410-047-C2
410-047-C2
    DIGILENT(迪芝伦)
    CMODC2C-MOD
410-047-C2 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com Cmod™ Board Reference Manual Revised October 26, 2012 This manual applies to the Cmod rev. D Overview Cmod boards combine a Xilinx CPLD, a JTAG programming port, and power supply circuits in a convenient 600-mil, 40-pin DIP package. Cmods are ideally suited for breadboard or other prototype circuit designs where the use of small surface mount packages is impractical. All Cmod boards include: Features include: • • • • • The Cmod board. • A single 3.3V supply voltage (voltage regulation provided on Cmod board where required); Adequate bypass capacitance on all CPLD voltage supply pins; All available user I/O signals brought out to DIP pins; Once programmed, CPLD designs are non-volatile; Designs can easily be ported between Cmods using different CPLD device families; All Cmod boards are compatible with the free Xilinx WebPack tools. Cmods were created to make the latest Xilinx CPLDs more practical for experimental and prototype circuits. They can plug directly in to breadboards or IC sockets, and they can mate with the Digilent Ceres™ board to utilize a collection of ready-made I/O circuits. Cmods are available with CoolRunner-II CPLD C2. C-Mod boards are especially useful for investigating designs across a variety of CPLD families. 1 1.8VDC regulator (C2 Mod) Functional Description Cmod boards, which measure just 0.7” by 2.16”, allow designers to experiment with CPLD-based designs in a variety of state-of-the art devices. Designs can easily be ported from one Cmod to another, so that design performance in different devices can be compared and contrasted. The 40pin DIP form factor allows Cmods to be used in breadboard or other through-hole circuits where surface-mount devices are impractical. They can be configured with a wide range logic circuits, from simple logic functions to sequential controllers. All available CPLD I/O signals are routed to the 40-pin DIP connections. JTAG Connector CPLD in VQ44 Package CMod-C2: XC2C64 40 pin, 600-mil DIP Connector Figure 2. Cmod circuit board block diagram. DOC#: 502-047 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 4 Cmod™ Board Reference Manual When used in conjunction with the Ceres board, Cmods can be used to rapidly implement CPLD based circuits, or to gain exposure to Xilinx CAD tools and CPLD-oriented design methods. The Ceres board provides Cmods with a power supply, a clock source, input buttons and switches, and various output LEDs. The Ceres/Cmod combination makes an excellent platform for use in teaching labs. Cmods are programmed with a sample design during manufacturing. This design, available at the Digilent website, can be used to verify Cmod/Ceres function. It also provides a simple reference design example of a Xilinx project. 3 CPLD Configuration Cmod boards contain a JTAG port for CPLD programming. The port consists of a pattern of six offset holes that are not loaded with header pins. To use this port, a row of six unattached header pins can be inserted into the end of a JTAG3 (or other) cable, and the other side of the header can be inserted into the offset hole patterns. Once the Cmod board is connected to the PC via the JTAG cable, the configuration software will automatically detect the CPLD. JTAG Signal XC2C64 pin XC9572XL pin XCR3064 pin TCK TDI TDO TMS 11 9 24 10 11 9 24 10 26 1 32 7 Table 1. CPLD JTAG pins. To configure the board from a computer using the JTAG port, first ensure the Cmod is powered with a 3.3V supply (such as provided by the Ceres board), and that the JTAG cable is properly connected to the Cmod and to the computer. Start the configuration program (e.g., the iMPACT programmer available in the Xilinx WebPack tools), and the board will be auto-detected. Device programming and other JTAG operations are available in a pull-down menu made visible by right clicking on the device graphic in the programmer window. JTAG3 Cable 6-pin header C-Mod Figure 3. JTAG cable used with Cmod. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 4 Cmod™ Board Reference Manual 4 Power Supplies Cmod boards require a single 3.3V supply on pin 20, and a single GND on pin 21. Current consumption is dependent on CPLD family, CPLD configuration, and external circuits. In most cases, current will be far less than 100mA, but the Xilinx data sheets for the particular CPLD should be referenced for more information. 5 CPLDs Cmod boards are available with CoolRunner-2, CoolRunner (XPLA), and XC95 CPLDs. All available CPLD I/O signals are routed to the DIP connector, and the JTAG signals are routed to a programming connector. CPLD pinouts are provided in tables 2 and 3 below. Please see the data sheets for the CPLDs available at the Xilinx website for more information. DIP PIN Ceres Signal C-Mod C2 C-Mod 95 C-Mod XCR XC2C64 pin type Function Block XC9572XL pin type Function Block XCR3064 pin type Function Block 1 CA 12 IO 4 12 IO 3 12 IO 4 2 CB 13 IO 4 13 IO 3 13 IO 4 3 CC 14 IO 4 14 IO 3 14 IO 4 4 CD 16 IO 4 16 IO 3 15 IO 4 7 IO 3 5 6 7 8 9 CE 18 IO 3 18 IO 3 18 IO 3 10 CF 19 IO 3 19 IO 4 19 IO 3 11 CG 20 IO 3 20 IO 4 20 IO 3 12 AN3 21 IO 3 21 IO 4 21 IO 3 13 AN2 22 IO 3 22 IO 4 22 IO 3 14 AN1 23 IO 3 23 IO 4 23 IO 3 15 AN0 27 IO 3 27 IO 4 25 IO 3 16 SW7 28 IO 3 28 IO 4 27 IO 1 17 DP 29 IO 3 29 IO 2 18 BTN3 30 GSR 1 30 IO 2 6 IO 2 20 15 VCC 26 VCCIO 9,17,29, 41 VCC 20 7,26 VCCIO 15,35 VCCINT 20 35 VAUX 19 21 4,17,25 GND 4,17,25 GND 16,24,36 GND 22 SW6 31 GTS2 1 31 IO 2 28 IO 1 23 SW5 32 GTS3 1 32 IO 2 30 IO 1 24 SW4 33 GTS0 1 33 GSR 1 31 IO 1 25 SW3 34 GTS1 1 34 GTS2 2 33 IO 1 26 SW2 36 IO 1 36 GTS1 2 34 IO 1 27 SW1 37 IO 1 37 IO 2 35 IO 1 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 3 of 4 Cmod™ Board Reference Manual 28 BTN2 38 IO 1 38 IO 2 37 IN3/CLK3 29 SW0 39 IO 2 39 IO 1 42 IO 2 30 LED7 40 IO 2 40 IO 1 43 IO 2 31 LED6 41 IO 2 41 IO 1 44 IO 2 32 LED5 42 IO 2 42 IO 1 2 IO 2 33 BTN0 43 GCK0 2 43 GCK1 1 40 IN0/CLK0 34 BTN1 44 GCK1 2 44 GCK2 1 39 IN1/CLK1 35 MCLK 1 GCK2 2 1 GCK3 1 38 IN2/CLK2 36 LED4 2 IO 2 2 IO 1 3 IO 2 37 LED3 3 IO 2 3 IO 1 5 IO 2 38 LED2 5 IO 4 5 IO 3 8 IO 4 39 LED1 6 IO 4 6 IO 3 10 IO 4 40 LED0 8 IO 4 8 IO 3 11 IO 4 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 4 of 4
410-047-C2 价格&库存
很抱歉,暂时无法提供与“410-047-C2”相匹配的价格&库存,您可以联系我们找货
