = AD6 IOSTANDARD = SSTL15; NET ddr3_addr[11] LOC = Y1 IOSTANDARD = SSTL15; NET ddr3_addr[12] LOC = AC3 IOSTANDARD = SSTL15; NET ddr3_addr[13] LOC = V2 IOSTANDARD = SSTL15; NET ddr3_addr[14] LOC = AC1 IOSTANDARD = SSTL15; NET ddr3_addr[15] LOC = AD5 IOSTANDARD = SSTL15; NET ddr3_ba[0] LOC = AA5 IOSTANDARD = SSTL15; NET ddr3_ba[1] LOC = AC4 IOSTANDARD = SSTL15; NET ddr3_ba[2] LOC = V4 IOSTANDARD = SSTL15; NET ddr3_ras_n LOC = Y6 IOSTANDARD = SSTL15; NET ddr3_cas_n LOC = Y5 IOSTANDARD = SSTL15; NET ddr3_we_n LOC = U5 IOSTANDARD = SSTL15; NET ddr3_reset_n LOC = U1 IOSTANDARD = LVCMOS15; NET ddr3_cke[0] LOC = AB5 IOSTANDARD = SSTL15; NET ddr3_odt[0] LOC = U7 IOSTANDARD = SSTL15; NET ddr3_cs_n[0] LOC = U6 IOSTANDARD = SSTL15; NET ddr3_dm[0] LOC = AE6 IOSTANDARD = SSTL15; NET ddr3_dqs_p[0] LOC = AF5 IOSTANDARD = DIFF_SSTL15_T_DCI; NET ddr3_dqs_n[0] LOC = AF4 IOSTANDARD = DIFF_SSTL15_T_DCI; NET ddr3_ck_p[0] LOC = AA4 IOSTANDARD = DIFF_SSTL15; NET ddr3_ck_n[0] LOC = AB4 IOSTANDARD = DIFF_SSTL15; QDRII+ Port Name NET qdriip_d[0] NET qdriip_d[1] NET qdriip_d[2] IO Location LOC = V8 LOC = V7 LOC = W9 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. IO Standard Type IOSTANDARD = HSTL_I; IOSTANDARD = HSTL_I; IOSTANDARD = HSTL_I; Page 12 of 21 NetFPGA-1G-CML™ Board Reference Manual NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET qdriip_d[3] qdriip_d[4] qdriip_d[5] qdriip_d[6] qdriip_d[7] qdriip_d[8] qdriip_d[9] qdriip_d[10] qdriip_d[11] qdriip_d[12] qdriip_d[13] qdriip_d[14] qdriip_d[15] qdriip_d[16] qdriip_d[17] qdriip_q[0] qdriip_q[1] qdriip_q[2] qdriip_q[3] qdriip_q[4] qdriip_q[5] qdriip_q[6] qdriip_q[7] qdriip_q[8] qdriip_q[9] qdriip_q[10] qdriip_q[11] qdriip_q[12] qdriip_q[13] qdriip_q[14] qdriip_q[15] qdriip_q[16] qdriip_q[17] qdriip_sa[0] qdriip_sa[1] qdriip_sa[2] qdriip_sa[3] qdriip_sa[4] qdriip_sa[5] qdriip_sa[6] qdriip_sa[7] qdriip_sa[8] qdriip_sa[9] qdriip_sa[10] qdriip_sa[11] qdriip_sa[12] qdriip_sa[13] qdriip_sa[14] qdriip_sa[15] qdriip_sa[16] qdriip_sa[17] LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Y11 Y8 Y7 W10 Y10 V9 AF8 AE8 AF9 AF10 AE10 AD10 AD11 AF13 AE13 AA14 AD14 Y15 AA15 AC14 AB14 Y16 AB15 AC16 AE20 AD19 AD18 AC19 AB20 AA20 AD20 AC17 AB17 AC9 AF7 AA9 AD8 AC8 AB7 AB12 AD13 AC11 AC12 Y12 AB11 AB10 AA13 AC13 Y13 AA12 AA10 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I_DCI; HSTL_I_DCI; HSTL_I_DCI; HSTL_I_DCI; HSTL_I_DCI; HSTL_I_DCI; HSTL_I_DCI; HSTL_I_DCI; HSTL_I_DCI; HSTL_I_DCI; HSTL_I_DCI; HSTL_I_DCI; HSTL_I_DCI; HSTL_I_DCI; HSTL_I_DCI; HSTL_I_DCI; HSTL_I_DCI; HSTL_I_DCI; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; Page 13 of 21 NetFPGA-1G-CML™ Board Reference Manual NET NET NET NET NET NET NET NET NET NET NET qdriip_sa[18] qdriip_w_n qdriip_r_n qdriip_dll_off_n qdriip_bw_n[0] qdriip_bw_n[1] qdriip_cq_p[0] qdriip_cq_n[0] qdriip_qvld[0] qdriip_k_p[0] qdriip_k_n[0] LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC = = = = = = = = = = = AB9 AD9 AE7 AC7 W11 V11 AB16 AC18 AA19 AE12 AF12 IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD = = = = = = = = = = = HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I; HSTL_I_DCI; HSTL_I_DCI; HSTL_I_DCI; DIFF_HSTL_I; DIFF_HSTL_I; BPI Flash Port Name NET bpi_clk_out NET bpi_we_n NET bpi_oe_n NET bpi_ce_n NET bpi_adv NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_addr_cmd NET bpi_data NET bpi_data IO Location LOC = C8 LOC = L18 LOC = M17 LOC = C23 LOC = D20 LOC = J23 LOC = K23 LOC = K22 LOC = L22 LOC = J25 LOC = J24 LOC = H22 LOC = H24 LOC = H23 LOC = G21 LOC = H21 LOC = H26 LOC = J26 LOC = E26 LOC = F25 LOC = G26 LOC = K17 LOC = K16 LOC = L20 LOC = J19 LOC = J18 LOC = J20 LOC = K20 LOC = G20 LOC = H19 LOC = E20 LOC = B24 LOC = A25 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. IO Standard Type IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; Page 14 of 21 NetFPGA-1G-CML™ Board Reference Manual NET NET NET NET NET NET NET NET NET NET NET NET NET NET bpi_data bpi_data bpi_data bpi_data bpi_data bpi_data bpi_data bpi_data bpi_data bpi_data bpi_data bpi_data bpi_data bpi_data LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC = = = = = = = = = = = = = = B22 A22 A23 A24 D26 C26 C24 D21 C22 B20 A20 E22 C21 B21 IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD = = = = = = = = = = = = = = LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; SD Card Connector Port Name NET sd-cd NET sd-wp NET sd-cclk NET sd-cmd NET sd-d0 NET sd-d1 NET sd-d2 NET sd-d3 IO Location LOC = AE15 LOC = AF15 LOC = AA18 LOC = AF18 LOC = AE17 LOC = AF17 LOC = AD15 LOC = AE18 IO Standard Type IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = LVCMOS18 LVCMOS18 LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. PULLUP; PULLUP; Page 15 of 21 NetFPGA-1G-CML™ Board Reference Manual PCI Express Port Name IO Location IO Standard Type NET pcie-rx0_p LOC = H2; NET pcie-tx0_p LOC = J4; NET pcie-rx0_n LOC = H1; NET pcie-tx0_n LOC = J3; NET pcie-rx1_p LOC = K2; NET pcie-tx1_p LOC = L4; NET pcie-rx1_n LOC = K1; NET pcie-tx1_n LOC = L3; NET pcie-rx2_p LOC = M2; NET pcie-tx2_p LOC = N4; NET pcie-rx2_n LOC = M1; NET pcie-tx2_n LOC = N3; NET pcie-rx3_p LOC = P2; NET pcie-tx3_p LOC = R4; NET pcie-rx3_n LOC = P1; NET pcie-tx3_n LOC = R3; NET pcie-clk_p LOC = H6; NET pcie-clk_n LOC = H5; NET pcie-perstn LOC = L17 IOSTANDARD = LVCMOS33 NET pcie-wake LOC = K18 IOSTANDARD = LVCMOS33; NET pcie-prsnt LOC = AA7 IOSTANDARD = LVCMOS18; PULLUP NODELAY; Ethernet PHYS Port Name NET mdc NET mdio NET phy_rstn_1 NET phy_rstn_2 NET phy_rstn_3 NET phy_rstn_4 NET phy_intrn_1 NET phy_intrn_2 NET phy_intrn_3 NET phy_intrn_4 NET rgmii_rxd_1[0] NET rgmii_rxd_1[1] NET rgmii_rxd_1[2] IO Location LOC = V13 LOC = W13 LOC = K21 LOC = L23 LOC = E25 LOC = D18 LOC = J8 LOC = J14 LOC = K15 LOC = M16 LOC = A14 LOC = B14 LOC = E12 IO Standard Type IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. LVCMOS18; LVCMOS18; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS18 LVCMOS18 LVCMOS18 LVCMOS18 LVCMOS18; LVCMOS18; LVCMOS18; PULLUP; PULLUP; PULLUP; PULLUP; Page 16 of 21 NetFPGA-1G-CML™ Board Reference Manual NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET rgmii_rxd_1[3] rgmii_txd_1[0] rgmii_txd_1[1] rgmii_txd_1[2] rgmii_txd_1[3] rgmii_rx_ctl_1 rgmii_rxc_1 rgmii_tx_ctl_1 rgmii_txc_1 rgmii_rxd_2[0] rgmii_rxd_2[1] rgmii_rxd_2[2] rgmii_rxd_2[3] rgmii_txd_2[0] rgmii_txd_2[1] rgmii_txd_2[2] rgmii_txd_2[3] rgmii_rx_ctl_2 rgmii_rxc_2 rgmii_tx_ctl_2 rgmii_txc_2 rgmii_rxd_3[0] rgmii_rxd_3[1] rgmii_rxd_3[2] rgmii_rxd_3[3] rgmii_txd_3[0] rgmii_txd_3[1] rgmii_txd_3[2] rgmii_txd_3[3] rgmii_rx_ctl_3 rgmii_rxc_3 rgmii_tx_ctl_3 rgmii_txc_3 rgmii_rxd_4[0] rgmii_rxd_4[1] rgmii_rxd_4[2] rgmii_rxd_4[3] rgmii_txd_4[0] rgmii_txd_4[1] rgmii_txd_4[2] rgmii_txd_4[3] rgmii_rx_ctl_4 rgmii_rxc_4 rgmii_tx_ctl_4 rgmii_txc_4 LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = D13 G12 F13 F12 H11 C13 E11 F10 E13 B15 F14 C14 H12 J13 G14 H14 H13 A15 G11 J11 D14 A13 C9 D11 C11 D10 G10 D9 F9 A12 C12 F8 J10 B11 A10 B10 A9 A8 D8 G9 H9 B12 E10 H8 B9 IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; PIC Interface Port Name NET pic2fpga_sck NET pic2fpga_sdo NET pic2fpga_ss_n IO Location LOC = AA17 LOC = V16 LOC = W16 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. IO Standard Type IOSTANDARD = LVCMOS18; IOSTANDARD = LVCMOS18; IOSTANDARD = LVCMOS18; Page 17 of 21 NetFPGA-1G-CML™ Board Reference Manual NET NET NET NET NET NET NET pic2fpga_gpi00 pic2fpga_gpi01 pic2fpga_sdi fpga2pic_sck fpga2pic_sdi fpga2pic_ss_n fpga2pic_sdo LOC LOC LOC LOC LOC LOC LOC = = = = = = = W18 V17 W15 W14 V14 V18 V19 IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD IOSTANDARD = = = = = = = LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; LVCMOS18; IO Standard Type IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = LVCMOS33; LVCMOS18; LVCMOS33; LVCMOS18; LVCMOS15; LVCMOS33; LVCMOS15; LVCMOS15; On-Board LED and Button I/O Port Name NET led_0 NET led_1 NET led_2 NET led_3 NET btn_0 NET btn_1 NET btn_2 NET btn_3 IO Location LOC = E17 LOC = AF14 LOC = F17 LOC = W19 LOC = W6 LOC = E18 LOC = AC6 LOC = AB6 Pmod Ports Port Name NET pmod_ja_1 NET pmod_ja_2 NET pmod_ja_3 NET pmod_ja_4 NET pmod_ja_7 NET pmod_ja_8 NET pmod_ja_9 NET pmod_ja_10 NET pmod_jb_1 NET pmod_jb_2 NET pmod_jb_3 NET pmod_jb_4 NET pmod_jb_7 NET pmod_jb_8 NET pmod_jb_9 NET pmod_jb_10 IO Location LOC = D19 LOC = E23 LOC = D25 LOC = F23 LOC = F19 LOC = G22 LOC = D24 LOC = E21 LOC = F20 LOC = E15 LOC = H18 LOC = G19 LOC = H17 LOC = J21 LOC = L19 LOC = F18 IO Standard Type IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = IOSTANDARD = LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; LVCMOS33; FMC Connector IOSTANDARD depends upon VADJ for LA, HA, and CLK pins. Port Name NET VADJ_EN NET SET_VADJ1 NET SET_VADJ2 NET FMC_LA00_P IO Location LOC = AD16 LOC = AF19 LOC = AF20 LOC = Y22; Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. IO Standard Type IOSTANDARD = LVCMOS18; IOSTANDARD = LVCMOS18; IOSTANDARD = LVCMOS18; Page 18 of 21 NetFPGA-1G-CML™ Board Reference Manual NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET FMC_LA00_N FMC_LA01_P FMC_LA01_N FMC_LA02_P FMC_LA02_N FMC_LA03_P FMC_LA03_N FMC_LA04_P FMC_LA04_N FMC_LA05_P FMC_LA05_N FMC_LA06_P FMC_LA06_N FMC_LA07_P FMC_LA07_N FMC_LA08_P FMC_LA08_N FMC_LA09_P FMC_LA09_N FMC_LA10_P FMC_LA10_N FMC_LA11_P FMC_LA11_N FMC_LA12_P FMC_LA12_N FMC_LA13_P FMC_LA13_N FMC_LA14_P FMC_LA14_N FMC_LA15_P FMC_LA15_N FMC_LA16_P FMC_LA16_N FMC_LA17_P FMC_LA17_N FMC_LA18_P FMC_LA18_N FMC_LA19_P FMC_LA19_N FMC_LA20_P FMC_LA20_N FMC_LA21_P FMC_LA21_N FMC_LA22_P FMC_LA22_N FMC_LA23_P FMC_LA23_N FMC_LA24_P FMC_LA24_N FMC_LA25_P FMC_LA25_N FMC_LA26_P LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = AA22; N21; N22; AB22; AC22; AF24; AF25; AA25; AB25; AE23; AF23; W20; Y21; AB26; AC26; AD26; AE26; Y25; Y26; W21; V21; W25; W26; W23; W24; U22; V22; R26; P26; T24; T25; V23; V24; R22; R23; P23; N23; T22; T23; R25; P25; M24; L24; M25; L25; P24; N24; U17; T17; T18; T19; M21; Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 19 of 21 NetFPGA-1G-CML™ Board Reference Manual NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET NET FMC_LA26_N FMC_LA27_P FMC_LA27_N FMC_LA28_P FMC_LA28_N FMC_LA29_P FMC_LA29_N FMC_LA30_P FMC_LA30_N FMC_LA31_P FMC_LA31_N FMC_LA32_P FMC_LA32_N FMC_LA33_P FMC_LA33_N FMC_HA00_P FMC_HA00_N FMC_HA01_P FMC_HA01_N FMC_HA02_P FMC_HA02_N FMC_HA03_P FMC_HA03_N FMC_HA04_P FMC_HA04_N FMC_HA05_P FMC_HA05_N FMC_HA06_P FMC_HA06_N FMC_HA07_P FMC_HA07_N FMC_HA08_P FMC_HA08_N FMC_HA09_P FMC_HA09_N FMC_HA10_P FMC_HA10_N FMC_HA11_P FMC_HA11_N FMC_CLK0_M2C_N FMC_CLK0_M2C_P FMC_CLK1_M2C_N FMC_CLK1_M2C_P FMC_CLK2_M2C_N FMC_CLK2_M2C_P FMC_CLK3_M2C_N FMC_CLK3_M2C_P FMC_DP0_M2C_N FMC_DP0_M2C_P FMC_DP0_C2M_N FMC_DP0_C2M_P FMC_DP1_M2C_N FMC_DP1_M2C_P LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = M22; N26; M26; R16; R17; K25; K26; N19; M20; P19; P20; P16; N17; N18; M19; U19; U20; T20; R20; AD23; AD24; AB21; AC21; U24; U25; V26; U26; AD25; AE25; AD21; AE21; AE22; AF22; R18; P18; U16; N16; Y20; U21; P21; R21; AC24; AC23; AB24; AA23; AA24; Y23; C3; C4; A3; A4; E3; E4; Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 20 of 21 NetFPGA-1G-CML™ Board Reference Manual NET NET NET NET NET NET NET NET NET NET NET NET NET NET FMC_DP1_C2M_N FMC_DP1_C2M_P FMC_DP2_M2C_N FMC_DP2_M2C_P FMC_DP2_C2M_N FMC_DP2_C2M_P FMC_DP3_M2C_N FMC_DP3_M2C_P FMC_DP3_C2M_N FMC_DP3_C2M_P FMC_GBTCLK0_M2C_N FMC_GBTCLK0_M2C_P FMC_GBTCLK1_M2C_N FMC_GBTCLK1_M2C_P LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC LOC = = = = = = = = = = = = = = D1; D2; B5; B6; A3; A4; G3; G4; F1; F2; F5; F6; D5; D6; Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 21 of 21
6015-410-001 价格&库存
很抱歉,暂时无法提供与“6015-410-001”相匹配的价格&库存,您可以联系我们找货
